Yeelight
Yeelight LED Bulbs
These are WiFi enabled LED Bulbs that come with excellent supporting software, and can also be controlled from Domoticz. Currently working with the White and Color LED Bulbs http://www.yeelight.com/en_US
Compatible Lights
The Bedside Lamp is not compatible with this Domoticz plugin as it uses Bluetooth instead of WiFi.
But your lights at gearbest and you help the Domoticz community.
Adding Yeelight Bulbs in Domoticz
You first need to enable developer mode on your bulbs through the Yeelight Android or iOS App. http://www.yeelight.com/en_US/developer. If developer mode is not enabled, Domoticz will not be able to communicate with your lights.
Then go to Setup -> Hardware, and choose the Yeelight LED Type. Enter a name (such as 'Yeelight Controller'), and then click Add.
Note that the IP address of the light is used as the device ID in Domoticz. For that reason, use static IP addresses for your lights (assign via MAC address reservation on your router). See next section if you did that too late and need to change IP addresses.
After a minute, Domoticz should start detecting your bulbs and be visible under Setup -> Devices
If your Yeelight is not found automatically, try adding it manually by clicking the 'Add Light' button
Modifying Yeelight Bulbs IP address in Domoticz
If after having setup correctly a Yeelight Bulb, one day, you have to (or just want to) change it's IP addresses without removing the bulb all its configuration and history, you will have to follow these steps:
- Stop Domoticz service (sudo service domoticz stop)
- Backup Domoticz database (DB is located into domoticz root directory, simply do cp domoticz.db domoticz.db-bak)
- Get a copy of that database (domoticz.db) onto your main computer
- Open it with an sql-lite browser software (DB Browser for SQLite for instance)
- Go into "DeviceStatus" table
- You now have to adjust the "DeviceID" with the new IP.
- IP addresses are stored into their Hexadecimal representation. That way "C0A8051B" means "192.168.5.27".
- See IPv4 address representations on Wikipedia for more informations. (and you can use an online converter of course)
- Save all the modifications
- Put the modified database back into Domoticz directory and make sure that the file is named "domoticz.db"
- Start Domoticz service (sudo service domoticz start)
- Enjoy !
This procedure can come in handy if, for instance, you change ISP and you have to reconfigure the router but want to makes things neater!
It is also a way of solving the error message: "Error: YeeLight: Exception: connect: No route to host"
Adding White Temperature Control (RGBW Bulb Only)
Important note : Those scripts will not work on the windows version of Domoticz
First You have to add a dummy selector switch, and set it as a dimmer on switch page
And get your yeelight IP (Fing app on Android do the job)
Then create a LUA Script via Domoticz event Editor:
This script turn Bulb ON if you choose a value from 1% to 100%. This script turn Bulb OFF if you set the dimmer to 0%. This Dimmer can be call on scene, groupe, events, or API call
DomDevice = 'nameofyourdummyselectorsetasdimmer';
IP = 'youryeelightip';
PORT = '55443'
if devicechanged[DomDevice] then
if(devicechanged[DomDevice]=='Off') then
DomValue = 0;
runcommandoff = "sudo echo -ne '{\"id\":1,\"method\":\"set_power\", \"params\":[\"off\", \"smooth\", 500]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";;
os.execute(runcommandoff);
DomValue = otherdevices_svalues[DomDevice];
CalcValue = ((DomValue-1) * 48)+1700;
if CalcValue==nil then CalcValue=0 end
runcommand = " sudo echo -ne '{\"id\":1, \"method\":\"set_scene\",\"params\":[\"ct\"," .. CalcValue .. ", 75]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
os.execute(runcommand);
print(runcommand)
print("Color Temp= "..CalcValue);
Here is the same script updated to DZVents:
active = true,
devices = { 'YeelightTemperature'}
port = '55443'
yeelights = {'192.168.xxx.xxx'}
for ix, ipadress in ipairs(yeelights) do
if (device.state == 'Off') then
domoticz.log('Turning light off')
runcommand = "sudo echo -ne '{\"id\":1,\"method\":\"set_power\", \"params\":[\"off\", \"smooth\", 500]}\\r\\n' | nc -w1 " ..ipadress.." " ..port..""
domoticz.log('Changing color level')
calcvalue = ((device.level - 1) * 48)+1700;
runcommand = " sudo echo -ne '{\"id\":1, \"method\":\"set_scene\",\"params\":[\"ct\"," .. calcvalue .. ", 75]}\\r\\n' | nc -w1 " ..ipadress.." " ..port..""
Adding simple Dimmer Control (RGBW Bulb Only)
This Script change Brightness Bulb from 0 to 100% This Script turn ON Bulb set it to dimmer value and White Temperature choose on the previous slider. This Dimmer can be call on scene, groupe, events, or API call
DomDevice = 'Yeelight Dimmer';
TempDevice = 'White Temp Yeelight'
IP = '192.168.0.207';
PORT = '55443'
DomValue = 0;
TempValue = otherdevices_svalues[TempDevice];
CalcValue = ((TempValue-1) * 48)+1700;
runcommand = "sudo echo -ne '{\"id\":1, \"method\":\"set_scene\", \"params\":[\"ct\", " .. CalcValue .. ", " .. DomValue .. "]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
print(runcommand)
print("bright value= "..DomValue);
Adding Scenes
Yeelight Bulb offer an API, who allow use to made scene : http://www.yeelight.com/download/Yeelight_Inter-Operation_Spec.pdf
Idea here is to reproduce scene who are stored on Yeelight App.
For White Bulb (Mono)
First You have to add a dummy selector switch and set it like this :
Then create a LUA Script via Domoticz event Editor, don't forget to set your script as de device one !
DomDevice = 'Yeelight Mono Scenes';
IP = 'Your Yeelight IP';
PORT = '55443'
if devicechanged[DomDevice]=='Off' then -- turn off
-- print(runcommandoff)
elseif devicechanged[DomDevice]=='Sunrise' then -- turn to sunrise mode from 0 to 100% on 15 minutes
runcommandsunrise = " sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"cf\",2,1,\"50,2,4000,1,900000,2,4000,100\"]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
os.execute(runcommandsunrise);
-- print(runcommandsunrise)
elseif devicechanged[DomDevice]=='Sunset' then -- turn to sunset mode from 100% to 0 on 15 minutes and turn off bulb
runcommandsunset = " sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"cf\",2,2,\"50,2,4000,75,900000,2,4000,1\"]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
os.execute(runcommandsunset);
-- print(runcommandsunset)
elseif devicechanged[DomDevice]=='Bright 25%' then -- turn to 25% bright
runcommand25 = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"bright\", 25, 500]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
os.execute(runcommand25);
-- print(runcommand25)
elseif devicechanged[DomDevice]=='Bright 50%' then -- turn to 50% bright
runcommand50 = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"bright\", 50, 500]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
os.execute(runcommand50);
-- print(runcommand50)
elseif devicechanged[DomDevice]=='Bright 75%' then -- turn to 75% bright
runcommand75 = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"bright\", 75, 500]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
os.execute(runcommand75);
-- print(runcommand75)
elseif devicechanged[DomDevice]=='Baby' then -- turn to Baby Mode
runcommandbaby = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"bright\", 1, 500]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
os.execute(runcommandbaby);
-- print(runcommandbaby)
elseif devicechanged[DomDevice]=='4-7-8' then -- turn to 4-7-8 mode
runcommand478 = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"cf_\",24,2,\"4000,2,4000,30,7000,2,4000,10,8000,2,4000,1\"]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
os.execute(runcommand478);
-- print(runcommand478)
I add a 4-7-8 fonction, who is a helping to sleep methode base on breath : http://www.medicaldaily.com/life-hack-sleep-4-7-8-breathing-exercise-will-supposedly-put-you-sleep-just-60-332122
Exhale completely through your mouth, making a whoosh sound.
Close your mouth and inhale quietly through your nose to a mental count of four : light is on 30% bright
Hold your breath for a count of seven : light is on 10% bright
Exhale completely through your mouth, making a whoosh sound to a count of eight : light is on 1% bright
After 8 cycles : Bulb will turn OFF because you are sleeping
