VERA
Principles
Following devices you have in the Vera, you *must* chose who will be the master (the one that initiates) and who will be the slave (the one executing). You can't have both at the same time or for example a switch you would get an infinite loop of each device asking the other to change its state.
A common pattern to have :
- a switch has Domoticz as a master, and Vera as a slave
- a power unity or temperature get its information from a sensor, and propagates from Vera to Domoticz, so Vera is the master and Domoticz the slave
- a door/window sensor is activated, and propagates from Vera to Domoticz, so Vera is the master and Domoticz the slave.
How to prepare
Domoticz
- Create in Setup/Hardware a hardware of the type "Dummy", let's call it VERA and click Add
- Now it is created, click on it on the button "Create Virtual sensor"
- Add as many virtual devices as you need to expose in Domoticz
- Now go to Setup/Devices and mark down their device number
Vera
- Under "Apps" install the one called EventWatcher
- Then click on the configuration link of the app
- Click on "Devices"
You will get there the id list of all your vera devices you will use later
Devices specific installation
Switch Master on Vera and slave on Domoticz
- Go to "Automation" and click "New scene"
- Under "Trigger" gives is a name (instead of "new scene" by default)
- For each device that will be master on Vera (and thus push a state do Domoticz) do the following (you can do it all in the same scene):
- Click on "add trigger"
- Select the vera device in the list
- Select "a device is turned on or off"
- Give the trigger a name "Name for this trigger:" ; if this is a switch you will have to make two, one for On and one for Off, better to add this in the name
- Select "device is turned on" for the first trigger (and do the "device is turned off" as a second trigger later)
- Click "back to trigger" to return to the triggers list
- Now on that device click on "Luup event"
- input the following, replacing "433" by your device Id in domoticz, and adapt your domoticz IP
local status, result = luup.inet.wget("http://192.168.0.28:8080/json.htm?type=command&dparam=switchlight&idx=433&switchcmd=On", 5)
- Click on "Save"
- In Domoticz, it is better to make the switch as "protected" in its options.
Switch Master Domoticz and Slave on Vera
- On Domoticz, edit the virtual switch you will match to the one in Vera
- Fill in the On Action with this (change to your IP and replace 41 by your vera device ID)
http://192.168.0.26:3480/data_request?id=lu_action&output_format=json&DeviceNum=41&serviceId=urn:upnp-org:serviceId:Dimming1&action=SetLoadLevelTarget&newLoadlevelTarget=100
- Fill in the Off Action with this (change to your IP and replace 41 by your vera device ID)
http://192.168.0.26:3480/data_request?id=lu_action&output_format=json&DeviceNum=41&serviceId=urn:upnp-org:serviceId:Dimming1&action=SetLoadLevelTarget&newLoadlevelTarget=0
- click on "Save"
Energy device
Vera
Fibraro wall plug
FWP:schedule 10mn local kw = luup.variable_get("urn:micasaverde-com:serviceId:EnergyMetering1", "Watts", 69) luup.log(kw)
local kwh = luup.variable_get("urn:micasaverde-com:serviceId:EnergyMetering1", "KWH", 69)*1000 luup.log(kwh)
local status, result = luup.inet.wget("http://192.168.0.28:8080/json.htm?type=command&dparam=udevice&idx=267&nvalue=0&svalue="..kw..";"..kwh, 5)
Nuon 6 plugs
Nuon: schedule -- Multiprise #1 -- 70 1 Multiprise Salon BinaryLight 28 local kw = luup.variable_get("urn:micasaverde-com:serviceId:EnergyMetering1", "Watts", 70) local kwh = luup.variable_get("urn:micasaverde-com:serviceId:EnergyMetering1", "KWH", 70)*1000 local status, result = luup.inet.wget("http://192.168.0.28:8080/json.htm?type=command&dparam=udevice&idx=268&nvalue=0&svalue="..kw..";"..kwh, 5)
