Domoticz version table V4
From Domoticz Wiki
Revision as of 09:05, 20 October 2020 by Rwaaren (talk | contribs) (Rwaaren moved page DzVents version table V4 to Domoticz version table V4 without leaving a redirect)
Version table V4
Version Commit Date Description
11807 f7a465aeb 20200322 Merge PR 3994 from nb-ceffa; Update clickatell SMS notification
11804 d93de7f79 20200321 dzVents: Add example in documentation and allow single quotes in JSON in CustomEvents
11803 f0aac95ee 20200321 Merge PR 3981 from MrHobbes74; Tesla: Introduced optional keep-asleep mode
11801 b01077542 20200321 Merge PR 4000 from domoticz; Making sure external Lua is found/used
11799 87bfd914d 20200319 Merge PR 3992 from rkluwen; Fix WS_Write() in case data is sent whilst the websocket connection is not completely set up yet
11797 b8a6fe4ee 20200319 dzVents: Better recognition of XML type data in httpResponses
11795 9bdb2217a 20200318 Updated OpenZWave library
11794 bc241ab28 20200315 Fix for issue 3983 missing set Used / Unused icon on device tab
11789 845b75216 20200315 Added CMake CMAKE_CXX_FLAGS to CMakeLists.txt
11784 91fa9181d 20200314 Merge PR 3980 from stas-demydiuk; Fix for issue 3978 Differentiate devices and scenes on devices tab when updating.
11782 f88d21a1a 20200313 Updated OZW/Configuration files
11781 08c5b7421 20200311 Added domoticz install script to repository
11780 10a4759be 20200310 Added missing 'break' in OpenZwave.cpp
11779 71f848e19 20200309 Merge PR 3974 from EvgenaNet; fix mapping of Xiaomi Wireless Single Wall Switch states to selector switch
11778 5b961b6d7 20200309 Merge PR 3962 from EvgenaNet; add extra Email setup header to Email setup section
11777 2948df585 20200306 Update OpenZWave library to 1.6-1004
11776 01672eca0 20200305 Updated RFXCom header (some devicetypes added)
11775 09054c6c9 20200304 Added safety check and log message in updateMeter function
11774 1424a52f1 20200303 Merge PR 3955 from guillaumezin; add DisableLogAutoUpdate and EnableLogDBAccess device options (plugin support)
11770 632cefdef 20200303 Updated Windows installer (InnoSetup project)
11769 bb2b710f2 20200303 Merge PR 3964 from ravsit-activum; push Humidity as float. Fix for issue 3960 missing decimals.
11767 bd53a11bb 20200302 Merge PR 3961 from dwmw2; Add support for HTTPClient PUT and DELETE
11765 0ebe1e951 20200302 Update History.txt to reflect latest beta
11764 8ee24743f 20200301 Fix for dzVents fileExists
11763 20462bb29 20200301 Fix for issue 3863 No way to change switch state without trigger a push (MQTT, etc.)
11762 0cd897fe1 20200301 converting typecasts to c++11
11761 31248bd2c 20200301 Fix for issue 3960 Increase resolution for pushers like influxDB
11760 f3a322870 20200301 Fix for issue 1856 InfluxLink wrong value sent. Correcting InfluxDB idx value (thanks to ravsit-activum)
11759 3248c0342 20200301 Reverting boost download location
11758 b956eedae 20200301 Travis Changing boost download link
11757 52f3ffd9f 20200301 Travis, reverting download location
11756 ab401616e 20200301 Travis changes boost download location
11755 9180df4af 20200301 Merge PR 3956 from xbeaudouin; Allow compiling with external JSonCPP
11753 3e4ddce06 20200301 Update SQLite to 3.31.1
11752 8fca4cd06 20200301 Removed outdated manual. Please use Wiki instead
11751 c86f9a55f 20200229 Merge PR 3954 from gordonb3; Fix `shift-count-overflow` and``stringop-overflow` compiler warnings
11748 b0db4e654 20200228 Merge PR 3953 from MrHobbes74; Making sure already installed tesla hardware deals well with new parameters
11745 a2ea9dab5 20200228 Corrected labels on Mobile desktop
11744 945568532 20200227 Merge PR 3952 from MrHobbes74; Improved/faster Tesla hardware, decoupling of E-Vehicle generic and Tesla specific code
11740 a1f0d3d83 20200226 Merge PR 3949 from stas-demydiuk; fix for issue 3937 Websocket requests very slow
11738 28779d5f1 20200226 Merge PR 3950 from stas-demydiuk; fix for issue 3930 Show Device idx in table on RoomPlan page
11736 d9869b646 20200226 Merge PR 3946 from Olifant1990; Evohome demand, show percentage instead of On/Off only in bigtext element
11733 4c5a78d79 20200226 Merge PR 3902 from dgrostoto; Make rtl433 compliant with new model (normalized keys)
11730 e18e456ed 20200225 Merge PR 3948 from xbeaudouin; Tesla, Added Outside temperature sensor.
11728 64b250d72 20200225 Merge PR 3935 from gadgetmobile; travis: update cmake to 3.16.3
11726 05b554362 20200224 Allow mutliple days in dzVents at command-option "at()"
11725 0372b84a0 20200224 PR 3947 from waaren/development. dzVents V3.0.1 ; add at() option to schedule commands at fixed time /day
11724 867979abf 20200223 Merge PR 3940 from MrHobbes74/Tesla
11724 ce9de8435 20200221 PR 3940fix flippering alertstatus when charging.
11724 0d7c98e10 20200221 PR 3940solve vcxproj.filters file messup
11721 cd9ab14c1 20200223 PR 3944 Merge from stas-demydiuk/device-refresh
11721 e6b8766cd 20200222 PR 3944Manually refresh devices table after changes to device (issue 3939)
11719 08149c5ee 20200221 Merge PR 3938
11719 098988a48 20200221 Merge PR 3938 from MrHobbes74/Tesla into development
11713 f122f02ad 20200221 Ignoring retained messages (Octoprint)
11712 4911d3132 20200221 dzVents: allow numeric values as customEvent data
11711 7327334e8 20200220 Merge PR 3927 from stas-demydiuk
11711 880c3b899 20200219 PR 3927 fix for devices deselected automatically (issue 3922)
11709 1fec8fe88 20200220 Merge PR 3926 from guillaumezin. Remove "Async Secure Read Exception: 1, stream truncated" message
11707 e47613f37 20200219 Extended printer progress (Octoprint)
11706 c260aaec3 20200219 Merge PR 3920 from MrHobbes74
11703 1eb38c073 20200219 Merge PR 3924 from stas-demydiuk
11700 fdd77b36e 20200219 Fix for wrong message in temperature report when Humidity/Baro is 0 (issue 3925)
11699 78ceba9df 20200219 Added Printing progress sensor (non-extended) to Octoprint
11706 686d2b078 20200217 PR 3920 Fix for Lua table uservariables_lastupdate return nothing (issue 3919)
11698 65c3ec418 20200219 Added content to Octoprint source files
11703 09f61f226 20200218 Remove extra spaces in function declarations (Devices.js)
11697 5fb04576d 20200219 Added OctoPrint hardware (Start of Implementation)
11703 42ebe9c5a 20200218 PR 3924 Fix for issue 3918 and issue 3922 Handle websocket messages by device table itself
11696 5a4048f3e 20200216 Fixing Panasonic poll interval (issue 3912)
11695 50e8ad98a 20200216 Fixes small compile warning
11694 7b3885f8a 20200216 Merge PR 3914 from stas-demydiuk
11694 e75eea3ae 20200215 PR 3914 Add WebSockets support on Devices page - Refactor websockets service - Extracted
11692 5db81d82a 20200216 Merge PR 3915 from MrHobbes74/FixMemleak
11692 a346cff6f 20200215 PR 3915 Fix for memory leak in usage of LuaTable
11690 f1c50073d 20200214 Fixed typos in SystemEvent.lua and respect system logLevel in EventHelpers.lua
11689 36e3c6da7 20200214 Merge PR 3910 from waaren/development
11689 df08bc16a 20200214 PR 3910 Changed backup duration calc to use difftime. Fix for compile issue on stretch (issue 3909)
11687 537f7decb 20200213 Merge PR 3901 from MrHobbes74/notifysystemfinal
11687 596151fc8 20200212 PR 3901 Replaced general pointer with Json string
11687 c06a3b111 20200210 PR 3901 update dzVents to V3.0.0 ( Add system-events and customEvents triggers as option to the on = { ... } section )
11686 e8d5c0f12 20200213 Merge PR 3904 from gordonb3/patchEvohomeWebLogging
11684 d768a8e95 20200213 Merge PR 3905 from gordonb3/fixMeterReport
11674 91c3475ac 20200209 Merge PR 3898 from EvgenaNet
11674 e828fd999 20200208 PR 3898 Add Xiaomi Wireless Single Wall Switch to XiaomiGateway
11672 ba48297aa 20200206 Fix bug in evohome device adapter causing state to be nil for evotouch
11671 df9de7020 20200202 Fix for issue 3849 Daikin setpoint stuck with old value in GUI after update until next poll
11670 f6af0fa0c 20200202 Fix for issue 3884 Youless LS120 not giving pulse readings anymore
11669 fd50d867e 20200201 Correcting small typo in dzVents wiki
11668 c1bc97ac0 20200131 Merge branch 'development' of github.com:domoticz/domoticz into development
11668 3630122d7 20200131 Fix YouLess with S0 meter reading
11665 ec3292db7 20200128 Merge branch 'development' of github.com:domoticz/domoticz into development
11665 6dcbec606 20200128 Merge PR 3871 from brucemiranda/development
11665 e85687f63 20200127 Create relay devices to try and track actual switching to provide other automatio
11662 b1892d740 20200128 Updated boost to 1.72
11661 4e045bac0 20200128 OZW, removed obsolete functions
11660 bdcf9463d 20200128 Merge branch 'development' of github.com:domoticz/domoticz into development
11660 0b6b2d64f 20200128 RTL433, support for PCR800 rain sensor in inches
11658 dd6a2b9b0 20200128 Updated Openzwave, added preprocessor to fix boost 1.72 issue
11657 1d05ce754 20200127 Stripping /r from custom Icon file
11656 8770e0474 20200126 Added option to enable/disable parsing triggers from update json script
11655 0fecfaa8f 20200126 Merge PR 3869 from szczukot/development
11655 857a82e90 20200126 [Satel Integra] fix 32 bit mode
11655 4be783005 20200126 Merge PR 30 from domoticz/development
11652 2ac631921 20200125 Merge branch 'development' of github.com:domoticz/domoticz into development
11652 a0a6069e4 20200125 Merge PR 3866 from waaren/development
11650 62d224d79 20200125 Update dzVents to 2.5.7 add option checkFirst to method switchSelector
11649 3aa55f248 20200125 Added User to Light/Scene/Text log
11648 3f0af8771 20200124 Correcting popup dialog font color cause by previous PR
11647 3a7f7ed6e 20200124 Merge branch 'development' of github.com:domoticz/domoticz into development
11647 8f144c6a0 20200124 Merge PR 3862 from brucemiranda/development
11647 f1c54950b 20200123 Create the Alert Device for the 1st entry everytime
11647 f68c28df1 20200123 Report the most recent Fault Log to an Alert Device
11643 ed03ba7fb 20200124 Fixes dashboard item refresh when item was not a favorite but was inside a roompl
11642 794116aa1 20200123 Changed indenting
11641 63863c8e1 20200123 Merge PR 3855 Correct OWL CM180 support
11640 db1696b83 20200123 Merge PR 3859 from stas-demydiuk/favorite-permissions
11638 9e6ea96b3 20200123 Fix for false positives in dzVents time.matchesRule(between hh:mm and hh:mm)
11637 2fd5ef937 20200122 Merge PR 3856 from waaren/development
11634 879e0db32 20200122 Added Netatmo Thermostat status as Utility/GeneralPercent (#3811)
11633 4f42c8355 20200122 Merge PR 3857 from brucemiranda/development
11637 1d7e17c9e 20200122 Update History.txt
11637 c0ada0d2e 20200121 Update dzVents to 2.5.6 add some time attributes and lodash tests
11631 fbade6811 20200121 RoomPlan page update (#3809)
11630 a78ebd671 20200121 Updated travis to checkout a specific OZW commit
11629 45deef1ac 20200121 Bumping version
11628 07e0f4585 20200121 Show average barometric values in report for temp/baro sensors
11627 03572fb0c 20200121 Updated Translations
11626 db7b49bb3 20200120 Updated OZW to 1.6-1007-g07acd313
11625 bf3d94118 20200120 Updated Openzwave configuration files
11624 97b6667af 20200120 Fix for issue 3849 Inverted custom floorplan icon for doorsensors.
11623 0fa94155c 20200120 Fix for issue 3850 Duplicate usernames allowed when adding or updating.
11622 245aa002a 20200120 Merge branch 'development' of github.com:domoticz/domoticz into development
11622 edbc39d08 20200120 Merge PR 3841 from brucemiranda/development. All Evohome OT messages decoded and associated devices created
11622 e22c3d277 20200117 Changing the error code display format to Hex
11622 5d038bc57 20200117 Removed printing of binary string error message
11622 d2635c191 20200116 Fixing Windows compile errors
11622 71576aafc 20200120 Merge PR 3851 from waaren/development. Fix for missing years when reporting from rain log-tab
11622 846a2511c 20200116 Fixing Windows compile errors
11610 4ed27582d 20200120 Corrected Dusk sensor display icon/status, removed duplicate check, added title
11609 70500a9c6 20200113 Removed debug line
11608 167c3fc3e 20200113 Add sanitize function to Time.lua to allow use of rawTime formatted time in match
11607 572ea130d 20200113 Fix dzVents time Rule evaluation by taking minutes into account.
11606 f37ec886a 20200113 Fix dzVents Time.lua: addAAA() added time to now. Should add to passed time-object
11605 7de1f368f 20200109 Merge PR 3824 from guillaumezin/http_authorize_bug
11603 30f98438b 20200109 Merge PR 3831 from bloob00k/iss3822
11601 320cb4334 20200109 Merge PR 3835 from EmerickH/development
11599 c4f4b1117 20200109 Merge PR 3837 from brucemiranda/development
11601 cebaeb79f 20200104 Prevent bug in console in Firefox
11605 7232c1981 20191231 Add authorization header only if no autorization already set, not only basic auth
11599 248ffbac7 20200106 Decode and display the Evohome OT messages
11597 70664be92 20191230 Merge PR 3821 from waaren/development
11597 877f29f8a 20191229 Update dzVents 2.5.5 Add Zwave fan to Zwave mode device adapter
11595 0af61139c 20191229 PR 3817Merge from cocooma/development
11595 da0bee2ef 20191227 Fix the Evohome external sensor temperature update
11593 a006ddd5a 20191224 Merge PR 3812 from waaren/development
11593 0b5c3a8c6 20191223 Pandoc versions still playing tricks on me modified: dzVents/documentation/REA
11593 200174ecd 20191223 Update dzVents to 2.5.4 (increase resilience when combining wildcards and magic chars
11590 d7cb21393 20191221 Merge PR 3802 from brucemiranda/development
11587 7898089bc 20191221 Merge pull request PR 3801 from gordonb3/EvohomeWeb
11581 3e498dcc4 20191220 Merge pull request PR 3807 from domoticz/asynctcptimeouts
11590 87b9acd48 20191220 Update EvohomeRadio.cpp
11587 f74a3bc52 20191220 Use error description from header if no other message is given (EvohomeWeb)
11590 d560a1fae 20191220 Further processing of 3FE0 messages for Evohome
11581 993f477b5 20191220 Implementing timeouts in ASyncTCP class
11587 f39535126 20191219 Merge remote-tracking branch 'upstream/development' into EvohomeWeb
11587 04fbd7746 20191219 match up EvohomeWeb to new HTTPClient GET method return
11579 289b1cf80 20191219 Implemented: Per User favorites (with viewer rights)(fix for issue 3778)
11587 d5209d330 20191219 Extended error code logging for CURL type calls
11577 a40d95110 20191219 Refactored some code around HTTPClient::GET
11575 92934d627 20191218 Update dzVents documentation and wiki
11574 30eab4f5d 20191217 Merge PR 3799 from waaren/development
11570 af55de6d8 20191215 Stricter checking of authorisation for API/JSON commands
11569 beddd6647 20191215 Merge PR 3798 from gordonb3/EvohomeWeb
11569 dfdcf2c08 20191215 Correct EvohomeWeb.cpp for updatet jsoncpp library
11569 2a5b61815 20191215 Workaround for Evohome v1 API session expiration
11566 beddd6647 20191215 Merge PR 3795 from waaren/development
11565 8a10ce1f7 20191213 Fix for issue 3750 use unique MySensors and TTN MQTT call IDs
11564 8ec0c6f42 20191213 Fix for issue 3794 removing scenes from device Tab causing devices to be removed
11563 d5e8a14bf 20191209 Unknown switch/scene idx now logged
11562 519d5653e 20191209 Removing debug messages
11561 d2abbdde6 20191209 MQTT added original hardware id in public topic
11559 71e945b32 20191209 Merge PR 3787 from domoticz/mqtt-updated-1.68
11560 773fed043 20191209 Updated Mosquitto to 1.68
11558 b152682f3 20191208 Merge Open ZWave update into development
11558 886909cf1 20191208 Updated Open ZWave to revision 5 ( 20191205 )
11558 886909cf1 20191208 Merge PR 3785 from VirgoFrank/development
11556 675474103 20191208 Merge PR 3785 Fix typo in README.md
11554 675474103 20191208 Make update script executing directly in the background
11553 2a47b97c4 20191207 Merge PR 3783 from waaren/development
11553 746d59242 20191207 Fix for issue 3781 Correct rounding errors in all astronomical sunrise / sunsets and day length
11551 d9871d452 20191205 Adjusted Next user agent (again), should fix issue 3777
11550 c4d5c5bd2 20191204 Corrected Naming function
11549 132e26f88 20191204 PhilipsHue, updating Names when lights/switches have not been added to the system
11548 852631140 20191204 Gui, Simplified theme settings Gui, added auto detection of location
11547 db289ac25 20191203 Fix for issue 3771 dzVents matchesRule triggers on multiple dates
11546 06d4b197d 20191203 OZW, implemented Frequency sensor
11545 79ce7c5b5 20191203 Added rule for Aeotec Smart Switch 7
11544 a13ac6154 20191203 Fixing memory leak. Fixed issue 3767 and issue 3761
11543 7983e1723 20191203 Merge 'Tweaking new updater' into development
11542 069a9e0a25 20191203 Tweaking new updater
11543 bc1a4f160 20191201 Merge PR 3766 from waaren/development
11543 7599a704a 20191130 Update dzVents to 2.5.2 (add base64 decode/ encode, depecrate some Yeelight specific API ca
11539 6c6c27a56 20191129 Testing new update method
11538 279ed7705 20191128 RFXCom implemented datatimeout for external P1 sensor
11537 dd5b007c9 20191127 Merge PR 3759 from akamming/development
11537 e8b25f437 20191127 Removed another confusing logline
11535 26559ab28 20191126 Merge PR 3757 from akamming/development
11535 99865925e 20191126 Removed extra logging Better Handling of connection_websocket_Closing state in connection::
11533 90106da09 20191125 Merge PR 3756 from robgeerts/patch-1
11532 c36545bd8 20191125 Making ClientID's for MQTT random per Domoticz instance
11533 96c7fa7a1 20191125 Pointer-cursor instead of regular mouse pointer.
11530 b89ba8735 20191125 Merge PR 3754 from gadgetmobile/fix_blebox_search_issues
11530 7396d6f39 20191124 Fix BleBox search issues with duplicate devices
11528 6ea6c9bef 20191124 Correcting MySensors MQTT Name
11527 c55e29c80 20191124 Different ID's for MQTT
11526 e85f7b50c 20191124 Merge branch 'development' of github.com:domoticz/domoticz into development
11526 4ef1c89fa 20191124 Merge PR 3749 from RDols/WebSocketCrash_FinalFix
11526 e579423b7 20191123 Fix for issue 3661
11526 f8572c123 20191123 Fix for issue 3661 Reverted of disabling abondened timeout
11526 386d102a3 20191123 Fix for issue 3661 Additional logging
11526 23df0c738 20191123 Fix for issue 3661 Prevention of deadlock
11526 f9eda8de5 20191123 Fix for issue 3661 Prevent race condition
11519 8e6b1d0ee 20191124 Travis linking SSL static
11518 d93c2981a 20191123 Merge PR 3740 from waaren/development
11515 3983cff51 20191122 Fix compile warning under GCC
11514 26783ab3f 20191122 Removed mosquittopp from MQTT CMakeLists.txt
11513 fec0b9af3 20191122 Using private mosquitto wrapper now as mosquittopp is deprecated
11512 f16283211 20191122 Better naming
11511 ac14c331c 20191122 Making CMake project more consistent (messages library/include found) better detection of l
11510 80616329f 20191121 Merge PR 3735 from neheb/patch-3
11508 866a07f0d 20191121 Merge PR 3745 from domoticz/travis-xenial
11508 d8b439879 20191121 Downgrading travis to xenial
11518 70e61b58e 20191121 Npm for buster require extra parm to make npm work again
11506 95e2be251 20191121 Fix for issue 3741 Jsoncpp deprecate
11518 4da054d7e 20191121 Update dzVents to 2.5.1 ( Add http xml handling similar to html json handling )
11505 25a8db026 20191120 Merge PR 3738 from syrhus/patch-1
11505 5aabdb73b 20191120 ClearTimers only on ActiveTimerPlan
11503 a18e48543 20191120 Merge PR 3736 from Spugna85/master
11501 01271c298 20191119 Revert "Changing deprecated function from JsonCpp"
11500 7457f766f 20191119 Changing deprecated function from JsonCpp
11499 c8ee757ce 20191119 Merge PR 3734 from neheb/patch-2
11497 b1170460a 20191119 Merge PR 3733 from neheb/patch-1
11499 fbff3b289 20191118 Serial/unix: Replace sys/signal with signal
11510 f50e2aeb9 20191118 Tado: Fix printf format for 32-bit
11495 6e41d34bc 20191119 Updated JSonCPP to 1.9.2
11497 52841aca9 20191118 Csocket: Replace sys/poll with poll
11494 2ce46a6b7 20191117 Merge PR 3731 from domoticz/travis-update
11494 56eeaef4f 20191117 Updated to Bionic dist
11492 77a7863ef 20191117 Updated MQTT CMakeLists.txt
11491 fdc90742a 20191117 Updated MQTT CMakeLists.txt
11490 ceae5146a 20191117 Fix compilation issues for CMake
11489 e6c3d51e4 20191116 Updated to MQTT 1.6.7
11488 d43435328 20191115 OZW, Support for Loudness sensor OZW, Support for Particulate
11487 ac3d2290d 20191114 Merge branch 'development' of github.com:domoticz/domoticz into development
11485 fdf18ae91 20191114 Updated Next agent (Should solve issue 3729)
11487 b086757f6 20191114 Websockets, disabled abandoned_timeout
11484 c6830ac50 20191113 Merge branch 'development' of github.com:domoticz/domoticz into development
11484 79705e6bd 20191113 Merge PR 3728 from denkovi1/development
11484 fb9423359 20191113 Update DenkoviDevices.cpp
11481 3d882ed4f 20191113 OZW, Updated configuration files
11480 205f5f928 20191113 Windows service now depends on RTC/Lan
11479 eef16abc9 20191113 Hardware Setup, removed username for Denkovi devices
11478 3a7c68e0f 20191112 Merge PR 3722 from RDols/FixOutOfBound
11478 33dd7dbc2 20191110 Fix for issue 3721 Iterator out of bound
11476 5c5f579c3 20191108 Merge PR 3719 from ffontaine/development
11474 12feb06f1 20191108 Merge PR 3718 from domoticz/asynctcpchanges
11474 f8046679c 20191108 AsyncTCP changes - proxyclient also connects when openssl is not compiled in - PluginTran
11472 8162892cc 20191108 Merge PR 3716 from akamming/development
11476 17107b876 20191108 CMakeLists.txt: add -c argument to build precompiled headers
11470 a7d7b856e 20191108 Merge PR 3713 from ffontaine/development
11472 14f602d00 20191108 Fix handling of abandoned timeout on websocket connections
11468 508cc66a1 20191105 Merge PR 3711 from xbeaudouin/lua-fix
11468 37e39a7b1 20191105 Fix detection of LUA version if not linking with the provided sources.
11466 a87018396 20191105 Add error message when nil value is passed to switchSelector method
11465 8358ec21f 20191104 Removed last math.tointeger in dzVents/runtime/device-adapters (worked around it with math.
11464 7d3c72999 20191104 Merge branch 'development' of github.com:domoticz/domoticz into development
11464 b1d497078 20191104 Merge PR 3708 from RedDigital/AsyncCompileFix
11461 1f53682f7 20191104 Updated translations
11460 35a55e7a8 20191104 Added Device IDX in Edit Dialog
11459 360de154d 20191104 Merge branch 'development' of github.com:domoticz/domoticz into development
11457 8961b767c 20191104 OZW, using Base64 encoder that supports Unicode as some configuration files contain Unicode
11459 85b5bfab1 20191103 Prevent error when using math.pow in user script but do give deprecate warning.
11456 df22581ed 20191103 New GetLocation call
11464 e9dfbd3d4 20191103 Fix for issue 3707 comparison error
11455 ab9599326 20191103 Websocket now supports webroot path
11454 8936bf00b 20191102 Merge PR 3700 from RedDigital/HueDimmerSwitch
11451 f7fca3dc2 20191102 Merge PR 3701 from RedDigital/ASyncTCP_Fix
11442 2c38e5c91 20191102 Correctly casting to lua_Integer
11470 e9bd383ce 20191101 DelayedLink.h: fix build with python 3.8
11451 c36893435 20191102 Fix for issue 3666 Trivial members down with copy initialization
11441 2f27da6e3 20191101 Removing casts
11440 ff4f7e0b3 20191101 Updating CMakeLists.txt
11451 40ada7b00 20191030 Fix for issue 3666 proxyclient adapted to AsyncTCP changes
11451 ff002b494 20191030 issue 3666 Evohome cleaned for AsyncTCP
11439 9954535e1 20191101 Updated to Lua 5.3
11451 b1212f570 20191030 issue 3666 Removed unused OnError and readcallback
11438 832919499 20191101 Merge PR 3699 from waaren/development
11451 7ee0d5ede 20191030 issue 3666 Removed unused OnError
11451 bae086c5f 20191030 issue 3666 ASyncTCP refactored
11436 292bac38f 20191031 Fixed buienradar compile issue
11451 b487977af 20191018 issue 3666 destructors virtual
11435 757ce0592 20191031 Merge PR 3702 from ffontaine/development
11454 1aa5a818e 20191102 Trivial members done with copy initialization
11438 f9c900f09 20191030 DzVents 2.5.0 ( to be used with Lua version 5.3 or newer )
11435 e2dfb2ece 20191030 CMakeLists.txt: Add USE_PRECOMPILED_HEADER option
11451 dfcc933ba 20191018 Fix for issue 3666 Displaying the P1 data correctly
11454 2fca3aa93 20191030 Hue Switch Implementation issue 3369
11433 4679664e8 20191030 Merge branch 'development' of github.com:domoticz/domoticz into development
11433 ee1ab521d 20191030 Merge PR 3696 from Spugna85/master
11430 6335f6683 20191030 Buienradar, changed rain url and added a retry
11429 ba5eb0458 20191030 Set state for Relay type of Evohome device
11428 08a543133 20191029 Code Cleanup
11427 6027b1d9e 20191029 Code Cleanup
11426 1016549ac 20191029 Code cleanup
11425 9f6c3fac6 20191029 Merge PR 3694 from ffontaine/development
11425 002842624 20191029 Main/unzip_iterator.h: include zlib.h
11423 548d6b65d 20191027 Merge PR 3684 from pagocs/development
11421 fea833f38 20191026 Allow use of lower / UPPER and Mixed case in timer rule text
11420 4b10ed95d 20191026 Merge PR 3691 from waaren/development
11418 b7923f1ee 20191026 Remove boost dependency
11417 89f1088af 20191026 Merge PR 3690 from neheb/hhh
11420 cf3f0b9d8 20191026 Correcting the handling of the free_fall state of the agara cube
11417 01d0b0361 20191025 SunRiseSet: Use round instead of std::round.
11415 9bcb67547 20191025 Blockly, display when there is a device error in the event
11414 71ad14048 20191025 Correct script notification escaping
11413 b51e1bea3 20191025 Merge branch 'development' of github.com:domoticz/domoticz into development
11413 88c59c469 20191025 OZW, ExcludeDevice failed detection
11413 ed0d9d254 20191024 Corrected Date/Time display
11413 6961c72ec 20191024 Correct new device index check
11413 a25ea4ae9 20191024 Merge PR 3686 from xbeaudouin/fix_strings
11413 cd9ef6fb4 20191024 Fix uneeded spaces in stings
11413 5286ff9c8 20191024 Merge branch 'development' of https://github.com/domoticz/domoticz into development
11404 9c8661a8b 20191025 Tado, fix compile error on FreeBSD systems
11413 8bf261454 20191024 Fix extra spcae in log message
11403 f8d69b5c3 20191023 Correctly finding if item with idx exists
11402 9f26e7a1a 20191023 Reverted escaping percentage character
11401 71f14f615 20191023 Fixed possible escape issue
11400 6ad3f0dec 20191023 Code cleanup
11399 6dda2bdf2 20191023 Code cleanup
11398 34e7e97ce 20191023 Removing runtime exceptions!
11397 cc1e0e400 20191023 Removing runtime exceptions!
11423 982e2e977 20191023 PR 3216 Added ENABLE_EXPORTS to solve the "undefined symbol: lua_gettop" issue
11396 08ecb8bdc 20191023 Code cleanup
11395 cd4ea98f6 20191023 Corrected argument type
11394 03c7a9957 20191022 Fix for issue 3679 Setpoint Popup in Dashboard
11393 a7b457734 20191022 Merge PR 3681 from waaren/development
11393 38abcd682 20191022 Fix dzVents tests after change to storesettings
11391 b715a9c62 20191021 Updated issue guidelines
11390 152131285 20191021 Handling raw text/json/xml
11389 b57091048 20191021 Removed unneeded timers Unsubscribing from broadcasters
11388 d724e76b1 20191020 Implemented: Option to replace switch with another (same type)
11387 9e73a01c7 20191020 Appveyor, updated to InnoSetup 6.0.3
11386 1861d195d 20191020 Removed debug console log
11385 27f9ef1e1 20191020 Removed unnecessary refresh functions as every change will be reported via the websocket
11384 878fd179f 20191020 Fixed Firefox websocket issue Removed non-needed type declaration in index.html
11383 310390538 20191020 OZW, added battery level in grid
11382 72d27fc68 20191020 Added devices folder to VStudio project layout
11381 8416a3f74 20191020 Checking Status object in TranslateStatusShort
11380 c029d6cb9 20191020 Updated to jquery-3.4.1
11379 2c0ad71c1 20191018 Merge branch 'development' of github.com:domoticz/domoticz into development
11379 67c3fc051 20191017 Merge PR 3671 from tuulingo/development
11376 ce6e27ed7 20191018 OZW, making sure we are not setting read-only values when switching
11375 a92e35c48 20191017 Updated OZW
11374 8c56987fa 20191017 OZW, updated configuration files
11373 f59efee0b 20191017 Dummy, better internal naming
11379 991db1087 20191017 Typo "note"
11372 75e83b3f5 20191017 OZW, checking for type=user when return internal value id's
11371 a4bb7f284 20191017 Buienradar, rounding values to 1 precision digit
11370 bdf8381c9 20191017 Merge PR 3670 from laszlovandenhoek/separateTotals
11368 23f69284c 20191017 Fix for issue 3669 confusion between local files with system files
11367 181894bb9 20191016 Added Next Rainshower Sensors in Buienradar hardware issue 3668
11366 e35da78e8 20191015 TempHumBaro can now be replaced independent of Subtype
11365 9526050e9 20191014 SetKelvin also available for ww lights
11364 942566992 20191014 OZW, casting 255 to (uint8_t) to avoid calling function with uint32_t
11363 8a7e53342 20191013 AppVeyor, using new InnoSetup version
11362 fc3fabb01 20191013 Derive Buienradar is it raining from actual rain rate issue 3665
11361 1872f7e5d 20191011 Fix for https://github.com/domoticz/domoticz/issues/3663 issue 3663] Buienradar Rain sensor
11360 52980957d 20191008 Merge PR 3662
11360 90497f6ec 20191007 Add Support for Hue LCG002 GU10 spot issue 3660
11358 3f0d814e9 20191007 Merge PR 3658 from Hollister-git/patch-1
11358 b2a7aa860 20191006 Merge PR 1 from Hollister-git/patch-2
11358 bdbb46d79 20191006 Update DashboardController.js
11358 b5fa17386 20191006 Update LightsController.js
11354 70c43e42d 20191006 Merge PR 3657 from Spugna85/master
11352 f998f6969 20191006 Buienradar, using correct precipitation value for rain sensor (not the last 24 hour!)
11351 f0c30f4c1 20191002 Added Used field to Device.Refresh
11350 3c9623175 20191002 Fix for issue 3645 OZW, making sure the correct hardware is referenced
11349 f0063c71e 20191001 Updated translations
11348 18f69cb7b 20191001 Updated OZW headers
11347 198d0aeb7 20191001 OZW, extended logging for exceptions
11346 732abe8b8 20191001 Updated OZW configuration files
11345 1fd5e3355 20190930 Buienradar another try to turn over counter
11344 ed0211ea6 20190930 Merge branch 'development' of github.com:domoticz/domoticz into development
11344 d3183af8c 20190930 Merge PR 3641 from TwinsenLGR/development
11344 5dc7fa46b 20190930 Merge PR 3639 from szczukot/BleBox
11344 ef098dc10 20190924 [BleBox] Try fix auto searching
11344 edfc71dba 20190924 Merge PR 26 from domoticz/development
11338 ce508a64c 20190930 Removed non-reachable code
11344 a6654b292 20190926 Fix for issue issue 3638
11337 c3a517bff 20190923 Settings/Login now using HTTP Post request
11336 314e25288 20190923 Updated Translations
11335 1f86284c4 20190923 Added empty lines
11334 083abdc7e 20190921 Enphase, added sample json
11333 b2a5d9097 20190920 ZWave, changed Instance to int (FindDevice)
11332 80d5dd233 20190920 Websocket, allow case insensitive header values for connection/upgrade headers
11331 c618c9d19 20190920 EnpahseAPI, smarter handling of data
11330 ca45a1c5b 20190920 Merge PR 3633 from alfniev/patch-1
11330 7cc499763 20190919 Update EnphaseAPI.cpp
11328 579035175 20190919 Merge PR 3632 from waaren/development
11328 b7dbaa817 20190919 Method silent() does work again in 11324 so test can be restored
11328 49ee314a3 20190919 Corrected some additional typos
11324 0697504ea 20190919 Lua UpdateDevice now signals pushers (WebSocket)
11328 f574b7c1f 20190919 Update to dzVents 4.29 (add setLevel, corrected typos and small bugs )
11323 c8d1eb93d 20190919 Buienradar, force resetting rain counter to zero on day change
11322 87d9dcf16 20190918 Removing C++14 calls (we're not ready yet...)
11321 3ace1a6c9 20190918 ZWave code refactoring
11320 6a20d5517 20190917 Merge PR 3631 from akamming/development
11320 9170bbbc8 20190917 Correct logline for httpResponse
11318 71899777e 20190917 Merge PR 3628 from leecollings/development
11318 97c550732 20190914 Fixed top and bottom padding issue on desktop breakpoint for navigation buttons
11316 0ee1110a6 20190914 Merge PR 3623 from darrepac/patch-3
11316 bdf478685 20190913 Update TeleinfoBase.cpp
11314 3b202bb17 20190914 Buienradar, checking timestamp now for day turn over
11313 05086475a 20190913 OZW,added label to duplicate DeviceID error/warning
11312 d7dc09b51 20190913 Merge PR 3622 from CamilloHT/patch-1
11312 23b7d3964 20190912 Update WebsocketHandler.h
11310 e663f6f00 20190912 OZW, simplified SendSwitchIfNotExists function
11309 b19bcd405 20190912 Merge PR 3620 from petergebruers/check_already_added
11307 7439b1b9e 20190911 EventSystem, removed private UpdateDevice function and using default MainWorker::UpdateDevi
11309 1b739f720 20190911 Add Logging to SendSwitchIfNotExists to detect devices with same DeviceID
11306 863df66f5 20190911 Better casting
11305 dc680e9f5 20190911 TITEM_UPDATEDEVICE now uses common update route
11304 c452a86bf 20190911 Updated Translations
11303 a2b9d46af 20190911 Added missing www files to VC project
11302 3330717ff 20190911 Removed duplicate code
11301 47100c04f 20190910 Fix for issue 3288 Scene Updates via Websocket
11300 b9f543612 20190910 SceneController refactoring (not done)
11299 bfcfcfb38 20190910 Added helper function MainWorker::UpdateDevice
11298 e11831937 20190909 Correcting indents
11297 5af8e5052 20190909 Merge PR 3614 from mooninite/development-thermostat
11295 588d244d2 20190909 Buienradar avoid rain counter loop
11294 b7b8d8f28 20190909 Buienradar, better rain counter loop fix
11293 621e60160 20190908 Updated translations
11292 0a44254c1 20190908 MQTT added option to specify TLS version number MQTT enabled TLS mode
11291 d16543bfe 20190908 MQTT, enabled SSL/TLS support (added preprocessor WITH_TLS)
11297 709c6d72e 20190908 OZW: Initial fan and operational state support
11290 dc1efebff 20190906 Floorplan, removed opaque background
11289 fd26dde60 20190906 Buienradar, making sure 24 hour rain counter does not loop before our day has ended Buienra
11288 55ada4a43 20190906 Buienradar, using other field as rain counter
11287 e5ceceb0d 20190906 SendRainSensorWU, corrected rain rate
11286 0d04c5746 20190906 Remarked debug test
11285 06ee61dac 20190906 Small Indent correction
11284 7f5742119 20190905 Merge PR 3607 from gordonb3/BelGasP1update
11284 84a7829bf 20190905 P1MeterBase: incorrect match on number value 1 instead of char value '1'
11282 7760f694c 20190905 Added Belgium sample
11281 581688f01 20190905 Correcting small type
11280 367ff3426 20190905 Updated OZW/configuration files
11279 bd984008e 20190905 Merge PR 3590 from domoticz/jswebsockets
11279 7bc84e72c 20190905 Merge branch 'development' into jswebsockets
11260 08c4722e0 20190904 Merge PR 3603 from gordonb3/BelGasP1
11260 4dfb17842 20190904 Missed Belgian gas meter in previous commit
11258 e59d345f5 20190904 Merge PR 3602 from gordonb3/BeLuxP1
11258 dee338f89 20190904 Add support for Luxembourgian (pre-decrypted) P1 telegrams
11279 a16cb97c8 20190905 Merged changes from development
11279 d0772c642 20190831 Dashboard Page using websocket as well
11258 4f448f702 20190904 Add support for Belgian P1 telegrams
11279 e02a96fae 20190831 Floorplan Page using websocket as well
11255 926ceb768 20190904 Removed old pthread comments/code
11279 bca8d26e9 20190831 Updating to latest code from development
11254 8e304b3d2 20190904 Fix for issue 3600 Buienradar settings not restored in hardware editor
11279 febd0872f 20190831 Scene Page using websocket as well
11253 2aa005972 20190901 Added Sun/Rain icons
11252 d845856f8 20190901 Renamed Rain48 icon
11279 9c4e79389 20190831 Corrected indent
11279 9e44fd466 20190831 Websocket now sends date/time on round 10 second period intervals
11251 56c1663db 20190901 OZW, now returns node names in battery level JSON call
11250 bc2f645bf 20190901 Buienradar added configuration options for timeframe/threshold
11279 3d7f822db 20190831 Light Page using websocket as well
11249 d56c7873c 20190901 Cleaned up Hardware gui code
11279 36bf6987f 20190831 Temperature Page using websocket as well
11279 d446191ba 20190831 Websocket now sends server time every 10 seconds
11248 c754dddaa 20190901 Fix for issue 3596 Buienradar Rain Switch
11279 d7d65fd82 20190831 Preparation for automatic websocket server time
11247 4bcca19c5 20190830 Merge commit 'refs/pull/3590/head' of github.com:domoticz/domoticz into development
11279 be010a7cd 20190831 Added livesocket to VStudio project
11279 c7b2d343d 20190831 Weather Page using websocket as well
11279 8ce8e615e 20190830 Added newline at end of file
11279 241cb2c27 20190830 Removed extra return and end of file
11279 42a35e060 20190830 Corrected indent
11279 9699065c1 20190830 Moved livesocket to ascending position
11247 a5a12a233 20190830 Removed last comma
11247 24ed11993 20190830 Corrected double require definition
11247 9cb71b585 20190827 Merge branch 'development' into jswebsockets
11235 da88d4957 20190829 Merge PR 3589 from Spugna85/master
11231 bb5b485ea 20190829 Corrected Light Log status naming
11230 99b3ecd3b 20190828 Floorplan, add support for SVG issue 3585
11229 a8ae4761d 20190827 Buienradar, limit rainfall to 1 decimal
11228 6d2a64bf1 20190827 Enlarged Camera window
11227 d98c53ffe 20190826 Added new Windows 10 serial port API method
11226 459fc63a1 20190826 Win32, Remove slow serial port scanning
11225 73afe9a3a 20190826 Buienradar, rain prediction, when average is zero, the rainfall will be zero
11224 3749ba476 20190826 BuienRadar changes UVI to Watt/m2
11223 a2794c242 20190825 Trying to support the FGRM-222 Slat position
11222 a571b5a09 20190824 Fixed typo (remove space after Windspeed) in Buienradar.cpp causing windSpeed to allways be
11221 cae660923 20190824 Buienradar, check rain prediction every 5 minutes
11220 3673be450 20190824 Updated OZW configuration files
11219 36a82f533 20190824 BuienRadar, added Rain prediction
11218 473f43b85 20190823 BuienRadar Forecast URL
11217 a2c744958 20190823 Implemented: native BuienRadar hardware
11216 130020b36 20190823 Updated OZW library
11247 99aa2334f 20190817 Merge branch 'jswebsockets' of https://github.com/domoticz/domoticz into jswebsockets
11215 3f2677818 20190819 Floorplans: Switched to WebSockets for real time updates
11214 e7672936b 20190819 YeeLight, add IP address in exception log
11247 c56e18936 20190817 Merge branch 'development' into jswebsockets
11213 aea5c0c52 20190818 HTTP Protocol update: Headers now accept and return a Python lists for multi-values
11212 b9599f9da 20190818 Merge PR 3576 from Spugna85/master
11210 d0d90e9c6 20190818 Improved DumpHTTPResponseToLog to handle deep structures
11209 8ab3a88a0 20190818 Merge branch 'development' of https://github.com/domoticz/domoticz into development
11209 ba377492f 20190817 Merge PR 3571 from Spugna85/master
11209 a652c8b09 20190817 Added pagination for Data Pushers
11503 0943a93c9 20191120 OpenWebNet: fix blind percentage inverted
11209 e363a32ae 20190816 Merge PR 3572 from funxiun/development
11433 31e9e7813 20191029 OpenWebNet: rename all class members with m_
11247 dc371bd0d 20190813 Merge branch 'development' into jswebsockets
11209 6a7baffdc 20190816 Added parameter to the Wunderground API call that enables decimal numeric precision for tem
11354 0397cfaba 20191005 OpenWebNet: Update CenPlus and blinds percentage
11209 89b46127d 20190816 OZW, changed/correct send switch code
11235 3c4a685df 20190828 OpenWebNet: change notify string anf update lights.html
11235 abd2addc9 20190827 Merge branch 'master' of https://github.com/Spugna85/domoticz
11209 99c74d672 20190815 Updated translations
11200 0a93167e9 20190818 Outbound websocket traffic handles expired session
11199 1223601c3 20190814 RFXCom, added support for Hunter Fan (USA)
11212 8477570d4 20190818 OpenWebNet: fix print error log
11235 3224ec76c 20190827 OpenWebNet: add custom open command
11198 0e345ea0f 20190812 BlindsT15, reverted extra check in json API for unit code (0 should be possible)
11197 9d087d87d 20190812 RFXCom, blinds T15, added Unit option
11209 0bdb08858 20190816 Update OpenWebNetTCP.cpp
11196 a380dfbe7 20190812 Merge PR 3559 from Spugna85/master
11209 39a34fac9 20190816 OpenWebNet: HMAC authentication (for MyHome Server1, screen 10 "..)
11196 cdde76891 20190811 Update DB_VERSION to 137
11196 2fc62d27e 20190811 Merge branch 'development' into master
11196 6e0a0e8a1 20190804 OpenWebNet: use standard sensor functions and types for domoticz
11196 8ef141238 20190804 Merge branch 'development'
11247 7e84ffdba 20190811 Merge branch 'development' into jswebsockets
11083 406281844 20190811 OZWm, Updated configuration files Updated translations
11082 e5b6d5d72 20190811 Fixed: S0 Meter with Lan could not be added
11081 b14dbb2c6 20190811 OZW, html, correcting section id's
11080 d8d412144 20190811 OZW, using correct Power/Energy combination for all known Fibaro Wall Plug types
11079 153b33f42 20190811 Merge branch 'development' of github.com:domoticz/domoticz into development
11079 22ee3f8b3 20190808 Minor lay-out change to dzVents markDown and wiki README
11079 0668faa20 20190808 Merge PR 3564 from waaren/development
11079 3a624c22a 20190808 Update dzVents to 2.4.28 (Add device-, scene-, group-, variable-, cameraExists functions an
11079 b736cab34 20190807 Merge PR 3561 from Jesse-Klaasse/development
11247 1586fc6cb 20190803 Merge branch 'development' into jswebsockets
11079 ae84c54ee 20190807 Merge PR 3556 from dheering/development
11079 d80e4ec45 20190807 Adds Philips Hue 'Geofence' sensor support (untested)
11079 b55b8274a 20190805 Handle additional TypeNames types
11079 2515928ac 20190802 SolarEdge frequency reading displayed as percentage, instead of Hz #3554
11079 0f411f781 20190801 Minor corrections in dzVents wiki Mark Down (MD) and dzVents wiki
11079 48d0fc164 20190731 Merge PR 3552 from waaren/development
11079 ef60982a9 20190731 Fix typos in documentation of last dzVents PR
11247 b448ad92b 20190731 Merge branch 'development' into jswebsockets
11079 d8577ff4b 20190731 Change method-name from protectOn/- Off to protectionOn / -Off
11079 dbc7843e3 20190731 Forgot the -a switch when committing
11247 743eb211c 20190730 Added comments to the javascript source code.
11079 e85b8b2be 20190731 Move device specific logic into the relevant device class rather than poluting the base cla
11247 cbe4bd044 20190730 Domoticz websockets example. The file livesocket.js is added and some other files were chan
11079 31d904238 20190730 Update dzVents to 2.4.27 (add generic attribute protect and methods protectOn and -Off) ne
11079 77d4961e5 20190729 Speeding up update script
11062 10c1d22b8 20190811 Increasing RFXCom buffer size to support larger Async messages
11061 22ed4c513 20190729 Blockly, handling incorrect time field
11060 31e3d263e 20190728 Added No Response configuration file
11059 65dcd11a0 20190728 Merge branch 'development' of github.com:domoticz/domoticz into development
11059 b8b7a83b9 20190728 Merge PR 3547 from nielsvissers/multi_1Wire_Busses
11039 8badca107 20190728 Fix for issue 3340 Forcing update scripts to use IPV4
11038 e45d0386b 20190728 FritzBox, using native function from DomoticzHardware.h
11037 00cf49f3e 20190728 MySensors, Using global SendTextSensor routine
11036 522b2766b 20190728 Add trend calculation in MainWorker UpdateDevice
11035 b2154bb1d 20190728 OZW, removed debugging, temporarily changed 2 config files
11034 68ee7a9b1 20190727 OZW, better battery support
11033 8faa48dc9 20190727 Bugfix: Resolved problem with HTTP Protocol Listen broken by previous fix.
11032 b79f8252e 20190726 Bugfix: HTTP Protocol not handling Connection:close header
11031 ad1a5b2ac 20190726 OZW Debug Value, removed Unit, added source Line
11030 ce6da7e73 20190725 Removed label in debug function
11029 cdc33c102 20190725 OZW, added temporarily debug info before GetValueLabel
11028 7db5338da 20190725 OZW, implemented Type_UserAlerts
11027 10bc0c87a 20190724 Adjusted nodeID case
11026 16ae08d07 20190724 OZW, extended logging with nodeID
11025 09a81f919 20190722 Startup script will now wait until the system time is set
11024 407d06c28 20190722 OZW, better battery updates for devices
11023 57082fa1c 20190721 Implemented: OZW, JSON call to retrieve current battery levels for all nodes
11022 6b0c42183 20190721 OZW, more work on Tag Reader
11021 68a9e5085 20190721 Updates OZW configuration files
11020 0df71c72f 20190718 Floorplan Editor, a little bit more AngularJS style
11019 9e11444c7 20190717 OZW, remove list type handling for door-locks
11018 20314edbd 20190717 OZW, support for Fibaro FGRM222 Slat/Tilt position
11017 d71e8b8a8 20190717 Update README.md
11016 7f9dac729 20190717 Merge branch 'development' of github.com:domoticz/domoticz into development
11016 6c2c90986 20190717 Refactor:" Device.Update to make it much clearer what it does
11014 2523f5e5b 20190717 Appveyor.yml, updated innosetup location
11013 0695130b2 20190717 Updated appveyor.yml
11012 f07b6520d 20190717 Updated appveyor.yml
11011 047a21fa5 20190716 Small optimization in CMake project file OZW, home security switch case
11010 287c46eb6 20190716 OZW, added missing vLabel variable
11009 0441c370d 20190716 OZW, ignoring Class Climate Control Schedule
11008 e888954de 20190715 Merge PR 3534 from kjlisby/formatting_error
11006 38bd77914 20190715 Updated OZW
11008 008df19cc 20190715 Corrected commenting and formatting errors introduced by me in latest pull request.
11005 65dd3fca2 20190714 Merge PR 3531 from neheb/patch-1
11003 a1a0344d8 20190714 Merge branch 'development' of github.com:domoticz/domoticz into development
11003 d4d925e71 20190714 Merge PR 3529 from kjlisby/fix_for_3398
11000 59332a7fc 20190714 Corrected Wind Speed/Gust for Weather type
10999 95649f7d8 20190714 Reverting OZW patch
11005 87749eb9b 20190713 WebServerHelper: Fix compilation - deprecated APIs
10998 d38fbc319 20190713 Updated OZW
10997 75c9a7aa6 20190713 Merge branch 'development' of https://github.com/domoticz/domoticz into development
10997 035023db9 20190713 Merge PR 3526 from petergebruers/fix_darwin_link
11003 8a4ef5c06 20190713 issue 3398 fixed.
10997 732ea2546 20190712 Fix linking on macOS
10994 720be9130 20190713 Relax 'Connection' header constraint so browser WebSockets can connect. Fixed server side p
10993 d45a852bd 20190712 Linking against resolv
10992 98e64761b 20190712 CMakeList added resolv library
10991 e872278dd 20190712 Updating SQLite to 3.29.0
10990 fab638bd0 20190712 CMakeLists added resolv library for OpenZWave
10989 9d2a6c0b5 20190712 Removed CMake udev dependency (not needed anymore)
10988 92aafc204 20190712 Updated OZW
10987 b562ccc6d 20190712 Updated OZW and Configuration files
10986 992a3f1ae 20190712 Undone sanitize for active field
10985 c9151107f 20190712 Prevent XSS vulnerability by sanitizing the add/update functions
10984 a87ba35cb 20190712 OZW, better handling of instance/index internally, user-codes and alarm class (needs more w
10983 6c039dcb4 20190712 Fixed: GUI, Floorplan, custom image for Custom Sensor (#3523)
10982 73dcb000f 20190710 Added HTMLSanitizer to CMake
10981 bc853c700 20190710 Added HTML Sanitizer function
10980 99b7671cc 20190710 Reverted SceneController Purify method
10979 d272ea297 20190710 Merge branch 'development' of github.com:domoticz/domoticz into development
10979 4d44ef87a 20190709 Merge PR 3394 from FrankvdAa/feature/EnphaseEnvoyMetered-ConsumptionReadings
10979 c390c7a2c 20190709 Merge PR 3381 from etherfi/development
10979 abfbe3262 20190709 Merge PR 3392 from waaren/development
10979 edd6ba066 20190708 2 lines were missing. No idea why
10971 abcd81756 20190710 Scene Controller, Purify Scene Names
10979 6f9b1ce41 20190708 Update dzVents to 2.4.26 ( Add Smoke detector with methods activate() and reset() ) modifi
10970 539ceda4b 20190707 RTL433, removed debug lines
10969 92944186d 20190707 OZW, silencing ALARM string values
10968 e25ebf3df 20190707 Implemented: RTL433, added rainfall_mm type
10967 da6853bc6 20190707 RTL433, added Power (Watt) type
10966 9a9c76c87 20190707 OZW, Added support for X/Y/Z Acceleration sensors
10965 3d378eab5 20190706 Merge PR 3383 from waaren/development
10962 d11c33725 20190706 Better door-lock command class support
10961 471382c50 20190706 Merge PR 3384 from domoticz/revert-3366-development
10965 3415a538e 20190706 Rename dzFormat to rawDateTime
10965 601342788 20190706 DzVents update to 2.4.25 ( add time-formats and bugfixes )
10961 2801f37ed 20190706 Revert "Activating a scene containing devices which are dimmable now correctly…"
10959 6ee6ce23c 20190706 Merge PR 3382 from petergebruers/fix_lux
10959 e7f7d8f20 20190706 Fix Lux multiplied by 10 (Z-Wave Update Value)
10957 20f8c1817 20190706 OZW Control Panel, support for more then 255 values
10956 7bfe4ffc6 20190706 OZW, added support for Electric_kVarh
10955 81177e8c0 20190706 Updated OZW configuration files
10954 f5e6c4187 20190706 OZW, added support for Electric_kVar (displayed as KW for now)
10953 ebc7baaf9 20190706 Merge branch 'development' of github.com:domoticz/domoticz into development
10979 84742a9cc 20190708 In case root["consumption"] is empty return and not write error entry to logs.
10953 548236e5b 20190706 Merge PR 3378 from FrankvdAa/feature/EnphaseEnvoyMetered-ConsumptionReadings
10953 b836a08ba 20190705 Added code to Enphase API to read (net) consumption counters from production.json. The cons
10950 93b875f79 20190706 OZW, checking in work on User Code (not finished yet)
10979 499d3e1d5 20190706 Added support for MySensors MQTT custom topic prefixes.
10949 011e9a7c6 20190705 OZW, fixed meter class polling
10948 4cd31ced8 20190705 OZW, NodePoll, now checking for Manufacturer and product id/type for Greenwave
10947 98bb7b339 20190705 OZW, Changing greenwave product description as it has been changed in the configuration fil
10946 d9a86d234 20190704 Trim To addresses
10945 0283a6bda 20190703 PhilipsHue, Corrected key to int conversion
10944 2836246ee 20190703 PhilipsHue, small code refactoring
10943 812d3acf8 20190703 Merge PR 3366 from nhale25/development
10941 b975268fc 20190703 Fixes for "Unknown" in Name field. Fix Lux value scale error. (#3341)
10943 e42d18341 20190630 Activating a scene contining devices which are dimmable now correctly sets the level parame
10940 cdf6aee88 20190701 Include tests for civildaytime / civilnightime
10939 d1b385e12 20190630 Modified: Time.lua
10938 66b956dae 20190630 Night]TimeRules)
10937 484763d6e 20190629 Merge PR 3364 from petergebruers/ozwcp_fixes
10935 75effa672 20190627 This should solve the OZW previous event cleared log message (it's provided as a byte)
10934 095835065 20190627 Forgot to merge this change
10933 d503f0f21 20190627 Add support for RM174RF (Fixes #3343)
10932 d0ec39faf 20190627 Renamed comment
10931 fddf888af 20190627 Updating OZW
10930 fdc7c0656 20190625 Update dzVents wiki
10929 e582bef89 20190624 Merge PR 3347 from waaren/development
10929 96748cad0 20190624 Comment a debug print
10929 a11b6bcf1 20190624 Update dzVents to 2.4.24 (Add rename method for devices, groups, scenes and user-variables)
10926 eb35e02ab 20190622 Bugfix: Secure socket write functionality restored
10925 c330e9858 20190620 Merge PR 3338 from petergebruers/link_macos
10925 4406d63e3 20190620 Fix OpenZWave linkage on macOS
10923 5109a9946 20190620 Merge PR 3332 from stas-demydiuk/help-btn
10923 c7e0b097f 20190618 Help button for dzVents scripts
10921 363e7a276 20190618 Add missing line in tests
10920 b9fadb918 20190618 Add tests for complicated wildcards
10919 88c448e8a 20190618 Merge PR 3330 from stas-demydiuk/noty-appcache-update
10919 fa138a6af 20190618 Fix appcache after noty update
10917 82867dc37 20190616 Set minimum boost version to 1.66
10916 3b8619154 20190616 Updated compile flags to suppress ABI warning
10915 32abee2a5 20190616 Fix wildcard handling devices in on = section with Lua magic chars in name
10914 c0edefe51 20190615 Merge branch 'development' of github.com:domoticz/domoticz into development
10914 095fdb280 20190615 Merge PR 3302 from davidlb/development
10914 a7ba8c048 20190615 Update History.txt
10914 3d25062d3 20190615 Merge PR 3320 from waaren/development
10904 b9a44f14a 20190615 OZW, Corrected Alarm value handling
10914 914344784 20190614 Have adduservariable and updateuservariable accept variabletype as text and integer and inc
10914 bd4d46050 20190613 Prevent entering a text as variabletype in API call
10903 4a622942e 20190615 OZW, Alarm Type now uses original index value (could create new/other sensors) OZW, Alarm,
10902 5b6ad6df3 20190612 OZW, silencing indicator warning
10901 ea560b74e 20190612 Bugfix: TCP transport issues under stress of large write volumes
10937 6a9e960fa 20190629 Fixes for ozwcp On behalf of https://github.com/jotakar See: https://github.com/domoticz/do
10900 b0b414ef6 20190612 Merge PR 3313 from waaren/development
10900 84fee9ada 20190612 Fixed test for LOG_ERROR (fmt changed)
10900 cee756574 20190612 Fix filename of scripts/templates/Timer.dzVents. utils.stringSplit as only stringSplit func
10897 9f2dcd957 20190612 OZW, new method for handling command_class_meter and some code optimization
10896 a3d3dab9e 20190611 Merge PR 3312 from waaren/development
10896 4f08e1ded 20190611 Allow changing icon for Lighting 5 types modified: www/app/devices/deviceFactory.js
10894 464997768 20190611 Updated OZW
10893 f7f5b88e4 20190611 Silenced some compile warnings
10892 82c9730b2 20190611 Add missing RainByRate subtype InfluxDB push, now supports RainByRa
10891 5fda8db55 20190610 Wrong positioned colon.
10890 b9d6c8744 20190610 OZW, removed ScaleID
10889 8a346b949 20190610 Removed unneeded initialization of variables
10888 6de055a8c 20190610 Merge branch 'development' of github.com:domoticz/domoticz into development
10888 df236a34e 20190610 Merge PR 3306 from Ittiz/development
10885 4a2ac0074 20190610 OZW, fixed internal command class alarm/sensor alarm
10884 d5fba2c9b 20190610 Updated Noty library
10883 2046a56fb 20190610 OZW, added ignored commandclass COMMAND_CLASS_INDICATOR
10882 ac85fc866 20190610 Gui, Choosing Icon for ARC type switches (#3305)
10888 ab4ba45a8 20190609 Broken ozwcache filename
10881 b06fb6b60 20190608 Updated OZW OZW, Added missing include needed because of the OZW updates
10880 7e533b0f3 20190608 Merge branch 'development' of github.com:domoticz/domoticz into development
10878 b3e6f2458 20190608 ZWave Setup redesign
10877 ebc06a6d1 20190607 Merge branch 'development' of github.com:domoticz/domoticz into development
10914 0e20d08e3 20190610 Removed unneeded cast
10914 f3f803c7c 20190607 Fix display of custom theme images when webroot is defined. Issue EdddieN/machinon-domoticz
10880 c97ba38b9 20190607 Update to dzVents 2.4.23 (#3294)
10877 709d703d5 20190607 Database backup now via send_file method
10873 4984b2cc8 20190607 Updated Highcharts
10914 2c7e02f87 20190607 Merge remote-tracking branch 'upstream/development' into development
10872 a42641070 20190607 Merge branch 'development' of github.com:domoticz/domoticz into development
10877 6135a48bf 20190607 Webserver Implemented send_file method
10877 a82106b7d 20190607 Request_handler, revert static functions (needed later in other class(es))
10872 6282f6396 20190606 Added ico mime type Fixed: unknown file types should not return a Content Type
10872 8af527813 20190606 Adding additional mime types
10872 0c0a96bb7 20190606 Added some video mime types
10872 d5e1ccd04 20190606 Correcting variable type
10872 7c5c5f193 20190606 Fixing compile error
10872 efdf53ee9 20190606 Correcting variable type
10872 8d649b3b0 20190606 Logger, removed duplicate include
10872 9bd82d50f 20190606 Connection, Removed debug lines
10872 f3d1265b0 20190606 Connection_manager, removed unneeded includes WebsocketHandler, removed unneeded includes
10872 14fb5d162 20190606 Websocket, removed unneeded include
10872 ff27054ad 20190606 WebsocketHandler, removed duplicate include
10860 f92807bce 20190606 Updated Highcharts to 7.1.2
10859 d1fceae42 20190606 Updated OZW configuration files
10858 0eec66405 20190606 Removed unneeded highcharts files
10857 2ca5f48f5 20190605 Line endings supported in text log (#3297)
10856 d357b84f4 20190605 Added smartDEN IP-PLC support (#3298)
10855 e9d52623a 20190605 Quick fix for GCM not working anymore (#3293) by Olifant1990
10854 87565f1e7 20190530 OZW better label searching (needs to be changed later!)
10853 e1d76ab56 20190530 OZW better label searching (needs to change later!)
10852 ba5df49ad 20190530 Fixed: GUI, Floorplan, fixed blind switching (#3267)
10851 a10091268 20190530 OZW, removed deprecated Type_SceneEvent functions
10850 aa9a0b899 20190530 OZW, don't delete internal node from database on Type_NodeRemoved notification (#3280)
10849 e501f0821 20190530 Fixed: Dashboard Scene/Group status refresh (#3288)
10848 9fe68a152 20190529 RFLink, re-enabled support for new ID's, old users (<9700) should receive new switches
10847 6bf70aad4 20190529 RTL433, correctly returning handling handled status
10846 e44511b41 20190529 RTL433, solve issue 3283
10845 8be606e56 20190529 Fix comparison operator COMMAND_CLASS_SCENE_ACTIVATION (#3286)
10844 bcd551b09 20190529 Merge branch 'development' of github.com:domoticz/domoticz into development
10844 a51b7927c 20190529 Added LCS001 (Outdoor Lily Spots) to GAMUT_C_BULBS_LIST (#3284)
10842 40a39f636 20190529 Updated OZW library, partly implemented use of Index instead of labels
10841 5afd0eb96 20190528 Manufacturer_id, Product_type and Product_id now as uint16_t
10840 9497b1f73 20190528 Floorplan, also prevent door-contact to be switched
10839 bd4137b2f 20190528 Fixed: GUI, Floorplan, contact type can no longer be switch
10838 96e923490 20190528 Merge branch 'development' of github.com:domoticz/domoticz into development
10838 7b8d01a2a 20190528 Fix for issue 3274 ( connection to Youless failed ) (#3277)
10836 2a6b5c74e 20190528 Reverted #3239 (causing issues in #3273) (we need a read-only switch type I assume)
10835 5a198fa54 20190527 OZW, some more work on COMMAND_CLASS_SCENE_ACTIVATION class, needs OZW PR to be accepted
10834 bae9c600d 20190527 OZW Central_Scene now generating label, ignoring class in AddValue as it is handled elsewhe
10833 229881056 20190527 OZW, Central Scene, support for more modes then single click, Updated OZW debug library
10832 5e0ec35ff 20190527 Updated OZW headers
10831 b3dad8504 20190527 Updated OZW configuration files
10830 2953319de 20190527 Bugfix; Scenes broken in floorplans due to Image not being specified
10829 0ca123e49 20190526 Update to dzVents 2.4.22; selector switchselector to accept levelnames / fix for wildcarded
10828 fdf1cb4e4 20190525 Merge PR 3269 from Drumstickx/development
10828 db8f3b07c 20190524 Fixed Buffer Overflow.
10914 790077c41 20190524 Merge PR 1 from domoticz/development
10826 fccd39bba 20190524 OZW, removed double label checking, better alarm index searching Ident fixing
10825 da33cd066 20190524 Correcting ID string on dashboard (fixes #3264)
10824 e8c05e7c2 20190524 Fixing possible buffer overflow in YouLess class reported in #3261 by Drumstickx (Now handl
10823 99ad14960 20190524 Reverting RFLink Blyss patch once again. (#3232)
10822 636d15f6c 20190523 Revert previous RFLink Blyss patch
10821 bd0be67d3 20190523 Merge branch 'development' of https://github.com/domoticz/domoticz into development
10821 6b7d7e0b1 20190523 Merge PR 3239 from stas-demydiuk/water-sensor
10818 b290d4041 20190523 Devices tab, TypeError: "response.result is undefined" (#3257)
10817 ecc1066cb 20190523 Merge PR 3256 from ffontaine/development
10815 2f982c380 20190523 Merge PR 3258 from domoticz/ftr-roomplan
10815 66a733b5c 20190522 Small corrections
10815 456b4a848 20190522 Dashboard Tab, Store current room as route param to preserve during page reload
10815 6cc7da424 20190522 Temperature Tab, Store current room as route param to preserve during page reload
10815 481aa1936 20190522 Utility Tab, Store current room as route param to preserve during page reload
10817 07aa8eb47 20190522 Remove appversion.default
10810 315b45b68 20190522 Merge PR 3252 from waaren/development
10808 a5b199136 20190522 Merge PR 3251 from ffontaine/development
10808 4d8bbaf4b 20190521 Appversion.default: bump version to 10717
10810 0854ec2de 20190522 Fix Telegram notification error when odd number of underscores in text
10806 e0894404e 20190521 Merge branch 'development' of https://github.com/domoticz/domoticz into development
10806 147881c87 20190521 Merge PR 3241 from szczukot/BleBox
10806 4fb562fa4 20190521 Merge PR 3248 from szczukot/Satel
10799 83344f4c6 20190521 Fixed gcc compiler error
10798 ab452ade4 20190519 OZW, removed schedule value type warning
10821 48350c94b 20190519 Properly display water sensor on dashboard
10797 45fe40b8c 20190519 Correcting on/off actions with http text as parameter (3236)
10796 aab10ed1f 20190519 Reverted RFLink Blyss patch
10795 9ee8427e3 20190519 OXW, fixed scene handling
10794 c692d1875 20190519 Fixed device table initial order column
10793 b70a232d3 20190519 Merge branch 'development' of github.com:domoticz/domoticz into development
10793 6f5fab6ba 20190519 Merge PR 3202 from szczukot/BleBox
10788 c7257d3ca 20190519 Fixed: GUI, Dashboard icon incremental counter (energy generated) not correct (#3231)
10787 00be58cbe 20190519 Merge branch 'development' of github.com:domoticz/domoticz into development
10787 e3ac352ed 20190518 Merge PR 3227 from szczukot/Satel
10787 2e2b291c7 20190518 Merge PR 3229 from stas-demydiuk/lightswitches
10787 dd6a445f1 20190518 Merge PR 3230 from stas-demydiuk/on-off-chart-setcolor
10787 e4c367ae2 20190518 Store current room as route param to preserve during page reload
10780 c46faa90e 20190519 Updated ZWave configuration GUI style
10787 6759c35b2 20190518 #3200 Interpretate "Set Color" command as "On" for Lights/Switches
10779 b502bf302 20190517 Update dzVents to 2.4.21 ( Fix wrong direction on open() / close() for some blind types ) (
10778 76fd7c14f 20190517 OZW, removed unnecessary includes
10777 47e03df2b 20190517 Updated OZW configuration files Small OZW log change, ignoring Unknown meter types
10776 d62155fd7 20190517 Updated OZW library
10775 8d856832b 20190517 OZW, removed obsolete code, slightly better logging if unknown meter label is received, fix
10806 18e061f8c 20190520 [Satel Integra] more logs and few cahnges in protocol.
10787 d3885322a 20190517 [Satel] fix for Integra 256 Plus
10774 97177ce0c 20190516 Merge PR 3224 from szczukot/Satel
10774 6fbd123a0 20190516 Fix 32 bit mode
10774 50045138c 20190516 Merge branch 'Satel' of https://github.com/szczukot/domoticz into Satel
10774 acf4d9bc5 20190516 [Satel Integra] fix 32 bit mode
10774 863310ae2 20190516 Merge
10774 bb815c861 20190516 Merge PR 25 from domoticz/development
10774 4df7ff05c 20190516 Merge from PR 24 from domoticz/development
10766 b74d43cb2 20190516 OZW, Slightly better logging
10765 68a09ddb3 20190516 OZW, better Alarm type logging. Bitset support (As value)
10764 681da1518 20190516 Removing needless refresh call
10763 792e9a609 20190516 OZW, more work on Alarm types
10762 0e41e9c34 20190515 OZW, added handling of short value types
11413 e5eda1ea8 20191024 Merge branch 'master' of https://github.com/domoticz/domoticz into development
10761 ca1256bf0 20190515 OZW, Better logging of unhandled label, ignoring List type for Alarm class (for now)
10760 718d524f1 20190515 OZW, Apply Node Config corrected for new 1.6 driver
10759 c82148816 20190515 Merge PR 3220 from xbeaudouin/smallfixes
10757 b4c803fd4 20190515 Device Tab, re-added ZWave ID display
10759 96b0266c1 20190515 Xml: fixed memory leak in XPath library
10756 8e9483871 20190515 Merge branch 'development' of github.com:domoticz/domoticz into development
10756 b8459a5f7 20190515 Merge PR 3217 from xbeaudouin/fix_python
10753 407706120 20190515 Updated OZW header
10756 8e7dc7035 20190515 Fix Detection of Python 3.x libraries on FreeBSD (Delayed Link).
10752 4c51a84ca 20190515 OZW, added sanity checks for values
10751 aaed3481e 20190514 OZW, Making sure if we need to read a Byte or Boolean
10750 428d72606 20190514 Implemented: GUI, OpenZWave added Refresh Node Information button Updated translations
10749 47f79d9fe 20190514 OZW, better logging when a exception is handled
10748 c51e73bd3 20190514 OZW, added more logging, enable internal debug log (value_changed)
10747 f90722b99 20190514 Fixed compile error!
10746 65d6b2f76 20190514 OpenZWave, changed Label checking
10745 700d72b41 20190514 OpenZWave, removed writing config functions, removed labels for COMMAND_CLASS_SWITCH_BINARY
10744 fc6ba4cb9 20190514 Fixed: GUI, OpenZWave Abort Include/Exclude button
10743 49269bf9b 20190514 Small code refactoring Added VStudio project folders for dzVents/Lua/Python
10742 0a2929147 20190513 Domoticz.Configuration crashed when there was no configuration
10741 320cc8a4f 20190513 Added OpenZWave Exception handling
10740 34b73c195 20190512 Merge branch 'development' of github.com:domoticz/domoticz into development
10740 57fe96bb8 20190512 Removed AppVeyor builds until VS2019 is supported
10738 211b88480 20190512 Fixed: GUI, Weight Log now displays correct Unit (#3211)
10737 e038a8fec 20190512 Fixed History.txt
10806 a19d5e1b2 20190519 Revert "[BleBox] fix header"
10737 c3df01b79 20190512 Add errormessage on failed write to dzVents generated-scripts, update dzVents to 2.4.20
11059 66dbfba36 20190728 Real revert
10735 56d3fa099 20190512 Updated OpenZWave to version 1.6
10806 0bb77acac 20190519 [BleBox] fix header
11059 b2b0506ac 20190728 Reverting changes
10806 84a25f5a8 20190515 [BleBox] searching refactor
10734 3ac5b237d 20190512 Updating history
11059 f4f3c42e7 20190727 Removed static function declaration (not used)
10733 ad2ec83fd 20190512 Merge PR 3206 from stas-demydiuk/#3205
10793 75b67a068 20190514 [BleBox] fix log message
10733 809fecf01 20190511 #3205 Fix date parsing in device logs
10793 659f676c8 20190510 [BleBox] support for tempSensor
11059 3059206cd 20190727 Small code refactoring
10793 b7d096e05 20190510 Merge PR 23 from domoticz/development
10731 5f3358188 20190511 Add Configuration functionality
11059 4f83f90f2 20190726 Fix3
11059 ac8d20a37 20190726 Fix 2 dirent.h
10730 467892e18 20190510 Implemented: EventSystem, option in Settings to enable/disable URL call logging containing
10729 6505ccffe 20190510 Implemented: DarkSky CloudCover sensor
11059 33b9da763 20190726 Fix dirent.h
11059 af5bc9d20 20190726 Fix include dirent
10728 867908674 20190510 Merge PR 3201 from waaren/development
11059 f5332a076 20190726 Adding support for multiple 1-wire busses by reading directory content
11370 7fe64b596 20191016 Separate monthly usage and return totals
11059 be79a17d8 20190510 Merge PR 3199 from domoticz/Stable_10717
10726 7dd6c53b2 20190510 AppVeyor back to platform 141
10725 fa657e3ca 20190510 Updates VStudio project files
11059 dfc4f9160 20190510 Merge branch 'master' into Stable_10717
10724 11ac56109 20190510 Updating travis
10723 43fd27ea6 20190510 Updating travis configuration file
10722 4e4ee999c 20190510 Updating CMake configuration file to use version 3.14 as minimum and added boost dependency
10721 bec760edd 20190510 Better way to check for boost version number (works also with boost 1.70)
10728 eb2241f71 20190510 Make utils.stringSplit available via domoticz.utils
10720 6edc7436b 20190510 Merge PR 3196 from waaren/development
10720 4e6b9f1c2 20190509 Modified: dzVents/runtime/tests/testHTTPResponse.lua
10720 c20433b48 20190509 Fixed dzVents error messages and test script
10717 b38b49e52 20190509 Bumping version number
10716 d1687cf72 20190509 Fixed: dzVents, Allowing no error message for HTTP calls (#3191)
10715 6b2cad75e 20190509 Merge PR 3195 from szczukot/BleBox
10715 b60437c40 20190509 Correcting ident
10710 7598f4a3e 20190509 Fixed: EcoCompteur now uses the port specified in the hardware setup (#3184)
10715 fa72e7f39 20190509 Removed constructor
10709 a432095ae 20190509 Fixed some compile warnings
10715 e4d8f6411 20190509 [BleBox] read uptime for the newest firmwares
10708 b2f3d8da5 20190509 Fixed: Log for Weight sensor (#3192)
10715 994e62e35 20190508 Merge PR 21 from domoticz/development
10707 0513720c8 20190509 Fixed: issue with slightly to large labels for the selector switch (#3187)
10706 261ad3e56 20190508 <PlatformToolset>v141</PlatformToolset>
10705 e9a8e99f8 20190508 AppVeyor V142/Old platform SDK
10704 224d02c9a 20190508 PlatformToolset set to v141 for release build
10703 a7b94c2d4 20190508 Correcting previous overwritten code Appveyor now uses VS2019 when building
10702 68aa5292a 20190508 Merge PR 3188 from szczukot/Satel
10700 8ecc1716e 20190507 Reverting changing from last build (...w?)
10699 7a483bb38 20190507 Issue with Session ID/Login - Appveyor, release build now also using VS2019
10698 dba7797c7 20190507 Merge PR 3181 from waaren/development
10698 2df8ba29a 20190507 Updating development beta version
10698 74f582b50 20190506 Merge branch 'development' into development
10693 785c6b1e3 20190506 HTTP error/status code is now always in a header returned
10692 78e50fc16 20190506 Merge branch 'development' of github.com:domoticz/domoticz into development
10698 2ce26a81b 20190506 Use string split function in cpp to get statusCode, -Text and protocol
10698 49ff1504a 20190505 Changed method to return HTTPResponse statusCode to dzVents
10690 4a71ec61a 20190506 Bumping version number
10692 31b166712 20190505 Add 'Configuration' column to 'Hardware' table to allow Python plugins to store config in d
10689 37d3028b1 20190505 Updated History
10688 88a90c320 20190505 Minor ui fixes for evohome (#3177)
10687 a885c0a5a 20190504 Get HTTP statusCode from HTTP header (#3176)
10686 f7fc15713 20190504 Merge branch 'hf-appveyor' into development
10683 c0c42dbeb 20190504 Using correct OpenZWave version
10682 dbee6750b 20190504 Merge branch 'hf-selectsel2' into development
10680 4c7a36dc8 20190504 Merge branch 'hf-HttpPostReturnCode' into development
10678 52de7fec5 20190503 Merge branch 'hf-selbtn' into development
10676 8fbd94d49 20190503 Merge branch 'hf-loglevel' into development
10674 ff26f9283 20190503 Merge branch 'hf-session2' into development
10672 be32422a7 20190503 Merge branch 'hf-session' into Development
10670 ed06da654 20190503 Merge PR 3170 from domoticz/Development
10670 03430d6f9 20190503 Merge branch 'hf-history' into Development
10666 281a59b7b 20190502 Fixed RFX868 Weather type
10665 75deb7a4d 20190502 Merge PR 3091 from domoticz/proxycereal
11059 649306c4d 20190506 Update version number
11059 75ca62fe9 20190505 Bumping version number
11059 2945c5074 20190505 Merge PR 3180 from domoticz/Stable
11059 2cb2f52c0 20190505 Updated History
11059 048a39e3a 20190505 Merge branch 'pr-3177' into Stable
10686 3f149f061 20190504 Using Windows SDK Version 10.0.17763.0 for AppVeyor
10686 c1ba4aa33 20190504 Using correct OpenZWave version
10682 76ff5e153 20190504 Selector selected color now more inline with rest of Gui
10680 782c471f1 20190504 Fixed: Allow empty response for HTTP POST calls in Schedule items
10678 92c100800 20190503 Fixed: Selector selected color
10676 d7382d001 20190503 Fixed: Light Log Set 'Level' for RGB switches
10674 3e2d7e776 20190503 Fixed session handling (also on logout)
10672 5487dcc51 20190503 Renaming browser session and making sure it is found at the beginning of the header
10670 062a33f2f 20190503 Updated History
10670 2f5bf0d0e 20190502 Fixed RFXCom Weather type
10643 c33b35df5 20190502 Fix double strating of event system at startup
10642 0e7cadf47 20190502 Added extra character to check for
10641 9bcca3f7a 20190501 Merge PR 3167 from stas-demydiuk/devices-page-select
10665 62007cc82 20190501 Replacing boost::mutex with std::mutex.
10639 ae76889d7 20190430 Add Parent member to Connection
10665 88eefab36 20190429 Removed boost lexical dependency
10665 8bb0ae610 20190428 Decreasing platform toolset
10638 6e5241001 20190429 Removed unnecessary includes
10665 70de76c00 20190428 Reverted IncludePath changes
10637 1c3a33c35 20190429 Merge PR 3164 from fullTalgoRythm/dev_evohome_setpoint
10665 4cc76d4e8 20190427 Migration to vs142.
10665 68ab46fc3 20190425 Merge branch 'development' into proxycereal
10634 17a58a52b 20190428 Reverting Target Platform for AppVeyor
10633 da72f51e6 20190428 Reverting version for AppVeyor (2017)
10632 178a25d9e 20190428 Update README.md
10631 1f04ddb38 20190428 Reverted to 2017
10630 5f348b9bd 20190428 Upgrading to VS2019
10629 c662f710c 20190427 Fixed compile warning
10628 d9e6020d9 20190427 Fixed compile warning
10627 1e31db087 20190427 Merge PR 3162 from nutki/development
10625 c87fd5082 20190427 Merge PR 3160 from correa/freescale-imx6
10623 8a83239e1 20190427 Merge PR 3159 from stas-demydiuk/safari-date-fix
10621 1687198d5 20190427 Merge PR 3163 from nutki/touch-scroll
10641 11aa929f4 20190430 #3052 Devices: "select all" will select items only on current page
10621 ac43f6741 20190427 Prevent touch stcroll while using jQuery wheel color picker
10625 a58b8d672 20190424 Add serial port for Freescale imx6 devices
10623 a04a770be 20190424 #3151 Fix dates parsing in Safari
10619 adef2936a 20190424 Moved call to std::srand from Helper.cpp to domoticz.cpp (#3158)
10618 30fa3ad0f 20190423 Use std::round instead of adding 0.5 and casting. (#3157)
10665 27a68e3b6 20190420 Merge branch 'development' into proxycereal
10617 7b4dcb887 20190423 Bunch of code fixes (#3150)
10616 ce1d6f4d7 20190423 Merge PR 3146 from szczukot/Satel
10665 4ce00e08f 20190411 Merge branch 'development' into proxycereal
10613 f7674abfa 20190423 Merge PR 3142 from tih/mkdir_deep-segfault
10611 13ca671ec 20190423 Merge PR 3140 from szczukot/BleBox
10665 d8bfb375d 20190402 Merge branch 'development' into proxycereal
11059 3f22fe04e 20190504 Restore evohome human readable text for evohome controller device
11059 d1f271533 20190504 Fix ui-popup li height in elemental/custom.css
10611 3efe8ed5c 20190407 [BleBox] fix for switches
10774 2f1a759a3 20190508 [BleBox] reading shutter box - new firmware
10606 00bb3a4da 20190423 Merge PR 3135 from Olifant1990/fixRainRateSensor
10637 b428bc31f 20190428 Remove legacy func EvoSetPointColor no longer required now set via css
10611 aadc95bc6 20190407 [BleBox] fix for shutter
10702 7e01c46fd 20190507 [BleBox] check for shutter box
10604 77a0b09a6 20190423 Small code refactoring
10616 6b670ca9b 20190411 [Satel Integra] small refactor
10611 4b47eceab 20190407 [BleBox] Add support for airSensor and use the newest api for shutterBox
10637 4aea1b9cd 20190427 Add support for evohome setpoint background colours
10627 124421303 20190425 Arilux fixes
10616 7dde55148 20190411 Merge PR 20 from domoticz/development
10611 17069c48e 20190406 Merge PR 19 from domoticz/development
10603 08d470cef 20190415 Update dzVents to 2.4.18 (add triggerIFTTT) (#3141)
10613 07af4d2e0 20190409 Avoid out-of-array pointer dereferencing in mkdir_deep()
10602 ce68fa52c 20190404 Update dzVents to 2.4.17 (#3136)
10601 6b3314a3b 20190404 Merge PR 3138 from jvandenbroek/xiaomi_gw
10599 ac3ca90fe 20190404 Merge PR 3137 from tih/fix-group-name-reference
10606 8a9f4666f 20190402 Update for rain rate on views
10601 2ec119cb7 20190403 Xiaomi Gateway Aqara Cube report battery status
10597 e46a0a97a 20190402 Merge PR 3131 from Olifant1990/fixRainHistory
10597 4829f2dc2 20190402 Added SendRainRateSensor function to make it more generic
10597 0768e2879 20190401 Merge https://github.com/domoticz/domoticz into fixRainHistory
10590 9ee890b44 20190401 HTTP Protocol: Added support for chuncked transfer encoding outbound
10589 ffea4a725 20190401 Merge PR 3133 from szczukot/Satel
10589 594429c97 20190331 [Satel Integra] fix for Inetgra256 and allow to change names
10589 5bc443a7f 20190331 Merge fPR 18 from domoticz/development
10582 65b4dd944 20190401 Merge PR 3134 from Evsdd/development
10580 4addab274 20190331 Update dzVents to 2.4.16 (#3129)
10579 2119afbe7 20190329 Do not allow enters/returns in arguments (thanks to Fabio Carretto)
10578 ee70db46f 20190329 Fixed possible SQL Injection Vulnerability (Thanks to Fabio Carretto!)
10577 9c9319ace 20190328 Correct casting of WEATHER union
10597 0db8ca42a 20190328 Added more comment on how to use sTypeRAINByRate
10597 2e582479a 20190327 Renamed devicename to be more generic
10576 2c65161ec 20190328 Fixed Typo
10575 32a239241 20190328 Corrected Chill in pTypeWeather
10597 145f924dc 20190327 Merge https://github.com/domoticz/domoticz into fixRainHistory
10574 42ff507e4 20190328 Alecto WS5500 corrected (pTypeWeather)
10599 e81256812 20190403 Put correct node name in button titles in association group view
10573 596224a79 20190327 Update README.md
10572 4f9807c8a 20190326 Updated Weather Underground for use with the new API, option to specify Lat/Long as locatio
10571 a65955e9c 20190326 Updated translations
10570 5f1406f0a 20190325 Merge PR 3118 from BmdOnline/development
10568 68345e6be 20190325 Merge PR 3116 from Evsdd/development
10560 2aeb522bf 20190325 Merge PR 3111 from waaren/development
10665 19dd58663 20190317 Merge branch 'development' into proxycereal
10665 ba03ba87f 20190312 Merge branch 'development' into proxycereal
10557 f9e8502c0 20190325 Merge PR 3110 from mpiederiet/patch-1
10582 26455848c 20190401 Fixed: Evohome SYNC bug
10568 9f1b22677 20190202 Added Evohome SYNC command
10555 7c41212af 20190325 Merge PR 3105 from stas-demydiuk/devices-improvements
10665 180734075 20190307 Merge branch 'development' into proxycereal
10568 de8d57411 20190202 Fix Evohome: corrected HEAT_DEMAND comment
10568 a1c2ed0ab 20190202 Fixed Evohome HEAT_DEMAND debugging
10568 ba543a5b5 20190130 Fix Evohome boiler demand bug
10568 d25a716c8 20190315 Merge remote-tracking branch 'upstream/development' into development
10551 9d7a24683 20190325 Updated RFXCom SDK
10665 414a3ca62 20190306 Merge branch 'postcontentlengthfix' into proxycereal
10555 9d6411fda 20190309 #3093 Devices: Hide disabled devices if such option is enabled in settings
10550 9d226dab3 20190325 Fix for boot 1.70 get_io_service, fixed #3117
10597 2ea5a5fe4 20190324 Fixed rain device for DarkSky
10560 c907f9889 20190312 Fix warning in Travis on using int where it should be long int
10549 b7b71f1fb 20190323 Import and enable "faulthandler" module to give Python stack dump for all threads in a plug
10555 2f21a5ddd 20190309 #3103 Devices: Fix sorting by Date in Safari
10570 1fe87b218 20190318 Energy calculation
10557 7de5668cb 20190311 Fix for running as non-privileged user
10555 6bc4b3bac 20190309 #3084 Devices: Ability to manually refresh device list
10548 3f713ad4f 20190314 Python Plugin protocols now always use Parameters values for Username/Password during authe
10560 3137ff696 20190311 Add missing Fan and Fan_Calender SQL statements for DeleteDevices and TransferDevice modif
10547 a76a0fdb0 20190308 Merge PR 3102 from pipiche38/patch-2
10547 375c7901f 20190307 Missing SET in the Update statement
10545 9a6f48a10 20190307 Merge branch 'development' of https://github.com/domoticz/domoticz into development
10545 fff1b80c1 20190307 Merge PR 3100 from domoticz/postcontentlengthfix
10545 83c4881aa 20190306 POST request fix where content-length header equals 0.
10542 284ecd6a7 20190307 Add Touch Device unction
10541 9c07ca852 20190306 Merge PR 3099 from chatainsim/patch-1
10665 718f0a298 20190304 Fixed shared server via mydomoticz bug.
10541 f14122f4e 20190306 Add Markdown by default
10665 c8b6bf58c 20190304 Merge branch 'development' into proxycereal
10539 289d917fb 20190306 Updated OZW configuration files Updated translation
10538 15ee45947 20190305 Updated OZW configuration files
10537 e316d79c0 20190305 Merge PR 3080 from waaren/development
10665 e3098e703 20190228 Extra checks on const bool mSecure
10665 1f7dbb4bd 20190228 Hopefully eliminated crashbug in do_reconnect() upon a socket close().
10665 e3b8b7dc4 20190228 Merge branch 'temp2' into proxycereal
10535 3d006098b 20190305 RTL433, implemented Moisture sensor (should implement #3089)
10534 e32df7075 20190305 RTL433, support for sensors reporting in Fahrenheit (Should fix #3088)
10533 9d462ee5b 20190304 Add experimental support for WebSockets protocol
10665 d4cee924f 20190228 Revert "Revert "Proxycereal""
10537 56476a039 20190228 Update dzVents to 2.4.15
10532 414dfe3d6 20190228 Added a JSON command to retrieve the cameras as user (without parameters)
10531 bf19d8bbb 20190227 Corrected Add/Update/Check UserVariable code
10530 4e23c377c 20190227 Logitech Media Server, added 'daphile' to the list of supported models
10529 ff2465b28 20190227 Merge PR 3075 from stas-demydiuk/#3352
10527 408e51aa7 20190227 Merge PR 3074 from domoticz/revert-3060-proxycereal
10529 aafd87f1d 20190227 #3352 Devices: Ability to select/deselect all devices in the table
10527 98ab58a9a 20190227 Revert "Proxycereal"
10525 31571d5ee 20190225 Merge PR 3060 from domoticz/proxycereal
10665 20a036a83 20190228 Merge branch 'proxycereal' of https://github.com/domoticz/domoticz into proxycereal
10525 94dbdc049 20190225 Removed orphaned file
10525 76beb034e 20190221 Fixing portable ssl context reset issue.
10665 08ccf351b 20190228 Adding CProxyClient::Enabled() to only start the proxyclient if configured.
10525 b30dfa1ba 20190219 Merge branch 'development' into proxycereal
10525 f84e27dd3 20190211 Merge branch 'proxyasynctcp' into proxycereal
10525 e4088c59c 20190203 Merge branch 'proxyasynctcp' into proxycereal
10460 4cc60ea52 20190225 Merge branch 'development' of https://github.com/domoticz/domoticz into development
10460 20e722181 20190225 Ordered CheckUserVariable function
10460 43cceab02 20190225 Correcting user variable enum
10457 1926b1b3d 20190225 Added Multi-Threaded example to plugins directory
10456 a0a439b35 20190224 Merge PR 3064 from Atirbal/patch-1
10525 57c3f704b 20190211 Merge branch 'development' into proxyasynctcp
10454 366cdec3f 20190224 Merge branch 'development' of github.com:domoticz/domoticz into development
10454 5bcd17e14 20190224 Merge PR 3062 from guillaumezin/managed_counter_dashboard
10456 c7bb69e4c 20190224 You forgot to inject $interval
10450 9395fab40 20190224 Fixing non-trivially-copyable type errors (fixed #3063)
10449 aa011c15b 20190224 TTN, add GPS coordinate in Uservariable (3050)
10448 530cd7c85 20190224 Clarified Uservariable types
10454 4833c59bf 20190224 Removing double brackets
10454 48c35f9bb 20190222 Show counter value instead of usaged (undefined) on dashboard for managed counters
10447 3f0a62a06 20190223 CayenneLPP, added initial support for LPP_UNIXTIME
10446 cd16ded7d 20190221 InfluxDB pushed: added option for remote proxy path
10445 3b90ce8ab 20190219 Setting _tActionParseResults repeat to 1 as default
10444 64baca662 20190219 Merge PR 3055 from stas-demydiuk/zwave-topology
10444 b24ae6e33 20190219 Fix file paths for z-wave topology window
10442 14a385a6f 20190219 Merge branch 'development' of github.com:domoticz/domoticz into development
10442 42fb8d6af 20190219 Merge PR 3054 from waaren/development
10439 6e39ed699 20190219 Removed double initialization
10442 900ff8695 20190219 Dzvents bugfix for RGBWW Set Color state and latitude / longitude exposure
10438 88cca36c3 20190219 Fixed variable initialization
10437 cfe0171d8 20190218 Initializing default values of result structure
10436 fb1eaa01a 20190218 Merge PR 3049 from stas-demydiuk/elemental-theme
10434 1a72814f8 20190218 Merge PR 3048 from stas-demydiuk/counter-fix
10525 5667fc20b 20190203 Merge branch 'development' into proxyasynctcp
10432 2621dde73 20190218 Updated OZW configuration files
10431 b1c9d9196 20190218 Add latitude / longitude, check in openURL and prevent table as parm in updateCounter (#304
10434 f47a11c88 20190215 EnergyReport: fix counter display when there is no counter data for particular day
10430 a51967f7c 20190217 Updated OZW configuration files Updated translations
10436 369b90e07 20190215 Elemental theme: fix line-height on events-editor and devices pages
10429 09534cd76 20190214 Add Roomplan, return new idx
10428 2178bf5a8 20190214 Updated Anna Thermostat Added ability to select presets on the Anna via selector switch. Ad
10427 75069fe9b 20190212 Update: Handle new OnResume message (replaces OnPlay when playback resumes)
10426 91a981efa 20190210 Merge PR 3034 from stas-demydiuk/3033
10589 3a272536d 20190210 Merge PR 17 from domoticz/development
10424 be4b34a1f 20190210 Merge PR 3031 from jgaalen/development
10422 e9cbe5038 20190210 Devices page update (#3014)
10589 962082603 20190206 Merge PR 16 from domoticz/development
10426 770481221 20190210 #3033 Show hardware setup page for all types of MySensors hardware
10424 0594e26a1 20190209 Changed states from Text Sensor to Switch
10421 a5af243b6 20190207 Fixed Anna to work with both firmwares (#3024)
10525 3ce10a962 20190127 Merge branch 'proxyasynctcp' into proxycereal
10420 82d64ae58 20190207 Update dzVents to 2.4.13 (domoticz.settings.location and (#3025)
10419 80fcf9023 20190206 Merge PR 3023 from 999LV/development
10419 a793ddc77 20190206 Skip Netatmo sensor timeout check for Thermostats
10417 4db378a40 20190206 Removed boost UUID dependency in project
10416 b4a90cace 20190206 Plugin Framework now pre-loads site module and adds sitepackages to Python path prior to pl
10415 469e795e4 20190205 Xiaomi added a bit more logging
10414 454811f71 20190205 Merge PR 3015 from waaren/development
10412 929f23ec1 20190205 Preventing Mainworker to kill application if a thread takes a long time to complete (fixes
10414 019c7265e 20190203 DzVents documentation update
10411 18671433e 20190203 Eventsystem, logging setpoint value
10410 55086d5c1 20190203 RFLink getting correct ID
10409 70aedcf96 20190203 RFLink removing debug code
10408 48b5ccc98 20190203 XiaomiGateway, correcting label names
10407 c07e23539 20190203 RFLink support for Blyss type (with high unit number)
10406 f3e4b26eb 20190203 Xiaomi, using correct (application default) way to update temp/hum/pressure (should solve #
10405 07f95646f 20190203 EventSystem logging name when issuing thermostat SetPoint/Mode/Fan command (solved issue 3)
10404 f2e8509c8 20190203 Next Protect, removing Heat/US checks
10403 3c0a6c3b0 20190203 Merge PR 2981 from stas-demydiuk/hardware-setup
10399 651db01a2 20190203 Updated OZW library
10398 2da1f3a01 20190203 Changed random generator (removed boost implementation), could solve #2982
10397 c6e03f586 20190203 Merge PR 3008 from p-hagen/development
10397 0456d0a49 20190202 Fix for Anna tehrmostat firmware 3.1.4 XML change (issue 3006)
10395 8fa6a5c52 20190202 Updated OZW configuration files
10394 cc75ca023 20190201 Stop updating domoticz devices when Netatmo data is not updated (#2995)
10393 bf9de9be9 20190201 WU, fixed possible chillsign error
10525 16badb2c1 20190127 Merge remote-tracking branch 'origin/development' into proxyasynctcp
10392 075523a51 20190201 DarkSky fixed possible wind-chill callsign issue
10391 4b5c80ac3 20190201 Merge PR 3004 from DewGew/patch-1
10386 c7a847948 20190201 Merge PR 2983 from alfonso-presa/development
10384 8ce87e91b 20190201 Merge PR 2986 from maxcrystal/development
10380 7e5dd16fb 20190201 Merge PR 2997 from guillaumezin/event_lms
10378 4ca9ae5fe 20190201 Merge PR 2964 from guillaumezin/managed_counter_report_2
10391 e20b0f3a2 20190201 Update utility.html
10391 5366c2f1f 20190131 Update lights.html
10391 ed815f2b9 20190131 Update scenes.html
10391 43a0c201e 20190131 Update utility.html
10373 5d41f13f3 20190131 Appveyor enabled SFTP again
10372 82099eed0 20190131 Appveyor enabling RDP
10371 59feb7d33 20190131 Enabled beta and debug mode
10370 9467e7257 20190131 Removed secure label
10369 c8ec20fd3 20190131 Merge PR 3002 from domoticz/AppVeyor-Fix
10568 de120d826 20190130 Merge remote-tracking branch 'upstream/development' into development
10369 be75e2c8c 20190131 AppVeyor add secure password option
10369 2de3e62c8 20190131 Switching upload protocol to FTPS
10384 e72e227f4 20190123 Fix report data tables header alignment
10366 aac7d3efe 20190129 Update dzVents to 2.4.12 (add managed counter device adapters + test + documentation) (#299
10403 a88ce3072 20190119 Extract PanasonicTV hardware setup to own page
10365 a62903bf5 20190129 DzVents: Avoid rescanning script directories (#2998)
10384 22414df59 20190123 Merge branch 'development' of https://github.com/domoticz/domoticz into development
10403 e007b3d30 20190119 Extract BleBox hardware setup to own page
10364 1cacdddf1 20190125 Added Parameter entry to inform plugin the language that the Domoticz UI is using
10403 c56e8b6c8 20190118 Extract hardware-specific configs to own pages
10384 6a5f8e6bf 20190120 Fix #2974: Show log of percentage devices
10363 601825979 20190123 Update dzVents to 2.4.11 (add function snapshot for sending email with camera snapshot) (#
10386 49f8ec9e4 20190120 Fix(python domoticz): Log should be upper case
10362 060accf8f 20190118 Merge PR 2978 from stas-demydiuk/energy-multimeter
10362 4a391290e 20190117 Fix counter calculations for EnergyMultimeter
10360 fca2d3053 20190116 Merge PR 2968 from stas-demydiuk/light-onoff-chart
10525 630bf6bbf 20181226 Merge branch 'proxyasynctcp' into proxycereal
10357 ea791ae54 20190116 Merge PR 2975 from waaren/development
10378 a908de673 20190116 Remove costs for reports customized counters type 3
10357 75b5951b8 20190116 Fix for ignored after### function in updateSetpoint thermostat_setpoint adapter
10378 12fa829dd 20190116 Handle Energy generated and Counter units for Managed Counters reports
10378 d9db2c033 20190116 Change default unit for Managed Counter to "?"
10355 27933233f 20190115 Add global variables to Paramaters dict
10378 6a09ebac9 20190113 Handle other units (m3, s) for Managed Counters in report, for future use
10354 40052ca81 20190114 Update version string in dzVents Lua files to 2.4.10 (#2967)
10380 05990d4f9 20190127 Clean TRIGGER during ParseActionString, makes Logitech Media Server device command Play Pla
10353 0fa125f68 20190112 Merge PR 2963 from waaren/development
10350 7deabe104 20190112 Merge PR 2958 from guillaumezin/managed_counter_report
10346 d9e8eea29 20190112 Merge PR 2956 from stas-demydiuk/light-onoff-chart
10360 7161f41cb 20190114 Add initial value to DeviceOnOffChart
10353 8327790f9 20190112 Revert timing changes in stage1.lua integartion test and removed initials in device-adapter
10360 1197a01b5 20190114 #2955 Include Timezone offset in DeviceLevelChart
10525 ebabb0783 20181220 Making long and long long cross platform safe.
10350 a5493a709 20190111 Only one view for Counter and ManagedCounter, correct log for Managed Counter (normal graph
10353 35020aa73 20190112 Added option to use afterXnn() and within() functions to updateSetPoint() and Changed Z-Wav
10346 14995b0db 20190112 #2955 Show state as "On" for setLevel commands in Device On/Off chart
10346 f0d8101da 20190111 Min point width for On/Off chart in Lights log
10525 85483702f 20181217 Merge branch 'proxyasynctcp' into proxycereal
10343 3e3f545ef 20190111 Merge PR 2953 from stas-demydiuk/light-onoff-chart
10350 1acb61256 20190110 Remove submodules (added by mistake)
10343 59d8202f9 20190110 Add On/Off chart to Lights log
10350 3da815939 20190110 Handle reports for Managed Counter, send 0 as counter value
10341 7b7f346c5 20190109 Merge PR 2948 from stas-demydiuk/events-editor-triger
10338 d5901c50b 20190108 Merge PR 2949 from waaren/development
10336 aac9c14ab 20190108 Merge PR 2936 from lechunlx/development
10331 b38ff1383 20190108 Merge PR 2951 from sergray/fix/issue2927_rtl433_arguments
10341 0818f8013 20190109 EventsEditor: Add ability to choose script type for Blockly
10341 c84e4094d 20190107 EventsEditor: Add ability to choose script type for Lua and Python
10331 c0528bade 20190107 Fix issue 2927: Remove hardcoded legacy rtl_433 command line arguments, which break RTL-SD
10338 64e93681c 20190107 SQLHelper: add call to GetCurrentScenesGroups on device state change
10525 33069f28e 20181226 Merge branch 'development' into proxyasynctcp
10329 b5b3c8aa3 20190106 Custom icons for: Contact Door Contact Push On Push Off Door Lock Door Lock Inverted
10525 eeba616be 20181217 Fixing connect host.
10328 ebcdbe89e 20190106 Fixed Kodi Notification setup display (hops)
10327 47bc52a59 20190106 Merge PR 2941 from stas-demydiuk/custom-icons
10525 3f6856f25 20181217 Clearing readbuf()
10525 717ad3aae 20181217 Merge branch 'proxyasynctcp' into proxycereal
10324 d36f0d06d 20190106 Merge PR 2944 from stas-demydiuk/highcharts-update
10324 abdc038a7 20190106 Highcharts: Update global font settings for chart
10525 0c03bbd6b 20181216 Merge branch 'proxycereal' of https://github.com/domoticz/domoticz into proxycereal
10321 4934f5599 20190106 Merge PR 2943 from stas-demydiuk/highcharts-update
10324 02c4216af 20190106 Highcharts: Hide range markers on Temperature Log page
10321 41faf2f1e 20190105 Override default font for Highcharts
10525 194dab3b6 20181216 Merge branch 'proxyasynctcp' into proxycereal
10321 2c4f48a8b 20190105 Remove duplicated Highcharts config
10321 0a70b00c6 20181225 Update highcharts to 7.0.1
10525 fcfb08334 20181216 Fixing compiler errors.
10525 3fe1c2811 20181217 Merge branch 'development' into proxyasynctcp
10317 2ccf9db7a 20190105 Merge PR 2942 from domoticz/revert-2939-development
10525 4f1f09ffb 20181216 Merge branch 'proxyasynctcp' into proxycereal
10317 2adb3ba93 20190105 Revert " Update highcharts to 7.0.1"
10315 b071bb119 20190105 Merge PR 2939 from stas-demydiuk/development
10336 538a1d4b6 20190108 Reordered lighttype in logical order
10336 4f6b4a69e 20190108 Recorded lighttypes in logical order
10327 fd4618ce3 20190105 Update default icon on device switch type change
10315 8d165c4fd 20190105 Remove duplicated Highcharts config
10336 7ef32fdef 20190107 Update LightsController.js
10327 ce3aaac94 20190105 Show default icon based on device switch type
10336 413506bc2 20190103 Update Livolo switch - manual adding
10312 351736588 20190105 Added Time/Sun set/rise to events frame
10315 1025cb1a1 20181225 Update highcharts to 7.0.1
10311 e588266e3 20190101 Renamed Contact icon (preparation for custom icon) Fixed possible counter icon issue
10310 5f666c117 20190101 Now supporting partly disabling blockly blocks (fixes #2920)
10309 d4d17b2be 20190101 Merge PR 2933 from itpansic/development
10307 2046806c8 20190101 HTTP Protocol: Datatypes Bytes and ByteArray now supported for outbound messages (allows se
10306 c37ac69dd 20181231 Removed dB for RFXtrx Noise Level
10309 8d38f1e81 20181231 Support double click and long press feature for "Xiaomi Wireless Dual Wall Switch"
10305 4dd3263e5 20181231 Using MapQuest Geo API (fixes #2929)
10304 30480b212 20181230 Fixed timer where one part of the combination is even or odd week (#2928)
10303 f39f9513b 20181225 Fixed Custom Icon upload message (https://github.com/domoticz/domoticz/pull/2925 PR 2925])
10525 d1f1418c1 20181217 Seems to be working now. Please test.
10302 ca729a4cf 20181223 Defined __STDC_FORMAT_MACROS (fixes compile error with GCC 8.2 PR 2924)
10525 4b5f4872e 20181217 Still contains debug info. iothread bug solved by moving it into connect member.
10301 b15219463 20181220 Modify call to domoticz API for adding a uservar in dzVents Integration test (#2922)
10525 49b67e41a 20181217 Implementing asynv_resolve() Still no avail. ioservice runs out of work too soon, for some
10525 fb1e7e791 20181216 Added some clarification source code comments.
10300 f03fc6682 20181220 MQTT Uservariables, Incorrect Field requested (fixes #2921)
10525 a90bdc352 20181216 Async tcp fixes.
10299 308cc442e 20181219 Corrected uservariable update
10298 67682dfd0 20181218 Removed UserVariable type change in EventSystem
10525 249966496 20181216 Fixing compiler error.
10297 fc4fc9633 20181218 UserVariable refactoring
10525 a0c191944 20181216 Merge branch 'development' into proxyasynctcp
10296 3aab2b2b4 20181218 Removed unneeded uservariable event trigger call (There could be no event if the variable h
10295 eebede121 20181218 Removed ghost function
10294 62274b5b2 20181218 Renamed SaveUserVariable function to comply with rest of the code
10293 4d7f35da2 20181218 Remove ghost functions from header
10292 1d883c17f 20181218 Removing obsolete user variable function Removed wrong code call in notification handler
10291 812b9c162 20181217 Merge PR 2915 from Pelicjan/patch-1
10289 cb31508b6 20181217 Merge PR 2884 from domoticz/rxserialize
10525 8b76fa5cf 20181204 Merge branch 'proxyasynctcp' into proxycereal
10289 07f83a507 20181216 1 should be l. Oops.
10289 3eba99f1a 20181216 Fixed tempsign1 & temperature1 typo.
10289 b3a945318 20181216 Merge branch 'development' into rxserialize
10282 4dc9787b9 20181217 PVOutput poll interval back to 5 minutes
10281 80d4a9f8c 20181217 Merge branch 'development' of github.com:domoticz/domoticz into development
10281 7f170d6c2 20181216 Merge PR 2914 from macjl/master
10278 39f5f9154 20181217 Back to top implementation
10589 119592aff 20181215 Merge PR 15 from domoticz/development
10291 b6be7a840 20181215 Update SQLHelper.cpp
10277 5188fbc0a 20181216 Reordered ESP3_RORG, added some unknowns
10276 7245e9b25 20181214 Updated translations
10275 d1a5b01eb 20181214 Merge PR 2912 from kovainfo/development
10275 fb79af469 20181213 Update XiaomiGateway.cpp
10272 593866dde 20181214 EnOcean3 implemented EPP D2-03-0A
10271 efa3e38b9 20181214 Increased PVOutput poll time to 10 minutes
10275 8e8bb638f 20181213 Update XiaomiGateway.cpp
10525 3bf7a0d09 20181204 Merge branch 'development' into proxyasynctcp
10270 1b010e5ea 20181213 Toon URLEncode password
10269 c7e556ab0 20181213 Added support for NodeOn Soft Button TSB-2-1-01
10268 89e9d633f 20181211 P1 Meter, allow 0 for the new as Usage/Amperage/Delivery sensors
10267 7c1293821 20181209 Fixed Blockly issue 2904
10266 89676963d 20181208 Improvement: Add StartupFolder to Parameters handed to plugins
10265 9e75a45a0 20181207 Added new Wind sensor without Temp and Chill
10264 80f11d60e 20181207 Using rolling code as id when sensor does not provide the 'id'
10263 3ab838779 20181206 Some code refactoring, initialization and fixing possible crash and subtype check fix
10262 d1895a2ea 20181206 RTL433, redone, added WGR800,PCR800
10261 d3773b1b3 20181206 Corrected casting to float
10260 47537f832 20181206 Corrected PostBinary Call
10259 de0042ec1 20181206 Corrected MySensorsBase::UpdateSwitchLastUpdate
10258 a8ed1880b 20181206 Merge PR 2901 from gordonb3/badfileend
10289 a2a59660f 20181216 Fixing compiler errors. Added usage example.
10256 1cae66782 20181205 RTL433, corrected char* mistake
10289 d4ef2f3f6 20181204 Merge branch 'development' into rxserialize
10255 37d1cc57e 20181205 Better logging for RTL433 (missing headers before!)
10254 d5b690f2d 20181205 Updated OZW configuration files
10253 b8aeb96aa 20181204 Updated translations
10258 73664e781 20181205 Fix compiler error in SQLHelper due to missing newline at end of file
10252 e2dde5d97 20181203 Merge PR 2891 from gordonb3/evohomeupd1811a
10525 3cdeb7e8e 20181126 Merge branch 'proxyasynctcp' into proxycereal
10252 1f7261b3f 20181202 Add HTTPClient::Cleanup() to mainworker Stop() +correct a call that became invalid after #
10252 185952ef9 20181202 LogitechMediaServer: remove HTTP timeout as a configurable option
10252 2a05eb7c3 20181202 Revert change of timeout parameter to float
10252 4602b1b29 20181130 Let EvohomeWeb use the new timeout override options in HTTPClient
10252 8a75e9cfc 20181130 Timeout values should be able to handle milliseconds
10252 5bf3e2ebb 20181130 Extend all binary methods to accept a timeout override
10252 6c0117e82 20181130 Let all httpclient methods process return header data
10242 fb60a00be 20181203 Updated OZW configuration files
10252 ae0468fcc 20181130 Reorganize httpclient class
10252 4eeb328ed 20181130 Correct debug output
10241 4299924c0 20181201 BugFix: UDP connections without a protocol specified crashed when writing data
10240 b3d247e38 20181129 DzVents update to 2.4.9; bugfixes (wind and youless device-adapter and twilight-handling) a
10239 33192317f 20181129 Merge PR 2889 from ffontaine/development
10237 060e8f61f 20181129 Merge PR 2887 from roldoe/honeywell-thermostat-fixes
10239 4b7766223 20181129 CMakeLists.txt: fix build with python and cmake <= 3.7
10234 9401b3e28 20181128 Corrected RSL label
10233 edf0249be 20181126 Fix test. All's fine again.
10525 ec90ca698 20181126 Merge branch 'development' into proxyasynctcp
10232 7f79ad1c7 20181126 Merge PR 2885 from gordonb3/evohomeupd1811
10525 e2619b29c 20181113 Merged with upstream.
10237 afe9699d7 20181128 Replaced std::time with the normal time function
10237 d533769d3 20181126 Honeywell thermostat fixes and improvements
10525 9844728ae 20181116 Merge remote-tracking branch 'origin/development' into proxyasynctcp
10228 2ba5e3381 20181123 Merge PR 2877 from jonferreira/development
10224 1b7e859de 20181122 Merge PR 2874 from JVaassen/fixes_1
10224 cef289019 20181120 Correcting idents and small label changes
10228 9496ff0bb 20181123 Update MQTT.cpp
10224 66097a336 20181119 Merge branch 'development' into fixes_1
10232 d01b1748f 20181126 Use binary methods from httpclient to gain access to return codes
10228 0bd9ba7a3 20181123 Update MQTT.cpp
10232 a9bcdc787 20181122 Add internal helper for handling Web calls to the Evohome portal
10228 6e131f7a2 20181121 Update MQTT.cpp
10217 9e90885e9 20181121 Added EvoHome radiator Valve Value to Pushers InfluxDB worker, removed duplicate wait
10232 608844c61 20181122 Change login methods to counter new limits introduced by Honeywell
10568 eadd1f2dd 20190130 Update VS version
10289 6da449559 20181126 Adding RF structures that can be serialized.
10216 3a7bedee5 20181120 Removed duplicate entry
10215 72aea2965 20181118 Merge branch 'development' of github.com:domoticz/domoticz into development
10525 71bad2388 20181113 Create frame bug fix.
10525 7713c20fb 20181113 Merge remote-tracking branch 'origin/development' into proxyasynctcp
10215 080ec1b36 20181116 Merge PR 2854 from jvandenbroek/openurl
10215 bab64a1a1 20181116 Merge PR 2847 from sq5gvm/development
10525 1ca63feab 20181111 Proper mydomoticz host.
10525 3b9613805 20181111 Added PDULONGLONG define.
10204 c8b321f55 20181118 OZW, handling 'kVAh' unit
10525 226b62058 20181111 Requestid is now longlong
10215 beb8d750a 20181112 Blockly put back possibly relevant quote stripping
10203 a7873a8bd 20181115 Removed inaccurate current sensor from P1 Smart Meter
10224 8c9d3e2a2 20181119 Update P1MeterBase.h
10525 1a77bf4f4 20181111 New proxycereal files that compile on Linux.
10202 dacd2e3e2 20181115 Merge PR 2864 from sidepipe/development
10224 5ae6abf29 20181119 Update P1MeterBase.cpp
10525 441dc288d 20181110 Reversed optimization. Was not good.
10215 397a1d99d 20181112 Blockly added OpenURL after seconds
10525 d77de0e7e 20181110 Optimized statitc member FromString()
10215 a1ccb381e 20181112 Merge remote-tracking branch 'upstream/development' into openurl
10202 4415a8981 20181114 Fix EvoHome hot water graphs
10224 324753797 20181112 Update hardware/P1MeterBase.cpp
10200 c673dd9e9 20181114 DzVents: include telegram as notification method (#2863)
10224 a6502b9ef 20181112 Update P1MeterBase.cpp
10525 192794e16 20181110 Updated #includes, & windows project file.
10199 fb2f16f4b 20181112 Update README.md
10525 9848b05f1 20181110 Removed thd old proxycommon, renamed proxyxereal.h to .hpp.
10525 af38f1839 20181110 Removed unneccesary headers and superfluous debug code.
10198 3662c39eb 20181111 Corrected P1 counter values for report
10197 90c959983 20181111 Corrected ID for P1 Current sensor
10525 2d4ed46d4 20181109 Client side cereal version ready to test.
10196 f3d73b6c3 20181111 Merge PR 2857 from stas-demydiuk/events-editor-improvements
10525 de145eb50 20181109 Added #ifdef NOCOULD
10525 e99e6df80 20181109 Renamed CPduExec to class to CerealHandler
10525 5a1d0f198 20181109 Ready for the proxy executor methids to be implemented.
10525 b3a02fb83 20181109 Serialization functions + test in proxycereal.cpp
10525 ed9c598c5 20181109 Started on cereal implementation
10525 bbc835d1a 20181108 CWebsocketFrame::Create as a static function
10190 b55ffc11c 20181111 Merge PR 2851 from fjgalesloot/development
10525 20da42315 20181107 Using deque in connection class
10525 1e63edfa6 20181107 Using deque
10525 1ba1329a4 20181107 M_ member prefixes
10525 7645deea8 20181107 WriteQ.empty()
10187 62315630a 20181111 Simplified S0 code, added S0 support (not verified!)
10196 8bc0e41e9 20181111 Revert adding math blocks to Blockly (C++ part is required)
10186 75e68f293 20181111 Fix for YouLess meter report
10525 705e8eb0b 20181107 Added #ifdef WWW_ENABLE_SSL
10196 a17fc6005 20181111 Small ident correction
10185 931126a4d 20181111 Global angular tend functions
10525 6403b3d43 20181107 Final changes for proxyclient using AsyncTCP class. "Domoticz hardware" proxy not tested.
10184 fd3917518 20181111 Added missing source file to CMake file
10196 cbcc97b07 20181110 #2834 Events Editor: use POST request to create/update events
10525 bfede56db 20181107 Before writeQ implementation
10183 e0a2bcf14 20181111 Added trend calculator (only for temperatures at the moment)
10196 cc549fdc4 20181110 Events Editor: Create "active" events by default
10215 5ca5b779b 20181116 Removed extra line
10525 2bcb91136 20181107 Implemented ASyncTCP ssl sockets. Still has a bug.
10215 fcba6a943 20181109 EventSystem Lua AFTER support for OpenURL
10182 fad48f6fb 20181111 ASyncTCP masking unreferenced local variable warning
10525 90ccb3f65 20181107 Reconnecting works - pong to be tested.
10215 32e5eb19a 20181116 Cleanup
10196 007839c5b 20181110 Events Editor: Add math blocks to Blockly
10525 c3ee8987c 20181106 Eliminating proxymanagerCollection
10181 50dd71e55 20181108 Merge PR 2850 from kovainfo/development
10190 44669df05 20181108 Typo in comments
10215 062895159 20181116 Remove unnecessary c_str()
10190 d87c6d35c 20181108 Add parsing of current readings to P1MeterBase code
10525 818b1cf51 20181106 Does authenticate now.
10215 43aa58e11 20181107 Fixes issue 2842 Username and password used in URL for downloading images from cameras sho
10181 2e87eac07 20181108 Support Aqara Vibration Sensor (v1)
10179 f09855711 20181107 Removed double closing tag in event editor
10525 2ad8c0c15 20181106 Proxy first try, only compiles. Uses plain server.
10178 13c95bf88 20181106 Merge PR 2828 from tih/dzvents-disable-fix
10176 e7beff054 20181106 Merge PR 2843 from zentorin/development
10176 286135afc 20181106 Fixed Watchdog thread's start when domoticz is running as a daemon
10174 543c5dd9e 20181105 Correcting more Lighting log issues
10173 27e83a933 20181105 Merge PR 2839 from emontnemery/philips_hue_fix_2780_2
10173 1e98061f2 20181104 Small corrections
10171 8dd6677b3 20181104 Fixing lighting log for dimmers
10170 4f07339fe 20181104 Updated translations
10169 5da814695 20181104 Merge branch 'development' of github.com:domoticz/domoticz into development
10169 526b45325 20181104 Merge PR 2830 from emontnemery/philips_hue_fix_2780
10165 ddcd3f350 20181104 Fixed incorrect P1 usage report in notifications
10164 e73b26d49 20181103 Merge PR 2836 from tih/more-folder-endings
10164 bffe4efb6 20181102 Ensure / ending to a couple more directory paths
10162 8a184c75b 20181102 Making internal download links HTTPS
10161 e695a8aa6 20181102 Fix user data folder ending
10160 d75673fe8 20181102 Fixes absolute path lookup
10159 f037f7696 20181101 RFXCom, firmware flash, making sure it is 100% when ready
10158 7e3ef71a8 20181101 RFXCom, Async, Stop displaying parameters when port is disabled
10157 a37d29827 20181031 Merge PR 2825 from molekuul/development
10155 e4ef8eea9 20181031 P1 Report graph tooltip now displays 'total' field again
10157 438c4dcb8 20181031 Added parameter to make libcurl continue to send authentication (user+password) credentials
10154 06e1339d4 20181031 Merge PR 2815 from stas-demydiuk/rgbw-picker-component
10152 06ff89336 20181031 Merge PR 2823 from DewGew/patch-1
10152 97a04e2d6 20181030 Update Events.html
10154 785e7c127 20181028 RGBW Picker Angular component -- Extract rgbw picker initialization to angular component --
10152 1b3c60240 20181030 Fix Translation to match language files
10149 0046914e3 20181030 Removed duplicate switch case
10148 5360f9b7e 20181030 Merge PR 2821 from emontnemery/rflink_fix_command2
10148 edab6b501 20181029 RFLink: Add missing trailing semicolon
10146 62a36c72a 20181030 Support for Westinghouse FAN
10145 a158d8709 20181029 Add PyObject_IsTrue
10144 b8dbafc30 20181029 Simplified logging
10143 da0f39884 20181029 Removed restart function
10142 217c90feb 20181029 Merge PR 2705 from gordonb3/OverrideIsStarted
10142 b321e86fe 20181029 Merge branch 'development' into OverrideIsStarted
10132 15a50e1a1 20181029 Merge PR 2817 from molekuul/development
10129 72b507903 20181029 Merge PR 2816 from emontnemery/rflink_fix_command
10127 ae2d2c38d 20181029 Merge PR 2810 from emontnemery/rgbww_tweaks
10124 3d0b1d446 20181029 Forecast button, displaying correct units
10123 e08c9e15c 20181028 Added support for Westinghouse Fan
10122 f0d75e6e2 20181028 Json udevice call now using 2 decimals for temperature (again)
10121 2771a93fb 20181028 Merge branch 'development' of github.com:domoticz/domoticz into development
10121 1ca88b3da 20181028 Merge PR 2812 from stas-demydiuk/events-editor-improvments
10118 ca76cde9e 20181028 DomoticzHardware introducing short names that can be used for threads/log messages. Only RF
10117 e4948b112 20181028 Getting forecast in gui language again
10116 b2ab513b4 20181028 Removed incorrect comments
10121 2865311e4 20181028 Events-editor: minor improvements -- Show disabled label for disabled scripts -- Highlight
10115 bb7298e26 20181028 Added report for Counter Incremental devices
10114 05bd96cef 20181028 P1 Smart Meter report chart, limit amount of decimals in tooltip
10113 258802347 20181028 Correcting cost calculation for P1 Meter reports with return usage
10112 3897dbd1f 20181028 Return darksky forecast in language properties
10129 070e5762e 20181029 RFLink: Add missing trailing semicolon
10127 c75279d71 20181028 Show RGB hex in uppercase
10169 66ec21734 20181103 Remove extra prints
10111 29095def9 20181027 Updated OZW configuration files
10110 de9a1692c 20181027 Correcting P1 Electric report for users with return delivery
10169 86adea528 20181101 Fix bugs related to dimmer and on/off switch
10127 6c52680b5 20181027 Small fixes for rgbww related UI
10109 fd70e8e3d 20181026 Merge PR 2804 from rhaamo/fix/timeval
10107 377be4a48 20181026 Implemented: Starting implementation of Taiwanese language (big thanks to berry lin!)
10106 b312629a5 20181026 Merge PR 2803 from rhaamo/fix/u_short
10104 3a63e9f16 20181026 Merge PR 2802 from rhaamo/fix/pthread_getname_np
10178 725fa19fb 20181031 Fix inability to disable the last active dzvents script
10102 e4845ba1b 20181025 EventSystem, Counter Incremental now working (not a great way!)
10101 216bc016a 20181025 Displaying large values for counter devices in widgets
10100 ddfb94173 20181025 RFXCom ProXL implementation
10099 4575e8d49 20181025 Patch for RFXCom ProXL hardware
10098 2259ef43b 20181025 Merge PR 2798 from stas-demydiuk/events-editor-scrolling
10096 e9a6c38c3 20181025 Removed debug line
10098 cd27fe8eb 20181024 Events-editor: fix scrolling in scripts list
10095 3a21852e3 20181024 Various NetBSD updates (#2782)
10094 758c86bd1 20181024 Merge PR 2796 from jvandenbroek/remote_asynctcp
10094 ea1fb3297 20181024 DomoticzTCP merged upstream
10109 d45d4bd5f 20181024 Fix timeval by better importing sys/time.h
10106 a080f413a 20181024 Replace u_short by uint16_t
10104 171c4bad5 20181025 Fix pthread_getname_np only available on GLIBC
10090 0556c1ce5 20181024 Div dialog-replacedevice display with basic-auth (solved #2578)
10089 a60b4c737 20181024 Added Blinds T14/R15/T16 to lights.html
10088 9c2029999 20181024 Fixed fatal Signal 6 after Database Restore (#2787)
10087 525851f38 20181024 Update Event editor (#2755)
10589 d8c332b54 20181023 Merge PR 14 from domoticz/development
10086 3c68fc31f 20181024 RFXCom ProXL implementation (#2795)
10085 851a9ba9a 20181023 Merge PR 2783 from tih/domoticztcp-fixes
10083 ae0903f9f 20181023 Merge PR 2784 from tih/popp-stop-quirk
10083 609628a62 20181023 Changed to 'else if'
10080 442f02a32 20181023 Merge PR 2791 from moroen/development
10094 3ed18c23c 20181023 ASyncTCP fix resolving IPv6 addresses
10094 97700a0a9 20181022 DomoticzTCP rewrote using ASyncTCP
10083 64e63d3fe 20181019 Add a quirk for the Popp Stop water cut-off valve
10085 5114b77fa 20181019 Make DomoticzTCP stoppable and restartable
10080 47dc3d499 20181023 Discover python3.x lib on MacOS
10078 a668baf91 20181018 Week Graph for 'counter' sensor now working
10077 4e320c7b3 20181018 Travis disabling OSX builds for now (has problems inside the build script)
10076 38339b247 20181017 Fix compiling for Win32 caused by XiaomiGateway patch
10075 8d9899072 20181017 Merge PR 2777 from kovainfo/development
10073 befb9b7ed 20181017 Add read only Unit attribute
10072 521a825b2 20181017 Removed debug line
10071 7b0baa7b1 20181017 Merge branch 'development' of github.com:domoticz/domoticz into development
10069 80e54821e 20181017 Added barometer using in custom log chart
10071 65527b956 20181017 Added getifaddrs as fallback for finding local ip when Boost.Asio fails (#2778)
10075 992b97751 20181016 Fix </a> tags
10068 5a58539ca 20181017 Corrected water graph display
10067 da68b115e 20181016 Merge PR 2776 from stas-demydiuk/log-routing
10064 470adf2f8 20181014 Fixed usage notation for kWh/Gas and Water widgets
10063 a4ee29f98 20181014 Reverted commit 93b71fb5adef035149a166546b33720fcae0a6c2
10062 a8c26ee8d 20181014 Merge PR 2775 from eiaro/darksky#2726
10067 d39f79caa 20181013 Add routing for log -- Fix formatting for decimals -- Fix counter and cost calculations --
10062 994839da0 20181012 Fix: DarkSky url fixed. https://github.com/domoticz/domoticz/issues/2726
10060 8b4174ca1 20181013 Fixed compile warnings
10067 4d52eced4 20180926 Add routing for log - Use /log route for CounterLog - Use /log route for CounterSplineLog -
10059 06741959d 20181011 Updated OZW debug library
10058 74656b6e5 20181011 Updated OZW header files
10057 253f7b8dd 20181011 Updated OZW configuration files
10056 93b71fb5a 20181011 Setting maximum precision to 12 for shortest presentation of %g (meter values)
10055 b884b50ad 20181010 MySensors, ignoring V_IR_SEND subtype
10054 3b529af76 20181010 Fixed MySensors IR switching
10053 efcd35b8b 20181010 Merge PR 2766 from kovainfo/development
10053 a07acb217 20181010 Add smoke detector parameter
10051 063857839 20181009 On/Off actions where incorrectly handled when setting the a RGB/W Color
10050 471d5a157 20181009 RFXMeter, Option to specify meter divider
10049 098a95eb9 20181008 Merge PR 2727 from Risca/telldus_runtime_detection
10044 2fe5bc124 20181008 Remove libusb folder
10043 af6417a24 20181008 Reverting PR 2729
10043 752f21b18 20181008 Merge PR 2765 from domoticz/revert-2745-development
10043 88d50e2ee 20181008 Revert "Fix </a> tags for DashboardController.js"
10040 002e3bf6e 20181008 Reverting PR 2729
10039 b48a53c3e 20181006 Bugfix: UDP Listener disconnection error
10038 600cb678c 20181003 Preparation for custom meter dividers
10037 b2ba312ac 20181003 Merge branch 'development' of github.com:domoticz/domoticz into development
10037 4e16c9380 20181003 Merge PR 2745 from kovainfo/development
10034 fb0468c64 20181003 Fixed water graph display
10033 8a17b4251 20181003 EventSystem, UpdateDevice, handle notifications
10032 7c2c39d46 20181002 Merge PR 2744 from denkovi1/development
10037 3cb8490ec 20181001 Update DashboardController.js
10030 54ab3c407 20181001 Merge PR 2723 from Claude2666/development
10023 66f5ae1ea 20181001 Request parsing now checking headers in lowercase
10032 39b9c7723 20181001 Fixed switch / dimmer recognition
10022 fd312856a 20180930 Bugfix: Device.Update: Convert Options values to strings explicitly and resolve SuppressTri
10021 03e3eecdc 20180929 Merge PR 2725 from kovainfo/development
10018 f995e0664 20180929 Merge PR 2729 from stas-demydiuk/log-routing
10016 d4242df64 20180929 Merge PR 2737 from denkovi1/development
10016 fb5397eec 20180928 Improvements
10016 5b4e70c10 20180928 Improvements
10049 acd8fba72 20181008 Tellstick: include stdafx.h in factory
10016 7659fa0a0 20180928 Update DenkoviDevices.h
10011 6476b6823 20180929 Merge PR 2732 from twpeltenburg/patch-1
10016 c2be057c7 20180928 Improvements
10049 6867cad5a 20181008 Tellstick: add new files to domoticz.vcxproj* files
10009 f5fb220c7 20180928 Implemented: Timer Plan, duplicate option
10021 a5852e61f 20180924 Add new Aqara Wireless Mini Switch
10049 81e17f9fb 20180924 Tellstick: add runtime detection of telldus-core
10021 ef1f1cca0 20180924 Fix Xiaomi Gateway Lum issue
10049 d5f361c7f 20180923 Tellstick: remove checked in telldus-core
10011 5055b26a6 20180926 Update XiaomiGateway.cpp
10008 31974a245 20180928 Updated translations
10018 2dd17686c 20180926 Add routing for log - Use /log route for CounterLog - Use /log route for CounterSplineLog -
10007 74c6ad3f6 20180921 Merge PR 2714 from JonathanLondon/development
10030 6a81f3f26 20180930 Update HardwareMonitor.cpp
10030 a683a14f5 20180930 Update DomoticzHardware.h
10007 97c473387 20180920 Merge branch 'development' of https://github.com/JonathanLondon/domoticz into development
10030 97d12225c 20180930 Update DomoticzHardware.cpp
10007 f7fa780a0 20180912 Corrected comment To/Cc
10030 6fb857848 20180922 Update HardwareMonitor.cpp
10007 d1dd9bde2 20180920 Update comments in SMTPClient.cpp for clarity
10007 9f6794a8e 20180912 Changed ending comments
10001 89868f4fd 20180920 Merge PR 2715 from hoxi/tellstick_fix
10030 44ea58450 20180922 Update DomoticzHardware.h
10030 c41c90f2a 20180922 Update DomoticzHardware.cpp
10007 34474a10e 20180911 Update SMTP line endings to comply with RFC
10001 0fb6d5555 20180916 Fixed Tellstick compilation errors (from boost to C++11 conversion)
9998 00a25f9c6a 20180909 Merge PR 2698 from JonathanLondon/development
9998 648c56ef3 20180909 Merge branch 'development' into development
9992 98912c1a8 20180908 Bug Fix: Stop TCP Listening connections crashing on plugin shutdown
9991 df70cc0c2 20180908 Merge PR 2709 from emontnemery/philips_hue_general_switch
10142 3e052bc53 20180905 Return for Stop() needs to be negated
10142 e69ec63a2 20180904 Change function type os Start/Stop/Restart back to bool
10142 d6421a1c5 20180904 Apply new threading stop signal to heartbeat worker
9989 2c3c17f6a 20180908 Corrected TE923 hardware class compile error caused by previous PR
9988 cf5341f13 20180908 Bug Fix: Moved PyType_Ready for TCP & UDP listeners to prevent crash
10142 2718d1ab6 20180904 Remove newly added Restart() from XiaomiGateway as well
9987 574d412df 20180907 Corrected GPIO StopHardware function
10142 244acb2d0 20180904 Remove redefinitions of Restart()
9986 b11aff2a5 20180907 Thread signalling (#2710)
10142 5ac6753b9 20180904 Add RestartWithDelay for slow (USB) hardware
9985 405834425 20180905 Bug fix: Transport code could crash on zero length message
10142 370f03443 20180904 Correct for simultaneous change
10142 7d8c8b4bc 20180904 Some work on CDomoticzHardware
9984 70530a8c2 20180905 Refactor ASyncTCP class to not require polling (#2701)
9983 5a4da8c18 20180903 Added native support for multiple Xiaomi gateways without any restrictions (#2596)
9982 6d8911170 20180903 Removed terminate call cause by previous thread changes
9981 80a813d81 20180903 Implemented new threading stop signal in hardware classes
9980 291b22ab7 20180902 Pushsafer, implemented priority
9979 0e3e15d4b 20180902 ASyncTCP, Removed unneeded typedef declaration
9978 f88969299 20180902 Merge branch 'development' of github.com:domoticz/domoticz into development
9978 936c21dd5 20180902 Merge PR 2683 from Batilan/fix_Ec3kMeter_crash
9998 d5aa7e86f 20180909 Change Hardware SQL table to store USB device in a TEXT not a varchar[]
9998 61c6b55b5 20180909 Resolve clash in DB version
9998 79c72167a 20180909 Revised update to support /dev/serial/by-id on Linux
9978 5e7a20aa2 20180902 Bug Fix: UTF characters in plugin files caused crash
9973 0baa233ad 20180902 Simplifying ASyncTCP usage Fixed double IsConnected call Classes don't directly use private
9998 7dfabb7b0 20180901 Add scan of /dev/serial/by-id/* and /dev/serial/by-path/* on Linux
9972 0a04a85ae 20180902 Working on a new method to stop threads ASyncTCP now using callbacks, this helps with termi
9971 2740ae358 20180901 Merge PR 2696 from gneluka/mcp23017-init-bug
9969 0bc946cdf 20180901 Merge PR 2681 from emontnemery/threadsafe_hw_shutdown
9969 bf2b8abdc 20180831 CTellstick: Reset m_thread shared ptr after join
9965 435cf2993 20180901 Merge PR 2680 from emontnemery/remove_readQueueMutex
9969 fdd8ad85e 20180827 Fix review comments
9965 6a71ced7b 20180830 Fix handling of non RFXCom messages in DomoticzTCP
9971 4c16bfc48 20180901 Fixed MCP23017 initializacion issue with inverse logic
9965 08eb798ac 20180826 Remove RFXCom specifics from CDomoticzHardwareBase
9969 05d4fb54a 20180823 Fix non threadsafe HW shutdown
9962 0737c6ad8 20180830 Better description of iterator functions. (#2691)
9961 0bdf2cf29 20180830 Fixing highcharts dropdown menu
9960 3974b5c4a 20180829 Merge PR 2685 from sweetpants/patch-6
9960 a4f9e5aaf 20180828 Default value 6.4 confusing after creating device
9958 3229d2ffe 20180829 Rewrite P1MeterTCP to use ASyncTCP (#2684)
9957 edc903137 20180828 Update Denkovi Classes (#2661)
9956 45e82eeab 20180828 Merge PR 2682 from emontnemery/stringstream_refactor2
9956 cfcd6bde0 20180826 Use std::strtoull / std::strtoll instead of std::stringstream
9954 45b61e733 20180826 Cleaning visual studio project
9953 a8cb8b272 20180826 Always displaying a password field
9952 89db9778c 20180826 Solving #2586
9951 eed74bf7c 20180826 Merge PR 2679 from domoticz/revert-2657-stringstream_refactor
9951 49ff6dafc 20180826 Revert "Use std::stoull / std::stoll instead of std::stringstream"
9949 02656117a 20180826 Undo previous fix (was not fixing it)
9948 78ed6e28a 20180826 Trying to fix possible crash ( std::invalid_argument' what(): stoll)
9947 2682b5ae0 20180826 Moved pressure forecast calculator to it's own class
9946 e2e22449a 20180825 New Hardware, The Things Network with CayenneLPP application(s)
9945 c23ab17d9 20180825 Merge PR 2657 from emontnemery/stringstream_refactor
9943 c15f2d1f1 20180825 Fix difference between domoticz.time object and trigger (#2675)
9942 5524d792d 20180825 MQTT removed obsolete OnMQTTMessage declaration
9941 9764af10c 20180825 MQTT Removed obsolete OnData declaration
9940 d61bb18e1 20180825 Start logging to file earlier in main()
9939 a93e2f9cd 20180825 Teleinfo, using a std::string in parser, moved crc checking to base class so other classes
9938 11137c1a0 20180825 Merge PR 2674 from llbrt/fix-TeleinfoSerial-frame-analysis
9936 c6a68efaf 20180825 Merge PR 2673 from sweetpants/patch-5
9936 fb97e8b06 20180824 IDX was showed as HEX not Int
9938 917a80497 20180824 Fix TeleinfoSerial frame analysis
9934 c5a53b6e3 20180824 MQTT: unknown idx received! shows no ID (#2672)
9933 6c7c769e5 20180824 Corrected some logging
9932 3f84e1f6b 20180824 RFXCom: printing noise level in log at startup
9931 fbd1529ea 20180824 RFXCom: implemented Noise Level for Pro firmware
9930 be2e3c9ed 20180824 RFXCom speed up firmware uploading
9929 518838d33 20180824 RFXCom: Supporting detection of Pro2, Pro XL1
9928 ae0b17e59 20180824 Merge branch 'development' of github.com:domoticz/domoticz into development
9928 38486716b 20180823 Merge PR 2669 from gordonb3/EvohomeGraphs
9928 2610db7c0 20180823 Merge PR 2668 from gordonb3/jointhread
9928 ed9462eae 20180823 Fix crash on disable hardware
9928 1cfba8b4a 20180823 Corrected oversampling for I2C/BME280
9928 1cdf55f6d 20180823 Repair graphs and reports for Evohome devices
9928 93c187f25 20180822 Merge PR 2666 from emontnemery/printf_format_check
9928 69da3aa63 20180822 Merge PR 2665 from emontnemery/fix_printf_warnings
9991 882903acc 20180906 Add Philips Hue dimmers / switches as GeneralSwitch - Add Philips Hue basic dimmers and swi
9928 ca8e3c765 20180821 Merge PR 2664 from jvanderzande/development
9978 63420e317 20180902 Adjusted float to double for ws (watt-second)
9928 4d3f88d3b 20180820 Merge PR 2663 from emontnemery/philips_hue_simple_dimmer
9978 d036b65a4 20180826 Fix Ec3kMeter crash on large integer
9928 6184e4368 20180821 Fix incorrect printf format strings and arguments
9928 38309d1bd 20180821 Check printf format string and arguments
9928 32d2b4ec3 20180820 HighLight the ZWAVE DeviceId in the Domoticz ID field on the Devices page. This is an updat
9914 14d321583 20180824 Updated RXFCom SDK
9913 4ef5bf01a 20180819 Increased heartbeat_check timeout to 5 minutes (process rebooted while doing a large databa
9912 50e029974 20180819 GoodweAPI changes (#2636)
9911 77917fd7d 20180818 CEventSystem::SetEventTrigger, Fixed CPPCheck warning
9910 f6070aaa3 20180818 Merge PR 2651 from ehousepro/development
9903 f158b5f59 20180818 Devices tab, removed unnecessary zwave node id as this is part of the ID already
9902 4dc82fc94 20180818 Devices Tab, Scene/Group log icon added
9945 dd7059b79 20180819 Use std::stoull / std::stoll instead of std::stringstream
9901 73e38c8c1 20180818 Fixed Temp+Hum log button in devices view
9900 4abb67b73 20180818 Denkovi, Fixed compile warnings introduced by #2606
9899 47bd3b177 20180818 Dropped unused EventActions table
9898 1f2ddd663 20180818 Merge PR 2646 from emontnemery/improve_isdebuggerpresent
9895 c4fcbb201 20180817 Merge PR 2606 from dzelyaydinov/development
9895 8256acbce 20180814 Update WebServer.cpp
9895 8b8f75721 20180814 Update RFXNames.h
9895 352050636 20180814 Update RFXNames.cpp
9895 5aecb196d 20180814 Update mainworker.cpp
9895 fbab95791 20180813 Merge branch 'development' into development
9910 f0b12d8a4 20180818 Update domoticz.vcxproj
9910 3e5b22304 20180818 Update .gitignore
9910 3d067845f 20180817 Linux Err
9870 039603bcd 20180816 Merge PR 2647 from emontnemery/boost_build_error
9910 871a43201 20180817 Linux Error
9868 eacaeb63c 20180816 Merge PR 2648 from pipiche38/patch-1
9910 5df56da15 20180817 Update Linux compile error
9868 ee0413c21 20180816 The devices are not created correctly
9910 9ff7ed77f 20180817 Update eHouse to new version of Domoticz - device discovery - unlimited selectable fields
9866 4b274d473 20180814 Move zwave patch to repo (#2630)
9865 92569e58b 20180814 Fix build on FreeBSD (#2628)
9898 122628217 20180816 Remove BSD implementation
9870 ff130808d 20180815 Fix build error when compiling with older (but supported) boost versions
9864 f2d389bdb 20180814 Scene activation code will now always be handled as ON (fixes #2624)
9928 9e3f94922 20180817 Fix bugs preventing update of dimlevel for simple dimmer (LIGHTING2 type)
9898 1b11e5e94 20180813 Implement IsDebuggerPresent() for other OS than Linux
9863 716a52556 20180813 Winddelen added start log message
9862 8201f6dec 20180813 Merge branch 'development' of github.com:domoticz/domoticz into development
9862 c033e27b9 20180813 Options fix for selector level from selector switch (#2640)
9860 61fed8ad4 20180813 Fixed Fan/RMP sensor
9859 e15845fd3 20180813 Do not abort while debugging (for now)
9858 552215448 20180813 Winddelen, using new API URL now, and including some more sensors
9857 5936d708f 20180813 Merge PR 2638 from emontnemery/arm64_stacktrace
9855 1971f30bc 20180812 2.4.7 fixes (#2639)
9854 d1666ce23 20180812 Better graph display for thermostat devices
9853 1b2f7a6c1 20180812 Don't abort while debugging (and using breakpoints)
9852 c1c32951a 20180812 Merge branch 'development' of github.com:domoticz/domoticz into development
9852 705df25ba 20180812 Merge PR 2611 from emontnemery/mqtt_disconnect_on_error
9849 e29d6e3eb 20180812 Updated OZW configuration files
9848 f5ebb7b28 20180812 Added missing include
9847 9e4716920 20180812 Fixed compile warning in Helper class O_RDONLY
9846 7cad0ff95 20180812 ICMP: Supress Windows 'handle' error reporting on disconnect (ignored anyway)
9845 d5934e5bf 20180811 Bugfix: ICMP and UDP disconnect set to signal as async
9844 cdd602038 20180811 JSON Protocol now returns Python structured objects rather than text
9843 a9aeb1f86 20180811 Merge branch 'development' of https://github.com/domoticz/domoticz into development
9857 55986b79a 20180812 Try to fix arm64 build error
9843 0f04a3ddd 20180811 Moved IsWSL to Helper file
9843 7bf6dee8e 20180811 Merge PR 2575 from emontnemery/sw_watchdog
9843 cbd1ef84b 20180810 Add additional WSL bug info
9843 62e61bbf0 20180810 Move signalhandler + backtrace generation + watchdog to own file
9843 d8845c20f 20180810 Review comments
9843 9dfa10b43 20180809 Name watchdog threads
9843 18f894191 20180809 Revert synhronization of m_lasttime
9843 248925709 20180802 Decrease mainworker heartbeat period
9843 aea0463d7 20180801 Fix win32
9843 a1e023bdd 20180811 Merge PR 2632 from emontnemery/energy_meter_mode
9843 af1bec445 20180801 Fix arm
9823 3685e83e0 20180811 Multiple bugfixes: 1. Objects returned to framework not released 2. Serial connections not
9843 24294f790 20180811 Store energy meter mode in options map
9843 8955dba10 20180801 Workaround for WSL bugs
9822 03daeb5fe 20180810 Merge PR 2625 from emontnemery/plugin_race_2
9843 8bc8322d0 20180728 ..
9843 d09ba9051 20180728 Windows build errors
9820 00b17c3ff 20180810 Merge PR 2627 from szczukot/development
9820 4ac6450cf 20180810 [1Wire] fix for old devices
9843 24564de4a 20180728 Improve error handler, small correction in webserver heartbeat
9843 ad6663fdd 20180718 Remove unsafe timeouts from HW classes
9820 a6231c017 20180810 Merge PR 13 from domoticz/development
9843 8def78c3f 20180718 Fix race condition preventing session clean timer from firing (io_service must be started a
9817 696904b8c 20180810 Fix for Wind temperature log
9816 5be3f09cf 20180810 Fix for #2612
9822 42226e8ca 20180810 Fix races in plugin framework
9843 08d75fe7e 20180718 Add watchdog functionality to webserver, mainworker and main thread
9815 31aa4ca35 20180809 Removing SetThreadName in ASyncSerial to see if this solved issue 2620
9895 0f05bbc44 20180813 Update SQLHelper.cpp
9814 d5bac925d 20180809 Merge PR 2619 from TimelessNL/development
9895 a9dbec81f 20180810 Update WebServer.cpp
9895 64b5fbb81 20180810 Update RFXNames.h
9812 e98c851e0 20180809 Added CloseDatabase function in SQLHelper
9895 a2128a158 20180810 Update RFXNames.cpp
9895 5b18ff225 20180810 Update CMakeLists.txt
9811 374561fe5 20180809 Merge PR 2612 from stas-demydiuk/single-log-route
9895 be9dfa841 20180810 Update domoticz.vcxproj
9895 fd0d0626b 20180810 Update mainworker.cpp
9809 3fcc92834 20180809 Merge PR 2607 from cincuranet/patch-1
9895 b3e06e8c3 20180802 Update DenkoviUSBDevices.cpp
9807 a593d3b8a 20180809 Merge PR 2605 from emontnemery/named_threads
9895 557c46fcd 20180802 Update WebServer.cpp
9895 84b62e7f6 20180802 Update RFXNames.h
9895 b123ff403 20180802 Update RFXNames.cpp
9805 71da8f4c0 20180809 Merge PR 2571 from pipiche38/development
9895 99570d677 20180802 Update mainworker.cpp
9895 734cbe186 20180802 Update HardwareController.js
9895 f8007b66e 20180802 Update hardware.html
9895 9bcfe83db 20180802 Update domoticz.vcxproj
9895 79bd9f109 20180802 Add files via upload
9895 344b239c7 20180802 Update CMakeLists.txt
9895 c1311eda9 20180802 Update DenkoviDevices.h
9811 b5049dc2b 20180805 Single route for different device log types
9814 96e3c628d 20180809 Rtl_433: Add support for wind_speed wind_gust wind_direction
9895 66e9021a1 20180802 Update DenkoviDevices.cpp
9809 547447a52 20180802 Fixed L3 max axis name
9805 ed439fea0 20180726 Remove unnecessary comments
9796 4952b51e2 20180726 Merge PR 2593 from sweetpants/patch-4
9805 4365c224f 20180726 Translate to English some French comments
9794 1e6be9708 20180726 Merge PR 2587 from jvandenbroek/domoticztcp
9805 17a260464 20180726 Comply with naming convention
9805 2aa36aa86 20180726 Prefix sec_counter with m_ in order to comply with rules
9805 625a7fc64 20180717 Better manage Target Humidity and Temperature
9794 fd8d94d93 20180723 Fix for Windows build
9805 3358acdad 20180717 Store target temperature and target humidity for each Mode
9805 d45a341fb 20180717 Trigger POLL of device information after a Power On/Off or a Mode change
9790 c473047a2 20180726 Merge PR 2584 from Olifant1990/versionNumber
9794 ac6b5eca7 20180723 No longer need to sleep 1 sec
9805 ff5a98480 20180717 Move sec_counter to a large scope in order to control and trigger GetMeterDetails()
9790 db5006542 20180722 Changed Major version number
9796 c9b254976 20180726 Change MQTT idx to Integer for scenes/groups inconsistency
9794 2f0d3960e 20180723 Fix crash on shutdown waiting for socket timeout
9788 41a2a5311 20180716 Corrected win32 version information
9787 70ccb3933 20180716 Reverted win32 setup filename
9786 154094bdb 20180716 Corrected innosetup installation filename
9785 7bd0f5f47 20180715 Merge PR 2560 from trandbert37/feature/dzvents_twilight
9785 f4b9925f0 20180712 Add version to wiki
9785 4af9efabe 20180712 Update dzVents version to 2.4.7
9785 ea156a4e3 20180712 Add civil twilight to template
9785 3cc40afc7 20180712 Add missing to nowtime
9785 c6446f498 20180712 Add civil twilight example
9785 2fcdffcf7 20180712 Update changelog
9785 496dbbb3d 20180712 Update wiki
9785 5810485c9 20180712 Merge branch 'development' of https://github.com/domoticz/domoticz into feature/dzvents_twi
9769 e9eb04a58 20180715 Merge branch 'development' of github.com:domoticz/domoticz into development
9852 a14570754 20180804 Disconnect on MQTT protocol error
9767 951879ede 20180715 Appveyor.yml updated to innosetup 5.6.1
9807 57ee39b33 20180801 Name all threads to aid debugging
9769 0df8bafaf 20180715 Python LogException upgraded to handle Python returning a NULL filename during stack tracin
9766 aa96ba0fd 20180713 Cleanup/refactoring
9765 5f13ca134 20180713 ASyncTCP, added uint8_t write function back in public declaration
9764 21b5c58fa 20180713 Yeelight, added safety checks
9763 dcb748721 20180711 Corrected spelling mistake and cereal includes
9785 d75886dce 20180710 Add tests for civil twilight start/end
9785 8946a3a38 20180710 Add tests for 'at civildaytime' and 'at civilnighttime'
9762 27a7bc2d0 20180711 Merge branch 'development' of github.com:domoticz/domoticz into development
9785 058e7cba9 20180710 Merge branch 'development' of https://github.com/domoticz/domoticz into feature/dzvents_twi
9762 9b171b113 20180711 Merge PR 2558 from Olifant1990/sortingTemperature
9759 e726266e9 20180711 Corrected boost::lexical_cast conversion to unsigned int type Changed union for EvoHome to
9762 65610eca3 20180710 Fixed temperature sorting in report
9785 ce0f1b138 20180709 Add support for civil twilight in dzVents
9758 42a33a990 20180710 Merge branch 'development' of github.com:domoticz/domoticz into development
9785 c3e54eec8 20180709 Merge branch 'development' of https://github.com/domoticz/domoticz into feature/dzvents_twi
9756 b165654c5 20180710 Added cereal header-only library (http://USCiLab.github.com/cereal)
9758 55cb65367 20180710 Update WebServer.cpp (#2551)
9755 de00245f9 20180710 Code Refactoring/Cleanup (#2552)
9754 d3b9626cc 20180709 Code Refactoring/Cleanup (#2548)
9753 ecea0d3e9 20180708 Code cleanup (#2543)
9752 1576d5406 20180707 Trace fix for old armada architecture Nest, Fixed compile warning
9751 34816ac62 20180707 Merge PR 2539 from jvandenbroek/thread2
9747 7702c3a26 20180706 Merge PR 2530 from emontnemery/signalhandler_spawn_gdb
9751 b49402839 20180705 Reverted EventSystem thread ptrs, changed 1WireKernel stop logic (needed after dropping boo
9751 c0d5d5ca2 20180704 Removed joinable()
9785 867b9397b 20180709 Merge branch 'master' of https://github.com/domoticz/domoticz into feature/dzvents_twilight
9751 aa4f5d616 20180703 Converted many boost functions to C++11
9741 195d46abc 20180703 Code cleanup, updated nssm
9740 87c2d1c57 20180702 Merge PR 2536 from jvandenbroek/concurrent_queue
9738 1787df38c 20180702 Merge PR 2537 from jvandenbroek/override
9747 32d27b6c6 20180704 Clean up conditional compile of gdb generated stacktrace
9736 cfb98f2a1 20180702 Merge PR 2534 from domoticz/Python-3.7-GIL-changes
9747 25706a180 20180702 Revert changes to signal handler for WIN32
9747 c679e5968 20180701 Attempt to fix OSX and Windows build errors
9736 463bb8e28 20180701 2nd version, Python 3.7 and 3.6
9736 64750ee9d 20180701 1st level Python tracing added
9747 53f2e8247 20180630 Improve formatting of gdb output. Demangle c++ symbols.
9747 c28d65cc2 20180629 Try to spawn gdb for improved stack trace
9740 97d37bde6 20180630 Concurrent_queue dropped boost dependency
9736 5f61c5be9 20180701 Initial version working with Python 3.7
9738 12686d40e 20180702 Fix OSX build override warnings
9732 89825c80f 20180629 Merge PR 2527 from guillaumezin/managed_counter_ui_improv_2
9732 9cfe88a6c 20180629 Trace last value for counter graph
9730 077648678 20180629 Corrected windows installer version
9729 2eda6299b 20180629 UI improvements for managed counters (#2524)
9728 096064709 20180628 Updated OZW configuration files
9727 70f8afaa7 20180628 Merge branch 'development' of github.com:domoticz/domoticz into development
9725 e46055b78 20180628 Corrected PhilipsHue code (removed to much)
9727 3a402ae90 20180628 Bumped version
9724 4bebb985d 20180628 OpenZWave, support for Seismic Intensity sensor
9723 7d8c01f74 20180627 Planning ahead
9722 11ef59cc9 20180627 PhilipsHue,using normal iterators again
9721 41a07b0bf 20180627 Ignoring evohome notifications
9720 927e3c43e 20180626 Influxdb pusher, add timestamp again
9719 4755cd845 20180626 Removed duplicate code line (OneWireSwitchPollPeriod)
9718 2ad415420 20180626 Some code cleanup
9717 16e1fd39a 20180626 Implemented: InfluxDB Data push, support for Username/Password
9716 e811fc31e 20180625 Merge PR 2517 from gordonb3/HarmonyHub180625
9713 2379d4cd1 20180625 Fixed string format caused by previous cleanup
9712 55f3f0645 20180625 Corrected CMakeLists.txt version number
9711 1f462049c 20180624 Merge PR 2480 from stas-demydiuk/graph-log
9711 4a80390c9 20180624 Corrected Usage and Sound widget on dashboard
9711 3ae875997 20180624 Merge branch 'development' into graph-log
9707 358df963a 20180624 OpenZWave, controller options for RetryTimeout, AssumeAwake and PerformRetur
9706 dc0401a0d 20180624 Removed obsolete razberry code
9705 975397828 20180624 Some code cleanup
9704 ff36d622b 20180624 Some code refactoring
9703 459aa0e72 20180624 Small code refactoring
9702 aa3058c51 20180624 Fix double version display
9716 31b4ca7ca 20180625 Correct display of `NaN` on empty runningActivityList - empty value corresponds with activi
9716 ec40d431b 20180625 Make debug lines available to the logging system
9701 b47a877f2 20180623 Merge remote-tracking branch 'origin/master' into development
9785 98723b7da 20180628 Bumped version
9701 a3a459069 20180623 Stable release 4.9700
9701 2772d9f64 20180623 Merge remote-tracking branch 'origin/development'
9697 728715527 20180623 Added command line option to display application version
9696 6dad46d65 20180623 Merge branch 'release-v4' into development
9696 223a5eb37 20180623 Correcting makerelease script
9701 0406efeb7 20180623 Merge remote-tracking branch 'origin/release-v4'
9696 cc8018520 20180623 Merge branch 'development' into release-v4
9696 6dcb442f1 20180623 Merge branch 'development' into release-v4
9691 9d50497a7 20180623 Code cleanup (Should fix a lot of compile warnings on OSX)
9690 22a88c325 20180623 Code cleanup
9689 d089c84e4 20180623 Some code cleanup
9696 95d577edd 20180623 Updating release build script
9688 07906ddd1 20180623 Merge branch 'release-v4' into development
9688 f02753ce9 20180623 Another GPIO public patch
9688 8a2b39d96 20180623 Correcting public GPIO functions (issue with last patch)
9688 074ddbee7 20180623 Correcting public functions for SysfsGpio (issue with last patch)
9688 cd212245f 20180623 Code cleanup
9688 d5acb0c7b 20180623 Fixed deleting Short-Log data point
9688 2d204fe41 20180622 Bumping version number
9688 e950a4967 20180622 Merge branch 'development' into release-v4
9673 1ff47d300 20180622 Rewritten CMD Specific phone selection method (#2509)
9672 d3f48f9a6 20180621 Fixing travis OSX build (#2508)
9671 9bc35b0ee 20180621 Reverting CMakeLists.txt cxx standard defines (apple will not build, fixing that later)
9670 602a5cfd5 20180621 Trying to fix Ubuntu compile warning (__STRICT_ANSI__)
9669 1c40c2f11 20180621 CMakeList removed CMAKE_CXX_STANDARD_REQUIRED (ubuntu PCH compile warning)
9668 bfa342c68 20180621 Travis/Ubuntu using libcurl4-gnutls-dev
9667 12cd1c8fc 20180621 Replaced all SSRR() defines to std::to_string
9666 0f6ec6134 20180621 EcoDevices, replacing static_cast<std::ostringstream*> with std::to_string
9665 d835e2eb9 20180621 Kodi, removed dynamic string cast define (error: dynamic_cast from rvalue to reference type
9664 bb100c13a 20180621 Forcing c++11 in CMakeLists.txt
9663 1af14730a 20180621 SolarMaxTCP, ensuring buffer is large enough
9662 0a9610673 20180621 SBFSpot, ensuring buffer is large enough
9661 24f1603d3 20180621 P1MeterBase, ensuring buffer is large enough
9660 0be04a7d9 20180621 EvoHomeWeb, ensuring buffer size is large enough
9659 114a968e8 20180621 PhilipsHue, cleaning up code
9658 0f123d4fb 20180621 Corrected PhilipsHue rvalue parsing
9657 7bc16dc00 20180620 Some more code refactoring
9656 e20071dee 20180620 Corrected double iterator declaration
9655 41fcb49f7 20180620 Some code refactoring
9654 9d865e8c9 20180620 Fixed uninitialized variable bug
9653 b77ef8a86 20180620 Updates for OZW configuration files
9652 dc3287f5a 20180620 RFXtrx Lucci Fan DC implemented
9651 eeb997e2c 20180619 Merge PR 2503 from gordonb3/PolledHarmonyHub
9651 7bd7e9a46 20180619 Merge branch 'development' into PolledHarmonyHub
9688 2b75fdb26 20180620 Fixed uninitialized variable bug
9688 05e21a5e9 20180619 Merge branch 'development' into release-v4
9688 6d0ff23f0 20180619 Merge branch 'development' into release-v4
9644 2b17ae723 20180619 Updated RFXCom SDK
9643 e38083bba 20180619 Updated OpenZWave configuration files
9688 7bcfead57 20180614 Merge branch 'development' into release-v4
9642 3cf883bcd 20180619 Removed: NMA Notification system (the service has stopped)
9641 48032d979 20180619 Merge PR 2498 from stas-demydiuk/fix-timers-deletion
9641 f2af81b6c 20180618 #2495 Fix Timers deletion
9639 786b9638d 20180614 Remove unecessary test (#2492)
9638 f6fc6fe37 20180614 Fix Direction issue .. (#2491)
9637 9198b303f 20180614 Fixed typos. (#2490)
9651 5833fd08e 20180619 Class that contains virtual methods must also have a virtual destructor
9636 31488e374 20180614 Corrected HardwareMonitor compile error
9651 d7ed46b09 20180619 Update changelog correct failure to reset ping counter forward request
9635 5f795b810 20180614 Code fixes and cleanup
9634 5f63b3241 20180614 GoodweAPI fixes (#2478)
9651 5d0588da1 20180619 Minor adjustments to logging and heartbeat timer correction
9633 fbadd64cb 20180614 Fixed selector switch protected mode
9651 724a05af7 20180619 Cleanup code - remove obsolete lines and functions - update comment sections - fix log l
9651 a20a3ec49 20180618 Full overhaul of HarmonyHub code
9688 8d2f23ca1 20180612 Merge branch 'development' into release-v4
9632 2d071ef80 20180614 Reversed MySensors Smartsleep actions
9631 16f24b5ed 20180613 CMake file using static SSL again
9630 f73ccf8da 20180613 Updated CMake project to use dynamic linking of openssl by default, and using libcurl4-gnut
9629 9b2a845ef 20180612 Merge PR 2486 from szczukot/development
9629 8f7e8135a 20180611 [BleBox] Fix restart after apply settings
9688 fd30dad92 20180611 Merge branch 'development' into release-v4
9629 98f43419c 20180611 Merge PR 12 from domoticz/development
9625 529bd73d9 20180611 Corrected Gas meter display
9688 504fadd39 20180610 Merge branch 'development' into release-v4
9624 75bf35e12 20180610 Corrected appversion in json result
9623 415a22d41 20180610 Merge branch 'release-v4' into development
9623 104958228 20180610 Small code cleanup
9623 ea7632cea 20180610 Corrected RFXMeter display in Utility/Dashboard tab
9623 45825639c 20180610 Corrected Counter incremental display on Utility/Dashboard page
9623 906f72f50 20180610 Merge branch 'development' into release-v4
9711 5979abddc 20180610 Extract device graph log to own page -- Own page for GeneralGraph log page -- Combine Perce
9616 fd814fe8b 20180610 Implemented application version number in JSON devices response
9615 965cf0097 20180610 Shorten some subtype names
9614 552982775 20180610 Correcting Lua freebsd patch
9613 cafc85688 20180609 Merge PR 2476 from cincuranet/patch-1
9623 547cfaf9a 20180609 Merge branch 'development' into release-v4
9613 05dfa6013 20180609 Fixed extra space
9611 92f39671a 20180609 Corrected relative secpanel path (have to use url/secpanel/)
9610 1cdfe6293 20180609 Corrected VStudio filters Updated SecPanel
9623 8b18127ed 20180609 Merge branch 'development' into release-v4
9609 425defb68 20180609 Security panel rewrite (#2045)
9608 b25fad427 20180609 Merge branch 'release-v4' into development
9606 9f9763596 20180609 Add generic CustomCommand handling for scripts (#2386)
9605 a7e802405 20180609 Merge branch 'release-v4' into development
9608 f31a230bc 20180609 Removing LTO compile flag, it's to slow
9605 cb7bfa1b8 20180609 Merge branch 'Whiskey24-fixDzVentsOnFreeBSD' into release-v4
9605 a90eb4e9c 20180609 Merge branch 'fixDzVentsOnFreeBSD' of https://github.com/Whiskey24/domoticz into Whiskey24-
9601 cc7c72fa6 20180608 Merge remote-tracking branch 'origin/release-v4' into development
9605 2bc9777d6 20180609 When compiling LUA, include FreeBSD as a target in addition to Linux when adding -DLUA_USE_
