Domoticz version table V2
From Domoticz Wiki
Revision as of 09:03, 20 October 2020 by Rwaaren (talk | contribs) (Rwaaren moved page DzVents version table V2 to Domoticz version table V2 without leaving a redirect)
Version table V2
Version Commit Date Description
5803 e8d70e808 20161021 RFlink: add gpio support
5809 57e00c90f 20161021 Fix copy/paste error causing wrong repeat interval setting
5802 ee1170c8d 20161020 Merge branch 'master' of https://github.com/domoticz/domoticz
5809 c761c858e 20161021 Fix lock problem when stopping Tellstick
5809 cb3eb56c2 20161021 Fix typo causing hardware view to fail. Fix Tellstick settings labels.
6080 bd9279ca5 20161020 Merge branch 'master' of https://github.com/domoticz/domoticz.git
5809 d6f392cfa 20161020 Add Tellstick settings
5800 aec59c999 20161020 Toon: Resetting retry counter before update
5821 e03f91b97 20161028 Don't send out dozens of copies of the same message
5809 b77ae8cce 20161020 Use boost::system_time instead of boost_chrono in order to avoid adding dependenc
5799 8c510bf5f 20161020 Toon: Setpoint now directly set in application, extra refresh is done later
5802 1d65a4c61 20161020 RFLink: new devices added
5798 b17ead3d3 20161020 Toon: Added some sanity checks
5797 d71ac73ca 20161020 Toon: Force updated after action
5824 09b938383 20161021 renamed frequency define
5796 c220a7c9e 20161020 Another Toon commit
5824 2dfe07d12 20161021 more responsive event system
5795 5eb42bc56 20161019 Reverted Tellstick patch
5794 b5f445973 20161019 Merge branch 'master' of https://github.com/domoticz/domoticz
5794 775574a96 20161019 Merge PR 925 from JoblyFonty/master
5794 4637dcfe4 20161019 Merge branch 'master' of https://github.com/JoblyFonty/domoticz into improve_tell
5790 2a1f5a970 20161019 Some updates for Toon
5789 93e922dc6 20161019 Fix for invalid sValue (size >240)
5788 5059312f4 20161019 Some changes for Toon
5787 f558e2762 20161019 Fixed Lua update device handler(FrBoulli)
5786 d06a147f9 20161018 Merge PR 922 from szczukot/SatelIntegra
5783 5f14463f7 20161018 Added YeeLight hardware class to VS solution
5782 8d7733715 20161018 Merge PR 921 from corbinmunce/master
5782 c61993913 20161018 Adding Yeelight files
5782 a58948f9e 20161018 Adding Yeelight files
5814 4839b1e1a 20161022 [BleBox] Read value of DimmerBox
5782 0c768a488 20161018 Adding Yeelight files
6508 043771f3c 20161017 Merge PR 43 from domoticz/master
5786 b5ab87413 20161018 [Satel Integra] setting for poll interval
5782 0de01ef6f 20161018 Adding Yeelight files
5782 e5eb97ddc 20161018 Adding Yeelight files
5794 64db0572e 20161019 Add support for repeating Tellstick commands
5786 46484c0a2 20161017 Merge PR 44 from domoticz/master
5776 a114ce671 20161016 Merge PR 919 from vil1driver/master
5776 8934a1a4a 20161016 New LUA table otherdevices_scenesgroups_idx
5774 d56f8894c 20161016 Merge PR 918 from dynasticorpheus/master
5774 bb24353d8 20161016 Allow compressed HTTP response to improve transfer speed and bandwidth utilizatio
5772 fec82eba5 20161016 Merge PR 917 from larber/master
5772 6d7878e27 20161015 Energenie 5-gang house codes go up to P (see page 27/40 of the RFXtrx user's guid
5770 9d81b24fb 20161015 Removed debug in Daikin module
5769 d1a53520c 20161015 Random user agent at startup
5768 265d4ce71 20161015 Increased Toon poll interval
5767 80e83c574 20161015 Travis, OSX another try to fix the openssl compilation issue
5766 448579092 20161015 - Fixed: Dummy, Creating a new sensor always used the same id
5765 e7d4ca5fb 20161014 Merge PR 911 from szczukot/MultiFun
5763 97cff9954 20161014 Fix compile error for RFPlayer
5762 3c8379405 20161014 Openzwave, Updated configuration files
5761 506ab9b82 20161014 Some more RFPlayer work, fixed a compile warning introduced by previous change
5760 966e353b2 20161014 Merge PR 908 from szczukot/SatelIntegra
5760 4cb7e7485 20161013 Merge PR 42 from domoticz/master
6508 ea44f2217 20161013 Merge PR 41 from domoticz/master
5756 a7ff55006 20161013 Merge PR 906 from RaymondNg2/master
5752 7ba3d7ac6 20161013 Merge PR 907 from szczukot/SatelIntegra
5748 0be50dc6e 20161013 Nefit Easy Hot Water Mode
5756 f5d50b986 20161013 increased the version
5747 2f110f741 20161012 Updated translations
5756 f6f3168b7 20161012 Use inline javascript instead of another file
5746 638a64c3e 20161011 ZiBlue, More work done
5745 e625b8a88 20161010 Start of ZiBlue RFPlayer implementation
5756 9d1d3ce48 20161009 This fixes the problem that the 'More Options' closes on click. This is a problem
5744 289b09a6d 20161009 Merge branch 'master' of github.com:domoticz/domoticz
5760 246050de3 20161013 [Satel Integra] Fix for common blind roller
5744 7d73da0eb 20161009 Merge PR 904 from szczukot/MultiFun
5760 7ca548cab 20161013 Add notification for sTypeAlert
5752 cea7a37ea 20161012 [Satel Integra] new controler for roller blind
5752 c505a9ce1 20161008 Merge PR 40 from domoticz/master
5739 c8ffbb912 20161009 Another patch for the philips hue groups, should now be in original state
5738 f7094e2ab 20161007 Merge PR 901 from szczukot/MultiFun
5765 2f51c0162 20161014 [MultiFun] fix warnings
5744 17ec84b44 20161008 [MultiFun] fix for temperature set
5744 edd50ac08 20161008 [MultiFun] fix for show errors
5744 66ff7d198 20161007 [MultiFun] fix for battery level
5738 1c0327046 20161006 [MultiFun] small fix
5733 c0e0bcd56 20161006 Trying to fix travis os X opensll build problem
5738 6e01bf663 20161005 [MultiFun] typo
5732 ef48fddc7 20161006 Reverted PhilipsHue White group patch
5738 97e5bec9b 20161005 [MultiFun] set temperature is more precise
5738 8d0f79599 20161005 [MultiFun] add 2 new devices and disable battery level
5731 3c0ccf51d 20161005 Merge PR 897 from szczukot/MultiFun
5849 2ca0b029e 20161101 Fix problem when a physical button is connected to an actuator.
5849 87430d471 20161004 fix conflict fix domoticz/master
5731 1cda28b53 20161004 Merge PR 38 from domoticz/master
6508 e6f3e3fba 20161004 Merge PR 39 from domoticz/master
5731 14c0d139c 20161004 [MultiFun] Support for small temperatures
5727 c57e1dd9a 20161003 Merge PR 894 from szczukot/MultiFun
5731 087a3438e 20161004 [MultiFun] New sensors
5727 e0183edec 20161003 [MultiFun] Add lowering temp
5727 f1154013d 20161003 [MultiFun] English translation
5727 3d618eac9 20161003 Merge PR 37 from domoticz/master
5723 aa2c91b99 20161003 Fixed VStudio filters caused by patch #883
5722 94c6a67ec 20161003 Added more info to the log line 'User: xx initiated a switch command'
5721 de6905c62 20161003 Merge PR 883 from szczukot/MultiFun
5721 25ff459e4 20161001 [MultiFun] fix warnings
5721 0f4b7f9e3 20161001 [MultiFun] support for WriteToDevice
5721 77739cc04 20161001 [MultiFun] implemented next registers
5721 64a167899 20160930 [MulitFun] reading next 2 registers
5721 03286e2c7 20160930 [MultiFun] Small cleaning
5721 33720e757 20160930 [MultiFun] fix compilation
5721 d3a9b027a 20160930 [MultiFun] fix compilation
5721 4f2e74fb6 20160929 [MultiFun] fix compilation under c++98
5721 4042664ba 20160929 [MultiFun] implemented more registers
5721 d475a167c 20160928 [MultiFun] fix compilation
5721 99cb57ba0 20160928 [MultiFun] Polish letters
5721 3ad0a3848 20160928 Merge branch 'domoticz-master' into MultiFun
5704 fd1f5ae4d 20161002 Merge branch 'master' of github.com:domoticz/domoticz
5721 f9c313e8e 20160928 Merge branch 'master' of https://github.com/domoticz/domoticz into domoticz-maste
5704 a283e51d9 20161002 Merge PR 890 from Evsdd/master
5752 3e6d2ddff 20161001 Merge PR 36 from domoticz/master
5704 ee1f8bca8 20160926 Fix: Evohome HGI80 fixed zone temperature sensor linking
5701 e92fa1899 20161002 Philips Hue, now handles non-rgbw groups
5700 bdf92f7f8 20160926 Increased Daiking popll interval
5699 dca92d4ab 20160926 Changes user agent for ATAG One
5698 82f1242f9 20160926 Merge PR 882 from Sneezydevil/master
5698 c7b09f078 20160922 Merge remote-tracking branch 'refs/remotes/domoticz/master'
5691 b6808b42b 20160923 Merge PR 885 from sijones/panasonic-on
5688 8edeed841 20160923 travid, bumped osx_image to xcode6.2, as it errored on 6.1
5698 7366b4e5b 20160921 HEOS: Fixed handling of Event Changes
5687 eb4408305 20160922 corrected travis osX build
5698 2d674b4ab 20160921 Merge remote-tracking branch 'refs/remotes/domoticz/master'
5686 dd62235e5 20160922 Corrected PushSafer label
5721 aa53cb91c 20160928 [MultiFun] Read temperatures
5721 81733d1fa 20160921 [MultiFun] Prepare for new hardware
5685 7dac1fca7 20160922 Added option to clear the log
5721 558c03672 20160921 Merge PR 34 from domoticz/master
5684 11ffa0e6d 20160922 - Changed: Forecast.io to DarkSky
5683 a1ed1d26c 20160921 Updated app-cache file
5682 10cdad39a 20160921 Merge PR 881 from appzer/master
5671 20202c489 20160921 Merge PR 878 from szczukot/1wire
5669 4c7467f31 20160921 Merge PR 877 from szczukot/blebox
5665 76dde9b85 20160921 Merge PR 876 from szczukot/master
5698 aa39ec147 20160921 Merge remote-tracking branch 'refs/remotes/origin/HEOS-ChangeEvents'
5698 57bc79518 20160920 HEOS Enable ChangeEvents
5698 44310f411 20160918 Added HEOS remote
5658 1e8f8df63 20160921 Merge PR 875 from Sneezydevil/master
5658 19b7409f2 20160917 Improved compatiblility with compilers
5658 c28543a02 20160917 Turned of Debug_logging, removed obsolete explicit function and fixed some small
5658 3ecd37202 20160916 Fixed Cmd_HEOSMediaCommand so commands get passed correctly.
5658 637c61518 20160916 Switched to ASyncTCP class.
5658 608c78976 20160916 Add files via upload
5658 f392316b8 20160915 Some fixed connecting to HEOS
5682 cba3efda4 20160919 Update README.md
5658 b0aa19417 20160915 Fixed Javascript error
5658 bc993e13b 20160915 HEOS => HEOS by DENON
5682 1b6192b94 20160919 add support for pushsafer.com notification service
5658 6f1800dbc 20160915 Fixed loads of errors when compiling
5682 27a2f380f 20160919 Update NotificationPushsafer.cpp
5682 f5d98dde1 20160919 Update NotificationPushsafer.cpp
5658 52d324c3b 20160915 Added HEOS files to msbuild
5658 cdcca23d8 20160915 Use PlayerID instead of idx for SendCommand
5682 c1c9e58ba 20160919 add support for pushsafer.com notification service
5665 039c1adc2 20160917 revert changes
5658 eb3e13a13 20160915 Added changes to webserver required for HEOS.
5682 2f34a54b1 20160919 add support for pushsafer.com notification service
5665 024049dea 20160917 Merge PR 32 from domoticz/master
5682 89d63c45e 20160919 add support for pushsafer.com notification service
5658 5a9b614bc 20160915 Code Cleanup / Added now playing.
5658 efe201ce2 20160915 Fixed wrong default port for HEOS.
5669 996d2dc67 20160917 [BleBox] patch for properly string (workaround for mainworker)
5682 56e40d343 20160919 add support for pushsafer.com notification service
5682 b42d490f7 20160919 add support for pushsafer.com notification service
5658 9f8e2f455 20160915 Added required changes for HEOS to HardwareController.js
5669 57a828dda 20160917 [BleBox] Add own SendSwitch
5691 249e4e5fd 20160918 Improve debug logging, log when command is OK
5658 e6e992319 20160915 Start of HEOS implementation
5671 a8d4a2024 20160918 [1Wire etc] Fix fo is_number() method
5682 8dafbd362 20160919 add support for pushsafer.com notification service
5669 6c5f52064 20160917 Merge PR 33 from domoticz/master
5691 4db863a30 20160917 Change to support TV's that can be powered on by Network
5641 3741a530c 20160913 Update for MyDomoticz
5640 0b64c8cf5 20160912 Fixed P1 Month Meter report Usage T2 costs Small code cleanup for kodi/Daikin
5639 204394110 20160912 Added missing hardware/Daikin.cpp file to CMake
5638 dceedb406 20160912 Start of Daikin implementation
5637 26e9b4806 20160911 Patch for OZW Fibaro FGS213/223
5636 fd3475b69 20160911 Merge PR 863 from szczukot/blebox
5634 73b496ce8 20160911 Fixed interval preference setting
5633 fe8d04db9 20160909 Merge PR 860 from gordonb3/P1WifiGatewayDebug
5633 9372f1d70 20160909 Add debug entry for open ended messages
5631 54dffacfb 20160908 Merge PR 858 from gordonb3/P1MeterPartialLines
5631 ba3f03aa2 20160908 Fix for P1 hardware submitting arbitrary partial lines
5629 ebdf3ce52 20160908 Merge PR 855 from sbouchex/1wire
5627 a413f75ea 20160908 Merge PR 854 from xbeaudouin/missing_cert
5625 2e0504a9a 20160908 Merge PR 857 from szczukot/blebox
5627 a50e733ea 20160908 Missing server_cert.pem install (used for https server).
5629 fc46bdc3f 20160908 Fixed device unicity issue on 1wire device due to 1wire linux bug
5623 e95ff5165 20160908 Merge PR 851 from xbeaudouin/clang_unsigned_warnings
5620 021f6cc7d 20160908 Fixed some clang compile warnings
5619 d35ab99d5 20160907 OZW, reverted back to version 331cd7d6eef6f9f2658b91e662644d88c31eaf64
5623 22ac8e4c7 20160908 Use result.empty() instead
5916 cb72e3942 20161114 Allow external automation agent to create instances of virtual hardware/sensors w
5618 84a9e29ed 20160907 OZW, reverted previous patch as it did not work
5623 395094420 20160907 Fix unsigned expression < 0 (that is always true)
5617 22a25e278 20160907 Fixed CLang compile warning
5616 ca42ab5aa 20160907 OZW, test for binary switching
5615 c65c5066f 20160906 Merge branch 'master' of github.com:domoticz/domoticz
5615 d458496af 20160905 Merge PR 849 from gordonb3/P1MeterMsgSize
5615 504224f11 20160905 Add check for middleware changing the P1 message content
5615 07c6e78d7 20160905 Fix possible overrun of m_bufferpos due to empty lines prepending a message
5615 646cab472 20160905 Add log for discarding oversized message
5615 87286ee76 20160905 Merge PR 848 from ffontaine/master
5665 1598a25b8 20160914 merge
5615 f44606055 20160904 Merge PR 847 from BmdOnline/master
5665 c8a6bb3ae 20160904 Change Level for lighting type
5636 8ad12597c 20160910 [BleBox] Add GateBox
5615 74506d673 20160904 MySensors groupID
5606 2eddb4ac5 20160906 Updated OZW configuration files Removed Fibaro FGBS213/223 patch, as this is solv
5605 c9708784f 20160904 Added temp. Aeotec Smart Switch patch back
5625 c38634f75 20160908 [BleBox] Show type id on list
5665 90f88bd76 20160904 Merge PR 31 from domoticz/master
5604 e001af62d 20160904 Fix the possible breakage between
5603 b2d6e2e4d 20160904 Merge PR 839 from xbeaudouin/fix_warning_kodi
5615 6ea21db22 20160905 fix MUSL build issue
5601 831988e0e 20160903 Merge branch 'master' of github.com:domoticz/domoticz
5601 99e35939c 20160903 Merge PR 843 from gordonb3/P1MeterCRCSettings
5598 424527d66 20160903 Rain Sensor, rain-rate now also uses multiply factor
5597 dcc09b1b0 20160903 OZW, removed Aeotec Smart 6 switch patch, previous patch solves also this problem
5596 2206d9269 20160903 Fixed html email input, entering multiple addresses could cause a browser error p
5595 72df66c51 20160902 Updated language files
5594 a5fbb31ce 20160902 Merge PR 842 from gordonb3/P1MeterCRC
5601 ed57694a3 20160903 Fix persistency of CRC validation button in P1 meter TCP hardware editor
5594 5315c36fb 20160902 Change descriptive text on hardware page
5594 71931abf2 20160902 Add hardware option to disable CRC validation on P1 messages
5590 aa28a6c7a 20160902 OZW, When switching on/off a switch, first try the binary sensor (fixes an issue
5594 61fec9007 20160902 Fix compiler warning about integer conversion in P1MeterBase.cpp
5589 f8f52c40b 20160902 RFLink: New devices
5588 a4a170f9d 20160902 - Implemented: MySensors, S_WATER_QUALITY, water PH - Implemented: MySensors, S_W
5587 3ab4fe306 20160902 Corrected previous lux patch
5586 793a2ddfb 20160902 Merge PR 840 from ldrolez/graph
5584 68ebfb3fa 20160902 Merge branch 'master' of github.com:domoticz/domoticz
5586 f09cc09a4 20160901 Show ranges for Lux sensors in month/year views
5603 09ca8d4c2 20160901 Fix the possible breakage between
5584 fb39a53e1 20160831 Merge PR 836 from gordonb3/P1Meter
5575 73a2e9efa 20160902 - Fixed: When checking for updates is disabled, it is now possible to check for u
5574 e9a7cf5d5 20160830 - Implemented: Air Quality graph, Avarage and Previous month/year
5573 47c0c55b3 20160829 Merge PR 827 from ldrolez/stats
5584 2607d9b77 20160831 Log reason for dismissing P1 messages
5571 b6b93f156 20160829 Merge PR 834 from xbeaudouin/fix_execinfo
5584 1eab76ae7 20160829 Fix P1MeterBase class definition
5584 4ced962cb 20160829 Add CRC check
5569 97095f416 20160829 Merge PR 835 from xbeaudouin/small_warnings
5584 96b2611c0 20160829 Don't try to match oversized lines
5584 df8ea27dd 20160829 Really discard complete message on validation failure
5569 23b85dd5b 20160829 Remove a warning about extraneous parentheses
5567 ce42dd192 20160829 Merge PR 833 from ffontaine/master
5584 2e1ec549f 20160829 Only return success if the complete value is a number The original validation rul
5584 6cca37a71 20160829 Recreate of unitialized pointer may cause dismissal of correct P1 message
5571 5cd5f211d 20160829 On FreeBSD backtrace(3) is handled on libexecinfo library. Removed an old variabl
5567 331cd7d6e 20160829 Fix ambiguous call to abs
5565 88b8898d0 20160829 - Implemented: Error Log, option to send error logs by email - TCP/IP connection
5564 7a483549d 20160829 Merge PR 831 from ffontaine/master
5564 d4785668e 20160828 Fix ambiguous call to abs
5562 775da2727 20160828 Merge PR 830 from rahul-bedarkar/build-fix-with-uClibc
5560 4b755755a 20160827 Hardware Monitor: Added a try/catch around the Fetch function as it seems that it
5562 1826b352b 20160827 add proper check for detecting header <execinfo.h>
5559 d107ac677 20160826 Merge PR 826 from xbeaudouin/fix_warnings
5559 118f80c9e 20160826 Removed some warnings (extra parentheses), comments in comments..
5557 8b56ea722 20160826 Merge branch 'master' of github.com:domoticz/domoticz
5557 6f7e43cf9 20160826 Merge PR 820 from GoranLundberg/master
5554 0ac106d3f 20160826 OpenZWave: ignoring invalid temperatures (also for sensors that report -999.9 whe
5553 f6c7dec3e 20160825 OpenZWave: Updated configuration files
5552 98b6a5dbb 20160825 Merge PR 817 from domoticz/extra-mill
5549 f4fa40e51 20160825 Merge PR 823 from xbeaudouin/freebsd_nosysinfo
5547 f128a3b23 20160825 OpenWeathermap: Fixed some code OZWCP: extra check for manager
5549 b6688c467 20160825 No more needed for sysinfo lib on FreeBSD since linuxprocfs is now handling this
5546 a8a31aedd 20160825 BleBox: Fixed compile warning
5545 6d8c10622 20160825 Merge PR 821 from sbouchex/notif_priority
5543 09fd9e2cb 20160825 Merge PR 819 from ldrolez/stats
5557 ef85deb26 20160824 Corrected Prerequisites for Ubuntu
5545 d23c7e1fd 20160824 Added #PRIORITY keyword to HTTP notifications
5541 60c065536 20160824 Merge PR 815 from llagendijk/goodwe-warning-fixes
5552 b24bd1c55 20160824 Update hardware.html
5552 b65ac486d 20160824 Update Winddelen.cpp
5536 d6a0d3ce8 20160824 Merge PR 816 from FLKone/patch-1
5536 0e613711c 20160824 Fixed wrong path logged when python script directory not present
5534 df44ef62a 20160824 Merge PR 814 from ldrolez/guifix
5573 105f5b6f2 20160826 Also get the average Baro/Humidity for the current day
5543 d20b4fa61 20160824 More useful to have the average Humidity and Barometer value in the history
5534 4dafc22ed 20160824 I18n label changed
5532 9df804bc3 20160824 Changing appveyor to sftp
5531 4a24e59eb 20160824 Fixed Compile warning for I2C class Corrected line ending for SetupController.js
5530 9e707e10a 20160824 appveyor, corrected deployment provider protocol
5529 a5aba6b0f 20160824 Updated AppVeyor and Travis build scripts
5528 bace85494 20160824 Merge PR 810 from sbouchex/http_headers
5528 e0f155299 20160822 Fixed HTTP notification content-type default value
5528 e421ab337 20160822 Http headers enhancements
5525 c5ab897f9 20160821 HttpPush, added 'Gas' value
5524 217af0255 20160821 Windows installer will not overwrite server certificate
5523 eee4db389 20160818 Merge branch 'master' of https://github.com/domoticz/domoticz
5523 3048d47f8 20160818 Merge PR 801 from ldrolez/guifix
5519 d1f9ae5a1 20160818 Updated appcache version
5523 9b085249d 20160818 Show the local I2C sensors in the right position in the list not at the end.
5518 e2b91a10a 20160818 OZW, Updated ZUno configuration file
5523 2249df0b4 20160818 Use relative path for OZWCP. Better if Domoticz is behind a reverse proxy.
5517 a7f58387c 20160818 AppVeyor, changed deployment to FTPS
5516 2c6c836dd 20160817 Merge branch 'master' of https://github.com/domoticz/domoticz
5516 f8dee77fe 20160817 Merge PR 798 from gordonb3/P1Meter
5516 ee70f6707 20160817 Fixed: Selector switch alignment in mobile mode
5516 98d67fc38 20160816 Added missing image in elemental theme
5509 8da7a3d42 20160817 make scripts now check if there are new commits
5508 859e894d2 20160816 Merge branch 'master' of https://github.com/domoticz/domoticz
5508 69bd8a8ba 20160816 Merge PR 794 from szczukot/master
5516 d47a37492 20160817 Remove include for Logger.h
5508 f9aa23570 20160816 Change method name
5516 1e5aafd07 20160817 Make normal/high/low tariff comments generic
5503 d560687aa 20160816 - Fixed: Logitech Harmony, Ping request now working as well for firmware 4.10.30
5508 93d906e3e 20160816 [Ble Box] move method from webserwer to mainworker
5516 7c25f215f 20160817 Correct handling of corrupted P1 messages
7347 bbe4bb19b 20160814 moved examples to a higher level
5508 a1cdb9faf 20160815 [BleBox] refactor and new method for useful all hardwares
5502 42ed029cc 20160815 Merge PR 793 from szczukot/master
7347 b007daac0 20160814 renamed dispatcher files
5502 2f69eea42 20160815 [Ble Box] Implemented Light Box
7347 f351b973f 20160814 moved ignored files to root
5502 b538e89ea 20160815 Merge PR 30 from domoticz/master
7347 b33cba147 20160814 should not be versioned
5498 e5cf1921d 20160815 - Fixed: Blockly, fixed extra quote when setting a user variable string value
7347 3a61a409f 20160814 moved the dispatchers to the runtime folder
7347 532d21e5b 20160814 image link fix
5497 085557fa0 20160815 Toon, Added Solar sensor (if available)
7347 f623f8534 20160814 Transfering dzVents files to proper location.
5496 cd0a8f153 20160814 RFXTrx: Double checking received Type/Length Goodwe: remarked debug log buienrada
5495 e15a8286a 20160814 I2C: Corrected calculation
5502 5a581f6e8 20160813 Merge PR 29 from domoticz/master
7347 4f3b00973 20160814 Initial commit. Adding .idea to ignore
5494 e0902fb4d 20160813 Fixed previous I2C fix
5493 06726727c 20160813 OpenZWave, added Z-Uno to manufacturer_specific.xml , this might be overwritten
5492 7c3a088c2 20160813 I2C, Fixed typo
5491 e0e1bba61 20160813 Merge PR 790 from ldrolez/guifix
5491 a23d51fea 20160813 Merge remote-tracking branch 'upstream/master'
5487 68d75a199 20160813 Merge PR 789 from ldrolez/tsl2561
5491 cb3c90abe 20160813 Nicer icon alignment in the navbar
5481 82dcc5d71 20160813 Updated RFXCom SDK header file
5491 61c49ef98 20160812 Merge branch 'master' of https://github.com/domoticz/domoticz
5480 561844184 20160813 - Changed: Waterflow sensor, now uses Node+Child as ID (for example 0x0801)
5479 16147708d 20160813 Cleaned up RFXCom classes Some logical/consistent ordering in the base hardware c
5478 7ba60f9c7 20160812 P1 Smart Meter Electra, Fixed Refresh drawing glitch when there was a return powe
5477 25d86482b 20160812 Percentage chart will now calculate the min value instead of 0
5476 6c244d5d1 20160812 NefitEasy, catching possible crash when reading/processing the Gas value
5475 c1718b89a 20160812 Merge PR 785 from szczukot/master
5487 92cd0b2eb 20160813 Local I2C sensors label change
5487 6724b56f1 20160812 Grouping of local I2C devices
5487 d5182ddf1 20160812 Changed the labels for easier grouping
5469 594766f02 20160811 Implemented: RFXMeter, Option to specify meter offset
5475 02aecc186 20160811 [BleBox] revert
5487 80f66bc42 20160812 Real lux calculation using formulas in data sheet.
5475 5e34de810 20160810 Merge branch 'master' of https://github.com/szczukot/domoticz.git
5468 17091a9d3 20160810 Merge PR 783 from xbeaudouin/master
5468 9287cf318 20160810 Adding more hardware monitor stuff on freebsd using linprocfs emulation.
5487 31bb0c54c 20160810 Added TSL2561 illuminance I2C sensor
5475 dff0cab9a 20160810 [BleBox] fix for shutter
5475 7e57e30d0 20160810 [BleBox] fix for shutter
5466 65f56cd17 20160810 Merge branch 'master' of github.com:domoticz/domoticz
5475 6b219b621 20160809 Merge PR 28 from domoticz/master
5466 eb5c6252f 20160809 Merge PR 781 from szczukot/master
5466 aa2629b75 20160809 [BleBox] use StringSplit
5466 d8bd6a3d8 20160809 Merge PR 782 from ldrolez/master
5466 30c23d824 20160809 [BleBox] fix for update node
5466 f6b17e153 20160809 [BleBox] fix return value
5456 4c8cc104b 20160810 Blockly, script path is now optional (if not used, script folder is used)
5466 1c37f12fe 20160809 HTU21D: 1 byte should be sent for commands instead of 2.
5455 7a6632611 20160809 Devices Tab, display hidden devices with the 'remove' icon instead of 'add'
5466 037dac949 20160809 merge
5454 5eed91922 20160809 Fixed: P1 Month report return counter
5466 719d8448c 20160809 Merge PR 27 from domoticz/master
5453 05158a5bf 20160809 OpenZWave, changed moisture sensor to a percentage sensor
5452 dd7d79903 20160809 Fixed compile error introduced by BleBox changes
5466 f9d0e51e2 20160809 [BleBox] implemented Light Box S
5451 40f340db2 20160809 Merge PR 779 from szczukot/master
5451 70b49e95a 20160808 Merge branch 'master' of https://github.com/szczukot/domoticz.git
5451 9e34a2f0b 20160808 Merge PR 26 from domoticz/master
5446 c4700c4b9 20160808 Merge PR 777 from piokuc01/patch-3
5446 da25e1f6e 20160808 Update html5.appcache
5443 c531c89b8 20160808 Merge PR 776 from xbeaudouin/master
5446 1131bf3dd 20160808 Fix aligment position button "BACK" and title report to set on all page the same
5441 0be7e3a5e 20160808 Removed map reference in new angularjs file
5443 55fdf1f41 20160808 Fix the error : Error: Webserver: File '/ozwcp/favicon.png': No such file or dire
5440 2025ce67c 20160808 Fixed EvoHome temperature override icon
5451 d0f291296 20160808 [BleBox] add shutterbox support
5439 3e4a5749f 20160808 OpenZWave, added support for Moisture and Tank Capacity sensors
5451 abc2a9835 20160807 Merge PR 25 from domoticz/master
5438 9de11b599 20160807 - Implemented: P1 Electra Report, Now also displaying the counters for Return
5437 feb387100 20160807 - Implemented: Blockly, option to excecute a script in the DO statement
5436 43c202068 20160807 Updated AngularJS to 1.5.8 Removed failure message in GCM
5435 24a8c3971 20160807 Updated Highcharts to 4.2.6
5541 8bb7e9d29 20160824 Change loop variable type in hash to size_t.
5434 60183b0c7 20160807 1-Wire, removed 'searching switches/sensors' log message as it is flooding the lo
5433 be9f83b43 20160807 Possible fix for the RFLink TCP reconnect issue
5541 3262b41d9 20160824 Incorporated gizmocuz's comments: Use str.size and a for loop in hash function.
5541 f200ca580 20160824 Fix warning for usage of += in if statement for ChildID. Fix logic error in the s
5432 cfd6e6b13 20160807 All hardware classes based on ASyncTCP, are now able to also use a hostname inste
5541 9c158db7a 20160824 Fix warning for usage of assingment in if statement in hash function
5431 546fc17b3 20160807 Merge PR 775 from llagendijk/views-fix
5431 c02b706d4 20160806 Remove duplicated code in www/views/hardware.html
5429 e3e9752b2 20160806 Updated OpenZWave Fixed some incorrect linkage declarations in the new MQTT code
5428 cdf4636ab 20160806 Merge PR 767 from llagendijk/goodwe-inverter-web-api
5419 3005dbefa 20160806 Merge PR 772 from szczukot/master
5414 ef9907eb8 20160806 Merge PR 774 from sjoerdmulder/tinyxml-cleanup
5428 ef8a2a8c5 20160805 Fix string references
5428 7630465b4 20160805 Replaced value parsing with pure C++, not using c-functions.
5412 b1455b1bb 20160805 Merge PR 768 from domoticz/crashuponwebserverstop
5428 4a0c80f18 20160804 Minor text change to make error message consistent with function name.
5428 b327b82bc 20160804 Removed std::stof usage as it is c++11. Replaced by strcasecmp/ _stricmp.
5412 5020322d6 20160804 Enhancement: Calling StopServer in CWebServer destructor instead of just deleting
5419 720f54e72 20160805 [BleBox] Add heartbeatreceived
5428 680abcc37 20160803 Merge branch 'master' into goodwe-inverter-web-api
5412 433eaf0e0 20160804 Deleting CWebServer::m_pWebEm, if StartServer() is being called anew after StopSe
5412 8fe01ca42 20160804 Joining CWebServer's ioservice thread upon stop().
5419 6ab84ce64 20160805 [SatelIntegra] optimizing
5419 fa6b36fc7 20160805 [OpenWeatherMap] change logs
5412 baa3e8c0c 20160804 Doesnt crash anymore upon stopping and webserver connections are still being stop
5665 5f0964426 20160805 [SatelIntegra] optimizing (often reading, without double events)
5419 92ac09ea9 20160803 Merge PR 24 from domoticz/master
5412 4320d839f 20160804 Webservers are now shared ptr. Part #1.
5406 278c1b9f1 20160803 Merge PR 759 from szczukot/master
5399 c3a5f0892 20160803 Merge PR 766 from piokuc01/patch-2
5397 af6cce039 20160803 Merge PR 765 from yop190/patch-1
5395 0c8b32425 20160803 Merge PR 764 from janakelarsson/master
5392 c946b8d6c 20160803 Merge PR 763 from domoticz/proxyfix
5406 a77d65bdb 20160801 [BleBox] small cleaning
5392 d0e0bd244 20160802 Merge branch 'proxyfix' of https://github.com/domoticz/domoticz into proxyfix
5406 8ff3c739b 20160731 [OWM] more logs for debug
5406 65c6e9c98 20160730 [BleBox] fix compilation
5386 078e7fb50 20160803 Merge PR 760 from sjoerdmulder/patch-1
5392 e3f6992f1 20160802 Fixed Unix compilation errors.
5392 cb0b8b941 20160802 Waiting a bit more before connecting to MyDomoticz upon startup.
5406 4535504e9 20160730 [BleBox] compilaction fixes
5406 de6055712 20160730 [BleBox] Implemented first device - switchbox
5395 abacf1855 20160802 Use .items() to iterate over dict
5392 8ddc0c37c 20160802 Re-enabled commented out code for debugging.
5384 4219b0c41 20160803 Merge PR 757 from narfight/master
5406 f38369a30 20160730 Merge PR 23 from domoticz/master
5395 d7f4d8f94 20160802 Don't attempt to close file if file pointer is NULL
5414 cd778eea4 20160806 Removing unused tinyxml copy
5399 c2f4628fa 20160803 Small correct for About
5384 aa7f824b4 20160729 Update Kodi.cpp
5397 80b70426e 20160802 Fix URL for removing node in a group
5386 227249c96 20160730 Fixing removal of association
5392 02d738b50 20160802 Some bugs fixed, but most importantly reconnecting works like expected again.
5382 7071bfc5a 20160726 Merge PR 754 from gaeljw/improveAngular
5382 1ac7a382e 20160726 [fix] In some cases, widgets could not be aligned
5380 0c928b4e0 20160726 Merge PR 711 from jotakar/master
5369 b76e55780 20160726 Merge PR 752 from d00616/update_mqtt
5369 7618cf656 20160724 MQTT Update: Windows Include fix
5369 2c06657b3 20160724 MQTT Update: Windows Include fix
5361 8e944da45 20160726 Merge PR 751 from gaeljw/improveAngular
5369 589b9911b 20160724 MQTT Update: Windows Include fix
5361 79bfc96b9 20160723 Refactor weather : upgrade appcache
5369 754fedf42 20160724 MQTT Update: Cmake and Windows fix
5361 ce8059192 20160723 Refactor weather, step 3 : re-enable widget ordering
5369 4618db94e 20160724 MQTT Update: Rename WWW_ENABLE_SSL to WITH_TLS for compatibility with unmodified
5361 72abf1fcf 20160723 Refactor weather, step 2 : page header
5369 6702b7ed9 20160724 MQTT Update: Add CMAKE_CURRENT_SOURCE_DIR to include_directories
5369 997296f42 20160724 MQTT Update: Update existing MQTT files
5361 71c904544 20160723 Refactor weather, step 1 : widget directive
5356 7b38b2afe 20160723 Merge PR 749 from llagendijk/fix-webserver
5428 1b34e62b5 20160803 Changed Goodwe driver to use inverter list as that contains more detail, adds sta
5428 147ec255b 20160722 Add vcxproj file adaptations for GoodweAPI on Windows
5428 6bc98888d 20160722 Add a driver for Goodwe power inverters via the unofficial Web-API
5352 1db358659 20160723 Merge PR 745 from gaeljw/improveAngular
5356 16e6d60bb 20160721 Merge branch 'fix-webserver' of https://github.com/llagendijk/domoticz into fix-w
5352 6ef3780f9 20160720 Remove unnecesseray div + upgrade appcache
5356 cfb275ef0 20160721 Fix typo in Webserver.cpp that breaks upfates of hardware
5352 7966d4ddb 20160720 Fix 6333ac5 : in some cases, blank spot can appear instead of widget
5356 30e36186b 20160721 Fix typo in Webserver.cpp that breaks updates of hardware
5349 dc4c447a9 20160720 Oops.
5348 61cc2c36a 20160720 Merge branch 'proxyreconnects'
5346 4787df46f 20160720 Merge PR 744 from szczukot/master
5346 f4356f1e8 20160719 Merge branch 'master' of https://github.com/szczukot/domoticz.git
5346 466789cbf 20160719 Merge PR 22 from domoticz/master
5342 6d1860e1f 20160719 Merge PR 743 from sbouchex/http_fix
5340 db63fa1dd 20160719 Merge PR 741 from WoLpH/usable-zwave-topology
5340 9f208d360 20160716 improved zwave topology usability
5348 46c92502a 20160720 Fixed some proxyclient bugs.
5342 2444bc02c 20160717 Fixed thread issue
5338 e7ce499b8 20160716 RFLink: Tiny Milight fix
5337 9cbdba66f 20160715 Merge PR 740 from szczukot/master
5335 9a6b19a43 20160715 Merge PR 731 from IgorYbema/master
5332 5594361bd 20160715 Merge PR 739 from szczukot/master
5330 8552fb6ae 20160715 Changed: MySensors, now ignoring rain-rate sensor as it is calculated by domoticz
5329 2a18f534b 20160715 Merge PR 738 from Evsdd/master
5327 b29b372a3 20160715 Merge PR 735 from gaeljw/improveAngular
5327 d2e60d3cb 20160714 Refactor temperatures : upgrade appcache
5327 90d59410f 20160714 Refactor temperatures step 3c : create view for temp log subpage
5327 9df5eb5c3 20160714 Formatting
5327 969f8ba47 20160714 Refactor temperatures step 3b : create view for custom temp log subpage
5346 0e81b4cd6 20160719 small code clearing
5327 5433b943f 20160714 Refactor temperatures step 3a : create view for notifications subpage
5337 39a48605a 20160715 Dont shows sTypeWINDNoTemp item on temperature tab
5318 21ee0f501 20160715 Merge PR 734 from szczukot/master
5327 96787d5d8 20160714 Refactor temperatures step 2b : clean up unused variables
5332 8fbbccec4 20160715 [OpenWeatherMap] Done
5318 47f463849 20160714 [OpenWeatherMap] initiaql commit for free weather service
5327 1199ce578 20160714 Refactor temperatures step 2a : move tophtm in plain Angular
5327 6333ac578 20160714 Refactor temperatures step 1 : use ngRepeat and a directive for widgets
5318 15e3ead63 20160714 [BleBox] Add wSwitchBox to identify
5314 5b6a71f40 20160714 Merge PR 733 from szczukot/master
5318 42f39e50f 20160714 [Satel Integra] change for ATD100
5314 fa88267fe 20160714 Merge branch 'master' of https://github.com/domoticz/domoticz
5329 f30647e57 20160714 Fixed: AtagOne deviceId due to webpage change
5314 1d464d8a4 20160714 merge
5305 c5446fbf4 20160714 Merge PR 730 from llagendijk/master
5314 08aaadd49 20160713 [BleBox] fix for compile
5314 400a07fe6 20160713 [BleBox] Initial commit
5314 749f2abba 20160711 Merge PR 19 from domoticz/master
5305 39c145808 20160713 Fix Ec3kMeterTCP references in msbuild
5301 dd4f31d2f 20160714 Fixed: milight set_level for normal remotes
6080 c09e9a688 20160713 Revert "RFLink: Fix set_level and Milight unit selection"
5849 78de97a27 20161004 rewrite enocean VLD support (D2) and bring partial UTI support (D4)
5305 4455bf2ff 20160713 Added Ec3kTCP to Visual studio project
5335 047419c82 20160715 Sanity check if agremeent array can contain given m_Agreement number
5849 c875d1def 20160710 Add support of nodon inwall module - 2 channels (Enocean)
5305 af2d34fae 20160708 Added a driver for the Energy count 3000 and compatible devices using the ec3k-se
5300 ab17334db 20160714 Changed: MySensors, not ignoring switch change check for Scene On/Off types
6080 a01596a05 20160713 RFLink: Fix set_level and Milight unit selection
5335 0b580bd98 20160709 Allowing multiple Toon agreementes
5299 7807147da 20160708 Fixed: Windows users are now also able to specify the wwwroot path starting with
5298 17d22a88a 20160708 Merge PR 728 from sbouchex/pushers_enhancements
5298 192b26546 20160707 Refactored code and fixed issue on switches
5296 235042afe 20160707 Added new GooglePubSub Pusher to the Visual Studio Project Moved all pushes to th
5295 29b7fae2d 20160707 Merge PR 727 from sbouchex/pubsub2
5295 b24f1f426 20160707 initial commit
5293 159010ad6 20160706 Fix possible crash with AccuWeather if an incorrect API key was entered
5292 74747367d 20160706 Merge PR 724 from domoticz/multipleuvccams
5290 99ef9eb77 20160704 Merge PR 725 from fabiopaolini/serialSamsung
5290 97cdb05cd 20160704 Add Samsung SoC serial support
5292 8b98a2b28 20160704 Changes in camera module to allow for more usb cams at once on the Raspberry.
5288 724dee4c8 20160704 Merge branch 'master' of github.com:domoticz/domoticz
5288 33180fdd6 20160704 Merge PR 722 from dynasticorpheus/master
5288 94a4517c2 20160703 Use http digest access authenticationtion if basic authenticationtion is not avai
5288 711a11889 20160701 Merge PR 717 from fabiopaolini/serialComm5
5288 033e77bac 20160701 Merge PR 718 from ffontaine/master
5288 f2bdd4127 20160701 Describe the Comm5 MA-4200 as an USB one
5288 331cc5ec7 20160701 Fix "no newline at end of file" warnings
5288 a43d42875 20160701 Merge remote-tracking branch 'upstream/master'
5288 a002fa3c1 20160701 Fix typo in main/RFXNames.cpp
5288 127f7ddbd 20160630 Add new hardware Comm5 MA-4200/MI-1000
5288 7b6f3b853 20160628 Option to request only Favorite devices via json (&favorite=1)
5275 cab4973e9 20160704 Changed lowest allowed temperature to -200 Prepared MySensors battery update patc
5288 a6d93aa62 20160628 Fixed incorrect Type display for FAN sensors caused by some pull request..
5274 e0ad61e53 20160626 Updated OZW configuration files
5273 9e35e1875 20160626 - Added missing AccuWeather files
5272 bc848cd58 20160626 - Implemented: AccuWeather Support - Changed: Wind Direction for o.a. Netatmo
5380 2b70dfa13 20160621 Webserver cpp Energy computed
5380 9ca1396ce 20160621 Rewirte clean SQLHelper.cpp
5271 5b20c5bf0 20160624 Merge branch 'master' of github.com:domoticz/domoticz
5380 cb111da30 20160621 Create SQLHelper.cpp
5380 3b83611ad 20160621 Delete SQLHelper.cpp
5271 0c927686b 20160623 Merge PR 713 from Evsdd/master
5380 188c2517f 20160620 Revert accidental changes
5271 ff6d46884 20160622 Added Evohome 'All Sensors' Off Setpoint
5380 8542b6137 20160620 SQLhelper fixed
5380 cc5d3c76e 20160619 Energy computed instead of read
5271 93e6b846b 20160622 Updated Evohome auto-naming of zones
5265 d90789572 20160624 EventSystem: Added Sound Sensor to utilitydevice[]
5271 cf865ec61 20160622 Fixed Evohome battery info (corrected)
5380 b50b8cc22 20160619 Energy computed instead of read
5271 c39429efb 20160622 Fixed Evohome battery info
5380 c1f7e88ec 20160619 Energy computed instead of read
5264 3ae0c35fb 20160623 - Changed: TE923, Rain counter devided by 2
5263 499b1f77a 20160620 Fixed Blinds T12, now includes a Unit code when creating
5380 3294fad27 20160619 Energy computed instead of read
5262 50afe31ec 20160619 - Updated: OpenZWave configuration files
5261 6e3f70299 20160619 Merge branch 'master' of github.com:domoticz/domoticz
5261 ca7e1bf4e 20160618 Merge PR 708 from sbouchex/master
5261 7880cbacd 20160618 Merge PR 703 from InfernoEmbedded/1wire-enhancements
5255 f619d0eef 20160619 - Updated: SQLite3 v3.13.0
5261 da202d54a 20160617 Fixed label issue on Kodi
5254 0b2751033 20160617 Updated History
5253 dc8cc65fa 20160617 Dummy, when a new sensor is created, add it to EventSystem Manual Light, when cre
5261 8de679e76 20160617 Fixed label issue on Kodi
5252 670ae7a55 20160616 Merge branch 'master' of github.com:domoticz/domoticz
5252 1113d8b80 20160615 Merge PR 702 from fabiopaolini/comm5-ma-fix
5249 529beb16c 20160616 - Changed: EventSystem, weather/rain value is now the rain-rate
5248 cadcdc4d0 20160615 Corrected rounding in rainrate calculation
5247 f55880bb3 20160615 Calculating own rainrate for last hour (initial testing)
5246 4747d1517 20160615 Merge branch 'master' of github.com:domoticz/domoticz
5246 80b1e44cc 20160614 Merge PR 699 from InfernoEmbedded/1wire-enhancements
5314 1d0456aca 20160613 Merge PR 18 from domoticz/master
5243 c427a44b4 20160615 MQTT, Added 'getsceneinfo'
5242 0bbf5e2b1 20160614 Fixed: Dummy/Selector Switch placement in create virtual switch dropdown
5241 141e2b2a9 20160613 - Implemented: Denkovi Smartden with LAN Interface
5240 d9512dd22 20160612 - Changed: ETH-8020, ignoring return message as it always returns (no more Succes
5239 90d0c97a8 20160611 Merge PR 697 from sbouchex/htttpost
5237 b230b3479 20160610 Merge branch 'master' of github.com:domoticz/domoticz
5237 ad1f27994 20160610 Merge PR 696 from sbouchex/notifs_logging
5237 2c7e5cd86 20160610 Added notifications error logging
5239 0c19f12f2 20160610 Added missing keywords to HTTP 'POST' notification
5237 9925cf9c4 20160610 Merge PR 694 from sbouchex/http_notification_post
5232 101454678 20160610 Updated Openzwave configuration files
5231 d8807cd58 20160609 Merge PR 691 from bobkersten/lightinglog
5231 0f3d50c9c 20160609 raise app cache manifest
5237 a717c30ad 20160610 Added "POST" method to HTTP notification
5252 0b9213b5f 20160615 Fix message parsing
5231 0b370e9db 20160609 fix for switch logs
5228 76374d093 20160606 Fixed Lightlog graph (caused by a previous pull request) (should end on 100%)
5227 4ab2c479f 20160606 Merge PR 684 from Evsdd/master
5227 ea4175747 20160605 Update to Master
5227 b71790435 20160605 Corrected domoticz.sln to reinstate debug config
5227 c164a3595 20160605 Updated Domoticz.js.gz to current and reapplied changes
5227 97ff24cec 20160604 Update to Master
5227 ace010a1f 20160604 Added Evohome 'All Sensors' button to add devices for all individual temperature
5204 61d45d1c4 20160605 Merge PR 682 from bobkersten/graphtweaks
5227 97581d8ea 20160604 Updated Switch log chart to show %level for Evohome Relay devices
5227 af3240303 20160604 Fixed problem to ensure all Evohome Relay TPI switches are read-only
5204 c0dc68f96 20160602 removed debug event handler
5227 2daec89b2 20160604 Fixed Evohome 0 demand and DHW device bugs
5227 99cc6d063 20160604 Tidy up to remove debugging code
5204 909639db9 20160602 Merge branch 'master' into graphtweaks
5227 e764a7039 20160603 Added devices to monitor zone heat demand
5198 97a1c7772 20160605 Merge PR 681 from xbeaudouin/fix_freebsd_usb
5227 1e916908e 20160603 Added Evohome zone temperature sensor device linking
5227 d2a458f9f 20160603 Added automatic zone naming for Evohome HGI80
5204 b27aabcce 20160602 removed excessive redrawing of graphs, which fixes a lot of animation glitches im
5198 4f84dccf3 20160602 Add /dev/cuaU* USB serial devices to the allowed serial ports under FreeBSD. Some
5196 112cbb70e 20160602 RFLink: Milight remote On/Off matches interface
5195 48290eaad 20160602 RFLink: Cleanup
5204 41527fdc9 20160601 removed loading options from temperature charts (no other charts make use of this
5204 b1a1d7261 20160601 prevent hiding all series, at least one serie should visible
5194 2e6670595 20160602 RFLink: Milight finetuning
5193 4cf01066a 20160601 Merge PR 678 from bobkersten/stateprovider
5193 eb84c9ec6 20160601 Youless energy devices now use the same combined energy/power graphs as similar d
5193 b5537200d 20160531 possible fix for youless power day graph (http://www.domoticz.com/forum/viewtopic
5193 f64e81c24 20160531 consistent yAxis label colors
5193 95b3ee3c9 20160531 persistent chart series visibility state consistent- and visually distinctive app
5188 18ad1a20b 20160531 RFLink: added initial MiLight support
5187 1660d9af3 20160529 fixed compare function (thanks to deece)
5186 172d7b6c7 20160529 Updated OpenZWave
5185 92b533859 20160529 Fixed Barometer display in Floorplan
5184 13f04a438 20160528 Merge PR 676 from domoticz/Floorplan-Params
5184 c2fc7bb40 20160528 Merge remote-tracking branch 'refs/remotes/origin/master' into Floorplan-Params
5181 5127f7f6f 20160528 Merge PR 675 from bobkersten/master
5181 1cf3d2173 20160528 match power/energy y-axis max
5181 aad29b144 20160528 Merge remote-tracking branch 'upstream/master'
5177 c63bfb058 20160528 Fixed general graph for sensor that did not support AVG Added AVG for Voltage sen
5181 9a27fae97 20160528 match power/energy y-axis max and undo shift by 30 mins
5184 3f2733ef7 20160528 Added 'fullscreen' query parameter
5176 c8dc3e8b4 20160527 Merge PR 672 from bobkersten/energy-tweaks
5176 b24f4fc57 20160527 forgot to rename a label
5176 c37b2a073 20160526 rotate image using css instead of new images
5171 f19686945 20160526 Merge PR 673 from bobkersten/energy-tweaks-locale
5176 e26fd1c9d 20160526 fixed conflicts in appcache
5171 9d4146508 20160526 added locales for changes to energy devices
5169 f95afbd7e 20160525 Fixed adding serial hardware caused by #657
5314 bf8d9c9b3 20160524 Merge PR 17 from domoticz/master
5168 37cd4584c 20160525 Corrected 1Wire setup (thanks to szczukot for spotting!)
5167 488531a2e 20160524 Fixed 1-wire issue reported by szczukot
5166 338cfdc0c 20160524 Merge PR 669 from InfernoEmbedded/1wire-disable-thread
5166 7b4b616f3 20160523 No need to initialize the threads to NULL - the comparison will evaluate to NULL
5166 a6dcad492 20160523 Allow 1wire polling threads to be disabled by setting their polling period to 0.
5176 198c20be5 20160525 energy device optimizations and correct labelling
5163 96842c3e9 20160522 Custom Sensor Month/Year graph now displays AVR
5162 b1c5776cb 20160522 - Implemented: MySensors, Implemented Acknowledge Timeout per Child sensor
5161 e4dc4f312 20160522 Merge PR 657 from InfernoEmbedded/1wire-enhancements
5261 4f9c3313c 20160616 Try OWFS again with no path, if the kernel driver is not available.
5246 3c3475ed5 20160614 Prefer OWFS over W1 Push the logging of which module is used down into the hardwa
5161 1579fc3ca 20160518 Fix indentation
5161 2cf5fe186 20160518 Remove stray global settings
5161 e7f36ce72 20160518 Remove stray global settings
5161 657a899b2 20160518 Fix bad merge
5161 149d13d2b 20160517 Make the OWFS mountpoint configurable Move 1wire configuration (poll period, OWFS
5161 d56a66ba3 20160517 No need to reinvent the switch block
5161 f6692e5db 20160517 Fix switch state detection for 1Wire devices
5148 e5acaddf0 20160522 Merge PR 668 from sijones/panasonic-fixes
5161 6850074de 20160517 Remove stray eclipse project files
5148 586524caa 20160521 AV Button fix
5161 0f0eea593 20160517 Factor out bus scanning and simultaneous temperature reads Limit bus scanning fre
5146 c74404ea1 20160520 RFLink: Added MiLight
5161 738906c45 20160517 Javascript variables can't start with numbers, so rename 1wire* to OneWire*
5145 a8dc718f6 20160520 Merge PR 667 from CurrentThread/master
5161 8beee4923 20160517 Correct simultaneous temperature read log message Remove superfluous simultaneous
5161 d396eb417 20160517 Split off a high frequency thread for polling 1 wire switches
5145 18163dfbe 20160516 Typo 'Problem saving Htto link!'
5143 8a58b87e5 20160516 Merge PR 662 from bobkersten/master
5143 57fb59551 20160516 Resolved merge conflict
5140 9f649e89b 20160516 - Implemented: S0 Meter TCP
5143 3ccebf7d0 20160516 Moved P1 baudrate setting to main hardware screen as opposed to a separate screen
5139 862c282aa 20160516 Merge PR 660 from larber/master
5139 6a91ba126 20160515 style changes + document meter api
5139 c87c6d2e5 20160515 style changes + document meter api
5139 07ba1083c 20160515 style changes + document meter api
5135 6807e74e1 20160515 Patch to correct line endings
5134 5d9c8fefa 20160515 Fixed: win32 compile issue for RAVEn
5133 abcaf9c4b 20160515 Merge PR 658 from larber/master
5133 f8e2e1e12 20160514 remove debug logging
5133 2aeafdec0 20160514 add buffer, read total consumption
5227 47173edd2 20160601 Added Evohome 'All Sensors' button to add devices for all individual temperature
5133 149d61c86 20160514 add usb to name so it shows port in dropdown on webpage
5133 6e0320282 20160514 raven impl
5227 3950693ca 20160530 Updated Switch log chart to show %level for Evohome Relay devices
5133 7352db2d1 20160514 undo attributes
5227 6cb1dba7d 20160528 Fixed problem to ensure all Evohome Relay TPI switches are read-only
5124 30f5523d0 20160515 Updated git attributes file
5133 fb98dbaa7 20160514 add raven to build
5227 5ebc7a56f 20160526 Fixed Evohome 0 demand and DHW device bugs
5123 5c7655ecf 20160515 Line ending patches OZW, Control Panel, Group option implemented
5133 f4404473c 20160514 whitespace
5227 77b3de7da 20160522 Tidy up to remove debugging code
5122 455d1e9bc 20160514 Merge PR 656 from zaphodus/patch-1
5133 762eb238f 20160514 initial raven checkin
5227 3829bd1a7 20160521 Added devices to monitor zone heat demand
5122 2d4e690c8 20160514 mysensors gateway heartbeat
5120 7b44eac99 20160514 Merge PR 654 from divendres/patch-2
5227 2152f80f6 20160515 Merge branch 'master' of https://github.com/Evsdd/domoticz.git
5227 c0c7f6b5d 20160511 Added automatic zone naming for Evohome HGI80
5118 1025af9a6 20160513 RFLink: New devices and modified current use
5227 cbe3426af 20160511 Merge PR 1 from domoticz/master
5117 685e86ae1 20160512 Added Git Attributes file (for correcting line endings) Updated Git Ignore file
5116 14282f0f9 20160511 Added Fitbit to CMake list (not usable at the moment!)
5115 f98dfca48 20160511 Changed: Nefit Easy Gas poll interval
5120 47e0269d0 20160508 OpenZWave is now on github
5114 95ad39041 20160505 Added General/Baro sensor to Eventsystem
5113 b9a0ff855 20160505 Testing Nefit Gas Usage
5112 0968b2cc7 20160505 - Changed: Wind Direction graph (now does not display directions when speed was e
5111 11092d6ec 20160505 - Fixed: KMTronic, did not work in timers/groups/scenes
5110 63772266f 20160503 - Changed: OpenZWave, Better support for Thermostat Modes
5109 9925f3629 20160503 - Implemented: OpenZWave, When including Thermostat Setpoints, the zwave Label wi
5108 f6e0771e9 20160502 RFXCom, corrected version number display in web interface (firmware >1000)
5107 ae182e781 20160502 Merge PR 636 from bobkersten/master
5107 d6534fea0 20160502 added reload button to piface hardware
5107 5c91e9ab2 20160502 Ability to force a counter update when interval changes are larger than a certain
5104 ff19aee38 20160502 - Implemented: RFLink: Displaying firmware version in the hardware setup
5103 92d400978 20160502 Temporary adding OZW FGK101 701/1001 to the manufacturer_specific.xml file
5102 fd92985c9 20160502 Dummy Temp Sensor now handles notifications
5101 d2d944f55 20160502 Merge PR 626 from sbouchex/http_hardware
5097 4b9d52d0c 20160501 Updated OZW
5096 9887eac78 20160501 Updated OZW Implemented /ozwcp/statpost.html
5095 2cd9ef33f 20160501 Dummy Voltage Sensor now handles notifications
5094 3c405ea9c 20160501 Merge PR 633 from defl/master
5092 20bc45977 20160501 Merge PR 631 from lnzmst/master
5088 d70b16d6c 20160501 Merge PR 627 from Evsdd/master
5085 c27352ca4 20160501 Merge PR 621 from EddyK69/fix
5083 94cd022f7 20160501 Merge PR 620 from bibulle/master
5081 d4627c821 20160501 Merge PR 617 from EddyK69/lua_expose
5092 e2257fa00 20160428 Minor edits. Replaced "not" operator with "!" to fix AppVeyor build failed.
5092 f1a14dfc5 20160428 Minor edits. Replaced "not" operator with "!" to fix AppVeyor build failed.
5078 4062d9645 20160501 Merge PR 615 from niziak/master
5101 2c620ea15 20160501 Renamed HTTP/HTTP client to HTTP/HTTPS poller, renamed class as well
5227 12f944b40 20160515 Added Evohome zone temperature sensor device linking
5092 f02dd4e05 20160427 MQTT client support for Battery and RSSI data.
5088 b7a1cf376 20160425 Fixed evohome bug which prevented overrides appearing on HGI80 devices
5101 518b2e9c2 20160423 Removed the "createVirtualDevice" lua function
5094 46ead91f6 20160501 Fixed a typo in the CMakeLists message() function call for Mosquitto external
5088 dfb784318 20160423 Added muti-room zone support to Evohome.cpp
5083 cf184faf1 20160420 PTEC with no tempo option shoud be set
5076 7dba7d89f 20160425 RFLink: Set_Level fix
5101 25cdf115e 20160422 HTTP/HTTPS client with the use of a lua parser
5075 5b6a3ef9f 20160419 RFLink: Added Device creation via hardware page
5074 b1b4e60c5 20160415 Merge PR 616 from bobkersten/master
5074 be8f06481 20160415 (PiFace) Use helper method for sending kwh values and improved code readability.
5078 21bfd92f1 20160415 webserver: Log error message if file not found
5072 f44afec51 20160414 Merge PR 612 from niziak/master
5072 0832e650f 20160414 make install: use default permissions for /www and /Config
5070 86f58c92c 20160413 Merge PR 611 from houk001/master
5070 22ffdaef0 20160413 Update Sterbox.cpp
5068 e9ed101a3 20160413 Fixing some compile error warnings on the PiFace class
5067 6eb7ab03c 20160413 Added some basic Tellstick sensor support (submitted by Per)
5066 6e0d2be7f 20160413 Fixed PiFace compile warnings
5065 7463f7a39 20160412 OpenZWave, added Node ID in hexadecimal in the Groups/Network Overview
5064 3ecfc85b7 20160412 PiFace, Fixed compile error on some systems (and some typo's)
5063 de6aaa61e 20160412 Merge PR 607 from bobkersten/master
5060 492928dd3 20160412 Updated Openzwave configuration files Addes Sterbox to Visual Studio Project
5059 a974cb44e 20160412 Merge PR 606 from houk001/master
5059 cb09fac67 20160411 Added files via upload
5059 685e79b61 20160411 Added files via upload
5059 d9f65b531 20160411 Added files via upload
5059 d74a24fcc 20160411 Update HardwareController.js
5059 a9ba96961 20160411 Update CMakeLists.txt
5081 b03167ade 20160412 Fix for LUA-values of counter-devices & added LUA-table...
5059 9a4ae0587 20160411 Added files via upload
5085 7fabe8a77 20160420 Added DeviceName to Scheduled item start
5081 c523b70f5 20160411 Merge PR 164 from domoticz/master
5059 c2e902826 20160411 Added files via upload
5051 b3a58a937 20160410 Updated OpenZWave config files
5050 4c2f134e0 20160408 Linking boost statically again (was removed), can still be disabled with a CMake
5049 31f530290 20160407 Merge PR 600 from EddyK69/fix
5049 8b3e4e9fc 20160407 Added EnableSetpointTimer & DisableSetpointTimer
5049 4120ad564 20160407 Added EnableSetpointTimer & DisableSetpointTimer
5049 7bc66dddc 20160407 Added EnableSetpointTimer & DisableSetpointTimer
5049 865cf308b 20160407 Merge PR 163 from EddyK69/master
5049 75600c218 20160407 Merge PR 162 from domoticz/master
5063 ab88ffadd 20160412 Added .AppleDouble to gitignore
5042 8b495ed36 20160407 Merge PR 591 from priority/labels
5063 895873737 20160412 Added ability to configure in- and output counters as energy devices. In the futu
5040 d4e41bd2e 20160406 RFLink: Changed current handling
5039 79245c39a 20160405 RFLink: Fix AOK fix
5038 3174455c7 20160406 Merge PR 592 from domoticz/dnpwwo
5036 ce629f2c4 20160405 RFLink: Fix AOK
5035 9fdc95d18 20160404 Lua now also logging as 'Status' message, same as blockly
5042 fc3c0dd36 20160402 Adds labels to scenes page
5034 8962906eb 20160403 RFLink: UV Fix
5038 4a229a27d 20160403 Add custom icon support for Dimmers
5033 225d9c2dc 20160331 Merge PR 589 from arjanwaard/master
5031 8558e54e6 20160330 Need more coffee, also changed the second occurence now
5030 abda30c58 20160330 Fixed startup problem (realpath) Fixed type in getgit script
5029 854b29674 20160329 Removed (
5028 97675ee0e 20160329 Added upgrade support for aarch64 architecture
5027 ba141c9aa 20160329 Fixed double openssl preprocessor in CMake file MySensors, Added gas flow as mete
5026 97a17b1c3 20160329 Fix compiler warning for gas
5025 d4edb330d 20160329 Fixed compile warning for previous change
5024 f3ec9dfa6 20160329 Fixed type casting on general sensor structures (Specially the usage of 'long', a
5023 82dff5085 20160329 Revert "Sorry Huge patch ! (lot of work)"
5022 6da03f85f 20160329 Sorry Huge patch ! (lot of work) More 64bit ready, correct type casts used now...
5049 468dad023 20160329 Merge PR 161 from domoticz/master
5021 94629d999 20160328 Some more php fastcgi work
5020 e7944d376 20160328 Fixed creating dummy hardware sensor caused by previous fix for custom sensor leg
5019 194da7883 20160328 Quick fix to solve summer time problems (till next year?) OZW, implemented contro
5018 d700557dc 20160328 Merge branch 'master' of https://github.com/domoticz/domoticz.git
5018 fb0625d28 20160328 Added command to switch between Default and Holiday timer groups
5016 bf7a641bf 20160328 Corrected Switch level for simple on/off switches used in for example Nefit/KMTro
5015 8ebaa68ee 20160327 Except in the precompiled header ....
5014 4885e163c 20160327 added #pragma once to all headers
5013 af31dd81a 20160327 Added fastcgi to cmakelist
5012 f9e90e9af 20160327 Fix for #583, The field "Axis label" is missing in the pop in "create Virtual Sen
5011 a3a7b1c84 20160327 Initial PHP support (needs to be converted to FastCGI later)
5010 ba3c52323 20160324 Changing back AreaSpline to Spline for energy day charts
5009 1b41d663f 20160324 Merge PR 580 from gordonb3/evohome
5009 374765d66 20160324 Evohome: correct handling of decimal device ID's with scripted evohome
5007 f85908223 20160324 Merge PR 579 from EddyK69/lms
5002 b38d56a8e 20160324 Merge PR 575 from ridingtheflow/dual_energy_graph
5007 4a2a89181 20160323 Update LogitechMediaServer.cpp
5007 9fed0de30 20160323 Update LogitechMediaServer.h
5007 6f85dbe89 20160323 Set HeartBeat on response from LMS server
4998 89e797b2f 20160324 Fixed some compile warning under 64bit
5007 506ac9864 20160323 Merge PR 160 from domoticz/master
4997 80b2c38b2 20160323 Merge PR 578 from EddyK69/fix
4997 bf11fdad6 20160323 Update html5.appcache
4997 3c1a87563 20160323 Update ScenesController.js
4997 f3ed6e4ba 20160323 Update UtilityController.js
4997 fa659634a 20160323 Update LightsController.js
5002 2b9946dd6 20160323 Re-enable crosshairs
4997 42579a848 20160323 Merge PR 159 from EddyK69/master
5002 3234da28c 20160323 Code review feedback: make hourly usage graph more readable
4990 f77eba4c8 20160323 RFLink: Added Halemeier switch support
4997 96fd8261e 20160323 Merge PR 158 from domoticz/master
5002 57b7cb327 20160322 Improve Power graph for instant+counter meter to show both hourly kWh usage and i
5314 2ae2ebe37 20160321 Merge PR 16 from domoticz/master
4989 7052604c7 20160320 Merge PR 574 from blmpl/master
4989 ee85a0bb8 20160320 indent fix
4989 9a550eed1 20160320 Merge branch 'master' of https://github.com/domoticz/domoticz
4985 2f8235e73 20160320 Fixed: Water Meter widget total value if using another counter devider then 1000
4984 e110a309c 20160319 Fixed compile warning
4983 b61e0f770 20160319 Correction of previous patch (status message will be displayed now)
4982 8954b979c 20160319 Netatmo, changed checking for weather station devices, or recover from server err
4981 32e3f3211 20160319 Fixed Security Panel battery level
4980 cb3ea89c0 20160319 Added support for MySensors S_Vibration sensor
4979 2bfac603f 20160319 Setup, Added option to configure degree days base temperature
4978 b5fe63d28 20160317 OZW, Ignoring battery level values of 0 Element theme, removed status text
4977 fc5fe6b6b 20160316 Merge PR 567 from gaudryc/fix_some_selector_switch_misses
4977 333061af1 20160316 Fix missing code
4977 78a332bf1 20160316 Update html5.appcache
4977 93a0c7703 20160316 Merge remote-tracking branch 'origin/master' into fix_some_selector_switch_misses
4971 2b21484b4 20160316 Merge PR 566 from domoticz/modifyfix
4971 dfb9f327a 20160316 Small change at which the Last-Modified http header date was wrong after content
4977 7690cacaf 20160316 Fix Selector switch management in Scene/Group
4969 1261d7979 20160316 Merge PR 565 from Melkoroth/master
4969 dc220f667 20160316 Add ByronSX door button to RFLink
4977 9fbb7c0da 20160315 Fix missing icon for selector switch in Devices tab
4967 1156a22c7 20160315 Merge PR 562 from gaudryc/speedup_sql_queries
4965 f97cb7ce2 20160315 Restored some lost code for new 'Custom Sensor'
4967 c37b36407 20160314 Speedup SQL queries on the DeviceStatus table and "Log" table and move old indexe
4964 976cb17a2 20160314 Merge PR 561 from gaudryc/fix_wrong_starting_value_for_kWh
4964 ae744fea6 20160314 Merge remote-tracking branch 'origin/master' into fix_wrong_starting_value_for_kW
4964 86df1e7f0 20160313 Merge remote-tracking branch 'origin/master' into fix_wrong_starting_value_for_kW
4959 912b8a583 20160314 Updated OZW, better switching between blockly/script editor
4958 668b69c5e 20160313 Addjusted appveyor.yml file (cp command now used with powershell)
4957 c44b19030 20160313 Fixed AtagOne return function
4956 3c7c800d3 20160313 Merging Blockly Changed
4955 3d1fda4bb 20160313 Added Atag One to CMakeList
4954 f81187e25 20160313 Upgraded blockly/code to latest version Implemented Atag One thermostat
4964 b09b60624 20160313 Fix a wrong starting value issue for ZWave kWh devices (for multilevel sensors al
4953 397dc7ac7 20160313 Merge PR 560 from jaylik/harmonyhub-fixes
4953 b9e944966 20160312 Fixed harmony hub url to use http -> implementation should be fixed to use ssl la
4964 66c20a941 20160312 Fix a wrong starting value issue for ZWave kWh devices
4951 d06bdf97f 20160311 Fixed: YouLess meter day display for Water/Gas Implemented: Icons for YouLess met
4989 344e66880 20160311 Check WiringPi libraries without Raspberry check [e.g. when run on orange pi, ban
4950 387254e0a 20160311 minor: Writing Nefit Easy debug info for pressure
4949 726f13311 20160311 Add Manual Blinds T12
4948 56d2e94b0 20160311 Latest RFXCom SDK MySensors, S_DUST and S_LIGHT_LEVEL now uses float value
4947 a6de9781c 20160311 Merge PR 557 from gordonb3/master
4945 548ec4dff 20160311 Error handling when attachment file can not be found
4947 175b24e0c 20160311 Evohome: adjust UTC times to localtime
4944 92e8ef0cf 20160311 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4941 c16e209e5 20160311 I2C patched #556
4944 a5a7d789a 20160311 Merge PR 554 from gordonb3/master
4940 52604510d 20160311 hardware: i2c: Fix weird declaration of read_reg array in ReadInt, WriteInt
4939 35047603b 20160311 Custom sensor now supports up to 4 digits Philips Hue, don't import scenes that d
4938 6cfa5b2c3 20160310 Added new Custom sensor to general decoding
4937 8d2ad2375 20160310 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4944 b811638b5 20160310 Fix invalid TimeUntil value in evohome SetSetPoint
4937 34fc74e5d 20160310 Merge PR 553 from gordonb3/master
4937 a697a8055 20160310 Fix ugly separator at start of Evohome zone status message
4934 925057d9b 20160310 Implemented Custom Sensor (alpha!!)
4933 e404b110f 20160309 RFLink: fixed wind speed
4932 7c719fd6f 20160309 Fixed: Handling first JSON parameter first
4931 8ede143a2 20160309 Corrected pevious patch
4930 c54fc93bf 20160309 Fixed: JSON Command parameter can now also be used as first parameter in url
4929 43ad5cc3a 20160309 Merge PR 551 from gaudryc/remove_graceful_stop_from_webserver
4929 790e3c51d 20160309 Remove unused attribute
4926 b9e399c53 20160309 Fixed crashing of serial class when cable got disconnected (introduced in #469)
4929 263ca352e 20160309 Remove all about webserver graceful stop
4925 a0843b37b 20160309 Merge PR 550 from gaudryc/fix_webserver_graceful_stop
4925 c8da7e168 20160308 cleanup
4925 1c7c6b248 20160308 Fix the exception thrown while stopping using graceful option.
4925 c48c06c4b 20160308 Secure the waiting loop of server shutdown.
4921 97c5a825d 20160308 Added log messages to the automatic database backup routines (this routine should
4920 427b757c1 20160308 Fixed: Sending email to port 465 (SSL) should now work
4919 ab5a11f08 20160308 Merge PR 548 from irimitenkan/master
4917 6c3d68448 20160308 Merge PR 547 from hansrune/syslog_facilities
4913 2e77df965 20160307 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4917 3e0d69d88 20160307 Log facility name set to "user" in case no -syslog on command line
4917 5191d21db 20160307 Merge remote-tracking branch 'upstream/master' into syslog_facilities
4913 4b7836c81 20160307 Merge PR 546 from EddyK69/fix
4919 ca371a9c6 20160307 ensure correct git repository path
4913 0e5eb0403 20160307 Merge PR 544 from arjanwaard/master
5033 22466e1f8 20160331 Always send RxMessage on first time adding bridge
4913 9aee25b3b 20160307 Replaced and with &&
4913 6b0a4ae31 20160307 Set lastupdate in db so web page is refreshed.
4913 da4248a3d 20160307 Set minimum level to 1 if lght is switched on.
4913 97a9791ed 20160307 Send on/off on swich, set correct brightness in db.
4913 fe78e3d6a 20160306 Set correct command for update in database
4913 e46bff2ee 20160306 Set correct command in database
4901 64c3e23bd 20160307 Fixed Notification for Sound Level
4900 ee54e302e 20160307 JSON udevice, native support for General/Sound, Added notification for Air Qualit
4913 1fbc7bb21 20160306 send correct level for RGBW lights
4899 a35958caf 20160306 Getting rid of extreem large buffer size...
4913 6d7d0ca46 20160306 Send level command if light is on and not full brightness
4898 7bcace834 20160306 - Changed: Stable ID generation for Philips Hue scenes (you need to delete all sc
4897 2a895ee9c 20160306 Fixed Notifications for some general sensors (like sound level)
4896 e65784214 20160306 Slightly better handling on scenes (Hue), still not 100% ok when adding/removing
4895 d06b132f7 20160306 Merge PR 534 from gaudryc/webserver_enhancement
4895 3765815ae 20160306 Merge remote-tracking branch 'origin/master' into webserver_enhancement
4895 1c82f0bf0 20160306 Handle abandoned connection to avoid memory leaks (appends if SSL handshake fails
4895 d1e5790eb 20160306 Add missing status ENDING_HANDSHAKE
4895 b72e3b064 20160306 Move the connection::status from std::string to private enum
4895 64b4d714c 20160306 Optimize the reply::add_header_if_absent method
4895 6971bab7d 20160306 Always do a graceful stop
4895 96b9ed2ae 20160306 Remove the server_base::is_stopping attribute which becomes unnecessary since the
4895 d223a332f 20160306 Remove the confusion with the connection::is_stopping method
4895 a679df597 20160305 Merge remote-tracking branch 'origin/master' into webserver_enhancement
4895 1636ac0bf 20160305 Merge remote-tracking branch 'origin/master' into webserver_enhancement
4895 54a2bc321 20160305 Merge remote-tracking branch 'origin/master' into webserver_enhancement
4895 5df8d0a7e 20160305 Merge remote-tracking branch 'origin/master' into webserver_enhancement
4871 24b0e0465 20160306 Fixed Philips Hue Scene activation (caused by Selector Switch Implementation)
4870 077b72697 20160306 Fixed on-delay caused by #540
4869 3130869f1 20160306 OZW, Aeotec Controller detection now with int32_t instead of string
4895 ebf05c47f 20160304 Merge remote-tracking branch 'origin/master' into webserver_enhancement
4868 61da2d3d6 20160306 - Implemented: Nefit Easy, Flow Temperature
4867 f664af3a6 20160305 Fixed updatebeta script for old rpi users
4866 8219aa06d 20160305 Changed mime type for fonts
4895 1cd8d185d 20160304 Merge remote-tracking branch 'origin/master' into webserver_enhancement
4865 0bfd8948b 20160305 - Implemented: Blockly/Lua Camera device, to send camera snapshots with subject a
4864 c7991d498 20160305 NefitEasy, added Worker started message
4863 c516b28dc 20160305 Support for more Aeotec ZWvave Gen5 sticks (blinking settings)
4862 50a100a77 20160305 - Implemented: OpenZWave, Node table, now also displays Manufacturer, Product ID
4861 87284e61d 20160305 download scripts should now work again with old raspberies (armv6l)
4860 33e4249c0 20160305 Nefit Easy, User Mode switch can now also be used to change between clock and man
4859 bdcfecf16 20160305 - Implemented: OpenZWave, Aeotec ZWave+ USB Controller, Enable/Disable blinking m
4858 e1f196703 20160305 - Implemented: Nefit Easy, Clock mode (as switch, On=Clock, Off=Manual)
4857 888a972d3 20160304 Adjusting download script(url between quotes)
4856 cbe5ac72f 20160304 Updated download script
4895 4d9dacba8 20160304 Merge remote-tracking branch 'origin/master' into webserver_enhancement
4855 d74821742 20160304 Merge PR 541 from gaudryc/update_sqlite_3_11_1
4895 5739a531c 20160303 Merge remote-tracking branch 'origin/master' into webserver_enhancement
4853 7d2456dd2 20160304 Merge PR 540 from gaudryc/fix_off_delay_management
4853 d36375dab 20160304 Update History
4853 49b91cf5a 20160304 Merge remote-tracking branch 'origin/master' into fix_off_delay_management
4853 380afc9eb 20160304 Add Selector switch OffDelay management
5288 cb740a630 20160701 Fix compilation error on mqtt
4855 5cce8386c 20160304 Update SQLite to 3.11.1
4853 2d41243cf 20160304 Revert to legacy method to handle OnDelay
4853 9678e058a 20160304 - Handle OnDelay and OffDelay the same way for all devices ; - Fix Selector switc
4917 180c7c285 20160307 First implementation of syslog facilities command line optional argument
4847 0b4dbb19e 20160304 RFLink: Added more devices
4846 1fb38bbe6 20160303 Moved history message to the correct history section
4845 f1b51d538 20160303 Merge PR 537 from gaudryc/fix_onoff_delays_not_saved_on_selector_edit_
4845 c6cbeabc0 20160303 Merge remote-tracking branch 'origin/master' into fix_onoff_delays_not_saved_on_s
4895 144aa6d1d 20160303 Make the use of the attribute server_base::is_stopping more consistent.
4842 9893938df 20160303 Merge PR 536 from EddyK69/history
4895 336f3466c 20160303 Revert to the previous implementation of server_base::stop to make the handle_sto
4895 65975648d 20160303 Fix the restart of the web server if the acceptor is still up despite of the exce
4895 0af929561 20160303 Add -wwwgracefulstop argument to stop the webserver gracefully.
4913 bf93c90bd 20160307 Update updaterelease
4895 62594d55b 20160303 Merge remote-tracking branch 'origin/master' into webserver_enhancement
4842 08d341a5b 20160303 CounterType 'Time' was reverted ;)
4838 6040e9ea5 20160303 Merge PR 535 from gaudryc/fix_selector_display
4842 5907ff26c 20160303 Merge PR 156 from domoticz/master
4838 2b1eeacfd 20160303 Fix a multiple buttons selected issue after refreshing a selector device status.
4845 00ff2897b 20160303 Fix on/off delays not saved on the selector switch edit form (#532)
4895 3f4ed9f09 20160303 - Centralize the Keep-Alive header management ; - Stop lying to client by sending
4836 214e0605f 20160303 Updated History file
4835 8e0dca170 20160303 - Database backup is now only possible for admin users - Better handling of white
4895 4271483ae 20160302 Fix graceful stop for "waiting-handshake" and "initializing" connections (can be
4834 83981251a 20160302 Release 3.4834
4833 2bd98a131 20160302 Fixed compile error when SSL was not used
4832 c12b320db 20160301 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4832 5a0725973 20160229 RFLink: Support for new devices added
4829 b11262505 20160301 Possible fix for Aeotec Smart Switch 6 AU with type 0x0103 and 0x0203
4832 39120e96f 20160229 Fixed typo (cdret)
4828 351aa84b7 20160229 Cleaned up code
4827 4a5b582b8 20160229 Merge PR 502 from jvandenbroek/master
4827 20ebfc7c4 20160228 Removed unused files
4827 83c86aba6 20160228 Merge remote-tracking branch 'upstream/master'
4820 064fd3c01 20160228 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4820 9bd58310e 20160228 Merge PR 526 from szczukot/master
4820 7f2bd2e0b 20160228 [1WireByOWFS] Try fix #430
4820 a6e85bb8a 20160228 Merge PR 15 from domoticz/master
4815 bd2584409 20160228 - Fixed Login form display caused by invalid cookie patch - Updatebeta/release sc
4814 9d4cf2910 20160228 Cleaned up VS sollution (moved openwebhard under Devices)
4813 6e6e076e9 20160228 Updated Openzwave
4812 7ec5c4d3e 20160228 Even easier sollution for Custom Template navigation url
4820 484b3fa68 20160228 Merge PR 14 from domoticz/master
4811 4bbd827a9 20160228 - Fixed control-c bug #518, #523 - Added www debug logging via preprocessor DEBUG
4810 73673a893 20160228 Merge PR 520 from gaudryc/make_a_clean_webserver_stop
4810 0de0bf7dc 20160227 Make debug logs active with _DEBUG.
4810 eae5b1980 20160227 Do not report idle timeout
4810 eb4af0da6 20160227 disable debug logs
4810 10f5bfc39 20160227 Merge remote-tracking branch 'origin/master' into make_a_clean_webserver_stop
4827 c4eae3e15 20160228 Merged HTU21D code in BMP085 class
4799 37350e29d 20160227 Changed: Preparation for RFXCom firmware ext2
4798 60cb5a117 20160227 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4810 a78eb2d1c 20160227 Check resources state before stopping them
4798 186bc591f 20160227 Merge PR 524 from szczukot/master
4810 fc46fa86c 20160227 Stop waiting connection now without waiting for read timeout
4798 d5ad665b3 20160226 Merge PR 522 from szczukot/master
4810 52a0e50f9 20160227 Remove StopServer and delete cWebem because StartServer is and must be called onl
4798 a2f5dd576 20160227 [Satel Integra] Fix for situation, when Data Timeout is set
4810 93aa1ef28 20160227 Avoid stopping cWebem twice
4798 fc7a109f9 20160226 [Satel Integra] Properly destroy hardware
4792 e7ff5266f 20160227 Fixed crashing when exiting application (fixed #518, #523)
4810 6f1b6c479 20160227 Allow to stop both HTTP/HTTPS or just one of the two
4810 71c9823a3 20160226 - Make the cWebem instance to wait for all connections to stop gracefully ; - Ign
4798 626b57768 20160226 Merge PR 13 from domoticz/master
4791 3c01f5bd4 20160226 Fixed issue 515
4790 25a3fb2de 20160226 Merge PR 519 from arjanwaard/master
4787 33cc618f2 20160226 - Implemented: RFXCom support for Lighting5 IT (Intertek,FA500,PROmax,...) - Clea
4786 d7841bbfc 20160226 Merge PR 518 from gaudryc/fix_exception_thrown_on_domoticz_termination
4786 e7a95c9e9 20160226 Fix abandoned connections not removed because the method connection_manager::chec
4786 c5d999355 20160226 Update log message (depending on the number of servers started)
4786 3d51f7a8d 20160226 Add typedef session_store* session_store_impl_ptr (easiest to change if necessary
4786 a87b22ecf 20160226 Fix a "pure virtual method called" exception on server termination
4786 e17ea7a61 20160226 Use std::string::compare method (instead of the operator !=) to validate a server
4786 6eaeede71 20160226 Declare the ssl_server_settings structure only if WWW_ENABLE_SSL is defined
4786 e579e4a2e 20160226 Use smart pointer to create a server or ssl server
4786 eaed27a7b 20160225 Merge remote-tracking branch 'origin/master' into fix_exception_thrown_on_domotic
4786 cda260dfc 20160225 Replace virtual method with function references
4786 b788d458c 20160225 Fix memory hazardous behaviour due to premeturate deletion.
4786 5e9524b1a 20160225 Fix server deletion from memory to avoid double free.
4786 e4d113586 20160225 Fix session management start/stop
4786 ac95eb52e 20160225 Refactor the logs to distinguish the two servers (HTTP and SSL).
4790 e63bb4577 20160225 Merge branch 'master' of https://github.com/domoticz/domoticz
4786 806c712a2 20160225 Update History.txt
4786 55e0efaee 20160225 Merge remote-tracking branch 'origin/master' into fix_exception_thrown_on_domotic
4768 bfaf34b30 20160225 fixed compile warning on build system for tlsv1_1/1_2
4767 405b6a003 20160225 Fixed crash on control-c with new webserver code
4766 2e889ff3d 20160224 Merge PR 515 from arjanwaard/master
4763 8f09843a9 20160224 Merge PR 505 from steplebr/master
4786 d6bd6c5a9 20160225 Keep track of the thread used to start the io_service and free resources on CWebe
4786 71cb73bae 20160225 Fix CWebServer and CProxyManager destructors to be called while the application i
4753 d875cbf9a 20160224 Merge PR 517 from gaudryc/fix_webserver_initialization_failure
4753 60ad56e10 20160224 Fix compilation issue
4753 67a901e93 20160224 Fix exception "pure virtual method called, terminate called without an active exc
4790 4072ce7a7 20160224 Remote Hue change now triggers events
4753 2e77cb4c7 20160224 Update History.txt
4753 d5e1d0000 20160224 Fix the webserver initialization failure
4766 6eb169073 20160224 Fix slider percentages and level value in Domoticz
4766 f3df4d7d2 20160224 Fix slider percentages and level value in Domoticz
4753 a8e76ff71 20160224 Always display the listening address
4747 4c9d83aca 20160224 Merge PR 514 from gaudryc/refactor_webserver_server_class_v2
4747 0bbae8c63 20160223 Close socket on write error
4747 6e3b1aa0c 20160223 - Fixed: Fix the closure of the Web server sockets by making a graceful shutdown
4747 089304186 20160223 Update History
4747 d19607d8a 20160223 Set the secure listening address like listening address defined with the -wwwbind
4747 267997cfb 20160223 Fix issue when no certificate file path is set in the command line
4747 e7d6b59f0 20160223 Fix compilation issue in environment with boost <= 1.57
4747 de4f506d9 20160223 Original domoticz_fork_refactor_webserver_server_class
4739 bb15c0b3a 20160223 Reverting to the state of the project at WebServer changes b1ede80
4738 8bc90d1d0 20160222 Fixed compile error in server_settings.hpp
4737 13d40b469 20160222 Merge PR 511 from gaudryc/update_to_sqlite_3_11_0
4735 b0c4dbb6e 20160222 Merge branch 'gaudryc-refactor_webserver_server_class'
4735 bac78dd63 20160222 Merge branch 'refactor_webserver_server_class' of https://github.com/gaudryc/domo
4735 e2e9e337b 20160222 Fix missing memory cleanup
4735 60cb2e64f 20160222 wording...
4735 88f0020e3 20160222 Fix missing trace on std::invalid_argument exception from the server_settings cla
4735 57ef470ed 20160222 Format error messsage
4735 a22ca2a93 20160222 Add -ssloptions argument to domoticz executable
4735 e48077cc6 20160222 Add -ssloptions argument to domoticz executable
4735 62e9b9789 20160222 Manage enabled/disabled server in one place (server_settings)
4735 abb81d379 20160222 Define webserver default settings in one place (mainworker)
4735 0266cdafa 20160222 Merge remote-tracking branch 'origin/master' into refactor_webserver_server_class
4710 b1ede806d 20160222 Merge PR 509 from gaudryc/fix_webserver_socket_graceful_shutdown
4710 c5049d9a8 20160222 Close socket on write error
4710 8a90e2990 20160222 Fix the closure of the Web server sockets by making a graceful shutdown before cl
4737 363ef8e90 20160222 Update to SQLite3 v3.11.0
4707 f092c1e78 20160222 Merge PR 508 from gaudryc/fix_issue_507
4735 4f0aea798 20160221 Update history file
4735 d9fdb5dfb 20160221 Add -sslmethod and -ssldhparam argument to domoticz executable
4735 f4b927b14 20160221 Fix merge
4704 a6446ca02 20160222 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4735 f8a9d8a7a 20160221 Fix merge issue
4704 2367c7ed1 20160222 Merge PR 504 from szczukot/master
4735 1a9129eb6 20160221 Merge branch 'refactor_webserver_server_class' of https://github.com/gaudryc/domo
4698 d488b98a7 20160222 Reverted back Lua to version 5.2 (What a pity!)
4735 3cbd21cf5 20160221 Merge remote-tracking branch 'origin/master' into refactor_webserver_server_class
4697 dbe2d231c 20160222 Merge PR 503 from domoticz/pifix
4704 6cf14d59a 20160221 [SatelIntegra] small cleaning
4704 fb240a479 20160221 Merge PR 12 from domoticz/master
4707 2b6855da4 20160222 Fix std::string::compare method issue (507).
4707 b4b0cf387 20160222 Fix std::string::compare method issue (507).
4692 f42a1dfb8 20160221 Merge PR 501 from xbeaudouin/freebsd_sensors
4827 e23b805ef 20160221 Merged changes with master
4763 3bc79e0fa 20160224 fix ms build project
4735 dbb241952 20160221 Merged
4763 06cddc0e1 20160224 Revert "Update domoticz.vcxproj"
4697 913e4e8a7 20160221 Pi crash should be fixed now. prefs_mutex was locked/unlocked wrongly.
4735 4479c91ae 20160221 Merged
4763 16ad5ac72 20160224 Update domoticz.vcxproj
4735 809c26193 20160221 Merged
4763 5c3b77a64 20160224 cleans ms build project
4685 519742ca6 20160221 Upgraded Lua to 5.3.2
4692 47ee3d22e 20160221 Forgot this one
4697 33acc7c05 20160221 Some more fixes.
4692 f534a4234 20160221 Added History information
4827 caf5d262b 20160221 Merged changes with master
4763 c1e650916 20160224 removed undesired stdafx
4684 488a537bb 20160221 Removed unnecessary empty std::string initialization
4697 42805b7e7 20160221 Fixed nullptr compiler error msgs on Raspberry.
4735 3e035c3e9 20160221 Fix multiple session cleaner start after restarting webserver
4763 bf7b1eba8 20160224 fixed ms build project
4683 bba40bbd8 20160221 Fixed OpenZWave battery level for some sensor types
4735 7ad757b7c 20160221 Fix the webserver not stopping and not restarting issue after an exception occurr
4697 1c6d0a811 20160221 Made CProxyClient a shared ptr class.
4692 0e4d12dad 20160221 Added FreeBSD
4763 f18975784 20160224 modified blind command type/subtype solved compilation issues translated comments
4682 c22cfad3f 20160221 Panasonic: Destorying worker thread in destructor
4735 202463fd2 20160221 Add the new include file webserver/server_settings.hpp
4692 0060d276a 20160221 Cosmetics
4681 d32b6b5e1 20160221 Possible fix for Panasonic memory leak (could be adopted for kodi as well)
4704 5c7894b6b 20160220 Merge PR 11 from domoticz/master
4763 3c7445912 20160221 fixed compilation problems
4692 349ef7f0c 20160221 Fix include path and FATAL -> FATAL_ERROR
4735 180bfb87d 20160221 Add server_factory class to create a new server based on server_settings type.
4680 f6d661aa3 20160221 refactored code (cppcheck)
4692 a5e1dec49 20160221 Add libsysinfo detection under FreeBSD
4827 9f006ef78 20160221 Added support for HTU21D(F)/SI702x Humidity+Temp I2C sensor
4763 1d1d5404b 20160221 added support for Legrand/Bticino openwebnet : blinds via ip gateway
4735 0905a6e24 20160220 Refactor the webserver server class to separate the HTTP and HTTPS implementation
4679 f3ad94b58 20160220 Fixed compile error for 1wirekernel
4678 ed5fb29b9 20160220 Device subtable fix
4704 a08144f4a 20160220 Merge PR 10 from domoticz/master
4677 9e323a422 20160220 Fix for 1Wire with multiple Illuminance and pressure sensors
4842 0dd5e5a59 20160220 Merge PR 155 from domoticz/master
4676 740eab172 20160220 Fixed TE923 compile error
4675 9bcc05ca3 20160220 Refactored hardware classes to use base SendRainSensor, SendVoltageSensor,SendPer
4674 622eb8e26 20160220 Merge PR 500 from szczukot/master
4674 1328ff092 20160220 Refactoring SatelIntegra for don't using DecodeRXMEssage
4674 37e03fe36 20160220 Merge PR 9 from domoticz/master
4671 040230a21 20160220 Merge PR 499 from gaudryc/security/fix_remote_endpoint_exception_in_we
4669 72945daad 20160220 Fix for MySensors V_Tripped, should always send an update
4668 a2e48794a 20160220 Refactored hardware classes to use base SendTempHumBaroSensor, SendHumiditySensor
4667 8206cf30a 20160220 Added ForecastIO in temperature patch
4666 a2fdb0bc7 20160220 Refactored hardware classes to use base SendTempHumSensor
4665 75a287868 20160220 Rrefactored hardware classes to use base SendTempSensor
4671 55d283f95 20160220 Fix a security issue (DOS) in webserver to prevent a remote_endpoint exception to
4664 34e472b2f 20160220 Added saving of editor theme to Event page
4663 bc1f17eaf 20160219 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4663 8f4120b49 20160219 Merge PR 469 from gaudryc/fix_asyncserial_port_stop
4663 57ab76b3e 20160218 Merge remote-tracking branch 'origin/master' into fix_asyncserial_port_stop
4651 e99522bb4 20160219 Possible fix for general doorbell switch
4650 e8c18293b 20160218 Fix for Itho
4649 f16ebf424 20160218 Fixed Itho appearance under utility on the dashboard
4663 ae6ca3bc2 20160218 Merge remote-tracking branch 'origin/master' into fix_asyncserial_port_stop
4648 a3de0c0d1 20160218 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4648 ec669e79c 20160218 Fixed zooming in Lightlog graph
4648 6b78d8ce7 20160218 Update RFX_Type_SubType_Values table
4648 5accb684d 20160218 Refactored Test/Add manual switch conversion to GeneralSwitch type (for o.a. RFLi
4648 49ddc50ee 20160218 Implemented: Manual Add Switch/Light "Itho" Fan type
4648 f0dd0fbd7 20160218 Implemented RFXCom: typeFan/Itho
4648 740f518cc 20160218 Merge PR 495 from szczukot/master
4648 493be01ad 20160218 Merge PR 494 from arjanwaard/master
4635 ca2c54b52 20160218 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4648 b08f29a29 20160218 Changed leading spaces to tabs
4648 616fd203b 20160218 Update GetLights
4635 cc4ebbc76 20160217 Merge PR 493 from Pigloox/master
4628 32ba9f9ed 20160218 OTGW, added missing 'return' after command and added logging
4627 ee3eca05e 20160217 -Implemented: Dummy hardware setup, Solar Radiation Sensor
4626 f9910812a 20160217 Implemented: Option to send direct commands to OTGW from hardware setup
4648 5e12faeee 20160218 [SatelIntegra] Refactoring
4625 bc8a69996 20160217 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4648 49e9f3477 20160218 [Satel Integra] Small refactoring
4648 02eb102f4 20160217 Merge PR 7 from domoticz/master
4625 480eba605 20160217 Merge PR 492 from szczukot/master
4622 79d2dceb2 20160217 Fixed security device battery low problem
4621 b50b7450e 20160217 Merge PR 491 from szczukot/master
4625 96962329d 20160217 [1WireByOWFS] fix for reading data for HobbyBoards
4621 5026bad48 20160217 [1WireByOWFS] Fix for reading to much devices on start
4621 9fd0e6739 20160217 Merge PR 6 from domoticz/master
4618 8e3d9cd64 20160216 Merge PR 490 from szczukot/master
4618 d85368434 20160216 [1WireByOWFS] Faster reading all temperature sensors
4615 91e491584 20160216 Merge PR 489 from szczukot/master
4618 0ab744d21 20160216 [1WireByOWFS] Faster reading all temperature sensors
4615 63dc0d688 20160216 [1WireByOWFS] Faster reading all temperature sensors
4615 e37b02ad9 20160216 merge
4615 7cd23c3a7 20160216 Merge PR 5 from domoticz/master
4609 7a7aa0512 20160216 Fixed two compile warnings
4608 f8cafe01f 20160216 Possible fix for Elec2/Elec3 sensors with different voltage settings in Domoticz
4607 cdbe9365a 20160215 Previous temperature is now the avarage temperature from the last period instead
4606 2f1366ce2 20160215 - Implemented: MySensors, Heartbeat LastUpdate for Blinds/RGB/W
4605 25ad77173 20160215 Corrected build order in CMake
4604 fb46e64a7 20160215 Fix for Current/Energy and Power sensor graphs
4603 55f311596 20160215 Merge PR 486 from xbeaudouin/master
4600 c4b19b40e 20160215 Merge PR 483 from gaudryc/fix_1Wire_compilation_issue
4600 626eb6aec 20160215 Fix hardware/1Wire/1WireByOWFS.cpp compilation issue
4603 41ceb3a54 20160215 Removed unused line
4603 512db4c9e 20160215 Fix detection of libtellduscore.so on OS that have this lib in other place than /
4600 314b38f6f 20160215 Fix hardware/1Wire.h compilation issue
4597 74b79738f 20160215 Fixed MQTT itterator compile error
4596 23fb57bc5 20160215 Merge PR 482 from gaudryc/send_device_options_on_MQTT_device_info_requ
4594 c5498f021 20160215 Merge PR 481 from EddyK69/timecounter
4663 0045d1367 20160214 Add comment to AsyncSerial destructor
4663 b3d4e398d 20160214 Make AsyncSerial::doClose private
4589 4daf22650 20160215 Merge PR 472 from szczukot/master
4663 7d773de6d 20160214 Update clearCallback method comment
4663 e41d83534 20160214 Call ::terminate() in AsyncSerial destructor.
4663 03b418bb1 20160214 Replace ::stop and ::stopIfOpened method with ::terminate (terminate by unregiter
4663 6a4310fa4 20160214 Merge remote-tracking branch 'origin/master' into fix_asyncserial_port_stop
4596 aa2c28c24 20160215 Fix missing Selector switch levels in MQTT device info response by returning all
4582 87493348d 20160214 Merge PR 480 from gaudryc/fix_security_devices_editform
4582 a7c4ae026 20160214 Fix Security devices edit form by hiding Selector switch options (#473)
4594 325e2bcc8 20160214 Updated comment
4580 9b30d2c5b 20160214 Fix for security panel battery status
4594 16e00c4ff 20160214 Fix Counter format & default valuename
4579 856aada02 20160214 Fix for MySensors gateway version number with latest beta
4594 644d79181 20160214 Merge PR 154 from EddyK69/master
4578 3ee6c5cc5 20160214 - Implemented: MySensors, Update date/time of sensors on receiving a heartbeat me
4594 09d055d2d 20160214 Merge PR 153 from domoticz/master
4577 671d13e0f 20160214 Razberry added option to supply username/password
4576 56dcd50ff 20160214 Adopted patch #474 from sijones
4575 5d995b66b 20160214 Merge PR 477 from EddyK69/timecounter
4575 04779354b 20160214 Updated appcache & language-file
4575 71fce9212 20160213 Merge PR 152 from EddyK69/master
4559 dc06e90c4 20160214 Merge PR 479 from gms1/master
4559 b69fdf3a5 20160214 fix issue 281 : user variable with type 'Time' don't work in events
4575 956cb55ec 20160213 Merge PR 151 from domoticz/master
4559 1de9702e9 20160213 out-of-source build is now working again
4559 660f77e2d 20160213 getgit macro should use the SOURCE_DIR variable given by the caller
4555 72203dde8 20160213 Removed unknown compiler warning
4615 50532236a 20160216 [1WireByOWFS] more logs
4589 297b11e62 20160214 [1Wire] Compile fix
4554 c2c842b73 20160213 Better description of the MQTT output channel in hardware setup
4615 ab0a5928e 20160216 [1WireByOWFS] Small fix
4589 5329acb39 20160214 [1Wire] fix in compilation
4589 a41fcbcf5 20160214 Merge branch 'master' of https://github.com/szczukot/domoticz.git
4553 52ee049e6 20160213 Fixed some compile warnings
4552 070adeb05 20160213 Fix for manual adding Blinds
4589 9f58cfcf8 20160212 Logs development
4589 9d5e06e83 20160214 [1Wire] Optimization for less frequent reading. Reading info about devices only w
4663 6f2a2d8ce 20160212 Fix dead code in the AsyncSerial::close method causing the method not to stop or
4551 104a8065f 20160213 Merge PR 470 from gaudryc/remove_unused_inheritance_on_openzwave
4589 d9b73dd8d 20160212 Merge PR 2 from domoticz/master
4575 c373a2d6c 20160213 Added DBconversion Time -> Counter
4663 6167a8916 20160212 Refactor AsyncSerial class by adding the methods stop and stopIfOpened
4551 60b43991a 20160212 Remove unused AsyncSerial inheritance on the COpenZWave class.
4575 a7f9c951a 20160211 Removed CounterDivider
4549 4af0622cc 20160212 Merge PR 467 from qvjester/master
4575 a58b171f8 20160211 Merge PR 150 from EddyK69/master
4549 33e5fb51c 20160212 Fixed Import of Old Month Data and added some logging to the process
4547 8b2816948 20160211 Merge PR 465 from gaudryc/fix_zwave_configuration_backup_filename
4547 9d23c1560 20160211 Update history
4547 4090d4e38 20160211 Merge remote-tracking branch 'origin/master' into fix_zwave_configuration_backup_
4547 1b80d3ae7 20160211 Fix filename when path does not contains any '/'.
4547 97c368587 20160211 Merge remote-tracking branch 'origin/master' into fix_zwave_configuration_backup_
4541 1b814bdea 20160211 - Changed: English translation Child to Children - Implemented: Romanian Language
4540 ed0fc86c1 20160211 Merge PR 463 from Pigloox/master
4547 c565d70a8 20160211 Fix filename attachment when saving ZWave configuration file
4575 48f149499 20160211 Merge PR 149 from domoticz/master
4538 9b4ccca55 20160210 Merge PR 461 from gaudryc/secure_and_optimize_webserver_code
4538 f145be8f1 20160210 Merge remote-tracking branch 'origin/master' into secure_and_optimize_webserver_c
4538 9bdfa10b1 20160210 Add charset on content type if reply attchment is a text file
4538 d8e87aa62 20160210 Add webserver/utf.hpp file to WebServer includes.
4538 0a84f701a 20160210 Update history
4538 f996e7c3e 20160210 Add missing file
4538 31059b462 20160210 - Optimize the reading method of the database backup file by allocating memory be
4538 34e3e76db 20160210 Merge remote-tracking branch 'origin/master' into secure_and_optimize_webserver_c
4524 2e7f4a2d8 20160210 Merge PR 460 from RafiiB/setup2
4538 9a5eea755 20160209 Merge remote-tracking branch 'origin/master' into secure_and_optimize_webserver_c
4522 b0f55ca16 20160210 Merge PR 457 from ToniA/master
4522 69ba825e2 20160209 Merge remote-tracking branch 'domoticz/master'
4538 4440fc18d 20160209 Optimize webem_action_function execution by replacing return value with an argume
4519 3b1540683 20160209 Merge PR 458 from xbeaudouin/master
4519 d6989ff79 20160209 Under FreeBSD pkg_config name for LUA is lua-5.2. Allowing LUA package to be auto
4522 d017de6e8 20160209 New LUA table otherdevices_idx
4538 a8f63bf88 20160209 Optimize the database backup file reading method by allocating memory before read
4538 f226197ed 20160209 Remove database backup from shared memory (CWebServer::m_retstr)
4517 d980dc32b 20160209 Merge PR 454 from EddyK69/history
4538 a61b324f1 20160209 Remove camera snapshot from the shared memory (attribute of the WebServer instanc
4517 e83541d82 20160209 History: Use alias :D
4538 368144ff4 20160209 Remove unnecessary session attribute _tWebEmSession::lastRequestPath (used to che
4514 ae4ad6814 20160209 RFLink: Added more switch types
4517 80dab0977 20160209 Merge PR 148 from domoticz/master
4524 2ac78e979 20160210 Patch for setup.html
4513 899f76e3d 20160209 Merge PR 453 from ffontaine/master
4513 a3babae6b 20160209 Remove appversion.h.txt from git repository
4511 60249c7db 20160209 Fixed MQTT hardware setup settings
4510 e0e01a03e 20160209 Merge PR 451 from gaudryc/fix_a_cache_refresh_issue_by_respecting_http
4508 efba02b5b 20160209 Merge PR 442 from ffontaine/master
4510 ccc64d9de 20160209 Fix a cache refresh issue by respecting HTTP standard (HTTP 304 and 204)
4506 6f06cb2a5 20160208 Fix for HQ-CoCo20 House/Unit code
4505 0763cf569 20160208 Merge PR 448 from ToniA/mysensors
4501 967e1029e 20160208 Merge PR 449 from gms1/master
4499 7c47f95dc 20160208 Merge PR 447 from clandmeter/lua
4497 22af7b36c 20160208 Merge PR 445 from gaudryc/optimize_login_process_and_session_managemen
4497 e073adcc4 20160208 Change session handling order
4497 a3cb0c86b 20160208 Remove session only when the Logout command has been executed
4497 98d1c0ddf 20160208 Do not save each command response in the shared memory (attribute of the server i
4497 0234f0af2 20160208 Fix wording in log message
4497 f599edc64 20160208 Ask the user to close his browser tab when logging out from domoticz using basic
4497 b88806f35 20160208 Fix Javascript syntax and format
4497 342b802cc 20160208 Update all existing cookies validity
4497 2ff6727d3 20160208 Fix number of days of cookie validity to 30 (instead of 45)
4497 f80567668 20160208 Fix strange character
4497 77d623946 20160208 Update history
4497 57c681fa0 20160208 Fix wording
4497 43bf9deb3 20160208 Fix wording
4497 87d2bdbd0 20160208 Merge remote-tracking branch 'origin/master' into optimize_login_process_and_sess
4505 f2ff75a9a 20160208 Merge https://github.com/gms1/domoticz into mysensors
4505 17dd1d0f5 20160208 Merge branch 'master' of https://github.com/domoticz/domoticz
4499 3d203dcfe 20160208 Fix detection of system Lua
4501 022bb875c 20160208 trying to fix the AppVeyor build
4476 8fd5fb068 20160208 Merge PR 441 from EddyK69/transferdevice
4508 0664cdede 20160208 Force static build of libraries
4473 50d0c096c 20160208 Merge PR 440 from ffontaine/revert-438-master
4497 0ea80050f 20160208 Fix a potential issue in login process using a certificate when the subjectDN of
4497 eb1093917 20160208 Format the code
4471 c6ddbe652 20160208 RFLink: Added new switch types
4473 a9e48dd70 20160208 Revert "Force static build of libraries "
4470 f1ddd0394 20160208 Merge PR 439 from ffontaine/master
4575 5e34b5e4a 20160211 Resolve merge-conflict
4497 19322de3d 20160207 Always remove cookie on unauthorized connection and force login on logout by send
4497 a35beb6b2 20160207 Remove unecessary logs
4575 5e960a1dc 20160210 Load Counter options
4470 8047e2335 20160208 Add appversion.default file to save default values
4468 684c87f47 20160208 Merge PR 438 from ffontaine/master
4575 4a9c90dcd 20160209 Removed CounterType 'Time'
4497 2599fefb6 20160207 Merge remote-tracking branch 'origin/master' into optimize_login_process_and_sess
4468 f5ea6f3ef 20160208 Merge remote-tracking branch 'upstream/master'
4575 48adb40f6 20160209 Reformat
4575 5222c5cc2 20160209 Added DB conversion for CounterType Time -> Counter
4575 84e1a3c53 20160209 Clear options on other countertypes / CounterDivider integer-check
4465 351c40989 20160207 Merge PR 436 from gms1/master
4465 2a5505f72 20160207 fix inconsistency when USE_BUILTIN_MQTT has not been set
4575 13478f57a 20160208 Initial Custom Counter
4476 fab110970 20160208 Fixed: Preserve DevicePlan & SharedDevices when transferring device
4575 da1dc4d3e 20160207 Merge PR 147 from EddyK69/master
4463 43247829f 20160207 Merge PR 434 from EddyK69/history
4476 e9914a30e 20160207 Merge PR 146 from domoticz/master
4461 59e315fb3 20160207 Force loading of non sun set/rise timers if location is not entered. (fixed #433)
4460 0a7b4cdfe 20160207 Merge PR 415 from EddyK69/timecounter
4460 c96ebdf76 20160206 Resolved merge-issue on domoticz.js (final?)
4460 997f0f5db 20160206 Merge PR 145 from EddyK69/master
4460 3e035d361 20160206 Resolve merge-issue
4460 32345e41d 20160206 Resolved merge-issue on domoticz.js (3)
4460 578b75895 20160206 Resolve merge-issue (3)
4460 090a4410d 20160206 Resolved merge-issue on domoticz.js (2)
4460 61cf696f6 20160206 Merge PR 143 from EddyK69/master
4460 9e124640f 20160206 Merge PR 144 from domoticz/master
4505 e1dff7836 20160208 MySensors USB gateway to support 38400 bps serial speed
4440 3877f6008 20160207 Fix for Dim slimer
4439 2e4d48d67 20160206 - Implemented: Scene Log
4438 6e301e820 20160206 Set default Netatmo forcast to 'wsbaroforcast_some_clouds' when its not yet been
4437 527846059 20160206 Fix for ZWave switch conversion
4436 612a573c4 20160206 Updated RFXCom - Lighting1 - CoCo GDR2 added - Lighting5 - Avantek added - Blinds
4435 b0fa2cde5 20160206 Netatmo: Added forcast calculation (could take 3 hours)
4460 912379408 20160206 Merge PR 142 from domoticz/master
4434 9ba089f46 20160206 Changed pTypeLighting2/sTypeZWaveSwitch to pTypeGeneralSwitch/sSwitchGeneralSwitc
4433 b2ce0dd16 20160206 Merged domoticz.js.gz
4432 b58524689 20160206 Merge PR 428 from sijones/Panasonic-fix
4430 18632e518 20160206 Merge PR 427 from EddyK69/schedules
4426 51dd921fe 20160205 Merge PR 422 from ffontaine/master
4424 f3298e5e0 20160205 - Removed pTypeGeneral/sTypeGeneral switch type (was not used) - Implemented pTyp
4635 dede194ac 20160217 Fix power usage display
4635 bfaeb6fd1 20160217 Fix power usage display
4423 8a1a03877 20160205 Merge PR 423 from Pigloox/master
4635 1a41cf1d5 20160217 Fix power usage display
4635 da0f45903 20160217 Fix power usage display
4635 d92728286 20160217 Update Teleinfo.cpp
4460 befdbcf0f 20160206 Resolve merge-issue (2)
4420 29fd51278 20160205 Merge PR 426 from badzz/master
4460 9d44d9d80 20160206 Resolved merge-issue on domoticz.js
4540 5574aa72c 20160211 Fix power display when PAPP is missing
4423 da0404c69 20160205 Fix bug power display with 'Tempo' contract
4497 cc51d7c4d 20160207 Optimize session management and add the Web server port in log messages.
4418 a5487d4cc 20160205 Merge PR 425 from gms1/master
4468 754a5f34e 20160208 Force static build of libraries
4460 0b1d32234 20160206 Resolve merge issue
4423 fcd0f0b81 20160205 Fix bug power display with 'Tempo' contract
4497 a00e0b526 20160205 Clean up expired sessions from database in order to avoid to wait for the domotic
4418 87c66d910 20160205 fixed issue 410: the install prefix is now configurable again
4460 619a44b1a 20160206 Fix CounterType Time issue
4426 50a2e197f 20160205 Fix cmake dependencies on git
4460 5ec21e2b7 20160205 Extracted fix for seperate PR
4416 2c36fbf76 20160205 Merge PR 416 from saerdnaer/patch-1
4460 372e58e1f 20160204 Updated cache-file
4460 2eebf3d47 20160204 Merge PR 140 from EddyK69/master
4413 333151e1c 20160205 Merge PR 417 from sijones/Panasonic-fix
4430 54e4bb0fe 20160205 Fix:ed SQL error when starting with new DB
4430 c2fe71a34 20160205 Merge PR 141 from EddyK69/master
4463 76d000b01 20160204 Updated History-file
4416 190495231 20160204 improved formating to make file better readable
4430 6a80a6973 20160204 Merge PR 139 from domoticz/master
4416 4f2e413b0 20160204 improved formating to make file better readable
4409 50d7bd4a4 20160204 Removing IPV6 IP address from login message (when IPV4) More debug info for Nefit
4408 df1c8f675 20160204 Merge PR 414 from gaudryc/fix_the_selectmenu_display_in_selector_switc
4420 f2b1e62ce 20160205 Fix random behavior on Piface
4408 78fb9addd 20160204 Fix the "selectmenu" element display in the Selector switch.
4432 3c2354832 20160205 Fix lost domoticz.js changes for Panasonic Remote
4413 f0f2561c4 20160204 tab space correction
4406 eae70a8a7 20160204 Merge PR 413 from EddyK69/lms
4413 5a1e2cbed 20160204 Better logic that we are talking to a Panasonic TV
4413 ebcf72531 20160204 Fix for double events when device is turned on.
4403 c306a0d84 20160203 Merge PR 412 from gaudryc/fix_selector_device_in_floorplan_tab
4403 15c8920df 20160203 Fix HTTP 404 error when displaying default icon on Selector device
4403 de97bbcb7 20160203 Merge remote-tracking branch 'origin/master' into fix_selector_device_in_floorpla
4403 38aad8c90 20160203 Fix select menu width and arrow.
4403 82c79a504 20160203 Fix the issue with underlying elements when user change the selector level
4403 813698634 20160203 Javascript syntax/format
4403 7d974dce4 20160203 Fix the issue with the underlying elements still visible
4403 feb176c0a 20160203 Remove the unecessary code
4391 be100f835 20160203 Merge PR 411 from JohnAdders/proxyroot
4391 ff25fa23c 20160203 Removed forward slash from before hash on ShowLayout as it was breaking navigatio
4403 cedd5aaff 20160203 Change method name and test to be more generic
4460 93d4d29e5 20160204 Added CounterType Time
4389 acefb57da 20160203 Openzwave, forcing getting product id/type when not set on new value update
4460 9eec158a1 20160204 Added icon for CounterType Time
4403 71f19fa13 20160202 Update html5 cache version
4460 be9fc1f0e 20160203 Added CounterType Time
4388 9ac0c0a3f 20160203 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4406 5898ff4d7 20160203 Logitech Media Server: Added support for Transporter
4403 548826b56 20160202 Implement Selector switch device using SVG
4406 ac5bce680 20160202 Merge PR 138 from domoticz/master
4403 8410db7eb 20160202 Javascript syntax and format
4388 8f45ef4c1 20160202 Merge PR 406 from elpeka84/tab_scenes
4385 7d19b9973 20160203 - Fixed: MySensors, barometric value was not used when below 995 hPa
4384 c41e8b4b2 20160202 Merge PR 392 from xbeaudouin/master
4380 a092d4300 20160202 Merge PR 388 from tuomaz/1wire-eds-pressure
4378 f944a340e 20160202 Merge PR 393 from szczukot/master
4388 9eb5cae37 20160202 Add translation for button on scenes and group
4375 34ebfc87e 20160202 Updated translation files
4374 e2520f76d 20160202 Merge PR 404 from elpeka84/translate_blinds
4372 24d72faaa 20160201 Updated translation files
4371 c4ba8fbdd 20160201 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4371 c29781285 20160201 Merge PR 403 from JohnAdders/currentcost
4371 e3a1ca0d6 20160201 Update comment
4371 5d0cde8a1 20160201 Fix compiler warning under windows
4371 843207b4b 20160201 Merge remote-tracking branch 'upstream/master' into currentcost
4364 f17d456e7 20160201 Nest Protect, update LastUpdate field when there is no change in state
4363 d14894a7c 20160201 Added Domoticz.js again
4374 8c6e9b9c1 20160201 Add translation for button Stop Blinds
4362 7df4d132d 20160201 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4362 27d6095bf 20160201 Merge PR 398 from stephaneguillard/master
4359 640873668 20160201 Updated OpenZWave configuration files, and language files
4358 a79b8874b 20160131 incrementing appcach file
4357 443260919 20160131 Fix for Revolt energy meter graph
4356 2a98d2ffc 20160131 Added missing file
4355 160b5dffc 20160131 - Implemented/Starting: Chinese language support, big thanks to wxws/健 马!!
4354 f8d4a0d5f 20160131 Fixed: Nest Protect (in combination with a thermostat) was not added to the syste
4378 af8772351 20160130 [Satel Integra] Now user can change devices names for output/zone/temp
4362 700ec27fd 20160131 Update EnOceanESP3.cpp
4353 125f4af99 20160131 Merge PR 397 from stephaneguillard/master
4353 ee9b1a1b1 20160131 Update EnOceanESP2.cpp
4378 a2ba0b110 20160130 Merge PR 1 from domoticz/master
4351 0f959b40d 20160130 Fixed: Next Heating/Cooling for multiple thermostats
4350 ea7fa8495 20160130 Fix for GCM id generation
4349 b183fbef8 20160130 Updated language files Added support for P1 iskra ME382 gas sensor
4384 988625f87 20160129 Not fixed. Forgot a line. Sorry
4348 76090a8f7 20160130 Better Nest Thermostat implementation (fix for multiple thermostats for multiple
4384 71f0c6f3b 20160129 Fix Build under windows
4384 e7cf55ab0 20160129 Allow domoticz to be compiled without builtin MQTT library
4347 a55ce30ae 20160129 Fixed possible crash in Nest thermostat when there are less 'structure' objects t
4346 fa67272d1 20160129 Merge PR 387 from Delaroyas/master
4342 3e9b5cfa4 20160129 Merge PR 389 from EddyK69/schedules
4346 d775daa6c 20160128 Merge remote-tracking branch 'upstream/master'
4371 c4e777f0e 20160128 Add support for multiple power sensors
4380 f0980c727 20160128 Add support for pressure readings from 1Wire-devices by EDS.
4371 4f425141c 20160128 Replace boost sleep_for with Helper function to allow wider range of boost versio
4337 095f3d54b 20160128 GCM Added Name for feature editor
4336 e80165435 20160128 Changed GCM url to also be iOS compliant
4335 e0a0cc7ad 20160128 Start of Google GCM implementation (needs testing)
4346 3011df54e 20160128 Fixed newly added heating/cooling logging using a swtich.
4334 a089e0ccf 20160127 Fixed NMA notification
4346 58464c2e3 20160127 Added Nest Heating/Cooling logging in a "switch" device.
4333 698201cb3 20160127 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4333 f7e470d02 20160126 Merge PR 369 from nayrnet/zwave-dimmer-fix
4342 77780717b 20160128 Changed: Extended JSON method schedules
4342 ebeee5115 20160126 Implemented: JSON method getsetpointtimerlist
4327 5bc173fdb 20160127 Fixed AppLamp White All Off command
4342 171d982ce 20160126 Merge PR 137 from EddyK69/master
4342 873b866fa 20160126 Merge PR 136 from domoticz/master
4326 1ed4c386f 20160126 Stop displaying internal hardware in the hardware tab
4325 ad61121d1 20160126 Merge PR 383 from EddyK69/schedules
4325 d271895b8 20160126 Revert getsetpointtimerlist method
4325 259d49915 20160125 Update html5.appcache
4325 9ce734daf 20160125 Merge PR 135 from EddyK69/master
4325 3ad1abbd5 20160125 Revert update cache-file
4325 5fe17f659 20160125 Update html5.appcache
4325 3642938e0 20160125 Removed comment
4314 a080e6f44 20160126 Merge PR 382 from nayrnet/mqtt-addlogmessage
4325 79ced3f37 20160125 Implemented: Extended schedules for SetPoints
4325 0d8ed324e 20160125 Merge PR 134 from domoticz/master
4325 5e67d6c5c 20160125 Merge PR 133 from EddyK69/master
4312 a8d7e20bf 20160125 Youless, Day Graph can now be zoomed
4325 1c08ef918 20160125 Merge PR 132 from domoticz/master
4311 c642f3e16 20160125 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4311 8a49c8f64 20160125 Merge PR 375 from sijones/panasonic-fixes
4311 80c2bda78 20160125 Merge PR 374 from EddyK69/switchselector
4311 ed3d0efba 20160123 Disable Dimmer-level notifications for now, will implement later
4311 53e2c2082 20160123 Disable Dimmer-level notifications for now
4311 cdf6d653a 20160122 Added Selector Notification frontend
4333 f5f834fd0 20160125 cleaner fix for dimmer values > 99
4311 b0c45de7b 20160122 Merge PR 131 from EddyK69/master
4333 ec224e8fe 20160125 cleaner fix for dimmer values > 99
4311 90ed8f5ce 20160123 Update History.txt with Panasonic Support added
4333 49f81f437 20160124 Merge branch 'master' of https://github.com/domoticz/domoticz into zwave-dimmer-f
4311 d3b8fea5c 20160122 Fix for "Off" command
4311 7aa489dd7 20160122 Merge PR 130 from domoticz/master
4299 116d62a41 20160125 Update OZW config file, updated language files
4298 4ab7980d8 20160122 Displaying no update message when manual checking for updates
4297 e2204531e 20160122 Fixed gui update problem for non-windows users
4296 4be640b35 20160122 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4314 b0db5602b 20160125 add mqtt support for addlogmessage
4333 02ef1a7f1 20160122 If dimmer has value > 100%, set value to 100%
4296 9855a97d4 20160122 Merge PR 363 from maartenbreddels/master
4288 023aa3db6 20160122 Small change in panasonictv
4287 21c06d01f 20160122 Fixed MSBuild project
4286 1b101d490 20160122 Merge branch 'sijones-domoticz/master'
4286 076d64875 20160122 Merged master fixed conflict.
4278 e35f15694 20160122 Merge PR 366 from szczukot/master
4296 dbbbe6192 20160121 made python interpreter an option in cmake file (run cmake -DUSE_PYTHON=On to ena
4275 9b32b1c49 20160122 Fixed PushOver notification configuration/testing Better Prowl/NMA notifications
4286 2575ea348 20160120 Bug fix and appcache bump
4274 f5bb8d3f4 20160122 Changed Notification Subject for some systems (otherwise we had double entries)
4286 bcfbfe851 20160120 Couple of changes to Logging of errors from the plugin.
4296 98ecff198 20160120 added python-boost to brew packages
4278 62d9c46ec 20160121 [Satel Integra] fix compilation
4296 4a0f54413 20160119 removed print statements
4273 2546f51af 20160120 Merge PR 362 from szczukot/master
4286 02b6b580f 20160120 Media remote changed to work with Panasonic TV
4278 d82a23ed0 20160121 [Satel Integra] Support for Polish letters
4286 bd5f4d4b6 20160120 Added panasonictv.cpp to CMakeLists.txt
4296 4e73fe2da 20160119 Merge branch 'master' of https://github.com/maartenbreddels/domoticz
4273 87043eae1 20160119 [Satel Integra] Add support for many partitions
4286 49ff79cc5 20160119 vs solution filter to include Panasonic files
4273 a8221edd1 20160119 [Satel Integra] Add support for many partitions
4296 41d44a2d2 20160119 added Python support for the editor/in-database script, enabled Python support ag
4286 1cfc294c2 20160119 Panasonic TV Plugin added (No GUI)
4273 7e6306e58 20160119 [Satel Integra[ Add a few protection code
4269 31ad24bdb 20160119 Implemented hack to switch on/off the Aeotec Smart Switch 6
4296 1a0fa4cea 20160119 added Python support for the editor/in-database script, enabled Python support ag
4268 12f5a195e 20160119 Merge PR 359 from nayrnet/elemental-theme
4268 c1daf9516 20160118 resize selectors to comparable size to sliders, ie thinner
4268 2f3a57cdf 20160118 doubleicon devices were just slightly larger than the rest.
4268 c8cd40425 20160118 dimslider fix for firefox
4268 7e23de7e3 20160118 seperate sizes for dashboard sliders
4268 d95f668db 20160118 adjust slider location for doubleicon devices
4268 fffcc1d02 20160118 adjust slider location for doubleicon devices
4268 762c628dd 20160118 rendering fix
4268 4e2b1a550 20160118 slider fix needed better implementation
4268 fa3f82db8 20160118 finally fixed slider issue, cheers G3rard
4268 294ad7f39 20160118 added support for selector switches, some more cleanup on mobile devices.
4257 8779259a9 20160118 Merge PR 358 from domoticz/wwwcontentfolder
4255 21171b134 20160118 Merge PR 357 from EddyK69/json
4255 621cf0ff3 20160118 JSON: Added PlanID and PlanIDs to output for Groups/Scenes (2)
4255 33e19afb6 20160118 Merge PR 129 from EddyK69/master
4311 08ee0cf0b 20160119 Finished SelectorSwitch notifications backend
4311 e448200c2 20160118 Initial SelectorSwitch notifications
4255 0f27469c9 20160118 Merge PR 128 from domoticz/master
4257 f87e0ce90 20160118 Added www folder as content folder in Visual Studio solution.
4246 a5b933523 20160117 Merge PR 351 from sbouchex/udevices_xml
4242 43547e677 20160117 Fixed travis file
4241 53e6f3dd5 20160117 Better update handling
4240 1e9827a2f 20160117 Windows, Check for new (beta) versions, with download option
4239 70341ba1f 20160117 Corrected Travis/Appveyor ourput file names
4238 16e924200 20160117 AppVeyor, use same file naming as other platforms
4237 23830c238 20160117 Fixed wrong hardware description for Mochad done by some developer some time ago.
4236 a4daa42b3 20160117 Fixed download url of previous appveyor patch
4235 cd65ae46c 20160117 Another appveyor change to always get the latest win32 libraries from our repo
4234 1eabfa7cf 20160117 Updated travis All default send sensor functions includes now a default name opti
4233 a739b2696 20160117 Another appveyor change
4232 8b7147e1d 20160117 Updated appveyor file
4231 e3866cd6e 20160117 Fix for dirent on windows
4230 de0351ebd 20160117 Merge PR 353 from dwmw2/master
4255 7793a62c3 20160116 Merge PR 127 from EddyK69/master
4228 277db5f6a 20160117 Small change for scenes/hue (nor using the original ID internally)
4230 0c1c252f9 20160117 Handle DT_UNKNOWN in directory entries
4227 55dc2d91a 20160117 Graph counterlogspline can now have negative numbers
4255 fb0573a8e 20160116 Merge PR 125 from domoticz/master
4226 b1164462d 20160117 Added missing jquery file
4246 6c988aa2d 20160117 Extended "udevices" API call by adding XML data injection with XPath
4225 b29af8e2c 20160117 Upgraded JQuery to 1.12.0 Implemented mass deletion of devices
4246 3e4362cf9 20160116 Extended "udevices" API call by adding XML data injection with XPath
4246 effc537ff 20160116 Extended "udevices" API call by adding XML data injection with XPath
4224 dbbf4f3fe 20160117 - Fixed, day notation in graphs (highcharts starts on sunday) - Fixed scenes on d
4223 215d9fd9a 20160116 - Changed: Alert sensor, removed level notation in user interface
4222 55df2c97e 20160116 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4222 27053b48c 20160116 Merge PR 349 from szczukot/master
4222 7d1809a4e 20160116 [Event System] add sTypeKwh
4215 8edd97a72 20160116 Better translation on the graphs
4222 6e7077f53 20160116 [Satel Integra] small cleaning
4222 fd2184271 20160116 Merge PR 12 from domoticz/master
4255 cb0302369 20160116 Merge PR 124 from EddyK69/master
4214 365c97000 20160116 SwitchScene, dont break out with an error if there are no lights in the scene
4255 d4d606e40 20160116 Merge PR 123 from domoticz/master
4213 6e30c3f2a 20160116 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4211 e47a5c0a3 20160116 - Implemented: Philips Hue, support for stored Scenes (create them with an extern
4213 3deac62fa 20160116 Add Play Favorites support
4210 ac0591286 20160115 Philips Hue, no error if group/0 can not be found
4209 430320705 20160115 Merge PR 347 from sbouchex/udevices_json
4206 b471efa35 20160115 RFLink: manual add RTS device fix
4209 8dcb34ce5 20160115 Added some comments
4209 e7fa615dc 20160115 Extended "udevices" API call by adding JSON data injection with JsonPath parsing.
4205 c15298c9a 20160115 RFLink: Manual Blinds fix
4204 8f489082a 20160115 Merge PR 346 from EddyK69/json
4198 c7880d56e 20160115 Merge PR 344 from nayrnet/x509-sso
4196 e8fb21c76 20160115 Merge PR 345 from nayrnet/icon-fix
4194 4c46483fa 20160115 Merge PR 339 from gaudryc/fix_selector_options_value_splitting_method
4198 f3d4e99cb 20160114 basic support for x509 sso
4255 a4a3611b7 20160114 Merge PR 122 from domoticz/master
4192 5131fb971 20160114 Merge PR 340 from EddyK69/schedules2
4189 96773a988 20160114 NE only update text sensors when there is a change
4204 3b058e1a3 20160115 Revert JSON HistoryLog (for seperate PullRequest)
4204 40f956727 20160115 Revert JSON HistoryLog (for seperate PullRequest)
4188 0645354b8 20160114 Add ne status code
4187 85bdcdaa6 20160114 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4204 44c1e51ac 20160114 JSON: Added HistoryLog method
4204 b4a328db4 20160114 JSON: Added PlanID and PlanIDs to output for Groups/Scenes
4185 73258ac4b 20160114 Expirimental Nefit-Easy via HTTP web server application from Robert
4204 652816875 20160114 Merge PR 120 from EddyK69/master
4192 61edc7012 20160114 Fixed: Wrong timertype conversion while updating to new version
4187 40f40d51b 20160114 RFLink: Show version at startup
4194 1efec27d7 20160114 Change the splitting method used to extract option values to prevent the problem
4184 8c23d7e5f 20160114 Fixed SignalLevel/BatteryLevel for CM180 (ENERY) device
4192 729f9e190 20160114 Merge PR 119 from domoticz/master
4183 db665d32b 20160114 Updating Language files/OZW for RPI
4182 6891eee13 20160114 Merge PR 336 from gaudryc/fix_unauthorized_characters_issue_in_selecto
4182 ad03491ea 20160114 Fix character issue by keeping actions escaped in data attribute.
4182 9583d836d 20160114 Update html5 cache revision
4182 c164a01f2 20160114 Retrieve action from the list before editing it (instead of passing it as an argu
4174 68befa083 20160114 Merge PR 334 from EddyK69/schedules
4174 d6b20390a 20160113 Implemented: Added scheduletype Odd/Even Day Numbers
4182 c26dc68c3 20160114 Fix selector actions length if user have saved more actions than levels (due to t
4174 eb0f84188 20160113 Implemented: Added scheduletype Odd/Even Day Numbers
4182 d058c84e0 20160114 Clean unauthorized characters from the level name while adding or editing it.
4174 4d063d0e2 20160113 Merge PR 118 from EddyK69/master
4182 3dbd6a6a4 20160114 Fix rename function not working when level name contains quote or double quote ch
4174 ce2a9806f 20160113 Merge PR 117 from domoticz/master
4182 453c982c3 20160114 Fix escaping management of the levelnames attribute
4169 b907e863c 20160113 Merge PR 330 from gaudryc/fix_selector_action_https_support
4169 d169a481c 20160113 Add https support to supported URIs list on action editing forms.
4169 2051b4c88 20160113 Add tooltip to Selector level action editing form (supported URIs list)
4169 5a5c987ad 20160113 Fix https support to Selector level action
4165 66a2e8e11 20160113 Merge PR 329 from gaudryc/complete_wording_issue_327
4165 9b6d88d2d 20160113 Complete wording issue 327
4163 b66165714 20160113 RFLink: Added more device types
4162 61fcb4725 20160113 RFLink: additional manual devices
4161 b434d5cac 20160113 Updated translations
4160 a62986584 20160113 Updated translations
4159 93d9baa7c 20160113 Another usage of correct temp folder
4158 bf5399020 20160113 Using temp folder under linux architecture
4157 25f826664 20160113 Updated openzwave
4156 c3b473c4e 20160113 Changed translation Weeknumbers to Week Numbers
4155 4398b630a 20160113 Merge PR 289 from algernon2/master
4150 63f0ac7ac 20160113 Merge PR 325 from gaudryc/optimize_selector_creation_and_switching_tim
4148 b3890927c 20160113 Merge PR 322 from EddyK69/schedules
4148 71c925137 20160112 Added Yearly weekday schedule
4148 b13b405bf 20160112 Merge branch 'schedules' of https://github.com/EddyK69/domoticz into schedules
4148 43edb3cf9 20160112 Merge PR 116 from EddyK69/master
4125 e4b53744f 20160113 Merge PR 321 from nayrnet/element-theme
4150 f8b49e3e5 20160113 Optimize the selector creation time (by cleaning and simplifying the code) and op
4123 d033b9db1 20160112 Merge PR 316 from nayrnet/element-theme
4148 80dbead7b 20160112 Merge PR 115 from domoticz/master
4120 babed8b15 20160112 Fixed localtime call
4119 334597721 20160112 Fixed win32 string formatting
4118 c11417bf4 20160112 Better email handling
4117 2867f2025 20160112 Better date format in email
4116 ce1582caf 20160112 Merge PR 319 from gaudryc/feature/refresh_selector_buttons_state_in_mo
4116 a14777f59 20160112 Remove unecessary elements from jquery selector to select an element with its id
4116 f8e6808bc 20160112 Add selector buttons state refresh in mobile mode
4125 93ce611fe 20160112 fixes for mobile devices
4113 efc3592ed 20160112 Merge PR 318 from IanDury/fix-installdir
4123 bd1c25cf7 20160112 Elemental Theme by Ryan Hunt
4113 bc9489121 20160112 Fix install path
4196 7f3fed374 20160114 fix logout for mobile devices
4123 2eb9c17b5 20160111 tweak slider offset, looks better on all themes
4111 a95b6cef5 20160112 MQTT, extra parameter 'parse', when false, it will not send the value back to MQT
4110 b5f7c3a40 20160112 Merge PR 315 from gaudryc/fix_selector_buttons_state_on_device_refresh
4110 f1ddd5afc 20160112 Fix selector buttons state on device refresh due to a jqueryui bug by unselecting
4108 32d7ae593 20160111 Merge PR 314 from gaudryc/feature/selector_switch_level_action
4108 02df93bdb 20160111 Fix wording
4108 6765326cc 20160111 Merge remote-tracking branch 'origin/master' into feature/selector_switch_level_a
4108 64600b602 20160111 Merge remote tracking branch 'origin/master' into feature/selector_switch_level_a
4108 12115eaee 20160111 Change DeviceStatus.Options field from VARCHAR(1024) to TEXT (to prevent from too
4108 47d7b487a 20160111 Handle 'Hide Off level' in Planning form by disabling command field (fixed to On)
4108 cab6ab1a6 20160111 Fix Selector style radio alignment
4108 b225f97e4 20160111 Hide legacy On/Off actions parameters in Selector editing form
4108 f458336a2 20160111 Update HTML5 cache version
4108 718e7808e 20160111 Add tooltip to Rename and Delete icons
4108 1e4d69b71 20160111 Move new level name validation to the dialog code.
4108 7ba1042a7 20160111 Add "Selector Actions" to Selector editing form and handle it.
4108 002acf1bc 20160111 Add "Hide Off level" parameter to Selector editing form and handle it.
4148 23e26883d 20160112 Initial Monthly (weehday)
4108 0377536b8 20160111 Fix javascript syntax and format
4148 fe10a331f 20160109 Merge PR 114 from EddyK69/master
4108 2babdc363 20160111 Save level names in data attribute to be able to hide a level without loosing it.
4108 487d02f80 20160111 Add LevelOffHidden and LevelActions attributes to selector device
4108 d91324c9c 20160111 Optimize options parsing
4108 cd716c1b2 20160111 Handle On/Off action for selector switch using device options
4088 5d1d90e52 20160111 Fix for possible battey level for RFXCom sensors
4108 37078a4a1 20160110 Add GetSelectorSwitchLevelAction to extract selector action from device options.
4108 8678ee849 20160110 Fix extended characters encoding issue (eg. level name containing accent)
4087 23c625e0e 20160111 Fixed alert sensor text on dashboard
4086 c477b1236 20160110 Merge PR 254 from JohnAdders/proxyroot
4086 d99abcd87 20160110 restore Request handler
4086 48c781cbb 20160110 bring branch up to date with master
4079 ec9c591cd 20160110 Small change on default device name
4148 3b6aef7c1 20160109 Merge PR 113 from domoticz/master
4078 7f07293c2 20160110 Implemented Manual adding of Philips SBC light
4077 ad6cb1d04 20160110 - Implemented: Philips Hue, support for Groups (create them with an external app
4076 20694bfc6 20160110 Better RGB2HSB conversion
4075 00bb966fa 20160109 Another try to fix min/max error
4074 10dbb45ac 20160109 Fixed compile error under linux
4073 af9470a19 20160109 setcolbrightnessvalue, now possible to enter direct hex value (json.htm?type=comm
4072 5192e9d54 20160109 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4072 1e4c414e0 20160109 Merge PR 305 from bobkersten/master
4069 cd73d0370 20160109 - Implemented: Dummy Hardware, option to create an RGBW switch
4068 f53196968 20160109 Fixed some default device naming issues for new hardware
4067 39c33813e 20160109 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4065 95c9ce0d9 20160109 Updated OpenZWave
4067 5db90bc49 20160109 Set executable flag on download update script
4064 110c699cd 20160109 - Implemented: Temperature Tab room selector
4063 9cb65412a 20160109 Merge PR 272 from PiterEL/patch-1
4061 ee8528100 20160109 Merge PR 287 from gms1/fixInstallPrefix
4059 5ec18e7fb 20160109 Merge PR 303 from domoticz/revert-286-fixOutOfSourceTreeBuild
4059 65352e11f 20160109 Revert "build issue: git should be called on source-tree instead of build-tree"
4057 8a7644666 20160109 Merge PR 286 from gms1/fixOutOfSourceTreeBuild
4055 5339b6a08 20160109 Fixed MySensor repeat patch
4054 6c0ee0412 20160109 Merge PR 293 from zaphodus/patch-1
4050 79ef6425c 20160109 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4050 b4cf4a824 20160109 Merge PR 302 from fets13/master
4047 90ef83cc4 20160109 - Implemented: Icelandic language support, big thanks to Magnus!! - Fixed possibl
4046 f0786d9d4 20160109 Merge PR 266 from gaudryc/secure_message_decoding
4148 d63a76047 20160109 Revert changes due to merge-conflict
4148 78e1d17b4 20160109 Implemented schedulte-types odd/even weeks & monthly
4046 6e240857c 20160106 Remove references to HardwareID 1000
4148 422c2540d 20160108 Minor changes
4148 601f527b3 20160106 Added odd/even weekly schedule
4046 1379e9e1b 20160106 Fix msbuild (2)
4046 fa682094d 20160106 Fix DomoticzInternal hardware in Hardware tab (listed but cannot be added, update
4148 1de1dd10b 20160105 Derived timertypes to timertypesextended for use with lights/scenes
4148 9df8f40dd 20160105 Merge PR 112 from EddyK69/master
4046 7a2c2978b 20160106 Fix msbuild
4046 cf115af43 20160106 Add DomoticzInternal hardware
4046 6bb586a39 20160106 Fix SetInternalSecStatus method, using PushAndWaitRxMessage and the new DomoticzI
4046 87f532109 20160105 Fix SwitchModal function
4046 73162db40 20160105 Merge remote-tracking branch 'origin/master' into secure_message_decoding
4148 deb4ef5db 20160105 Finished Save extended schedules on scenetimers
4148 4b72287e5 20160105 Finished Save extended schedules on timers
4148 88a060aec 20160105 Merge PR 111 from domoticz/master
4148 347e62a08 20160104 Merge PR 110 from EddyK69/master
4072 d5ff68fe1 20160109 Fixed missing usage value in (virtual) P1 Smart Meter device
4222 719f51665 20160106 Merge PR 11 from domoticz/master
4032 dfd3c6fc3 20160108 RFLink: Added more device types
4050 4d331c6e0 20160108 Process incoming messages with ack request
4031 b58102e18 20160105 SQLHelper.cpp: different ItemTypes cancel each other from q
4030 d8e19a6ee 20160105 Making sure the passcode for switches/groups are checked
4148 4f3014f85 20160104 Merge PR 109 from domoticz/master
4155 f9d7fbabb 20160104 Revert "revert changes"
4029 719e4edfa 20160105 Fixed: Translation on Dashboard when no favorite devices are available Fixed: Lig
4155 e4f7871fc 20160104 revert changes
4028 8b54a8d6b 20160104 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4155 1f0ca3afd 20160104 insert missing brace
4028 ffae0994f 20160103 RFLink: added more devices
4061 b4f73603a 20160102 .) initialize CMAKE_INSTALL_PREFIX after CPACK_PACKAGE_NAME has been initialized
4026 9f498f9a0 20160104 SBFSpot: support for multiple inverter instances Fixed some default sensor naming
4155 7bffb26a7 20160103 LightwaveRF inline relay
4057 5be6c0161 20160102 git should be called on source-tree insteaf of build-tree
4025 6cb767b73 20160102 Updated MyDomoticz config labels
4024 f9be3978a 20160102 Merge branch 'master' of https://github.com/domoticz/domoticz
4024 d7d01be9e 20160102 Merge PR 284 from domoticz/ConnectionCleaned
4021 707f582a0 20160102 Update OZW Aeotec Multisensor6 configuration file
4020 81cc5d83f 20151231 Add extra snippet file to prevent 404 error in eventsframe
4046 7daa83edc 20151227 Merge remote-tracking branch 'origin/master' into secure_message_decoding
4019 d1f28da8e 20151231 Snippet file missed from initial commit
4148 6ce931d21 20160104 Revert changes due to merge-conflict
4148 cbefecf5c 20160104 Added extended scheduler to Add/Update timers
4024 842caebb9 20151230 Cleaned up connection.cpp. Now there's only one handle_read(), etc. instead of di
4018 489e3ef9c 20151231 Fix bug when zero scripts are defined
4148 ca1a78e66 20151228 Initial setup for expended timers
4017 84e167c0e 20151229 Merge PR 277 from domoticz/Move_scripts_to_DB_and_add_editor
4148 8eaa7c8ef 20151227 Merge PR 108 from domoticz/master
4015 5eff3d8c1 20151226 Merge PR 271 from domoticz/MyDomoticz
4015 fefbf37fe 20151221 Session cookie parsing bug that was solved earlier by Gizmocuz fixed login issue
4015 bd59af6c7 20151221 Merge branch 'master' into MyDomoticz
4015 6563a05bf 20151221 Removed some unused code.
4015 b894b530b 20151221 Removed some unused code parts.
4015 0c1572be0 20151221 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
4015 8b231a772 20151221 Made it possible for urls like https://my.domoticz.com/my/[instanceid]/#/Dashboar
4015 c04d74c86 20151220 Merge branch 'master' into MyDomoticz
4015 3f495502e 20151213 Fixed NOCLOUD compiler directive support.
4015 5d97574fc 20151213 Merge branch 'master'
4015 8be644fca 20151213 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
4015 7e5063d78 20151208 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
4015 2153a3268 20151208 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
4015 181acabfd 20151208 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
4015 6e56edc72 20151207 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
4015 10313c482 20151206 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
4015 3c602e9bb 20151205 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
3877 fbf1a8afc 20151226 Merge PR 273 from djoele/master
4015 a56c2803e 20151213 Needs testing.
4015 cab0813ab 20151213 Working code, except for not modified caching.
3874 4ea6785d5 20151226 Merge PR 274 from EddyK69/json
4046 f0d03900c 20151223 Merge remote-tracking branch 'origin/master' into secure_message_decoding
4015 2df9fa669 20151208 lockfree queue doesn't link on raspberry. changed it to std::queue which is prote
4015 f831d9815 20151208 scoped_lock doesnt compile on Raspberry. Using unique_lock.
3874 c4215b6cf 20151223 JSON: Updated gettimerlist & getscenetimerlist
4015 caa6c83ba 20151208 Sync with master.
3874 b2b97a761 20151222 Merge PR 107 from domoticz/master
4046 a08d23501 20151222 Merge remote-tracking branch 'origin/master' into secure_message_decoding
4017 f08f52ce8 20151229 Add Lua script editor to Domoticz web UI
3877 26cd1b9d5 20151222 Back and Report button were not visible on certain devices
4063 7576f9bb3 20151222 Correct alignment in one line
3877 5f444cb4e 20151222 Merge remote-tracking branch 'refs/remotes/domoticz/master'
3869 3494b9e90 20151223 Fix a couple of incorrect message names
3868 3740090c9 20151221 RFLink: added support for more devices
4046 1728c61a1 20151220 Merge remote-tracking branch 'origin/master' into secure_message_decoding
3867 b2d275ef2 20151221 Changed YouLess day graph
3866 2b321ce81 20151220 Fixed typo in history file
3865 929fd69a1 20151220 Merge branch 'master' of https://github.com/domoticz/domoticz
4015 bc3708f58 20151208 Disabled Last-Modified caching for now. There's still a bug.
4015 ae20f2bc1 20151205 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
4015 24cf6f74b 20151208 Set proxy threads to 1.
3865 10491742d 20151220 Merge PR 268 from djoele/master
4015 207e4cfb2 20151208 Eliminated WriteThread. Crash bug seems to be solved.
4015 e3c953042 20151205 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
3865 d15202a9b 20151220 Better way to do this (as suggested by dnpwwo)
4015 39ffefe9b 20151208 Code cleanups.
3865 39de75df9 20151220 Revert "Retry for pull request 221 (avoid vertical scrollbar when viewing graphs
4015 33e8cb472 20151207 Using async_write now. Ssl errors are gone.
4015 a2213148d 20151205 Removed debugging info.
3865 5daacb707 20151219 Retry for pull request 221 (avoid vertical scrollbar when viewing graphs from flo
4015 1703242a3 20151205 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
3865 f3763c7ef 20151220 Kodi script commands extended to include addon execution
4015 7b05e7270 20151205 You can now change Domoticz masters via Proxy or TCP on the fly.
3865 3149ea242 20151219 Merge remote-tracking branch 'refs/remotes/domoticz/master'
3858 040f3031f 20151220 - Implemented: Blockly, now possible to use expressions in notifications/email/SM
3857 cb2d0d381 20151219 - Implemented: Blockly, now possible to send a notification with a user variable/
4015 b673a4b51 20151205 Added defines for pdu handlers.
4015 e14e09197 20151205 Implemented reply::AddHeader also in request_handler.cpp. This was needed for not
3856 bf200f952 20151218 Updated appcache to make previous commit work (otgw version)
4046 d1f6e269f 20151218 Secure RxMessage decoding by removing m_LastDeviceName from m_mainworker instance
3855 c0845ff9d 20151218 Fixed: TE923 fixed sleep calls, changed to usleep
4015 5dcd490f8 20151205 - Additional files committed from merge. - Removed some proxy debugging informati
3854 6b2371daf 20151218 Merge PR 265 from jvandenbroek/master
4015 5ba1aabb3 20151205 Merge with Master.
3854 6a16eafa6 20151218 OTGW and RFXCOM hardware version consistency
3852 58061c067 20151217 Merge PR 264 from gaudryc/fix_selector_switch_feature_merge_issue
3852 396131255 20151217 Fix invalid Selector level if its level equals 100.
3849 27223a16a 20151217 Small change to not remove a cookie when cookie was found
3852 a337f1298 20151217 Fix bad selector deviceid length (Lightning2 deviceid are 7 characters length but
3848 4e40f1f34 20151217 Fixed possible problem with multiple cookies in authentication
3847 8fbc0de8f 20151217 Fixing my previous fix...
3846 8304a015e 20151217 Small correction on previous change (add manual light/switch for new switch type
3845 be4d2cda3 20151217 Small modification for new switch type
3844 768e3a555 20151217 Merge PR 262 from gaudryc/feature/selector_switch
3844 fb6379cd0 20151216 Merge remote-tracking branch 'origin/master' into feature/selector_switch
3844 8ada8a8e2 20151216 Merge remote-tracking branch 'origin/master' into feature/selector_switch
4015 074c827f1 20151205 - Implemented reply::AddHeader function. - not_modified fixes.
4015 c8cf89b58 20151205 Http response 304 support added. Needs additional boost libraries on Windows (boo
3844 c63589f43 20151216 Fix Command column width in Planning
4015 202353067 20151205 Reconnect to slave revisited.
4015 e3be0203f 20151205 Automatic master reconnect after proxy reconnect (needs testing).
3844 3c23f81bb 20151216 Update html5 cache version
4015 8b4666c92 20151205 Sleep between writes (workaround for openssl) only on Windows.
3844 695200ee3 20151216 Merge remote-tracking branch 'origin/master' into feature/selector_switch
4015 83e4b99a3 20151204 Fixed bug, request body is not null terminated.
4015 aee9b2376 20151204 Added extra sleep in between writes for peace of mind of openssl.
4015 a9b464a7c 20151204 Previous version doesnt work due to invalid server ip.
3844 e9c440dc3 20151216 Fix planning feature for Selector Switch
4015 e707ebfea 20151204 - Implemented write queue, WriteThread. - Domoticz hardware also connects if prox
4015 910c7f09d 20151203 Ready to test. More updates to come.
3844 484d6e070 20151215 Fix unreachable code to refresh Selector device specially.
3844 e72616086 20151215 Fix unselected selector device buttons when multiple selectors are displayed on t
4015 e3e19f1bf 20151203 Still has a lot of debugging information.
3844 f82b771d4 20151215 Merge remote-tracking branch 'origin/master' into feature/selector_switch
4015 cf752707f 20151203 Minor change. Not for production.
4015 d42016e0c 20151203 Intermediate commit. Not meant for production use.
3827 9e952d72b 20151216 Merge PR 263 from domoticz/version_with_auth
4015 d7a77b05d 20151203 Merge branch 'master'
3824 e91349eb6 20151216 RFLink: timeout optimization
4086 9c0017ade 20151215 Merge remote-tracking branch 'upstream/master' into proxyroot
3844 97f4a78a1 20151215 Fix multiple selectors display issue
3823 752be3554 20151215 - Implemented: OTGW, added firmware version number in hardware setup page
3844 26d45807d 20151215 Fix merge issue
3844 b817dcc6d 20151215 Check if status and level are equal before switching Selector device where "Only
3822 a7f0b9b19 20151215 Merge PR 261 from jvandenbroek/master
3827 8a7e36752 20151216 Fix misinterpration of rights
3827 b59d665d6 20151215 Return version with successful auth, fix unauthorized getconfig
3844 9bd1316eb 20151215 Check if level value is valid before switching Selector device
4015 cac62f788 20151202 Merge remote-tracking branch 'refs/remotes/origin/master'
3820 5746273b9 20151215 Merge PR 260 from gaudryc/fix_javascript_syntax_error
3844 366c3a998 20151215 Check Selector command
3844 e8d32fb12 20151215 Add some documentation
3820 96dd370e5 20151215 Merge remote-tracking branch 'origin/master' into fix_javascript_syntax_error
3844 beb80f42f 20151215 Add new Selector Switch virtual device : it is like a dimmer with 11 levels, each
4086 b14e5199c 20151215 Merge remote-tracking branch 'origin/master' into proxyroot
3817 a52ec09ad 20151214 Removed datetime stamp when using syslog
3822 ea07f0df6 20151215 OTGW read GPIO A/B status (new firmware feature)
3816 daa647f35 20151214 - Fixed: Manual add LightwaveRF type (DeviceID was wrong)
3815 8da527bd1 20151211 Merge PR 255 from JohnAdders/currentcost
4015 672a3937c 20151130 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
3815 42aad58f5 20151210 fixed initialize of baud rate
3815 f8f12e124 20151210 fixed sending wrong variable
3815 273c62719 20151210 Fix windows build issues
3815 df074ba15 20151210 Add currentcost files to windows project
3815 1188a598c 20151210 Replace space after string
3815 e3f178fef 20151210 remove stray log message
3815 b3b9fa209 20151210 Combine readings into one so that redaing matches what is shown on device
3815 81825ada1 20151210 merge upstream, fix conflicts in hardware ids
3799 70987e61e 20151211 Updated OpenZWave
3798 1fd151226 20151211 Merge PR 256 from hellqvist/poppwallplug
3820 fff4eb4ef 20151215 Fix javascript syntax
3798 5d6934463 20151210 Added OZW config file for POPP Wall Plug Switch Schuko (IP44).
3796 1e61db175 20151210 Merge PR 253 from emms007/master
3796 d20eb3416 20151210 MQTT Implement "Toggle" switchcmd for switchlight
4086 53bf79613 20151210 Merge remote-tracking branch 'upstream/master' into proxyroot
3796 577ebdaa3 20151210 Implement "Toggle" switchcmd for switchlight
3793 c0eec81ab 20151210 Merge PR 252 from lightbullet/master
3793 114b9d69f 20151210 Option to use dymanic and static OpenZwave lib
3793 71266acd7 20151209 Adding new OZW config file for Eurotronic valve
3790 8812cbfec 20151209 Updated translations
4015 807fdf050 20151130 Added version number to login pdu.
3789 cbf19a775 20151209 - Implemented: Log View, added options to display All/Status/Error
4015 98c0d7999 20151130 Merge branch 'master'
3788 5d844b34c 20151209 Solaredge API, now using minus 10 minutes
3815 b091c61bb 20151207 Merge remote-tracking branch 'upstream/master' into currentcost
3787 2bc44f061 20151209 Added new SolarEdge class to CMakeList
3786 c66d3f190 20151209 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4015 f18a02ad7 20151130 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
3784 bbab7d1a5 20151209 Netatmo, using refresh token after a sucessfull login Implemented: SolarEdge via
3786 3c7881eb4 20151209 RFLink: timeout fix
3783 1ea33c123 20151208 Merge PR 251 from bugzy/master
3781 bb3b6a2de 20151208 RFLink: Added Unitec switch support, fixed rain rates and optimized serial heartb
3783 207cdbd51 20151207 Enable dupport for CM19A usb transmitter via mochad
3780 afdfc01f1 20151206 Merge PR 247 from djoele/master
3780 6bdbde232 20151206 Revert change from pull request #221. dnpwwo found that this changes causes part
4222 1c7b8f945 20151205 Merge PR 10 from domoticz/master
3778 63293383f 20151205 Merge PR 246 from szczukot/master
3775 340daf492 20151205 Removed angularjs map dependency
3774 bd5848a5f 20151205 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3815 e9ddfb083 20151207 Add support for baud rate for the CurrentCost serial device
3774 ba70fe495 20151205 Add support for Play command from Events
3772 91f741954 20151205 Updated openzwave configuration files Removed parsing the hardware pointer to the
3815 6e19cd830 20151207 Allow suport for earlier versions of the xml format without sensor tag
3771 43db57273 20151204 - Implemented: Thermosmart option to set specify outside temperature sensor
3815 2a30207ea 20151203 merge master
3770 1591b20e3 20151204 Fixed thermosmart unpause
3769 6f5344bce 20151204 Changes Thermosmart pause action
3768 b4bfd5314 20151203 Changed: Not decrementing switch dim level while sending command
3767 1bd09572f 20151203 - Fixed: Changing device order when selected a Room in the lights/utility tab
3766 4bfe2416e 20151203 When sending commands, set RSSI level to 12 (means '-')
3765 251060a59 20151203 Fixed: Manual add Blyss type had wrong Group code
4015 c0df5ae8f 20151130 Added some comments.
3764 653cddfff 20151203 Added Dummy sensors Wind+Temp+Chill
4015 cabc96039 20151130 Typos.
3763 22f7e0ed9 20151202 added a mutex in TCPServer
4015 bd6084ce5 20151130 Small but important fix.
4015 b58d5b843 20151130 Fixed compile errors on Linux.
3763 afb4c7c98 20151202 Merge PR 243 from gaudryc/fix_tcpserver_stopping_crash_or_stopping_loo
4015 16803e642 20151130 Accessing http://my.domoticz.com/ redirects to Dashboard, when not logged in. Add
4015 aa5d10a34 20151127 Merge branch 'master'
3763 859d36c49 20151202 Stop the shared server before stopping the mainworker.
3763 5da8f7404 20151202 Stop shared server anyway (if port equals 0, stop it but does not restart it)
3758 1bfd60e8c 20151201 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3763 30ba8f7dc 20151202 - delete m_pTCPServer each time the server is stopped ; - delete m_pTCPServer at
3758 58cc5f55d 20151201 Netatmo, added URL Encoding for username/password
3758 633dffbd3 20151201 Merge PR 238 from kerkenit/master
3758 d1744fa8c 20151201 Fixed typo status bar
3758 c98024b5c 20151201 Merge remote-tracking branch 'domoticz/master'
4015 4d76072d5 20151123 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
3815 168418a08 20151203 Remove executable flag
3815 dbfeda31b 20151203 Initial version of support for CurrentCost meters
3742 0d99eef9a 20151201 Added a mutex in TCPServer
4086 ea5a5993e 20151209 Add option to allow adding a webroot to enable domoticz to be proxied
3741 afab87f4b 20151201 OpenZWave: always accept first notification state change
3815 8c5a50f02 20151201 Ignore exe from cygwin build
4015 1b954cdaf 20151127 Started shared server support.
3740 9363f1e51 20151201 Merge PR 230 from sijones/limitlessImprovements
4015 0361cd698 20151126 Resolved bug when closing the tcp socket twice.
4015 55782f405 20151126 Implemtented timeouts.
4015 3aae18c99 20151126 Added debugging code for no-reconect problem.
4015 a2f2be239 20151125 Syncing with master.
3736 759ce5e1a 20151201 Added extra exception check for web server request handler and reading system fil
3735 a15210574 20151130 Merge PR 236 from JohnAdders/master
3735 9f0b94762 20151130 Upped minimum cmake version required to lowest that doesn't have warning and move
3735 810c1fdb0 20151130 Use built in find_library for openssl in MQTT
3735 da2744b06 20151130 Merge remote-tracking branch 'upstream/master'
4015 ba7e93ecf 20151123 Merging with master.
4015 62d8ef029 20151123 Merging with master.
3726 fa52733dc 20151130 Merge PR 237 from gaudryc/fix_deadlock_in_event_system
3778 82e17971a 20151205 [Satel Integra] fix for crc calculating
3726 610ae80a6 20151130 Fix deadlock in EvenSystem by unlocking mutex before calling a method that locks
3778 3cfdb8d5b 20151130 Merge PR 9 from domoticz/master
3724 0fd694186 20151129 Fix for RFY Switch (on/off)
3723 281feb204 20151129 Fix for battery level on linux hardware devices
3722 f2626a6f2 20151129 Added battery value to DecodeRX function
3721 0cf8cc227 20151129 Added number of items dropdown on the uservariables page
3720 765ce2d53 20151129 Merge PR 235 from gaudryc/update_sqlite_392
3718 b7ea20c33 20151129 Merge PR 233 from gaudryc/optimize_queue_item_memory_allocation
3716 5da0c206d 20151129 Merge PR 234 from gaudryc/fix_dumptriggerlevel_option
3714 f8f4e7211 20151129 Updated to allow use of DNS names as well as IP addresses
3716 8c1e6e7bd 20151129 Fix zwave DumpTriggerLevel option name
3720 1d1265f7c 20151129 Update to SQLite 3.9.2
3718 0bed7a814 20151129 Optimize memory allocation
3713 6d4e9daef 20151128 Added mutex in DecodeRXMessage for remote domoticz commands
3712 976f07c09 20151128 Implemented: Waterflow sensor
3740 1223d08ca 20151130 display bug fix
3711 0cc964846 20151128 Implemented: Logging connection attempt from remote domoticz instances
3710 67a381bef 20151128 Fixed compile error under linux
3740 0ec24e5f9 20151127 Merge upstream changes
3709 457d44976 20151128 Changed: Using RXQueue again
3708 bf5fe0ebe 20151127 - Fixed: Month temperature report avarage is now calculated by the daily avarage
3735 c6b3d5eaa 20151130 fixed for cygwin compatibility
3707 bdb612b14 20151127 Openzwave: Updated BeNext doorsensor (test phase)
3706 f973f87d9 20151127 Merge PR 229 from gaudryc/fix_logout_command_response
3735 211b3a193 20151127 Merge remote-tracking branch 'upstream/master'
3704 344356af9 20151127 Merge PR 228 from gaudryc/fix_session_cleanup_delay
3706 f3829917f 20151127 Fix dologout command response to return {"status":"OK", "title":"Logout"} instead
3704 275ad5d0d 20151127 Fix a cleanup issue to clean up every 15 minutes only (not on every method call)
3702 32b8eb8ed 20151127 Merge PR 226 from correa/cmake-cleanup
3700 934e8969d 20151127 Applied patch for session coockies (#180)
3699 dfd9da4dc 20151127 Added mutex in DecodeRXMessage Fixed event system variables
3698 8f9af2226 20151127 Merge PR 227 from Rimco/master
3698 f34337f9b 20151126 Updated serial.cpp for FreeBSD 9 compatibility.
3702 c659f8943 20151126 Include internal zlib as build option and use standard Find_Package for OpenSSL.
3696 5900b4f58 20151126 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3758 14c44c921 20151130 Merge branch 'domoticz/master'
3758 1b0cb81db 20151130 Merge branch 'master' into domoticz/master
3696 bf498526f 20151126 Merge PR 224 from matjoker/patch-2
3696 2ba8b14d7 20151126 Update EnOceanESP3.cpp
3692 b2743dad6 20151126 - Fixed: CMakeList.txt - Fixed: Blockly, Set user variables (you need to resave y
3696 9dac7cf37 20151126 Update EnOceanESP3.cpp
3691 7d2e77019 20151125 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3691 d73f6005a 20151125 Merge PR 215 from arjanwaard/patch-1
3735 5398f496d 20151127 treat cygwin like linux where appropriate
3691 34afb6318 20151125 Merge PR 221 from djoele/master23
3686 95326f40e 20151125 Reverted RXQueue (caused default names not to be set) Netatmo: Faster setpoint re
3735 5c457659c 20151127 quieten cmake when building in cygwin
3758 0c2d0edfc 20151130 Merge remote-tracking branch 'domoticz/master'
3691 0855a3d32 20151125 Fixed the appearing of horizontal scrollbar when viewing a graph from floorplan d
3685 d360720c1 20151125 OpenZWave: Now able to control a MultiLevel switch as basic On/Off switch
3691 c802bfaa9 20151124 Update PhilipsHue.cpp
3735 8b19b0dfa 20151127 fix warning around ssl include on first run of cmake
3684 a2f732cf7 20151124 Fixed: Sending commands from remote domoticz instance
3683 4750cafc6 20151124 - Fixed: Setting user variable from Blockly - Updated Language files
3682 f15088610 20151123 updated js
3758 4ac32d858 20151130 Decreased version number
3758 a250a3380 20151130 Changed tags to minimal data
3681 373e35a10 20151123 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4054 e5363bd3b 20160105 Update MySensorsBase.cpp
3758 5faaea9b8 20151125 Fixed viewport metatag
3679 7dd68bbd5 20151123 - Implemented: Day display in energy/gas/water/temp report
4054 65457a949 20160105 Update MySensorsBase.cpp
3681 2cfaee19f 20151123 RFLink: Added additional devices and fixed meter values
3758 0a5ab1e3d 20151125 Fixed viewport metatag
3758 318357d78 20151125 Fixed device pixel width for iOS devices
4054 2da8a1aca 20151123 Resend failed command
3678 2351e80e3 20151123 Netatmo, allow reconnect
3677 9387c9f49 20151123 Merge PR 211 from correa/hardware-cleanup
3758 0f130f595 20151125 Fixed iPhone 6 image
3677 efba0e52d 20151121 Clean-up access specifiers in DomoticzHardware making private data that is expose
3758 37edcc06e 20151125 Support for iPhone 6 splash screens
4015 24c4f92f5 20151118 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
3677 d9fd79353 20151121 Clean-up DomoticzHardware friends moving member methods and data to protected ins
3758 be772b2ab 20151122 Merge remote-tracking branch 'domoticz/master'
3740 04c363499 20151127 Applamp bug fixes
3674 2e94eb6de 20151121 RXQueue refined Some code cleanup
3673 d51eac5bc 20151121 Merge PR 130 from gaudryc/fix_deadlock_using_rxmessage_queue
4015 952976cf9 20151123 Added proxy tab in dashboard. Temporary commit to see if reconnecting works bette
4015 f8e2346c9 20151118 Merge branch 'master'
4015 38563f646 20151114 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
3640 fbf773899 20151121 Merge PR 207 from correa/master
3638 03eaddb2a 20151121 Merge PR 203 from dwmw2/dynamic
4015 a82e16dfc 20151118 Merge branch 'MyDomoticz' of https://github.com/domoticz/domoticz into MyDomoticz
3634 3bd0e1ebb 20151121 Merge PR 202 from dwmw2/master
4015 30f1ce0fb 20151114 Merge PR 194 from djoele/MyDomoticz
4015 5e312fd13 20151118 Merging www folder of master branch.
4015 6629c95c2 20151114 Merging with master branch.
3673 a1cfe34c2 20151115 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_qu
3628 e9fd1e0aa 20151121 Merge PR 210 from kerkenit/master
3626 b48cd1eb5 20151121 - Implemented: Netatmo, support for multiple Thermostats
3628 4fe90eb98 20151121 Floorplan undefined message
3625 963c83db6 20151121 Changed OZW protection configuration handling
3624 380745485 20151121 - Implemented: OpenZWave, added COMMAND_CLASS_PROTECTION in configuration options
3623 01b0b1c46 20151121 Merge PR 205 from sbouchex/smtpclient_bug
3620 10b69055c 20151121 Remove multiline text artefact left onscreen
3619 7b6da32f3 20151120 Fix for Netatmo hardware configuration after name change (#209)
3618 1bd49fb47 20151120 - Fixed: CM180i graph display
3617 5f45c1904 20151120 - Changed: Fritzbox, Now updating text sensor on connect/disconnect
3616 1a3a4249c 20151120 Merge PR 208 from PA4WD/master
3616 a205171eb 20151119 Fixed html typo's
3638 1338eb9a8 20151118 Add USE_BUILTIN_LUA build option
3616 ef8b23efe 20151119 fixed typo's
3638 616ef67d1 20151118 Add USE_BUILTIN_SQLITE build option
3613 4dea1f465 20151119 Changing reconnect messages
3638 48a2133a2 20151118 Add USE_STATIC_LIBSTDCXX build option to use dynamic toolchain libraries
3634 8ecfb6d8c 20151118 Include CMAKE_CXX_FLAGS when building precompiled header
3612 849c9bafd 20151119 fixed a typecast
3611 e78b57fe5 20151119 Merge PR 206 from sidepipe/master
3634 d09a67f27 20151118 Only add '-static-libgcc -static-libstdc++' to link flags
3623 4ff736e75 20151119 Fixed an issue with smtp client (Removed hostname, it's handled by curl)
3634 07a46aee8 20151118 Remove stray -DPCHCOMPILE from message output
3634 ff54b2b1f 20151118 Use CMAKE_CXX_COMPILER_ARG1 when building precompiled header
3609 fa1bcb415 20151119 making constanst static
3640 c47ed0904 20151119 Add support for Comm5 MA-5x Relay and Sensors hardware
3623 b75081e9a 20151119 Fixed an issue with smtp client (missing FQDN client name)
3611 0cfad882b 20151119 Support multi-inverter mode.
3634 f2dae99ab 20151118 Only use backtrace() for glibc, not all Linux targets.
3608 3aa362f1c 20151118 - Changed: Modified AyncTCP - Implemented: MySensors Ethernet gateway keep alive
3607 44e4515c2 20151118 Merge PR 200 from dwmw2/master
3607 9629fd363 20151117 Escape item names in devices tab
3605 0f6bc3d81 20151117 - Implemented: MySensors Ethernet gateway will now request the gateway version on
3604 2204a62cc 20151117 RFLink: bug fix on unknown command, changed wind speed value
3603 95def9ca6 20151116 Removed debug lines
3602 4e7c10e2a 20151116 - Implemented: Nest Thermostat, support for multiple thermostats
3601 9e8fa331c 20151116 Merge PR 198 from matjoker/patch-1
4015 6810f72fe 20151103 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
3601 3920cd6ff 20151116 Update EnOceanESP3.cpp
3599 837c97349 20151116 Renamed Netatmo Weatherstation to Netatmo (as it also includes the Thermostat)
4015 5d0de4d72 20151103 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
3598 f7b3adf44 20151115 - Implemented: Wind Beaufort scale
3597 a95fe7879 20151115 Implemented: Wind Graph, option to delete a short-log data point
3673 16a09ab90 20151031 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3529 b2855703f 20151101 Merge PR #181 from gaudryc/add_daemonname_and_pidfile_arguments
3673 6a7dd74b7 20151030 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3527 54ceb5528 20151101 Merge PR #180 from gaudryc/fix_core_while_cleaning_sessions
3525 b1a44f76f 20151101 Added degree days header in temperature report
3524 3e82bbfdc 20151101 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3541 f0dd7c898 20151031 Fix for reloading totals of S0PCM5
3524 a5617b79a 20151101 Added playlist lua functionality to Kodi devices
3522 7390a2c1f 20151101 RFXCom, support for Home Confort TEL-010
3529 5c9afdbc0 20151101 Add the daemon name and pid file path to the daemon arguments to allow multiple instances t
3527 0f6cb67c9 20151101 Fix segmentation fault while cleaning timed out sessions
3521 ea4b80a94 20151031 Tagging release version #3.521
3520 7034da52b 20151031 Changed update values to integers
3519 b6f404c08 20151031 Removed total uptime in seconds because of json problem under linux
3518 6a4e02a91 20151031 Updated translations Added uptime in about page
3517 1f332c3a5 20151031 Merge PR #173 from gaudryc/fix_denial_of_service_caused_by_stalled_sessions
3517 a9c60721d 20151030 Merge remote-tracking branch 'origin/master' into fix_denial_of_service_caused_by_stalled_s
3673 d739a1046 20151027 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3507 7334d35d3 20151031 Implemented IP address when loging in the system
3506 f8d6ad7ca 20151031 Fix previous fix
3673 75a6b3841 20151026 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3505 5b3823d46 20151031 Fixed type cast issue in GCC
3504 e346b6465 20151031 Fixed sending SMS notification from lua/blockly (one or multiple destinations)
3503 f45b486cf 20151031 Mobile dashboard: Added more log options Mobile dashboard: Option to set setpoint
3544 a123242bc 20151031 Make log timestamps optional
3502 25eeb1a3e 20151030 Removed lua cleanup (might cause a crash some how!?)
3501 e6b8a7a06 20151030 EventSystem, optimized Blockly calls (saves a lot of calls and cpu) - Fixed:
3500 20f0ff749 20151030 Lua, added otherdevices_weather and ###_Weather variables
3499 3c31e0a9f 20151030 Implemented: EventSystem now also reacts on master switches when a slave switch state chang
3498 4758ef53d 20151030 Oeps... removed debugging in weather underground
3497 bc682d2c0 20151030 Eventsystem/Blockly now supports Weather sensors: UV/Distance, Wind Gust (or speed when gus
3496 f15ff4f17 20151030 EventSystem/Blockly fixed pTypeThermostat
3495 747bdebed 20151030 Added json variable 'CounterToday' for kWh sensors when no daily value has been recorded ye
3494 e55990137 20151030 Fixed blockly uservariable usage in new method
3517 999a5036b 20151028 Move cWebem::nextSessionCleanup attribute from public nextSessionCleanup to private myNextS
3517 77c059f25 20151028 Optimize the call to the method mytime
3493 2ac25d2a1 20151029 Brining back blockly old utilties variabled for people who used the old method
3517 d600da118 20151028 Move cWebemRequestHandler::cleanTimedOutSessions() to cWebem::CleanTimedOutSessions, and cl
3492 30ff19c73 20151029 TCP, Better disconnect
3517 db7f34104 20151028 Add timeout to session to be able to clean session list (Part 2)
3491 66e06df5d 20151029 Added support for RFLink over TCP (ser2net)
3490 c6e65fd23 20151029 Merge PR #175 from domoticz/HttpHeadRequests
3517 3b82d16d9 20151028 Add timeout to session to be able to clean session list
3517 ff10b9549 20151028 Remove session database if cookie/token has expired
3673 a3cff34f7 20151025 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3488 f9161551e 20151028 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3517 a1030ccbc 20151028 Prevent from spoofing expiration time
3517 da0f2236a 20151028 Check token expiration while restoring session
3488 5fa8e372d 20151027 Merge PR #171 from szczukot/master
3488 6fdf06fd0 20151027 Merge PR #8 from domoticz/master
3488 e95222f0c 20151027 Merge PR #170 from ToniA/beta
3481 89ae9285d 20151028 Updated Openzwave Fixed MQTT uservariable bug (idx not found message)
3480 bf537fac9 20151027 Merge PR #169 from ToniA/beta
3488 07ed19ffb 20151026 Fix cURL command line to upload multiple files at once
3480 b32cafe44 20151026 Fix environment variables
3874 21f292d46 20151026 Merge PR #106 from domoticz/master
3478 1817e1c47 20151027 Merge PR #168 from ToniA/beta
3478 cb10b88cd 20151026 Create checksum, history and version files on Travis-CI builds
3476 17e768644 20151026 Removed obsolete .svn exclusion in build scripts
3475 e72ac1b08 20151026 Merge PR #167 from ToniA/beta
3475 e9dde8469 20151026 Merge remote-tracking branch 'upstream/master' into beta
3472 eb60d31f8 20151026 Merge PR #166 from ToniA/beta
3475 d64f35f5e 20151026 Fix domoticz.tar creation for OSX
3472 a836a9034 20151026 Change Windows artifact name
3470 cf0e3226e 20151026 Merge PR #165 from ToniA/beta
3470 8eb6d3cd1 20151026 Fixed Travis-CI FTPS URL, Appveyor to use an environment variable as FTP password
3468 116782627 20151026 Updated SQLite Changed file reader in request_handler
3467 55bcd7f97 20151026 Merge PR #164 from ToniA/beta
3673 b439be350 20151024 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3467 a33241930 20151025 Windows installation package name change, CI build FTP deployment to 'beta' directory
3465 6fde251d0 20151026 Merge PR #163 from szczukot/master
3488 469bc0984 20151027 Merge branch 'master' of https://github.com/szczukot/domoticz.git
3465 f87c8f28f 20151025 Merge PR #7 from domoticz/master
3462 ff862227d 20151025 Updated travis file
3461 bf782532a 20151025 Updated appveyor file
3460 f9b2800b5 20151025 Updated travis configuration Sorted History
3459 9bdbc518f 20151026 Merge PR #160 from ToniA/master
3456 72e662e92 20151025 Blockly, some devices values can now be stored directly into a uservaribale
3455 a95890312 20151025 Blockly, Option to compare sensor value against another sensor value
3454 848c7ba93 20151025 Merge PR #162 from CyberClwn/patch-1
3454 6f99a5c46 20151025 Update download_update.sh
3452 edd46c9c6 20151025 More user rights checking
3451 28a4de60c 20151025 Requesting cameras now only enabled for admin users
3459 eba83a920 20151025 .travis.yml, add the domoticz/domoticz repo into deployment conditions
3673 e0616c7cf 20151022 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3450 43bffdea7 20151025 Checking security rights for certain pages
3449 e6a6bcd3e 20151025 Logwindow, Added option to filter text Blockly, Split Utility Sensors into multiple groups
3459 cb40b4d39 20151025 Refactor .travis.yml, add stub for FTPS deployment
3448 9b26d808e 20151025 Logitech Media Server: Add support for User Authentication on LMS server (EddyK69)
3447 e15b99463 20151025 Displaying MySensor gateway version in hardware setup
3446 803b9ff88 20151025 Renamed example rain prediction script MySensors now using ACK
3445 c32bff996 20151024 Changed appveyor settings
3444 d546d821b 20151024 Added arabic/hebrew language to git
3443 2b9bc1183 20151024 Added new sound class for SecPanel
3442 41c4cde6a 20151024 Fix for security panel audio (bringing back the media sound files)
3441 d8e2efe1d 20151024 Fixed error in UpdateHardware (caused by logitech media server change!)
3440 70b90960a 20151024 Removed debug in thermosmart
3439 946c61348 20151024 Changed appveyor template
3438 d8189d91c 20151024 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3673 92fb5688a 20151021 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3438 1d94d916b 20151024 Merge branch 'master' of https://github.com/domoticz/domoticz
3435 40e816c27 20151024 Added Pause switch for thermosmart
3434 bd23a1107 20151024 Hebrew translation (big thanks to mickeyv!!) Arabic translati
3433 b6519121d 20151024 Merge PR #157 from ToniA/appveyor
3433 c99d9cf03 20151023 Appveyor build artifact upload to deployment server, add a newline to the end of the last l
3874 ef98b0181 20151022 Merge PR #101 from domoticz/master
3438 e67b80632 20151024 Add 'Set Volume' support in lua
3433 cb2a2df1c 20151023 Appveyor build artifact upload to deployment server
3673 d6f25199d 20151021 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3430 570a6466d 20151022 Merge PR #153 from gaudryc/refactor_cWebemRequestHandler_handle_request_method
3427 24795c88b 20151022 Merge PR #154 from EddyK69/lms
3427 1cfe133a3 20151021 Merge PR #100 from EddyK69/lms-dev
3427 d60073d6b 20151021 Merge PR #99] from EddyK69/master
3430 37d4bb968 20151021 Merge remote-tracking branch 'origin/master' into refactor_cWebemRequestHandler_handle_requ
3427 280cba1da 20151021 Merge PR #98] from domoticz/master
3419 4bcd0415d 20151021 Merge PR #152 from gaudryc/fix_long_term_authentication_cookie_2
3419 fe5c1408d 20151021 Comment out "user authenticated" log
3419 d8454d50b 20151021 Fix missing session.expires while restoring session.
3419 afbe1687f 20151021 Fix LastUpdate field not updated
3419 cedb39ec9 20151020 Remove expired user sessions while web server is intializing.
3419 a4d71227c 20151020 Log debug in _DEBUG mode
3430 a8bc34387 20151021 Refactor the handle_request method to have only one place to do authentication and clarify
3419 589564087 20151020 Fix comments
3412 59d9bf477 20151020 Merge PR #149 from szczukot/master
3488 de418ebfa 20151027 Fix for events u
3465 b5828faa9 20151025 Add event handle for sTypeAlert
3412 8157b89bc 20151020 [Satel Integra] Another fix for ATD100
4015 b6b79281b 20151029 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
3412 9a3bf659b 20151020 Merge PR #6 from domoticz/master
3409 17c1d2ed6 20151020 Removed authenticated log
3408 56f3eb822 20151020 Small error correction on web session restore only display log messaged when in debug mode
3407 f2157b6d6 20151020 Merge PR #148 from gaudryc/fix_long_term_authentication_cookie
4015 d7826a5ea 20151029 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
3407 4529acf67 20151020 Remove unnecessary log
3407 da930618e 20151020 Restore session if missing
4015 7671cbac5 20151016 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
3407 b4fb7dd47 20151020 Reduce RemoteHost max length to match IPv6 max length (45).
4015 c0d7a3584 20151016 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
3407 93c476656 20151020 Add remote_host to session and storedSession
3407 775005dc9 20151020 Add the interface session_store to allow a cWebem instance to save/restore user sessions.
3401 58d5fbd5a 20151020 Merge PR #147 from szczukot/master[https://github.com/domoticz/domoticz/pull/ V2
3401 4bce5db47 20151019 [Satel Integra] fix for ATD100
3401 25b739f6c 20151019 Merge PR #5 from domoticz/master
3397 473d98ffe 20151019 Removed debug for toon
3396 d28b0e522 20151019 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3427 90f39b95e 20151021 Logitech Media Server: Add LUA Playlist support
3394 755c8a908 20151019 Initial test for toon users (only usage 1/2 at the moment) with new firmwares
3396 3f8d36172 20151019 RFLink: additional devices added
3427 e2ae888f3 20151019 Merge PR #97 from EddyK69/lms
4015 9c47fc6b7 20151029 Merging with master branch.
3393 74f71fc39 20151019 Updated Openzwave
3392 6ddfa7d2d 20151019 Removed debug alert message in the ultity tab
3427 5ad1a1861 20151019 Merge PR #96 from EddyK69/master
4015 3733be81a 20151029 Merging with master
3427 793e73fc3 20151019 Merge PR #95 from domoticz/master
4015 44ab3d85d 20151016 Changed default values of maxinstances in WebServerHelper.cpp. Removed some unused code in
3391 2f4d60c73 20151019 Updated translations
4015 f61f56b48 20151016 Reduced amount of log lines. Fixed subsystem differences.
3390 c5a724c10 20151019 Fixed correct session deletion when logging out
3673 9ecf94cc5 20151018 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3389 426c48b06 20151019 Fixed special characters in comments
4015 1aa4e1c83 20151016 Syncing master branch.
3388 a25a8c33e 20151019 Merge branch 'gaudryc-fix_webserver_design_issue'
3673 20c9f225b 20151018 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3388 34d2550f3 20151018 Merge remote-tracking branch 'origin/master' into fix_webserver_design_issue
3388 5f84eb02d 20151018 Merge remote-tracking branch 'origin/master' into fix_webserver_design_issue
3388 7623b8fec 20151018 Merge remote-tracking branch 'origin/master' into fix_webserver_design_issue
3373 82acf3b86 20151018 WU log when started
3372 dfb7f0e85 20151018 Removed debug line
3371 a72d82771 20151018 Fix for MySensors presentation handling
3370 d1202bf86 20151018 Fixed graph for Current/Energy (revolt) sensors
3369 4d60c1d0f 20151018 Another update for mysensors setup
3368 ef3a46096 20151018 Small update on mysensors setup
3367 fd6648240 20151018 If signal level is 12 (not from an RF sensor, or from a sensor that does not support RF s
3366 328d0441d 20151018 Merge PR #145 from EddyK69/lms
3673 04b83d709 20151014 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3366 fe018eff8 20151017 Logitech Media Server: Add iPeng iPad support
3364 797065b35 20151017 Merge PR #144 from EddyK69/lms
3364 6b9d96507 20151017 Update appcache
3364 d4d940b19 20151017 Merge PR #94 from EddyK69/lms-dev
3388 3b87ae04b 20151018 Replace static method access.
3388 3bd20e834 20151018 Fix static issues
3673 98995eae1 20151014 Make concurrent_queue and queue_item_trigger non copyable
3388 79978058c 20151016 Move cWebem::myNameValues to request::parameters
3388 accd232a3 20151016 Move cWebem::m_outputfilename to WebEmSession
3364 5ba393512 20151017 Merge PR #93 from EddyK69/master
3673 4dcaea3fc 20151013 Use _DEBUG to enable/disable RxMessage queueing debug
3364 e4c9ff9d9 20151017 Merge PR #92 from domoticz/master
3388 7ee79fa76 20151016 Rename cWebem::m_sessionids to m_sessions
3673 1171b532a 20151013 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3388 4fefac125 20151016 Merge remote-tracking branch 'origin/master' into fix_webserver_design_issue
3388 dd707ad40 20151016 Move all current user to the WebEmSession structure ; - Add WebEmSession to command and a
3355 60b0f3314 20151017 Corrected previous rfxsensor AD/Volt sensor value (should have been a multiply)
3364 ff189a7d3 20151017 Fix: Misc. Logitech Media Server fixes
3354 f73f3effd 20151016 Corrected RFXSensor AD/Voltage
3388 ae2d4fa21 20151015 Remove attribute cWebem::m_guestuser because it is always empty (not used)
3673 16b8f761c 20151013 Add the class queue_element_trigger allowing to wait for the message to process ; - By de
3364 a93f14ad3 20151014 Merge PR #91 from EddyK69/master
3673 507b6460c 20151013 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3388 42be1d47b 20151015 Replace cWebem::m_actsessionid with request::session::id
3353 290c21fcf 20151016 Openzwave updated config files/cp
3388 f949c831c 20151015 Add http_session attribute to the request
3364 77ea39592 20151014 Merge PR #90 from domoticz/master
3352 4bc50e68a 20151016 Fixed code line ending in OWFS Fixed security panel audio
3388 4b16966d4 20151015 Add request argument to all commands, rtypes and actions (keep working, it just change meth
3351 04229105f 20151015 Fixed distance sensor in devices display Added missing include in header
3350 914a36a7e 20151014 Merge PR #141 from ToniA/master
3673 d9e30904d 20151013 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3347 b835f2453 20151014 Corrected security panel sound (and the bug that was introduced by it)
3350 cad22392c 20151013 Merge branch 'master' of https://github.com/domoticz/domoticz
3346 7b4a16110 20151013 Updated windows build script Now using 7z instead of zip for the windows libraries (saves 4
3345 dcc5a7db1 20151013 Windows, updated to Boost 1.59
3344 58b29a917 20151013 Windows, Updated libcurl/openssl, removed openssl dll library dependency
3350 4dba4d69c 20151013 Experimental OSX & Linux matrix build on Travis-CI
3343 fcc41c073 20151013 Travis back to boost 1.55 (no newer version allowed)
3342 b955dea8a 20151013 Updated travis to use boost 1.56
3341 30c9bf15d 20151013 Another implementation try for travis
3364 b0f185be7 20151013 Merge PR #89 from domoticz/master
3340 b0028acf3 20151013 Updated travis to use boost 1.56
3401 d6f4f8354 20151012 Merge PR #4 from domoticz/master
3339 11ef66a87 20151013 Updated openzwave config files Fixed translation problem in Meter setup Removed debug messa
3338 ca2a41ab6 20151012 Updated language files
3337 729ddb2a1 20151012 Merge PR #138 from EddyK69/lms
3337 538d26805 20151012 Merge PR #88 from EddyK69/lmsnotify
3337 c251e8a40 20151012 Update appcache
3337 7ee75c279 20151012 Merge PR #87 from EddyK69/master
3673 f79b3300e 20151012 Force the queue to unlock while the server is shutting down ; - Manage the empty message
3673 d81f03665 20151012 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3337 ceac5ec95 20151012 Merge PR #86 from domoticz/master
3307 03de879e2 20151012 Easing component heartbeats
3306 cc029b1b0 20151012 Hardware Monitor (Windows) added warning log message when OpenHardware monitor is not insta
3305 ab17eb08d 20151012 Hardware Monitor (windows) now always starting worker thread for heartbeat message
3673 84044e438 20151011 Fix Appveyor and Travis CI checks because they use older version of Boost that does not sup
3337 461e86e35 20151012 Merge PR #85 from domoticz/master
3673 e060ecfd6 20151011 Replace std::vector<unsigned char> with RBUF (ie. array of unsigned char) because std::ve
3304 ba4543406 20151011 Merge PR #137 from domoticz/fix_incorrect_string_compare
3673 e71282442 20151011 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3304 2b08b0c27 20151011 Fix incorrect string compare
3302 263162ec9 20151011 Added Voltage/kWh graph to floorplan
3301 0e025b1b5 20151011 Merge PR #136 from domoticz/fix_missing_favorite
3301 62cb52ae7 20151011 Add check for Device Type
3299 3355909d4 20151011 Merge PR #135 from szczukot/master
3299 4456a419d 20151010 [Satel Integra] Changes for ATD100
3299 5d000f015 20151010 Merge PR #3 from domoticz/master
3295 6b97265e5 20151010 Fixed typo in HardwareBase
3294 3f5d5ff3b 20151010 Merge PR #134 from ToniA/master
3294 df12e7649 20151010 Merge branch 'master' of https://github.com/domoticz/domoticz
3337 ebd6c8e32 20151009 Merge #84 from EddyK69/lmsnotify
3337 58de53292 20151012 Added new models / Added 'Disconnected' state
3337 4d661e0df 20151009 Updated appcache
3291 2d037eee8 20151010 Merge PR #133 from ToniA/travis
3337 febbeb89a 20151009 Added SetVolume/Changed AUDIO->PLAYING
3294 b6f6e374e 20151010 Travis-CI should not have artifact definitions if there are no upload targets
3337 440acbead 20151008 Add Blockly event triggering & Set Event capabillity
3291 e74a5c234 20151010 Travis-CI tar content definition
3337 b414ecd32 20151008 Merge PR #83 from EddyK69/lms
3288 517156121 20151010 Merge PR #132 from ToniA/master
3291 fceb604ad 20151010 Travis-CI artifact definition, also just attempt to build the master branch
3337 727cb2163 20151007 Solved compile error
3288 73ac8faa4 20151010 Dashes instead of underscores in Appveyor artifact name
3337 06c4d74e0 20151007 Merge PR #82 from EddyK69/lmsnotify
3285 b3223363f 20151010 MySensors, now accepts semicolons in payload
3288 6dded0036 20151010 Create Windows installer ZIP, update README with build status descriptions
3284 f53eab518 20151010 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3337 d69e8e4d7 20151007 Update appcache
3337 e6a7291e8 20151007 Added Stopped state
3284 7f961ac9a 20151009 Update README.md
3337 0bf2fca57 20151007 Merge branch 'lmsnotify' of https://github.com/EddyK69/domoticz into lmsnotify
3284 fd48197ab 20151009 Update README.md
3281 8c3149185 20151010 Add indexes to log tables
3673 6b35f1521 20151009 Merge remote-tracking branch 'origin/master' into fix_deadlock_using_rxmessage_queue
3337 a1e8e3648 20151007 Merge PR #80 from EddyK69/master
3280 15ca56b9e 20151009 Updated appveyor.yml
3279 81cef6f4f 20151009 Making openzwave thread safe
3299 1357a7ee7 20151009 Merge PR #2 from domoticz/master
3278 65e4319b0 20151009 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3278 d68477f57 20151009 Merge PR #129 from ToniA/master
3278 5ac808ab3 20151008 Add an empty line at the end of appveyor.yml
3673 6569b1f3d 20151009 Make a defensive copy of unsigned char All_commits
3278 0853b0a76 20151008 Fetch the whole Git history to have the correct Domoticz version number
3278 f141c41c4 20151008 Travis-ci.org and appveyor.com build scripts
3673 d27df017c 20151008 Fix deadlocks between the thread calling the function MainWorker::DecodeRXMessage and the t
3273 4e0376367 20151009 PiFace, corrected line ending in header file Hardware Monitor (Motherboard Sensors) is now
3272 3bed32e2f 20151008 Removed compile warning for unused exception variables in release mode better logging when
3271 24aca05ae 20151008 Merge PR #126 from EddyK69/fix_reloadnotifications_devicedelete
3337 ec4d4af93 20151007 Merge PR #81 from EddyK69/master
3271 1d0bcf7a6 20151007 Fix: Reload notifications after deleting device
3271 d69143f33 20151007 Merge PR #79 from domoticz/master
3268 849cbb102 20151007 Shutdown crash fix
3267 e77cce59a 20151007 Settings/Log, option to clear all short-log data Settings/Bac
3266 6237ae23b 20151006 Merge PR #124 from EddyK69/lms
3266 90096050a 20151006 Update appcache
3266 0ad3fff90 20151006 Merge branch 'lms' of https://github.com/EddyK69/domoticz into lms
3266 aaa713b91 20151006 Merge PR #78 from EddyK69/master
3266 7bb1431cc 20151006 Merge PR #77 from domoticz/master
3260 62b212e1e 20151006 Merge PR #115 from domoticz/fix_user_query
3257 33a966db4 20151006 Switch from RFXtrx.h constants to hardwaretypes.h
3256 f4c44e568 20151006 Fix for shortlog
3255 29f67c46a 20151006 Corrected a possible crash when update device was called without a valid hardware id fixed
3266 b2b7cd6a4 20151006 Fix: Logitech Media Server: Use MacAddresses as unique ID...
3254 a4d5b5ea0 20151006 Merge PR #120 from EddyK69/lms
3254 98e4d609a 20151005 Logitech Media Server: Enabled Boom & SqueezePlay
3254 c7094d90c 20151005 Merge PR #76 from EddyK69/master
3254 35dcbe46f 20151005 Merge PR #75 from domoticz/master
3250 08c516d67 20151005 Updated angularjs
3249 f03ea23ed 20151005 Display hidden scenes in Blockly
3248 f6ce9398d 20151005 Merge PR #117 from EddyK69/lms
3248 2178ee35e 20151005 Fix: Logitech Media Server: wrong status other device...
3248 b5598de41 20151005 Merge PR #74 from EddyK69/master
3248 803c9ebb4 20151005 Merge PR #73 from domoticz/master
3242 be551a3c1 20151005 Merge PR #118 from gaudryc/fix_security_issue_on_predictable_session_id
3242 80385c093 20151005 Fix a critical security issue on predictable Session IDs.
3240 a05488b4b 20151004 Typo correction for previous patch (sorry)
3239 563b7e0da 20151004 Fixed previous patch
3238 0557b721e 20151004 Better memory usage calculation under linux
3260 15b4f3906 20151004 Show the PlanID
3237 0a1d745aa 20151004 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3260 1e6edd2a6 20151004 Fix query and possibly empty order
3237 145553590 20151004 Merge PR #114 from szczukot/master
3237 0af6d5959 20151004 [Satel Integra] fix for ATD100 devices
3237 79a50254b 20151004 Merge branch 'master' of https://github.com/szczukot/domoticz
3237 d15618000 20151004 Merge PR #1 from domoticz/master
3230 ad2e21ef9 20151004 Fix for Current sensor with negative values (sTypeCurrent)
4015 abd2fb545 20150927 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
3229 abb715c18 20151004 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3227 b4dab8b74 20151004 Updated OZW config files
3229 a1f82bd11 20151004 Add set event capability to Media Players
3237 6ee035781 20151002 Merge branch 'master' of https://github.com/szczukot/domoticz
3226 1954b6572 20151003 Add Blocky event triggering
3225 482aa099f 20151002 RFLink: Fixed manual device add panel test button for ARC
3224 94f98e13e 20151002 Merge PR #113 from domoticz/silence_the_osx_build
3224 fbf8c95c8 20151001 Silence the build on OSX The large amount of warnings is obscuring a failing build Although
3337 f535834ff 20151005 Added play & pause states
3337 dcdb3f138 20150929 Merge PR #72 from EddyK69/master
3221 b17ed7b7b 20151002 Added debugging switch to aid troubleshooting
3224 4da74fb60 20151001 Boyscout (dangling else warning resolved)
3220 ba28762e8 20151001 Add logs for Alert type in domotczdevices.js (thanks to fantom)
3219 ba99feffb 20151001 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4015 d1258c56f 20150927 Merging master branch.
3219 743193fd4 20151001 Merge PR #112 from szczukot/domoticz_fantom
3215 fa2bad8c8 20151001 Fixed sql query in openzwave hard reset controller
3214 ae3290713 20150930 RFLink: added support for additional protocols
3213 c14fc86cf 20150930 Corrected kwh meter for mysensors
3212 ffee11035 20150930 Added global function to detect if sensor is a light/switch
3248 a4b7a149c 20150929 Merge PR #71 from domoticz/master
3211 191d47434 20150930 Merge PR #111 from xs4/mqtt
3211 7bd4b6b84 20150929 MQTT: add switchType in output message
3209 7c77a94f0 20150929 Merge PR #109 from domoticz/hide_hidden_scenes
3337 07caab400 20150929 Resolve merge conflict
3209 aa617ed0b 20150929 Skip scenes with names starting with $
3337 9cbecb1e3 20150929 Added basics for LMS notifications
3337 8731c5a10 20150928 Resolve merge conflict
3207 431d581f5 20150929 Dphttp.html added missing select/td end tag added counter creation back for dummy sensors
3206 cc8b81ace 20150929 Merge PR #108 from EddyK69/pushover_recipient
3204 72832cfd4 20150929 Fixed typo in meter settings
3203 792a26058 20150929 Partly rollback of PR #76
3337 763b1e325 20150928 Merge PR #70 from EddyK69/master
3202 c87c4afc2 20150928 MySensors using new kwh meter
3201 fdc3b2023 20150928 Correcting spelling
3248 d7e480063 20150928 Merge PR #69 from domoticz/master
3200 95e083a87 20150928 Dummy Hardware, Ampere Single (single ampere value, other ampere sensor expe
3199 997555f90 20150928 Merge PR #105 from EddyK69/pushover_recipient
3206 339325dee 20150929 Fix: Pushover add Device parameter
3199 40de7e529 20150928 Added option to add device notification parameter
3199 81b1bd8ef 20150928 Added option to add device notification parameter
3199 cf66f8c16 20150928 Add option to choose device/apikey
3199 cd4c857a4 20150928 Add option to choose recipient/apiuser
3199 2441b64e2 20150928 Merge PR #68 from domoticz/master
3192 c91ba4b3c 20150928 Patch for i18n correction in meter setup
3191 09c3fbeac 20150927 Fixed counter incremental water display and icons
3190 2a66aaef3 20150927 Updated language files
3189 7f877a78e 20150927 Merge PR #103 from gaudryc/fix_kwh_units_in_device_graphs
3189 65863d16d 20150927 Fix Energy units in day and week graphes, Power label in day graph.
3187 1916eb310 20150927 Fixed PhilipsHue (when using new firmware)
3186 024305ab0 20150927 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3186 1f736ec24 20150927 Add Media Notifications
3184 1d89ed2e4 20150927 Always allow new hardware when creating dummy sensors
3490 0a73895e6 20151029 HEAD requests do not return response body anymore.
3183 35b576d45 20150926 Corrected kwh update script
3182 50cc00781 20150926 Fixed voltage graph display from dashboard
3181 379e1707f 20150926 Pvoutput now uses directly the new kwh sensor updated translations
3180 a7b6649ad 20150926 Option how to display the kWh day graph (Power or (k)W/h)
3179 fac7d55a7 20150926 Merge PR #101 from xs4/mqtt
3337 ae4d3443a 20150925 Merged with master
3179 301975e1f 20150926 MQTT: report updates on virtual devices
3177 ae924d41a 20150926 Updated angular/ui-bootstrap
3176 15b542bf1 20150926 Fixed graph display for CM180 CM180 display counter in kWh instead of Wh
3337 19cd472e0 20150925 Merge PR #67 from EddyK69/master
3175 0ebd64063 20150926 Merge PR #100 from xs4/mqtt
3175 aa9fca3a8 20150925 MQTT: fix double message after broker restart
3199 52529b90a 20150925 Merge PR #66 from domoticz/master
3173 42aada020 20150926 Fix disconnect race condition
3172 22cdfb131 20150925 Merge PR #99 from EddyK69/lms
3172 cf6f0cb42 20150925 Revert PAUSED-state (not relevant)
3172 d0c705fe0 20150925 Add icons for LMS player
3172 e966bf929 20150925 Merge PR #64 from EddyK69/master
3172 37edf4b79 20150924 Merge PR #62 from EddyK69/master
3172 66b9da067 20150923 Fix left/right arrow & Split play/pause buttons
3172 ab840656f 20150923 Fix issue with ", Level: x x%" after titles
3172 19def0d94 20150922 Fix year (0) & code cleanup
3172 bf1c9bca4 20150922 Merge PR #60 from EddyK69/master
3172 de2377dc4 20150922 Fixed compile warnings
3172 1414d823f 20150922 Removed unused code
3172 5644fd7fc 20150922 Added new models & changed artists-fields
3172 6885234d7 20150921 Merge PR #58 from EddyK69/master
3337 18b335ef3 20150925 Merge branch 'lmsnotify' of https://github.com/EddyK69/domoticz into lmsnotify
3337 673c70337 20150925 Merge PR #65 from EddyK69/master
3172 b3d24ead0 20150925 Merge PR #63 from domoticz/master
3237 fb4231aff 20150929 [Satel Integra] changes on ATD100
3219 cbf5831cf 20151001 [Satel Integra] changes for ATD100
3337 25d27e020 20150924 Initial LMSNotify code
3119 e9f98736f 20150925 Fixed CustomImages support
3172 826f66756 20150924 Merge PR #61 from domoticz/master
3219 01bb15e0f 20150925 Merge PR #19 from domoticz/master
3118 3d24d61ae 20150925 Merge branch 'master' of https://github.com/domoticz/domoticz
3172 e7fd87122 20150921 Final commits
3118 0d614677e 20150925 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3115 eb4a42345 20150925 Add media player notifications
3172 9ca72111c 20150921 Merge PR #56 from EddyK69/master
3114 970a29a49 20150924 Change default port to 9090
3118 20110a5fb 20150925 Fixed ID display of text sensor
3113 395f447a7 20150924 Better support for MySensors text value
3112 5d2fdfa45 20150924 Fixed kwh graph display caused by previous git pull request (now displays 5 minute history
3172 d3613f177 20150920 Correct merge-conflict
3111 3914f864c 20150924 Merge PR #95 from szczukot/master
3172 aa9cc208d 20150920 Merge PR #54 from EddyK69/master
3111 2855da847 20150923 [Satel Integra] increased amount of logs
3111 6641c5d34 20150923 Merge PR #18 from domoticz/master
3107 2a1600393 20150923 Merge PR #84 from xs4/mqtt
3172 d007f2841 20150920 Change for merge-conflict
3107 4e0cfd0a0 20150923 MQTT flat mode is default
3107 8308ac8dd 20150923 MQTT: on upgrade preserve original settings
3172 5703b0315 20150920 LMS
3101 e6711c7cb 20150923 Merge PR #93 from gaudryc/remove_rfx_file_buffer_from_class_attributes
3172 d2854f4a3 20150920 LMS remote
3107 1ea0b6a40 20150923 Merge remote-tracking branch 'origin/master' into mqtt
3172 edec58608 20150919 LMS remote
3172 696eb11b8 20150919 Merge PR #52 from EddyK69/master
3098 a54984c3a 20150923 Merge PR #94 from domoticz/server_version_with_login
3172 024358151 20150922 Merge PR #59 from domoticz/master
3098 7e27a048a 20150923 Ignore osx, backup and Zwave config files
3101 e5577e855 20150922 Fix std::map reference argument :-(
3098 a1b50e788 20150923 Add server version to JSON logincheck response To facilitate enabling features in client ba
3172 e0397965d 20150921 Merge PR #57 from domoticz/master
3095 bc08bf81b 20150922 RFLink: Added Dim and Bright support
3101 7bdb00811 20150922 Remove the attribute m_Firmware_Buffer from RFXComSerial class in order to update RFX firmw
3094 1bd51bfe2 20150922 Kodi backend moved to asynchronous
3093 bdf47b0e1 20150922 Mysensors, more work on default naming
3092 b8ad67509 20150921 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3092 e8ac9f601 20150921 Merge PR #87 from gaudryc/force_brute_force_attack
3092 6661a69be 20150921 Merge PR #88 from gaudryc/fix_Prowl_log
3092 c711d2eb0 20150921 Merge PR #89 from gaudryc/force_value_graph_for_energyCM-generalKWH_devices_with_
3172 be0beb011 20150918 Merge branch 'lms' of https://github.com/EddyK69/domoticz into lms
3092 d04b0af85 20150921 Merge PR #90 from gaudryc/show_0_values_in_GeneralKWH_device_day_graph
3172 0a723d74e 20150918 Merge PR #50 from EddyK69/master
3083 4db8db0a8 20150921 Updated history file
3082 c76ebf49b 20150921 Fixed previous patch
3172 5904d23c0 20150921 Merge PR #55 from domoticz/master
3081 e97e214e4 20150921 Allowing more http post content types
3092 ca09e6281 20150921 Log brute force attack
3092 ba293d4ef 20150921 Fix error log while retrieving Prowl result code
3092 acd9551cb 20150921 Show "no consumption" values in General/kWh device day graph
3092 065258875 20150921 Force Energy/CM### or General/kWh device to display Value graph even if it has Usage
3080 6da7d9d29 20150921 RFLink: added more device types
3172 f59d82e43 20150920 Merge PR #53 from domoticz/master
3111 d6c52054c 20150920 Merge PR #17 from domoticz/master
3079 a46628e8f 20150921 Fixed openzwave kwh sensor (when no power sensor is used)
3078 49fef98ed 20150920 Merge PR #83 from tofra/master
3075 136e1a0d5 20150920 Merge PR #85 from EddyK69/fix_pushon_pushoff
3078 c6f5916ad 20150919 Corrected CMakeLists, and removed the database changes
3075 b28485184 20150919 Fixed PushOn PushOff commands on Floorplan
3107 50a3fe49f 20150923 MQTT: outgoing topic configurable
3075 bd5ccb695 20150919 Merge PR #51 from domoticz/master
3078 96c457f22 20150919 Added pushbullet notifications
3107 39b275910 20150919 MQTT: use floorplan and plan names as topic
3072 68569e3e2 20150918 Merge PR #77 from szczukot/master
3070 8bb2d562b 20150918 Merge branch 'development'
3063 9ebfc4aad 20150918 Merge PR #81 from EddyK69/disable_excessive_logs
3063 142d7cc91 20150918 Disable excessive logs
3063 0248f82af 20150918 Merge PR #49 from domoticz/master
3059 b17952a43 20150918 Merge PR #79 from domoticz/devices_with_plan_fixed
3059 4d3d08216 20150917 Fix bug in previous pull request
3057 8a2f223c1 20150917 Merge PR #78 from domoticz/revert-76-devices_with_plans
3070 695e34b87 20150918 Changed: All Energy sensors have been transfered to General kWh sensors (more accurate)
3070 b7be07e56 20150918 Corrected DeviceID/Unit for new kwh sensor
3057 5e4dacc21 20150917 Revert "Devices with plans"
3055 949747167 20150917 Merge PR #76 from domoticz/devices_with_plans
3070 05e033328 20150918 More work on the new kWh sensor, MySensors supports more default naming Fixed MQTT compilat
3070 33ed8af7d 20150917 Added new kwh sensor to the devices tab corrected old kwh sensors counter value for the cur
3070 5f82c68d5 20150916 Fix for new kwh sensor
3070 1103c8ee0 20150916 Testing new kwh sensor for openzwave
3172 b9582300a 20150918 LMS remote
3051 a03575e32 20150916 Better device query for openzwave
3172 7176e3554 20150915 LMS remote
3050 544a57929 20150916 Better serial port enumeration (old method took 3 seconds !!)
3172 72e644464 20150915 LMS
3049 33053e197 20150916 Merge PR #74 from szczukot/master
3172 d5e39a1f2 20150915 Redo changes after merge-conflict
3172 e68d0a511 20150915 Fix for Master-merge
3047 7ecfb7d29 20150916 Merge PR #71 from xs4/mqtt-tls
3172 a319e7894 20150915 Edit for merge-conflict
3172 36982e228 20150915 Merge branch 'lms' of https://github.com/EddyK69/domoticz into lms
3044 a400c444a 20150916 Removed debug lines
3043 766d132e2 20150916 Fixed possible incorrect device updates for openzwave
3172 37f3aef6e 20150915 Merge branch 'master' into lms
3042 7d6f77340 20150916 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3072 c35581577 20150917 More info on web site about alert sensor
3049 82530e7bc 20150916 [1Wire] fix reporting when more than one unit is used
3042 41105b5ef 20150916 Merge PR #70 from szczukot/master
3047 d76326a76 20150916 Renamed column and parameter name to Extra
3042 74b9b6fda 20150915 Merge PR #16 from domoticz/master
3038 10ecb3c47 20150916 Small fix for graphs
3047 0aa85070f 20150915 MQTT: add ca file option.
3037 39724cc0c 20150915 Merging changes
3172 edbe4de46 20150915 Edit for merge-conflict
3172 e7a985075 20150914 LMS
3037 17524be11 20150915 Merge PR #69 from szczukot/master
3042 123920d19 20150915 Fix for cursor icon for sTypeAlert on Dasboard
3037 f3e28eb77 20150915 Merge PR #15 from domoticz/master
3172 6a7b07c7d 20150914 Merge PR #46 from EddyK69/master
3031 c9ea6dd75 20150915 Merge branch 'master' of https://github.com/domoticz/domoticz
3037 c64e2e714 20150915 Add logs for sTypeAlrt
3037 50b5ffd54 20150915 [Satel Integra] small cleaning code
3031 3b588dd26 20150915 Merge branch 'master' of https://github.com/domoticz/domoticz.git
3037 e4f496453 20150915 Merge PR #14 from domoticz/master
3028 e0db34f48 20150915 Working on a new kwh sensor
3063 75f20e821 20150915 Merge PR #47 from domoticz/master
3027 2bb76731c 20150915 Merge PR #68 from szczukot/master
3172 957f1b0db 20150913 LMS
3172 35eb9f40f 20150913 Merge PR #44 from EddyK69/master
3024 4a5d79106 20150915 Merge PR #67 from EddyK69/fix_kodiremote_dashboard
3024 a8b992fdb 20150914 Fix: Kodi remote not working on Dashboard...
3024 2e39524f7 20150914 Merge PR #45 from domoticz/master
3055 ffcfc3192 20150916 Identify same device in other plan Add to JSON as array of plan ids
3027 f78b8c77d 20150914 Merge PR #13 from domoticz/master
3172 dd1adf327 20150912 Merge PR #42 from EddyK69/master
3018 703280e86 20150915 Merge PR #61 from PiterEL/patch-3
3055 18c997161 20150914 Ignore backups, cookie and db files
3055 90429bf8a 20150914 Include the PlanID when fetching device(s)
3016 4489f4505 20150914 Merge PR #66 from domoticz/fix_osx_build
3016 5da9b9540 20150914 No Posix real time extensions library -lrt on OSX
3031 24f9b2210 20150915 RFLink: Added support for Elmes sensors
3024 a45f766ea 20150913 Merge PR #43 from domoticz/master
3014 559861f09 20150914 RFLink: Added more device types
3013 4ba97c750 20150913 Merge PR #64 from domoticz/remote_setpoint_set
3172 a14227edf 20150911 LMS
3013 6d80f48df 20150913 Add support for setting setpoint at remote server Forwarding OpenTherm Gateway setpoint Log
3018 008df2368 20150913 Fix to use always backround from styles in events
3011 765fe4136 20150913 Merge PR #60 from szczukot/master
3172 62c55c346 20150911 LMS
3027 3282bbb15 20150914 Extend for sTypeAlert type
3011 366661dbb 20150912 Properly alert icon on devices tab
3172 03d07c238 20150911 Merge PR #40 from EddyK69/master
3011 49ac2d937 20150912 [Satel Integra] small changes on logs
3024 d37774c2f 20150912 Merge PR #41 from domoticz/master
3011 a569c9218 20150912 Merge PR #12 from domoticz/master
3006 ddcbb549f 20150911 Fixed return month report costs
3005 e1bec0536 20150911 Fixed windows pre-build step when there are spaces in the source path
3172 df6a14251 20150911 Merge PR #37 from EddyK69/master
3004 58430c833 20150911 Fiex: Serial ports for windows 10 - Changed: OpenZWave, Fibaro Wall Plug, now using multi
3024 c623020a6 20150911 Merge PR #39 from domoticz/master
3003 17e4e3090 20150911 WIN: Fixed serial port detection
3002 356aa76dd 20150911 Merge PR #58 from EddyK69/fix_group_onoff
3002 797dde311 20150911 Fix group/scene enums
3002 30de31965 20150911 Fix for group on/off command (dimmers)
3172 a763ccc95 20150910 LMS
3002 57813536c 20150911 Merge PR #38 from EddyK69/master
3172 a9662a550 20150910 LMS
3002 28303690b 20150911 Merge PR #36 from domoticz/master
3172 7a640761f 20150910 Merge PR #35 from domoticz/master
3002 1720a27fd 20150910 Merge PR #34 from domoticz/master
2995 f29b46133 20150911 Fix for group on/off command
2994 8c86770f7 20150910 RFLink: Fixed Test button and manual add device when used with RFLink
3011 42b688873 20150909 Merge PR #11 from domoticz/master
2993 ac9ad002f 20150909 Merge PR #50 from PiterEL/patch-2
2991 dc9914038 20150909 Merge PR #56 from szczukot/master
2991 b057fd5cb 20150909 Merge PR #10 from domoticz/master
3172 ea80aa78e 20150908 Merge PR #32 from domoticz/master
2982 d8952110e 20150909 Updated openzwave config files fixed group, set level
3002 c9dc3babd 20150908 Merge PR #33 from domoticz/master
2981 ac217e99f 20150908 Small fix in evohome InitZoneNames
2980 a18614c89 20150908 Merge PR #55 from EddyK69/fix_keep_sceneactivator
2978 a3e92c289 20150908 Merge PR #54 from EddyK69/cleanup_timers_schedule
2980 da57ca0fa 20150908 Fix: Keep scene-activatorcommand while updating DB
2978 01207788c 20150908 Fix: Cleanup expired (scene)timers
3172 90100c2e0 20150908 Merge PR #31 from domoticz/master
2978 7ebe48b70 20150908 Merge PR #30 from domoticz/master
2974 de22f4968 20150908 Fixed missing languages
2973 f99389801 20150908 Updated appcache
2972 24d64077a 20150908 Merge PR #53 from sijones/limitless-disco-mode
4015 89ef7d4c6 20150910 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
2978 50bf51da7 20150907 Merge PR #28 from domoticz/master
2970 eb2fa5d58 20150907 RFLink: Corrected timeout handling
2969 366c1af79 20150907 Merge PR #52 from EddyK69/json_hardwaretype
2964 e41ce864f 20150907 Merge PR #51 from EddyK69/cleanup_timers_schedule
2964 82a34ebbd 20150907 Added function that deletes expired (scene)timers
2964 d621fbda5 20150907 Merge PR #25 from domoticz/master
2991 d1e828df2 20150909 Add log window on Device tab for sTypeAlert
2969 5f2979081 20150907 Merge PR #26 from domoticz/master
2991 00b8fa32a 20150909 Add log window for sTypeAlert on dasboard
2991 e5c736b0c 20150909 [Satel Integra] fixing for ATD100
4015 aea61a640 20150903 Fixed m_actTheme typo.
2964 bcf30a60d 20150907 Merge PR #24 from domoticz/master
2991 6e42d663f 20150908 [Satel Integra] fixing in ATD100
4015 51e895900 20150903 Merging master branch
2969 c8967140f 20150907 JSON: Added Hardwaretype to Devicesoverview
2991 8a9381f04 20150907 [Satel Integra] Add support for ADT100 temperature
2957 faa6bfb38 20150907 Option to replace an Energy device
2991 f0fcdeccb 20150907 Merge PR #9 from domoticz/master
2969 6ad0912c6 20150907 Merge PR #22 from domoticz/master
2993 a296ac8da 20150907 Add name for Mi Light
2956 471c48337 20150907 Safety checks around webserver actions
2969 a03fab0e8 20150907 Merge PR #20 from domoticz/master
2955 970255ea5 20150907 Serbian language support, big thanks to siklosi!! Slovenian l
2972 6b13ec3f3 20150906 Applamp/Limitless Disco Mode Command Implementation
2954 d11a02a55 20150906 Scenes/Groups now only show up on the devices tab when the filter is all or used
2953 76cd940b1 20150906 Fixed group off command
2952 db4f30658 20150906 MySensors text sensor now supports multiple childs, and request value is taken from the dat
2951 43874fbfb 20150906 Fix for scene/group commands (command was taken from translation)
2950 d549398ba 20150905 Merge PR #49 from EddyK69/fix_gpio_interrupts
2950 12b9ed7c6 20150905 Fix: Simultaneous GPIO-interrups not handled
2950 843f1e804 20150905 Merge PR #18 from domoticz/master
2946 828b36293 20150905 ID of text sensor now displayed in hex
2945 edb65d6fc 20150905 MySensors, V_IR_RECEIVE and V_IR_SEND
2944 b6f5c26ae 20150905 Soil Moisture, now using large deviceid (mysensors can now support multiple sensors in one
2943 1f275e7cf 20150905 Link colors in settings now have the correct color
2942 c858fb675 20150905 MySensors, V_TEXT, V_HVAC_SETPOINT_COOL and V_HVAC_SETPOINT_HEAT - VS2015 Re
2941 924dbdfe3 20150904 RFLink, only show debug info in debug mode
2950 a6ed2140c 20150904 Merge PR #14 from domoticz/master
2940 4b0ed3992 20150904 Removed static buffer size variables
2939 bb2f15ab2 20150904 Merge PR #48 from EddyK69/fix_cleanup_wolnodes_after_deletehardware
2939 39246d991 20150904 Fix: Delete all related WOLNodes after delete Hardware
2939 7abf21690 20150904 Merge PR #13 from domoticz/master
2935 bb7e0b563 20150904 Better way to add a device multiple times to a scene
2939 e4ff8f655 20150904 Merge PR #11 from domoticz/master
2934 8a6c2b8e9 20150904 Scene, option for 'stop' (blinds)
2933 3475231c6 20150904 Fix for WU/Forecast (was showing login)
2932 36c6cd46f 20150904 Preparations for MySensors V_TEXT
2931 dd2fdd7f3 20150903 Merge PR #46 from perkovich/master
2931 781176a02 20150903 Removed code added in wrong file.
2931 d23f1c2b7 20150903 Removed auto capitalization for username.
2991 d41d5c0e0 20150902 Merge PR #8 from domoticz/master
2931 2ccb2ee4d 20150903 No auto capitalized first letter in username
2927 7e085b787 20150902 Added missing rflink types
2926 59d427235 20150902 Merge PR #45 from szczukot/master
2926 7825fcbdf 20150902 Merge PR #7 from domoticz/master
2926 48c070941 20150902 [Satel Integra] Bugfix - sending command to properly output
2926 7515b04cd 20150902 Merge PR #6 from domoticz/master
2917 4c6c6b21c 20150902 Merge PR #44 from EddyK69/bugfix_hardwarecontroller
2917 69c921adb 20150902 Bugfix HardwareController (Kodi)
2914 6b096e6fa 20150902 RFLink: added additional devices
2917 487d68c0a 20150902 Merge PR #10 from domoticz/master
2913 c80bde655 20150902 RFLink: Added additional switch types
2912 9b960c71c 20150902 Merge PR #43 from EddyK69/bugfix_hardwarecontroller
2912 dbe5f9677 20150902 Merge PR #9 from domoticz/master
2907 6e1de11b2 20150902 Corrected counter value for energy sensors in report view
2906 d419451f6 20150902 Merge PR #40 from mattsjo/master
2912 794b1c5b0 20150902 Bugfix HardwareController (Tellstick)
2964 0bb20af4f 20150901 Merge PR #8 from domoticz/master
2912 61ae510d8 20150901 Merge PR #7 from domoticz/master
2903 f5589e3e2 20150901 Merge PR #39 from EddyK69/fix_compile_error_rfxcom
2903 356252795 20150901 Fixed compile error in RFXComSerial
2899 07fdee505 20150901 Merge PR #38 from EddyK69/bugfix_scenes_devicemenu
2964 d5d8eef58 20150901 Merge PR #6 from domoticz/master
2899 7ba0d6f78 20150901 Update DevicesController.js
2912 161d16985 20150901 Merge PR #4 from domoticz/master
2903 1264a77d5 20150901 Merge PR #5 from domoticz/master
2899 fdb9df241 20150901 Merge PR #3 from domoticz/master
2964 b4f83f755 20150901 Merge PR #2 from domoticz/master
2896 47699ae23 20150901 RFXtrx ASA protocol implemented
2903 3dce92333 20150901 Merge PR #1 from domoticz/master
2895 24f43f448 20150901 Updated translation
2894 f899da1a4 20150901 Scene codes now handles again seperate status (on/off)
2893 14c00f5aa 20150901 Merge PR #37 from EddyK69/bugfix_scenes_devicemenu
2893 b8a20d40b 20150831 Fixed switching scenes/groups from Device-menu
2893 c7a357b5d 20150831 Merge branch 'master' of https://github.com/EddyK69/domoticz
2906 69c87951b 20150831 Corrected counter value
2906 589b8e884 20150831 Fixed Rego6XX problems:
2887 3ab53b902 20150831 Fixed Add Scene/Group devices Added Tellstick in windows project
2926 1235345f1 20150831 Merge PR #5 from domoticz/master
4015 ce2d0f6a4 20150830 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
2886 49d39eabc 20150831 Merge PR #36 from martenbohlin/master
2893 1b2f613cb 20150831 Merge PR #3 from domoticz/master
4015 db14d0746 20150830 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
2883 1992e942f 20150831 Webserver, Forcing value to be cleared while checking for action
2882 a4517a40b 20150831 Devices Tab, now displaying scenes/groups Option to hide scen
4015 6eaf6e321 20150830 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
2893 67d0a37bd 20150831 Merge PR #1 from domoticz/master
2881 16c6ce83e 20150831 Merge PR #33 from ghoben/group_on_off
2879 245adcd0e 20150830 OpenZWave, only use kwh meter if a valid value is received
2881 9d7d58cad 20150830 Bugfix, logging group_on/group_off
2878 37a3bf9e3 20150830 Kwh meters now show today usage in mobile view instead of the kwh meter
2877 3c040a8ef 20150830 Display delivery icon on dashboard
2876 f8e4b9eda 20150830 Supprot for reports for previous patch
4015 50ef764f6 20150830 .
2875 b381970dc 20150830 Added option to specify Usage/Meter type (usage/return) added browser cache translations
2886 784664ee5 20150830 Added basic suport for Tellstick
4015 138136d71 20150830 URL decoding base64 password.
2886 c856eab9c 20150829 Ignore all files added by cmake and make
2874 97ea420f9 20150830 Reverted lighting2 group patch
4015 1bf714414 20150830 Merged head branch
2873 5e086a255 20150829 Fixed compile issue for old GCC
2872 fada9bab4 20150829 Support for multiple scene/group codes
2871 9812f0a11 20150829 Added the scripts patch to previous patch
2870 f09c31270 20150829 Changed: non-windows systems, scripts can now use a relative patch to the scripts folder
2869 9403e32ac 20150829 Merge branch 'master' of https://github.com/domoticz/domoticz.git
2893 d73773ad9 20150829 Updated .gitignore
2869 bc57dcd85 20150829 Fixed status messages for episodes
2867 39fe6678b 20150829 OpenZWave, Include/Exclude progress dialog
2866 3414fe333 20150828 Fix DeviceStatus to WOL mapping
2865 076cc73aa 20150828 Merge branch 'master' of https://github.com/domoticz/domoticz
2865 d6321ede4 20150828 Merge PR #28 from ghoben/cmake-destination
2926 088caaeb6 20150828 Merge PR #4 from domoticz/master
2865 26fd6cc7f 20150828 Generating appversion.h always in the domoticz home directory during building.
2865 90839cf51 20150828 Merge remote-tracking branch 'domoticz/master'
2865 c9209482e 20150828 Merge remote-tracking branch 'domoticz/master'
2926 860b27228 20150828 Merge PR #3 from domoticz/master
2865 437f228ef 20150828 Fixed user login
2865 cad7897b9 20150828 Fix for missing boost 1.56 time function
2865 4b953ff55 20150828 MySensors, corrected sending localtime
2865 916bb6d49 20150828 Fixed compile error on non-windows systems
2865 cdfb04bc3 20150828 Test, added additional portal to ICY hardware class
2865 0b441c14d 20150828 Only initialize/destroy windows winsock once
2865 0fe88e6eb 20150828 Merge PR #27 from ghoben/enocean-switch-button-handling-change
2865 d7da86d41 20150827 Fixing merge issue, using atoi instead of lexcial_cast
2865 9b137fe25 20150827 Changed line ending
2865 1b58f38d9 20150827 Merge remote-tracking branch 'domoticz/master' into enocean-switch-button-handling-change
2865 90ad1acef 20150827 Merge PR #25 from ghoben/enocean-switch-button-handling-change
2926 919466e3e 20150827 Merge PR #2 from domoticz/master
2865 3d2354020 20150827 Merge remote-tracking branch 'domoticz/master' into enocean-switch-button-handling-change
2865 b833b7407 20150827 Added Gas meter icon
2926 48020fba9 20150827 Merge PR #1 from domoticz/master
2865 d0c155336 20150827 Merge PR #23 from EddyK69/JSON
2865 61b016f1f 20150827 Added json functions for enable/disable (scene)timers
2865 c97689567 20150827 Merge PR #20 from szczukot/master
2865 d5667d5ff 20150827 Actual fix
2865 9df7ff618 20150827 Fixed compile warning
2865 c5222b530 20150827 Fix for Netatmo rain gauge
2865 473a5869d 20150827 Merge branch 'master' of https://github.com/domoticz/domoticz.git
2865 c475728de 20150826 Merge PR #19 from szczukot/master
2865 52a8c9572 20150827 Fixed MySensors kwh counter (when using multiple counters in one node)
2865 8eb484fca 20150826 Fixed MySensors V_Flow (was not handled)
2865 b3f5129ff 20150826 Changing EnOcean switch behaviour to show button presses and releases. Each button will be
2865 0c8a832ad 20150826 Updated counter icon to higher resolution
2865 c10ccdfae 20150826 Merge PR #18 from szczukot/master
2865 0075f08cc 20150826 [Satel Integra] Change subtypes and handle alarm
2865 f86576b0e 20150826 [1Wire] Skip checking silicon_serial_number while reading devices
2865 bcd94f451 20150826 [Satel Integra] Add thread-safe
2865 80bace870 20150826 MySensors Water Flow now recorded in a percentage sensor (need to change thi
2865 76344f5d1 20150826 Added Soil Moisture log in dashboard/devices tab
2865 20278d72e 20150826 Added option in general graph to delete day values
2865 d066eec35 20150826 Fix for Satel password in hardware setup
2865 3ac199cd4 20150825 Fixed some rounding issues for the water meter (as it is now displayed in liters)
2865 f0dedeb16 20150825 Updated cache file
2865 1e53b9578 20150825 Displaying water values in Liter
2865 8abd09e88 20150825 Fix for toon kwh counter after restart
2865 901241818 20150825 Devices Table, some more room for the SubType field
2865 0668e2670 20150825 [Satel Integra] optimization of the number of queries to hardware (szczukot)
2865 0963eed27 20150824 Icons for RFXMeter Gas/Water
2865 3888d3d3a 20150824 Reverted water adjustment for mysensors, best to use the correct divider in the settings
2865 8351f20d4 20150824 Fixed MySensors Water meter to work with the default devider
2865 e76da6050 20150824 Fixed adding a manual lighting 5 device for Aoke
2865 066e55e36 20150824 Ignoring no data returned in HTTP Notification
2865 238c05b42 20150824 Changed scene menu icon
2865 baf327fb8 20150824 Changed HTTP POST handling
2865 2e76354c3 20150824 Merge PR #12 from szczukot/master
2865 3a06242bd 20150824 [Satel Integra] Increase the input buffer
2865 5befbdf25 20150824 [Satel Integra] removes special value from ansewer
2865 019d3cb31 20150824 Merge PR #1 from domoticz/master
2865 500e70dcb 20150824 Test for Toon kwh counters for addon switches
2865 0e7309f9c 20150823 Another version increase (final test for gui upgrade problems)
2865 06c074bbe 20150823 Increasing version number
2865 7d0abdbdf 20150823 Updated browser cache
2865 8a0ca972d 20150823 Reverted integra changes in hardware setup (!please check before you commit!)
2865 a3409d4ae 20150823 Fixed hardware setup caused by integra changes
2865 5ae183f62 20150823 Fixed update script for armv6 systems
2865 2e9693a52 20150823 Changed: EnOcean rocker inclusion (thanks to zorgluf!)
2865 ffa54845b 20150823 Weather tab, nofications
2865 ffae56037 20150823 Changed: Switch icon picker now has a fixed height Counter Incremental small ico
2865 fc5660510 20150823 Merge PR #10 from szczukot/master
2865 f47fefdc5 20150823 Merge PR #9 from szczukot/master
2865 a9b95fe55 20150823 [Satel Integra] fixed missing bracket
4015 5ef001f81 20150827 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
2865 6bf080501 20150823 [1Wire] Lightstate report only if state is changed
2865 52bfb0f3d 20150823 [Satel Integra] Add support for password
2865 0fcd3960b 20150823 Improved Custom Images in editor
2865 ea6e29e43 20150823 [Satel Integra] Small fixing for testing Git
2792 0dfbde09a 20150828 Fixed mapping from DeviceStatus to WOL
2791 c436be7e5 20150823 Improve custom icon handling
2865 66bdee46c 20150823 Icon Uploader, uploading went wrong with large files Icon Uploader,
4015 5e866b74a 20150823 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
2790 3c7a98683 20150822 Added heartbeat for SatelIntegra
2789 5f65d2869 20150822 Fixed some compile errors
4015 598c22039 20150828 .
2788 824072437 20150822 Implemented: Satel Integra hardware support (big thanks to Fantom)
4015 61856ee77 20150827 Auth reason, deleted domoticz instance, several fixes.
2787 f12a381bf 20150822 Added -lrt to the CMakeList.txt
4015 d95b5e8f0 20150826 Drive test 3
4015 b6102bd34 20150822 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
4015 f9baf51c9 20150826 Google drive test 2
2786 39c8504b5 20150822 Small patches by bizziebis
4015 f30f2f75d 20150822 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
2785 9a29c1f8e 20150822 Update openzwave configuration files
4015 005f8d21a 20150825 Google Drive test
4015 b49001624 20150823 Sunday commit.
2784 376dca9cb 20150822 Force one version up
4015 9c19cbcf7 20150823 ...
2783 60b171297 20150822 Merge branch 'master' of https://github.com/domoticz/domoticz.git
4015 0aca15592 20150822 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
4015 cb58cb92d 20150822 Try if pi doesn't crash on disconnect now.
4015 dc797802a 20150822 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
2781 a9658e712 20150822 New gui update ready for test
4015 8c767a501 20150822 Added version # to login.
2783 1c9ce0cc6 20150822 Making script executable
2780 dd797052b 20150822 Working on alternative update method
4015 0e00ab6a8 20150822 Reconnects when api user details change.
4015 f657d5e20 20150821 Setup pages changed and added password to authentication.
2779 ae66e1ac4 20150822 Reverted changes (did not solve gui upgrade issues)
2778 8f42ef7cb 20150822 Fixed compile error
4015 406045f5d 20150821 Commit before pull.
4015 401d9fadb 20150819 Temporary commit
4015 5de2d1feb 20150818 Merge branch 'master'
2777 1441bed91 20150822 Changed curl file write
2776 f0f4de158 20150822 Changed download links
2775 672956a8e 20150822 Reverted update download order
2774 f9314ac4e 20150822 Fixed compile error
4015 9ebfafcef 20150818 ...
2773 083012565 20150822 Added missing lines
4015 d7ceb8332 20150817 Merge branch 'master'
2772 6f49469ea 20150822 Added include file
2771 d9976a2d7 20150822 Fixed: Displaying server time when geo location was not set correctly
2770 e341c2f30 20150821 Merged changes
2770 c33cc90a4 20150821 Merge PR #7 from domoticz/Expand-Kodi-Remote
2767 92062e743 20150821 Changed: Removed dependency of client_id for Thermosmart
2770 4ecaf4f39 20150821 Expand Kodi Remote
2766 c357e9291 20150819 Cleanup code, thanks to ThibG!
2765 a24d23098 20150819 Philips hue missing lights patch windows makeversion windows 7/10 compatible
4015 6565f377f 20150816 Part of assignkey implemented.
4015 806fc2ac7 20150816 Other test.
2764 6238b09ee 20150819 Forcing version update
2763 e33e3d491 20150819 Possible fix for beta download via gui (but will work the next time, or the next time)
4015 958b672ab 20150816 Merge branch 'MyDomoticz' of /home/domoshare into MyDomoticz
2762 f7255de9b 20150819 Changes sunset/rise, not displaying seconds anymore
2761 1b268474c 20150818 Fixed rflink rain meter caused by previous patch
4015 f1f591c30 20150816 Test commit.
2760 02607a957 20150817 Removed debug line (just in case)
2759 ea2183863 20150817 MySensors, S_LIGHT now creates an initial switch again Netatmo, Rain Sens
4015 c5595e45f 20150816 Merge branch 'master'
2758 a60a8d68d 20150817 Openzwave, changed the way temp/hum sensors are send to domoticz
4015 fb23ce8cf 20150816 Changed hostname.
2757 e36427988 20150817 ThibG Fix a few errors detected by cppcheck d26e78b ThibG Fix incorrect format strings det
2756 620b34a8f 20150816 Option to add a log message via the json api (see wiki)
4015 1c86ae690 20150816 Added proxycommon.cpp and proxyclient.cpp to list of compiled sources.
4015 b1bbba5f7 20150816 ..
2755 42ab70d31 20150816 Http get, reverted connection timeout to 30 seconds again (to see if this solves some downl
2754 efc2faf81 20150816 Write correct hash code to version file
4015 aff15e49f 20150816 Different instance id (hardcoded)
2753 cc18ea3ce 20150816 Removed some overhead files
4015 54efbea27 20150816 Scratch version setup
4015 e77c24841 20150816 Typo.
2752 dbbf52181 20150816 Merge PR #4 from bizziebis/master
4015 7e5bc5791 20150816 Moved proxclasses.
4015 878a843c0 20150816 Added proxy sources.
2750 6daf71c26 20150816 Updated INSTALL.txt to use git checkout
2749 79bda2003 20150816 Merge PR #3 from domoticz/ipv6
2749 b98faf261 20150816 This is the ipv6 branch were domoticz doesn´t crash anymore on ipv4-only hosts.
2752 ad351cb3f 20150816 Update TemperatureController.js
2747 1b405c7e7 20150816 Reverted makeversion change changed appversion handling so it does not need to recompile th
2746 0d2200f48 20150816 Merge branch 'master' of https://github.com/domoticz/domoticz
2744 f379ca18f 20150816 Changed updatedom script (to pull/compile from github) added updatebeta/updaterelease to qu
2746 7561d16ff 20150816 Command mv changed to move
2743 d3d755459 20150816 Have to increase git revision number for old beta installations to work
2742 dfd7b8d35 20150816 Updated beta/release scripts to work with github
2741 0055b4ab3 20150816 Corrected line endings on unix files
2740 54b5d897f 20150816 New getgit cmake script, changes in html there where not committed by VS2015
2739 01e645125 20150816 New CMake script, removed SVN version script added git version script svnversion renamed to
2738 95bb21157 20150815 Some more github changes added About display
2737 c3f59fcac 20150815 Fixed IPV4 connection message (removed IPV6 address)
2736 a9ed98ae1 20150815 Increased version number
2735 988788463 20150815 Merged IPv6 patch back into the HEAD trunk.
2734 02c03aa86 20150815 Removed remark lines
2733 45cca8c8e 20150815 Fixed: "Missing status "Stopped" for blinds" in EventSystem (thanks to bizziebis!)
2732 bf6deddca 20150814 Right fix for serial ports windows
2731 8ee422d0d 20150814 Fix for serial ports windows
2730 d72ec2d77 20150814 Updated openzwave config files
2729 bdaab888b 20150814 Implemented: GetSceneTimerList (thanks to Eduard!)
2728 71eee04de 20150814 Enabling old com port recognition for windows < 10
2727 b7fe5869e 20150813 MySensors, Negative temperature sensor MySensors added support for
2726 3d284b7fb 20150812 Reverted curl timeout patch (not the issue of download problems)
2725 8e5d67995 20150812 Force version increase for download test
2724 021217de6 20150812 Reverted curl connection timeout to 30 seconds again (check if updates can be downloaded ag
2723 9fea643a3 20150812 Fix for scene/group set level command
2722 7c580c38e 20150811 Fix order of magnitude
2721 b170217e0 20150811 Scenes RFY switch command now correctly handled
2720 4a39a74e9 20150811 Support for negative usage Store samples in Meter table
2719 8f38e4ca0 20150811 Added new hardware class 'winddelen' to msbuild system
2718 85e035bc2 20150811 Test with openzwave water meter
2717 ee7c5a4e9 20150810 Add Winddelen backend
2716 2173029c1 20150810 Add Winddelen virtual hardware
2715 c3afb56b6 20150810 Removed debug line in add new hardware webserver)
2714 4ad5ed2ad 20150810 fixed localtime_r issue for apple users
2713 8554e5905 20150809 Add Winddelen FrontEnd Hardware CRUD
2712 17d96da37 20150809 Add Winddelen HTYPES
2711 0c1a81128 20150809 Enabled internal voltage/current again
2710 e451bd509 20150809 Enabled thermosmart thermostat
2709 e07b88c45 20150809 MySensors, renamed V_LIGHT to V_STATUS and V_DIMMER to V_PERCENTAGE to be co
2708 659f23c00 20150809 MySensors added support for S_SCENE_CONTROLLER, V_SCENE_ON, V_SCENE_OFF
2707 68edaa264 20150809 Catch SIGHUP signal for log rotation (LarsForum)
2706 fcfc0cbef 20150809 Thermosmart Thermostat Option for Dummy device to create Soil
2705 ed72a1de0 20150808 Reverted latest sql safe patches, caused database column not be created
2704 992bc3fee 20150808 Added Kodi remote v1
2703 bb0a8c684 20150808 Changed: Windows serial port Enumeration (now also supports windows 10)
2702 292fb4255 20150808 Changed: OpenZWave, Alarm/Notification mappings update (xs4)
2701 59ae34cc9 20150807 In debug mode (windows) start with correct database path (in case visual studio is not run
2700 913321ff5 20150807 Some more safety patches (thanks to Thibaut!)
2699 f9176673d 20150807 Upgraded windows build system to VS2015, you have to update the windowslibraries.zip
2698 cdd598b6b 20150807 Implemented: Option to enter a description for each sensor/switch/scene
2697 6d0eb76c3 20150807 Web Server can now be bind to specific address (-wwwbind) (seb) - Implemente
2696 4f5170f8e 20150806 RFLink: added FA20RF broadcast (requires RFLink 1.1 Rev28)
2695 b879fd04a 20150806 RGB Popup to select color/on/off RFLink: Added various sensor
2694 7ddc68c20 20150806 RFLink: Added various sensors/devices
2693 ad0552ad2 20150806 Fixed update rain log duo sql safe_query implementation
2692 0ed736709 20150806 More work on MySensors S_RGB
2691 bb2cc2d29 20150806 MySensors, switch names where always set to default name (was caused by safe_query
2690 5322679ad 20150806 Fixed browser cache
2689 c0762fea2 20150805 Some more patches for sql safe_query
2688 f9bfbac34 20150805 Changed: disabled timeout for smartwares thermostat (no incomming data from device) - Imp
2687 b44d724d8 20150805 Some code cleanup
2686 6923037d4 20150805
2685 e548691b1 20150805 Fixed check scene status duo sql safe_query implementation
2684 412ec73a9 20150805 Small code cleanup
2683 b847aabd0 20150805 Fixed p1 smart meter log (caused by new safe_query changes)
2682 d2f91fa06 20150805 -Implemented: zwavetopology screen, tooltip to indication what will be reported in the grou
2681 6a0162d07 20150805 Now using escape/unescape in html/js fixed possible crash in rtrim/ltrim function fixed pos
2680 0d79b00e1 20150805 Changed: Internal HTML/JS changes to support all types of characters in the sensors name
2679 53c7a82d6 20150805 Upgraded SQLite to 3.8.11.1 in source folder
2678 12214a6f4 20150805 Changed: SQL Queries, now using safe_query to escape all strings (big thanks to Thibaut!)
2677 f86e2da86 20150805 Email Notifications where always enabled after restart
2676 86e6e5ee0 20150804 -fixed: potential issue on setting Temperature attribute on the next node even if it does n
2675 475f506bf 20150804 Temperatures not updated on UI without refreshing browser or changing tabs
2674 52a0d3775 20150804 Renamed "Anna Thermostat" to "Plugwise Anna Thermostat"
2673 2885e1b1a 20150804 Kodi Shutdown fix
2672 23a12f5e4 20150804 Added new class to project
2671 259b51e48 20150804 Implemented: Support for the Anna Thermostat (NEM)
2670 e4901cf3d 20150803 Security Panel delay, now again possible to set delay to 0 (directly)
2669 855faf99a 20150803 Fixed revolt energy graph
2668 f7ddb6da8 20150803 Revolt, added support for Voltage/PowerFactor/Frequency Revolt, Ene
2667 a7278c240 20150802 Fixed shutdown
2666 dc0110bb4 20150802 Implemented: OpenZWave, added Ultraviolet sensor type support
2665 974fc9448 20150802 Danish translation (big thanks to jokkemokke!!) - Add Kodi media command int
2664 1254e3d9e 20150801 Add Kodi command interface to web server
2663 636164486 20150711 Added cross hairs to editor
2662 df4ae389a 20150711 Add Kodi logging and shutdown
2661 8a5ee40fb 20150710 Fixed: pushover sound notification (thanks to Eduard)
2660 debdad7ce 20150710 OpenZWave, multi instance association support (thanks to xs4!!!) Op
2659 f25a20b0f 20150710 Openzwave, fix for all homeid casting
2658 c404c11a1 20150710 Openzwave nodes, fixed issue casting string to unsigned integer
2657 13f86b0dc 20150710 RFXCom firmware upload, added warning text and download link
2656 e2331061e 20150710 RFXCom (Serial) option to update the firmware via the web interface
2655 24f5fed26 20150710 Moved openzwave web commands to openzwave class
2654 baf03872b 20150709 Option to rename unused devices
2653 b70816ce7 20150708 Moved webserver openzwave code to openzwave class
2652 618e88801 20150708 Possible implementation of openzwave co2 sensor
2651 12af585fa 20150707 Redone last rfx loader changes
2650 e1a58814a 20150707 Previous rfx uploader worked, fine tuning now
2649 32a006e5b 20150706 Another bootloader addon
2648 df3c381c2 20150706 Another rfxcom firmware upload patch
2647 f447ea0f5 20150706 New rfxcom firmware upload patches
2646 9ced85373 20150706 Another upload fix attempt
2645 98176dcb7 20150706 Internal changes to firmware uploading
2644 55e693d72 20150706 Removed: (needs more testing) RFXCom (Serial) option to update the firmware via the web i
2643 83eb2831c 20150705 Support for the odroid temperature sensor
2642 8e71489cd 20150705 Changed: BMP085, when forecast is unknown, its calculated directly based on the pressure
2641 503fa56b7 20150705 Post command handling
2640 686d8267a 20150705 Implemented: RFXCom (Serial) option to update the firmware via the web interface
2639 6d4be9418 20150705 Extra boundry checks
2638 76e0dbf1f 20150705 Changed: Lowered HTTP connection timeout to 10 seconds
2637 2c9430e09 20150705 Modified the RFXCom firmware uploading, but it is disabled for now
2636 4e11c200f 20150704
2635 ab6b9a61d 20150704
2634 16f0f24fa 20150704
2633 8ff113911 20150704
2632 ad81d038d 20150704 Fixed owenership of firmware file
2631 bde5c076b 20150704
2630 b1690981a 20150704 Fixed compile error for gcc
2629 592d72b14 20150704 Fixed typo
2628 0ab9df744 20150704 Implemented: RFXCom (Serial) option to upgrade firmware form web interface
2627 4563fda20 20150703 Updated openzwave
2626 c7195a9a0 20150703 Option to flash sensors when an update is received (enable in the settings p
2625 396e3ccb5 20150701 Changed: Short Log cleanup method
2624 c4f0b32ee 20150630 Usability update for Kodi
2623 9454647d7 20150630 Removed text shadow on highcharts
2622 6a5c8d6dd 20150630 Davis Logger
2621 9ec7cb6d5 20150629 Reduce Kodi logging
2620 fa57a00ef 20150629 Changed: OpenZWave, when receiving a timeout notification, do not flag node as 'dead', only
2619 6feee3d06 20150629 Fixed some translations in the datapush options
2618 3ee73f736 20150628 Another http push localization fix
2617 14c006850 20150628 HTTP Push table localization (thanks to cgaudry)
2616 1aa06b6c9 20150628 Reverted IPV6 patch
2615 ce4773576 20150628 Web Server now also listens on IPV6 addresses (big thanks to chimit!)
2614 02b691c52 20150628 Mochad secure support (thanks to Simon)
2613 ffb39e45c 20150628 Tweak status text for long descriptions
2612 42316e913 20150628 Fixed typo include
2611 4e84d821e 20150628 Moved code outside webserver class to their main classes (like devices)
2610 db72864e6 20150628 Possible fix for RFLink
2609 2d0e0bd2f 20150628 Fixed: Devices Tab, set device to unused Updated highcharts
2608 38da37a90 20150628 Fixed compile error moved some code out of the webserver class
2607 f42d89c1a 20150628 Resolve a couple of case sensitivity issues
2606 c11e06cca 20150627 Ubuntu std::to_string workaround
2605 d9277f8e7 20150627 Add Kodi device support
2604 f48e84449 20150627 Implemented "Stop" state in blockly in switch states
2603 576ff7303 20150627 Added items to support media
2602 bce02f141 20150627 When clicking on the log button, browser page now always go to the top
2601 b05d6eefa 20150627 Fixed Netatmo wind sensor values
2600 94d6cde92 20150627
2599 2cb919376 20150627 Fixed typo in razberry class
2598 216983aa1 20150627 Text/Alert Sensor logging (when called from json api) Support
2597 208825d89 20150625 Data push optimized netatmo implemented wind sensor various internal improvements
2596 fa3806f26 20150624 Making sure the ID of the temp sensors is not to high
2595 56f2bef21 20150623 Fixed netatmo class header
2594 34fedd47c 20150623 Added netatmo to the cmakelist
2593 e5377840b 20150623 Updated appcache
2592 e5429aa50 20150623 Initial support for the Netatmo Weather Station (Big thanks to Sébastien!)
2591 4046dee6e 20150621
2590 991ca6793 20150621 Added example buienradar script fixed language in element template
2589 af133986f 20150621 1-Wire negative values
2588 22d14c6ab 20150621 Updated OpenZWave configuration files
2587 72f443e62 20150621 Rain Report Temperature Report
2586 bd211d135 20150618 Notifications, new option "Ignore Interval"
2585 00b7832bc 20150618 Implemented: HTTPS support for On/Off actions
2584 21b1f532f 20150618 Changed: EventSystem, not adding sensors from disable hardware HTTP Data p
2583 f4a5db19b 20150617 PiFace, added new states to a queue
2582 2d470c39f 20150617 Fixed: Battery low (typo) notification
2581 95e4e90b5 20150617 Added translations in the custom temperature graph/http push
2580 53e1f14cb 20150617
2579 d66df9326 20150617 Removed duplicate command line parameter using old windows xp inet_top function
2578 517fff26a 20150616 MySensors added support for S_SMOKE/S_DIMMER Tooltip bug for the Du
2577 7c6c72d09 20150615 Improved: Notifications
2576 0262bbcd0 20150615 RFLink: fixed "Manual Add device"
2575 dfc2e25f1 20150615 Implemented/Changed: Notifications with Priority "Emergency" are always send, regardless
2574 367e4e9ab 20150615 Initializing SSL library before starting the web servers
2573 85d7b702d 20150614 Stable release #2563
2572 e2ad668c4 20150614 Implemented: MQTT command to request device information
2571 867ffc3e7 20150614 Implemented: RFXCom, sTypeTH13/sTypeTH14
2570 523eb606f 20150614 Corrected a compile error
2569 6dbd3c00c 20150614 Implemented: MQTT commands to send a Notification
2568 4d975888f 20150614 Implemented: MQTT commands to switch light, switch scene and set user variable
2567 3c69872a9 20150614 Implemented: Blind status "Stopped" now also displayed on dashboard
2566 c4e19e758 20150613 Ozw fan modes value list not queried when empty
2565 d8130b334 20150613 Fixed possible ozw crash when getting list items
2564 71796855a 20150613 MQTT Username/Password MySensors, S_LOCK
2563 61894ac0c 20150613 Added MQTT TLS build support
2562 ae27e4bb4 20150613 Removed time seconds dependency in hardware classes replaced the mqtt_time function
2561 2b35cedcf 20150612 Implemented: MySensors, V_UP/V_DOWN/V_STOP/S_COVER
2560 49325e545 20150612 RFLink: Added transmit verification
2559 8b55cc096 20150612 RFLink: Added support for more protocols
2558 ea624a86f 20150611 Removed makefile from MQTT build folder
2557 47d31af6b 20150611 Improved database restore
2556 117ee2170 20150611 Another teleinfo patch
2555 95e91eac5 20150611 Fixed dashboard display without roomplans (thanks to cgaudry!)
2554 334962946 20150610 Included patch for double disk mounts included patch for razberry (thanks to Michael)
2553 433bd23c8 20150610 Updated openzwave (big rename from aeon to aeotec)
2552 bbecee081 20150610 All date/time/sun is now left aligned
2551 0962551a1 20150610 Fixed teleinfo header (thanks to... ;)
2550 7139c805b 20150610 -fixed for teleinfo (thanks to tophe46)
2549 431cc5518 20150610 Solved user visible tabs after login
2548 7f84dd15e 20150609 Wind gust tooltip
2547 34d33ba38 20150609 Updated openzwave updated language files removed gettickcount64 for win32
2546 c6704b805 20150608 New MQTT library
2545 89aaaa769 20150608 MQTT, added RSSI/Battery Level
2544 78963500d 20150608 Json udevice, now possible to supply raw device parameters again
2543 44dbac019 20150607 Added popp-zweather configuration file
2542 cf702b1e2 20150607 Fixed rgb2hex function (correctly checking of undefined)
2541 3f08e2832 20150607 Removed debug lines in the thermosmart class (not finished!)
2540 6c4f63e19 20150607 keeloq commands can now be send (push on button) - scene tab now displays date/time/sun -
2539 5dc1d370f 20150606 Fixed: Removed update notification in the login screen
2538 eaa256ed5 20150606 Temperature icon fix
2537 1733e7993 20150606 Added new HTTPPush (thanks to Seb!), still being worked on
2536 99e7efcf2 20150606 CustomIcon bugfix
2535 6c1202002 20150605 Custom tab now only displayed when there are html files in the template folder, an
2534 1c96925e3 20150604 Added mutex to MQTT
2533 d74728976 20150604 Checking in mqtt work....
2532 8883f260b 20150603 Changed: Light/Switch log now includes seconds in popup
2531 1d88d5142 20150603 Small fix for OTGW modulation levels
2530 d66c13852 20150603 Implemented: Option to Enable/Disable the Custom tab for non-users (admin)
2529 5a50e5c68 20150603 Fixed: CM113 "Watt", now only displays 1 phase if phase 2/3 are 0 (not used)
2528 81ab556ae 20150603 Changed: Teleinfo, added support for CBEMM meters (TELEINFO_TYPE_MOTDETAT), thankx to berty
2527 70b12bed2 20150602 Changed: Scenes, now supports adding security devices
2526 685a65fcb 20150601 Corrected commandline warning text for 'sslcert'
2525 0eabf148e 20150601 Fixed utility setpoint temperature sign
2524 0a4cb3d96 20150531 Implemented: Lithuanian language support (thanks to our translators!)
2523 1d19bbd2d 20150531 Openzwave, now displaying "long" version number
2522 7df88e873 20150531 Updated translations
2521 10b54f7de 20150531 Kodi: Function rename
2520 22b04fb1f 20150531 Kodi: fixed possible log issue when string contained percentage character
2519 d47aa8c86 20150531 Changed: Enlarged windows console log window Some code cleanup included mutex in for localt
2518 1b37b162a 20150531 Kodi notify handle multiple IPs
2517 b56dcde7f 20150530 Removed mutex for localtime
2516 2e9329365 20150530 Some openzwave changes
2515 3cd7fba54 20150530 Fixed Notification Settings test button
2514 38015c527 20150530 Openzwave removed some deprecated function calls
2513 9dc050839 20150530 Updated to openzwave master branch
2512 f6a6c3040 20150530 Increased wait time for logitech harmony hub
2511 d9298ba56 20150530 Fixed: OpenZWave, node poll status in table/checkbox
2510 3c3a3b577 20150530
2509 79af9c451 20150530 Fixed TE923 time
2508 bbc783568 20150530 Fixed unix time logging
2507 1a2127e3d 20150530 Removed some remarks causing the zipato to not turn on/off
2506 52a23de41 20150530 Made localtime call thread_safe for systems that do not have localtime_r
2505 1baa0e7f1 20150530 Changed: OpenZWave Color Command Class (you need to re-include the node)
2504 4f1175a4b 20150530 Added custom icon support
2503 49836ace0 20150529 Updated openzwave reverted highcharts-more.js.gz
2502 45b4a015b 20150527 Implemented: OpenZWave, Added extra alarm type switches
2501 8783a4ba5 20150527 Added cleanup trigger files Translated timer settings added support for openzwave alarm typ
2500 8df262cba 20150526 Changed: Not sending actual motion sensors off command, only updating internally
2499 bfe805cf9 20150526 Changed: Setpoint Up/Down rounds up to 0.5 degrees - update sqlite database
2498 0fbd69aaa 20150525 Corrected OTGW tcp shutdown
2497 d81d575bf 20150525 Corrected OTGW patch
2496 01f3225c5 20150525 OTGW base revert
2495 914afa8fc 20150525 Now with correct files
2494 2272840a6 20150525 Reverted OTGW patches
2493 3dd3aca24 20150525 Fixed problem with hardware name/username/password encoding
2492 e06232de3 20150525 Fixed Nest Away status query
2491 805da0e35 20150525 Nest, implemented Away mode
2490 18574bbd9 20150525 'Nest Thermostat' hardware support
2489 10de80f49 20150525 EventSystem, checking if notification contains two parameters S0 Meter, R
2488 0f7a1ea6a 20150524 Changed: Log Window more angularjs
2487 b1160c678 20150524 Added mobile switch icon
2486 a79ccef7d 20150524 Fixed possible compile error for std::cout
2485 a6d2db0cf 20150524 Changed: Serial Port names (now always as string)
2484 2ad11d603 20150524 Changed shortlog cleanup routine again
2483 67db380e4 20150524 Added new ping class to CMake
2482 6bdb420a2 20150524 Implemented: Native 'Ping' (System Alive Checker) Changed: 1Wire, checking for valid value
2481 fb272c382 20150524 Added icons to Kodi notification
2480 b23cc511c 20150523 Some changes against undefined signs
2479 11e18a7fa 20150523 Fixed compile issue (gcc 4.6)
2478 a6874e9a9 20150523 Changed: RFLink controller initialisation detection (reported by gkroone) Removed: Duplicat
2477 3b809d769 20150522 Extra check in short-log cleanup
2476 83ea53920 20150522 Cleaned up some code
2475 fe0a7c019 20150521 merged "SecureWeb-KeepAlive" branch into main trunk
2474 bdc4f913e 20150520 Implemented: KMTronic USB-> RS485 relay hardware
2473 0dd066140 20150519 Implemented/Changed: Scene devices now supports both on and off delays (off = ondelay + off
2472 10657b2f7 20150519 Fixed blockly setting uservariable string after xx seconds
2471 ce9c06778 20150518 Removed debug line
2470 7d2238164 20150518 Changed some code for cleaning up short log
2469 6d4aaee68 20150517 Updated openzwave vision configuration files
2468 f9329551e 20150517 Small code cleanup
2467 73cc6bbce 20150517 Fixed custom http notification
2466 f020b3437 20150517 Fixed: HTTP Notification (Script) stop url encoding subject/message
2465 6caf8bfac 20150517 Some fine tuning on the harmony class
2464 ab84da696 20150517 Small cleanup on harmony class
2463 4abd67dc9 20150517 Changed: Logitech Harmony Hub code
2462 4f3a11b4b 20150517 Current sensors now also display actual state in caption
2461 4865aa5b6 20150517 Implemented: SolarMax inverter with Lan interface
2460 db1f53145 20150517 Uservariables, display Idx value (thanks to ikkemaniac) Incre
2459 5aa7615bd 20150517 Add Kodi notifications
2458 0e8ec5909 20150517 Add Kodi notifications
2457 f0f41f3c8 20150516 Changed: Logitech Harmony Hub code
2456 24a799df9 20150516 Removed translations for custom fields in the http notification system
2455 bf0cc341e 20150516 HTTP Notification - Changed: HTTP Notification, can now handle both HTTP and Scrip
2454 aeb9dff75 20150515 Better logging of used webserver ports, option to start without webserver (-www 0)
2453 33fa86dab 20150515 Updated: HarmoneyHub class (Thanks to Jan)
2452 b7801e453 20150515 Possible fix for OTGW outside temperature
2451 6246b5edc 20150515 Implemented: MySensors, V_CURRENT
2450 3ab8e44f7 20150514 Some minor changes
2449 cb00f0403 20150514 Changed: Better new update notification when launching browser
2448 86c234b16 20150514 Events/Lua, User Variable can now be set after XX seconds Ope
2447 ddee4bd2c 20150513 Fixed: User Editor, updating a user could result in random password change Implemented: Dev
2446 77387149e 20150512 Removed debug breakpoint
2445 959ac490d 20150512 Implemented: KMTronic USB/WEB relay hardware
2444 5e0a01b52 20150512 Implemented: OTGW, MsgID=14 and MsgID=17 (if reported)
2443 b8adc01ae 20150511 Implemented: Sanity check for OpenZWave NetworkKey Length
2442 210236ad0 20150511 Fixed: Blockly, possible saving of 'ghost' events
2441 682edde35 20150511 Implemented: MySensors, V_WIND/V_GUST/V_DIRECTION
2440 587d90c33 20150510 Implemented: MySensors, V_RAIN
2439 d3c12600f 20150510 Implemented: Counters in P1 Electra/Gas month reports per day
2438 fc1624337 20150510 Implemented: CORS browser support Implemented: Settings, Battery Low check
2437 438c1cd17 20150510 Changed: General Graph, min value is now calculated dynamically
2436 c65db8ec6 20150510 Scene/Group, now possible to add same device multiple times, as long as the
2435 dd40830ac 20150510 Changed: Now possible to disable serial hardware when usb port is not available Changed: Fi
2434 6f74970d7 20150509 Changed: Now using OpenZWave security branch
2433 63fb5d17d 20150509 Small patch on the request path
2432 5bc0f6e62 20150509 Changed: MySensors, Battery level now applied to correct NodeID Blockly, now esc
2431 9d7d47610 20150507 Fixed: Setting correct folder permissions on the backup folder
2430 78f231b2f 20150507 Changed: MySensors time request now returns localtime
2429 268458958 20150506 Reverted webserver
2428 88b021131 20150506
2427 103961407 20150505 Changed webserver keepalive check
2426 578c3fe4d 20150505
2425 f9c6a2445 20150505 Implemented: RFXCom pTypeInterfaceControl messages
2424 48c858dd7 20150505 Added cmake file for sqlite
2423 7e271280b 20150505 SQLite is now part of the build process
2422 6df514eea 20150505 Pushover/NMA now use the subject again
2421 6ff6b5e7f 20150505 Gui display problem when going from Scenes to the Devices table
2420 4c126789b 20150505 C++03 fix for std::map erase without iterator
2419 b8809bc7e 20150505 Some changes to the webserver
2418 51807a4fc 20150504 Corrected handle pointer
2417 38577358d 20150504 WebServer, keep-alive, big thanks to chimit!!!! Email Port, please
2416 d35511671 20150503 Basic Auth, log message when a wrong username/password is provided (thanks t
2415 57c94d4a1 20150503 Hardware setup, passwords containing specials characters devices tab, add
2414 57655e9b9 20150503 Implemented: notifications, option to send to specific systems
2413 384f0de67 20150503 Implemented: 'Custom HTTP' notification system
2412 223adb07e 20150503 Update checksum file should now properly be downloaded
2411 3a8eeb176 20150502 Now checking for updates twice a day, or when user manually checks for updates
2410 03132d4b0 20150502
2409 77c127cef 20150502 Changed: Moved curl folder to windows libraries folder (windows compiler, download the new
2408 f7b9eafa5 20150501 Implemented: Option to supply custom notification messages
2407 74f05ae8c 20150430
2406 39345550a 20150430
2405 4f250bb80 20150430 Updated appcache
2404 8e3d46503 20150430 Option to Enable/Disable notification systems
2403 3668ad289 20150430 SMS Notifications - Solved: Wind Graph generation could cause a crash
2402 4f7e90f36 20150429 Fixed CMake file
2401 3870508b2 20150429
2400 b4d823488 20150429 Better fix for wind graph calculation
2399 023c66c32 20150429 Fixed possible division by zero in wind graph calculation
2398 7602e780c 20150429 Checking in some work
2397 73d0c1288 20150428 Implemented: RFXCom, mode6 (Keeloq protocol) support
2396 fe7ed8459 20150427 Fixed: Compiling under ubuntu (issue 'rm CMakeCache.txt' first)
2395 c94e88077 20150427 RFLink: disabled debug, corrected support for KAKU door/window sensors and dim values - F
2394 49be1a109 20150420 disabled debug, corrected support for KAKU door/window sensors and dim values
2393 8f8605d98 20150409 Committing some work in progress for MySensors MQTT, wont work without a private sketch
2392 8060edb66 20150409 Implemented: Greek language support, big thanks to George!!
2391 099cce858 20150409 Fixed: Not handling invalid barometer svalues (duo invalid json call)
2390 d411bf6a5 20150409 Updated openzwave library
2389 6bf5587bd 20150409 Fixed: Update UserVariable from json
2388 356a11a36 20150408 Fixed RFLink compile error
2387 dc25b0197 20150408 Itoa fixed
2386 0f42d2a8a 20150408 Fixed abort handler
2385 b1ed753f6 20150408 Fixed html typo
2384 bed853dbe 20150408 Adding the files
2383 c73920c3c 20150408 Testing stack trace (non-windows only)
2382 f148586d6 20150408 Added AC(NewKaku) dimmer support
2381 be3431c08 20150406 Fixed: P1 Gas, shortlog graph hour shift duo DST
2380 81f656cbd 20150406 MySensors, now using float for temphumbaro sensor
2379 dcf232c47 20150406 MySensors corrected ID/Battery level for TempHumBaro sensor
2378 e4d9391ca 20150406 Fixed: MySensors, now supports multiple light child id's
2377 09cf15561 20150405 Changed: Swapped counters for 'Toon', usage/delivery 1 and 2 where inverted - Implemented
2376 fa1864f1d 20150404 Fixed cmake script
2375 78c3198e1 20150404 Changed: Inverted open/close for BlindsT10
2374 46fd0dc9b 20150404
2373 bdc299153 20150403 Implemented: 'Toon' zwave switches support
2372 f1603aec3 20150401 S0 meter, setting CurrentUsage to 0 when nothing received for more then 5 minutes
2371 75fbbe218 20150401 Change for S0 Meter kwh counter calculation
2370 131585c3b 20150331 Implemented: Devices tab, Barometer/Text log option Changed: Wind sensor, now using max spe
2369 80bbe3046 20150330
2368 251e7ccae 20150330 Added Hungarian language file
2367 65555a311 20150330 Implemented: Hungarian language support (big thanks to Isty1974!)
2366 7649f802e 20150330 Fix tables for daylight saving
2365 9ab836936 20150329 Corrected S0 Meter total
2364 c5865190e 20150329
2363 6e52ba4c2 20150329
2362 657be5a0d 20150329 Changed: voltcraft heartbeat timer
2361 a4a70849a 20150329 MySensors, now using actual value for LUX sensors, instead of percentage
2360 7570822d3 20150329 Another MySensors Update for forecast rain
2359 14ae09a7b 20150329 Patched MySensors Baro sensor to report rain is pressure is below 1010 and cloudy was repor
2358 0f3e04d02 20150329 Reverted previous change, gcc cant handle it
2357 ee1c21fbe 20150329 Cleanup some header files to avoid recompilation
2356 1e26fa80d 20150329 Implemented: BMP085/MySensors forecast Cloudy/Rain when pressure is <1010 hPa and original
2355 c198179ad 20150329 Fixed: Closing Voltcraft usb device handle after reading Updated: OpenZWave
2354 da962147b 20150328 Updating existing P1 meters with new ID(1)
2353 379646800 20150328 Changed: P1 Electra/Gas meters now have an ID, update all your domoticz instances ! - Cha
2352 4e35b5d9f 20150327 Force cache refresh
2351 d2ededde1 20150327 Dimmer On image fix
2350 61370af7b 20150326 Some more sanity checks on wunderground
2349 028d2c7e5 20150325 Extended windmeter support
2348 701754ceb 20150325 Added RFLink to "add manual"
2347 49a7f2e0e 20150324 Implemented: MySensors Voltage/UV/Lock value
2346 0616fc9a0 20150323 Enabled RFlink device support
2345 f07dff35c 20150323 Small change for co2 reader
2344 0a07b3ac3 20150323 X10 support Added
2343 a91ce3094 20150323 Implemented: Mertik (Thermostat 3) added Second Up/Second Down option in the popup
2342 d27be95fa 20150322 Implemented: MySensors, Saving/Loading VAR values
2341 8b7ac173b 20150322 Implemented: MySensors Water meter
2340 fb4f3cf40 20150322 Improved MySensors support, removed some duplicate status text in webgui
2339 69968c6e4 20150322 Changed dimmer code to use renamed icon
2338 0cdad1e66 20150321 New RFXCom sdk implemented
2337 c1e602cdc 20150321 Changed: Air Quality (CO-2) sensor class
2336 dbe725469 20150321 Possible zwave door_lock support
2335 1fe940a3a 20150321 Added UV sensor and several protocols
2334 1222e4f57 20150321 Force refresh
2333 914901375 20150321 Improved support for multiline sensor values
2332 9fd52f7d1 20150319 Fixed translation key separator
2331 b782a1287 20150319 Changed Javascript translation system to I18Next Fixed: TeleInfo (TDF) Hardware ID
2330 d8b831402 20150317 Implemented: Distance Sensor (cm/inches)
2329 375240571 20150316 Updated some translations
2328 628218e38 20150315 UVC camera default parameters where incorrect Fritzbox received from/to w
2327 4c618c5be 20150315 Fixed scrolling of graphs when launched from floorplan
2326 81dc8f270 20150312 Fixed maximum logline length
2325 08ddb4739 20150312 Committing initial RFLink work
2324 c165d932a 20150309 Updated translation files
2323 7bf4475c5 20150309 Small parsing changes for GPIO
2322 eb19e00cd 20150309 Fixed: Updating hardware settings for GPIO
2321 829bdbaa0 20150308 BMP085 auto detect I2C bus at startup
2320 e1abb8adc 20150308 Changed: OpenZWave, when a switch/dimmer is turned off, and this node has a Power/Energy se
2319 d4b281553 20150308 Some more translation work
2318 e8e23960a 20150308 Updated: Floorplans, Tablet/Phone friendly.
2317 c0efa1ae9 20150307 WOL, only allow ON command
2316 f625f6d54 20150307 Fix for mertik popup with password
2315 6a342ebb6 20150306 Implemented: Mertik (Thermostat 3) Up/Down popup Internal HTML changes/translations
2314 145cf640d 20150304 Skip thread check for 1Wire
2313 ae8709bf3 20150304 Fixed: ZWave Light dimming
2312 8dc1b3e57 20150304 Set hardbeat timeout to 60 seconds
2311 bd3c803b0 20150304 Implemented: Sound Level sensor (dB)
2310 36063191e 20150303 Added: Finnish/Lithuanian/Czech language
2309 efdf3e2a2 20150302 OpenZWave, Small patch to get preferred power meter for energy transmission
2308 fee7f90dc 20150302
2307 42cec0d32 20150301 Fixed typo
2306 917222dfa 20150301 Changed: Meteostick support (thanks to Devilsnet) - Changed: Handling timeout (dead node)
2305 9243003b1 20150301 Enabled fullscreen checkbox
2304 db5e8c636 20150226 New I2C class for BMP085
2303 a76f32994 20150225 Added ETH8020 class
2302 1ad6121c4 20150225 Implemented: Support for the ETH8020 relay board
2301 ffc602bb8 20150224 Fritzbox added Switch for when a call is connected/disconnected
2300 808df465f 20150224 Implemented: Warning when deleting a Blockly event
2299 75a31f9ce 20150224 Changed: Transferring a device will now look internally which device is newer/older Impleme
2298 b2ef6609e 20150223 Changed: Avoiding possible RTC/NTP clock drifts
2297 0b96edd1a 20150222 Fixed compile warning
2296 39a6126f9 20150222 Fritzbox Hardware type for caller ID (Beta!)
2295 0d029bab6 20150222 Fixed: Firefox, RGBW/Setpoint popup
2294 6b969db47 20150221 Implemented: OTGW sending current time/day, new stable release
2293 f49be0558 20150221 Implemented: Setpoint Popup
2292 7731a3426 20150220 Implemented: Displaying OpenZWave version
2291 4ededfbbb 20150220
2290 037cdc9a7 20150220 Implemented: EnOcean, added support for TempHum.02
2289 fea75f7e7 20150219 Different log color for status messages, fixed current graph on dashboard
2288 ce226a603 20150219 Fix for FreeBSD
2287 0bb651dc3 20150217
2286 13b671a65 20150217 Updated: TE923, now supports battery levels (good/bad)
2285 31d1018db 20150217 HTML patch for new OZW node state
2284 3055193cf 20150217 Patch for OpenZWave node state
2283 f9302ebc0 20150216 Changed: kWh meters that do not provide current usage will now calculate the usage in the d
2282 c0caa7f84 20150216 Short log meter table not skipping same value any more Updated openzwave
2281 dfcf11de3 20150215 Implemented: RGBW Popup to select color/on/off
2280 95a54c0a3 20150215 Forcing machines with armv6 architecture to use the armv7 updates
2279 95c596282 20150215 Fixed chrome download error warning
2278 588d00962 20150215 Implemented: Scenes/Groups, additional On/Off delay option
2277 5fb16cce7 20150214 Openzwave dimmer patch (thanks to Gilles!)
2276 f036a2540 20150214 Reverted last str patch duo incompatibility between g++ and MSVC
2275 896ea140c 20150214 Reverted style patch
2274 4d212f413 20150214 Changed: ZWave lights/dimmers can now be dimmed in percentage from 0..100 (Thanks to Gilles
2273 8678fc095 20150214 Made copyright positioning 'fixed' to match banner
2272 7f2c8faea 20150212 Removed patch signs
2271 4af3a3986 20150211 Added support for /dev/ttyU* as serial ports
2270 f86f45cad 20150211 S0 meter, option to configure meter 1,2 and 3 Updated openzwave config files
2269 395f0c955 20150209 Possible fix for CM180 total power report
2268 da024aeb2 20150208 Bmp085 fix when not connected, rasopberry UVI settings
2267 1f408bc8f 20150206 Implemented: Raspberry Pi 2 Internal CPU Temperature
2266 1e12d3479 20150206 Fixed failed browser cache message popup
2265 c6ef4fbe9 20150205 Changed MySensors Serial, Added MySensors TCP, starting with MQTT implementation, hashing p
2264 1e4b44d7d 20150205 Make app cache erro close after 1 second and refresh
2263 f2cd25e1e 20150201 Supporting battery level for mysensor devices
2262 6e6b9e8bf 20150201 Better grouping of mysensor sensors
2261 ce1e5b583 20150130 MySensors: Now possible to control V_LIGHT/V_DIMMER sensors
2260 947868a9f 20150129 Some more MySensors work
2259 9044a0a2d 20150129 Committing some more MySensors work
2258 00f78b61a 20150125 RFXCom ImaginTronix protocol setup
2257 a4691ce96 20150125 Patch for SMTP (RFC 2822)
2256 0920ef1b0 20150125 Removed debug breakpoint
2255 1db43cd08 20150125 Added more MySensors devices
2254 b8771dbda 20150125 Added more MySensors devices
2253 3582d2829 20150125 Make floorplan dropdown work with themes
2252 a85bea373 20150124 Fixed: YouLess counter value in Report
2251 5a17f958b 20150124 Reverted email patch
2250 b6c52be67 20150124 Added error event to appcache
2249 78ee72dba 20150123 Fixed: Gui, working with Sensors that contains special characters in the name
2248 ab2c3bda9 20150122 Possible fix for android slider width
2247 be1eb177b 20150121 Added windows ssl libraries
2246 9d96a0ccb 20150120 Fix for thermostat schedules and smtp date
2245 ced79a3c9 20150120 Updated scripts
2244 b7604a7a0 20150120 Better cmake patch
2243 acabd7019 20150120 Added support for openssl in cmake file
2242 92c777559 20150120 Fixed some compile warnings
2241 3e16ffc09 20150120 Implemented: native HTTPS support
2240 d7719dddf 20150119 Fixed icon uploader
2239 dfc3ed576 20150118 Corrected upload button translation
2238 835f98813 20150118 Updated openzwave config files
2237 59aa7a146 20150118 Fixed debian compile warning again
2236 5a79d59bf 20150118 Fixed manifest
2235 353b3c6c5 20150118 Added translation to custom icon upload
2234 b193912ea 20150118 Overwriting icons will now also overwrite them on disk
2233 887021761 20150118 Custom Icon uploader will now overwrite existing base icons in the database
2232 3abf6ebf9 20150118 Fixed compile warning on debian
2231 0fcbef25e 20150118 Removed unsetting upload file
2230 3ea2eb1cd 20150118 Added new customicons icon for menu
2229 ec88b987a 20150118 Fix: when partial custom icons where uploaded, list is now refreshed
2228 9ffa27c92 20150118 Added more log message when uploading of custom icon failed
2227 bc595b6e7 20150118 Added missing controller file
2226 b37581418 20150118 Fix for Update check in dropdown menu
2225 58e8ae5f2 20150118 Implemented: Option to upload/use Custom Icons for On/Off switches (See updated manual)
2224 9d4516e08 20150117 Another shared_ptr compile fix
2223 19916b067 20150117 Using boost shared_ptr now
2222 13f52b9c4 20150117 Fixed compiler warning
2221 cbe3b5642 20150117 Checking in some work (iconset uploader not finished yet!)
2220 5a6e44107 20150116 URLEncoded dynamic appcache files, changed BMP085 forecast calculation result
2219 288e6f23d 20150116 Added BMP085 forecast calculation
2218 60aaf9a6d 20150114 Fix for Remove Actions in Lights/Switches
2217 70a0d5e94 20150112 Fixed: Dimmer slider resize
2216 a5a6a8039 20150112 Implemented: Wind Gust chart
2215 7dc1e460d 20150111 OTGW control setpoint now also in TCP mode
2214 57fa23135 20150111 Implemented: OTGW, added support for setting the Control Setpoint
2213 3e3d32cd0 20150111 Added some translations, fixed setup pushover text
2212 edcd8ad85 20150110 Changed some OZW configuration files
2211 4282b0932 20150110 Fixed: Windows Exit application from trayicon
2210 ba5b4f244 20150110 Implemented Previous Barometer month/year graph, changed settings
2209 cc8784e87 20150109 Added some more strings to translate, possibly fixed login screen issue
2208 a9f581733 20150108 Added some openzwave strings for translation
2207 99dc00890 20150108 Updated openzwave config files
2206 cc84a64de 20150107 Reverted update script for now
2205 e30854432 20150106 Implemented: PushAlot notification system (Thanks to Toni!)
2204 f4e94328f 20150106 Reverted BMP085 forecast calculation (seems to crash the application) changed the update sc
2203 97daa8457 20150106 Changed BMP085 prediction routine
2202 c252f9af8 20150106 BMP085 forecast calculation
2201 ed095ee05 20150106 Evohome battery patch
2200 d46e5c88c 20150106 Evohome support for relays, a simulated outdoor sensor using the WU device and battery leve
2199 0a9b00336 20150105 Changed bmp085 code (negative temp values should now work)
2198 b5b57457e 20150104 Openzwave using label 'Alarm Type' type now
2197 74b7cd417 20150103 Better appcache handling for themes
2196 af9b7aae6 20150102 Added simple blue/gray theme
2195 f5bb2af9d 20150102 Changed: Themes are now sorted, ignoring .svn folders
2194 058b78e78 20150102 Gui Theme selection
2193 9d45f68f2 20141230 Updated openzwave configuration files
2192 32e40b76b 20141230 Removed AddTaskItem patch (went wrong in lua/blockly scripts)
2191 3fc63c79e 20141226 Some more evohome patches, added newline at the end of 1wire/teleinfo class
2190 d143f820b 20141224 Implemented: Evohome support (Thanks to Will!)
2189 5e3e0c5d9 20141223 Changed Evohome subtype checking
2188 c6c78e5e4 20141223 More evohome implementations
2187 786640d7d 20141223 Implemented new sensor General/Current
2186 e81095e65 20141223 Some more evohome additions
2185 4d9c00e30 20141222 Implemented: Cubie internal Voltage/Current sensors
2184 5cc0cd6f0 20141222 Fixed std::min/max compile warnings
2183 4ae96e264 20141221 Added some evohome addons
2182 9bee1b117 20141219 Updated translations
2181 34c2fda10 20141219 Implemented more work for the Smartware Radiator
2180 798166241 20141218 Force appcache refresh
2179 e89bdb8ee 20141217 Added a switch for the new Radiator type
2178 c0d5d8efe 20141217 Implemented: Manual add Smartwares Radiator switch/device (will be visible afterwards at Ut
2177 f883ad42d 20141216 Implemented: P1 SmartMeter, support for the Gyr E350 (Gas reading), Changed: OpenZWave, unh
2176 2b08e56e4 20141214 Implemented: Option for Dummy device to create Ampere Sensor
2175 a76cccef2 20141214 Fixed: Dashboard, Scenes now not displayed if user does not have the rights to them
2174 b56c8508f 20141213 Changed: Mertik, will now display status=ON when received Up/Down command
2173 012668229 20141213 Fixed: Broken floorplan add
2172 ef8a83e98 20141213 Implemented: Icon scaling setting per floorplan
2171 2275a508b 20141212 Updated Teleinfo (Added 'EJP' contract thanks to Laurent)
2170 08637fddd 20141212 Openzwave handling notification alive type
2169 01a8ab85b 20141211 Fixed: Add floorplan broken
2168 6b84ce2c3 20141211 Fixed compile error for users without openzwave
2167 29aa51180 20141211 Changed icon sorting function to be compatible with old compilers
2166 c22800ba2 20141211 Switch icons now sorted by name added a few more icons (thanks to piotr)
2165 fa174ea2b 20141210 Implemented: EnOcean3, added support for door level
2164 8688eb04f 20141210 Removed debug breakpoint
2163 026dabf51 20141210 Openzwave, added vision ZD3102 with id=0203 to manufacturer specific file
2162 d76ce5e0b 20141209 Added a Christmas Tree switch icon
2161 0ebcb5062 20141208 Fixed: Temperature trend-line toggle removed range chart data
2160 99e6097c6 20141208 Added: Floorplan Scalefactor to webserver calls
2159 7bd5ff88d 20141208 Added: ScaleFactor to floorplan table
2158 a340a242d 20141208 Implemented: ZWave battery values for all sensor types that reports this
2157 9db176b71 20141207 Implemented: ttyACM serial ports if available
2156 c08fc90d5 20141203 Fixed: Setpoint timers, 'when' selection
2155 accc9194f 20141203 Updated translations
2154 10f4c8ef2 20141203 Added: Floorplan config to show Scene names
2153 6146f4e86 20141201 Added: Floorplan support for Alert devices
2152 68c61aad8 20141130 More logging for SBFSpot
2151 34cdc2ae7 20141128 Implemented svg mimetype and image cache support
2150 fbac76f87 20141126 Implemented: Scene/Group, Blinds Percentage(+Inverted) can now set the percentage level
2149 d9ed75d01 20141125 Implemented latest openzwave manufacturer changes Enabled internal hardware sensors again I
2148 126c5f557 20141124 Added: Floorplans dynamically added to appcache if not present
2147 078c7ea64 20141123 Added roomplan selector to lights/utility tabgroups changed date/time logging/eventsystem/o
2146 29a11bd1a 20141123 Included latest openzwave manufacturer file
2145 fc6169cb6 20141121 Implemented: Alert Sensor (update via udevice json call)
2144 8eb68c181 20141120 Disabled: Internal hardware monitoring, some users have issues with latest changes
2143 32a28df68 20141120 Fixed: Override pages now checks for authentication
2142 535cc36f6 20141120 Implemented: OpenZWave, COMMAND_CLASS_COLOR_CONTROL (for o.a. Zipato RGBW) (needs to be acc
2141 34d153fd0 20141119 Hardware monitor, added hdd infront of unix hdd mountpoints
2140 f6d0bc499 20141119 Hardware monitor fixed load offset on unix devices
2139 17ec7ae45 20141119 Added name for hardware monitor
2138 54f8e703c 20141119 Changed: Motherboard sensors logging, there will be new devices, and this time working as n
2137 d1a064d1b 20141117 Implemented: Dimmer, on/off actions
2136 cab6be66e 20141116 Implemented: OpenZWave, when doing an Inclusion, "allow new hardware" is enabled for 5 minu
2135 aaca742eb 20141116 Changed zwme_kfob configuration file, reverted node patch
2134 ad27630aa 20141116 Updated: Remove event handlers when leaving page
2133 ee5b2db57 20141115 Updated: AngularJS library Implemented: OpenZWave, support for COMMAND_CLASS_THERMOSTAT_MOD
2132 405c62e20 20141113 Another fix for the Fibaro RGBW
2131 4d378d3a6 20141112 Fixed: OpenZwave RGBW controller
2130 42ce92de6 20141112 Reverted STL usage on tinyxml
2129 bb2df8c6d 20141111 Redesign of openzwave control panel implementation
2128 abaf87462 20141110 Implemented more openzwave control panel commands
2127 c9f5f5c01 20141109 Fixed compile error for non openzwave users
2126 084e42222 20141109 Added ozwcp
2125 96d9a94b3 20141109 Added tinyxml
2124 3dff45398 20141109 Started with including the openzwave control panel (still needs a lot of work!)
2123 1f1aebb30 20141109 Fail update if checksum file can not be downloaded
2122 c5d49aa7a 20141109 Forcing update for sha256sum check
2121 c303bc60b 20141109 Implemented: sha256sum checksum checksum checking while downloading a new beta/stable
2120 232c5cf05 20141109 Updated: WindowsLibraries on server Changed: OpenZWave Fibaro RGBW configuration file (had
2119 dbd7a69cb 20141109 Updated: floorplan image handling and animation
2118 b84d0c037 20141109 Renamed floorplan animation label
2117 45cab4e36 20141108 Openzwave better support for switch_multi_level
2116 450c3341f 20141107 Implemented: OpenZWave, Controller Node, option for Nightly Network Heal (disabled by defau
2115 47bfb50cb 20141107 Implemented: OpenZWave, Blinds Percentage Inverted (Thanks to PIM) Implemented: OpenZWave,
2114 facf92de6 20141106 Checking in CPPCheck changes
2113 f4dd1aaa0 20141105 Removed executable rights from example script
2112 50c6886de 20141105 Implemented: Manual add Thermostat2 switch (type HE105)
2111 380143386 20141103 Msbuild, fixed debug startup folder
2110 34ab7677b 20141102 Removed svnversion.h from svn (msbuild)
2109 75e7a1469 20141102
