Renault Zoe API
Purpose
I created this script so I could get information about my Renault Zoe and display it on 3 virtual sensors.
Dependencies
The script needs to be run on a linux system or the Raspberry Pi that Domoticz is running on.
Domoticz Setup
You need to create 3 virtual sensor
1. Text Sensor for charge status 2. Custom sensor with an Axis Label of Miles or KM 3. A percentage sensor for the battery percent
Installation instructions
1. Place the script in a location of your choosing 2. Make the script executable chmod +x /path/to/script/ 3. Edit the infomation at the top of the script 4. Run the script!
Script for Miles
For miles to be converted from KM, you need to install bc.
sudo apt-get install bc
Script:
#!/bin/sh
#User Variables ****EDIT THESE***** DO NOT DELETE THE """"""""
vin="VIN NUMBER"
renaultusername="Renault Email Address"
renaultpassword="Renault Username"
domtoiczusername="Domtoicz username"
domtoiczpassword="Domtoicz password"
domtoiczip="Domoticz IP address"
peridx="Perecnt IDX"
textidx="Text sensor IDX"
milesidx="Miles IDX"
scriptpath="Directory to script eg. /home/user/zoe.sh"
#Script Variables
token=`curl -H "Content-Type: application/json" -X POST -d "{\"username\":\"$renaultusername\",\"password\":\"$renaultpassword\"}" https://www.services.renault-ze.com/api/user/login | sed 's/.*"token":"//' | sed 's/".*//'`
batpercent=`curl -H "Authorization: Bearer $token" "https://www.services.renault-ze.com/api/vehicle/$vin/battery" | sed 's/.*level"://' | sed 's/,.*//'`
charging1=`curl -H "Authorization: Bearer $token" "https://www.services.renault-ze.com/api/vehicle/$vin/battery" | sed 's/.*charging"://' | sed 's/,.*//'`
plugged1=`curl -H "Authorization: Bearer $token" "https://www.services.renault-ze.com/api/vehicle/$vin/battery" | sed 's/.*plugged"://' | sed 's/,.*//'`
rangekm=`curl -H "Authorization: Bearer $token" "https://www.services.renault-ze.com/api/vehicle/$vin/battery" | sed 's/.*range"://' | sed 's/,.*//'`
chargertype=`curl -H "Authorization: Bearer $token" "https://www.services.renault-ze.com/api/vehicle/$vin/battery" | sed 's/.*_point":"//' | sed 's/",.*//'`
remaining=`curl -H "Authorization: Bearer $token" "https://www.services.renault-ze.com/api/vehicle/$vin/battery" | sed 's/.*_time"://' | sed 's/}//'`
#Script
if [ $chargertype = "ACCELERATED" ]
then
chargetype="Fast"
elif [ $chargertype = "SLOW" ]
then
chargetype="Slow"
fi
if [ $plugged1 = "false" ]
then
curl -i -H "Content-Type: application/json" "http://$domtoiczusername:$domtoiczpassword@$domtoiczip:8080/json.htm?type=command¶m=udevice&idx=$textidx&nvalue=0&svalue=Not%20Plugged%20In"
elif [ $plugged1 = "true" ]
then
if [ $charging1 = "false" ]
then
curl -i -H "Content-Type: application/json" "http://$domtoiczusername:$domtoiczpassword@$domtoiczip:8080/json.htm?type=command¶m=udevice&idx=$textidx&nvalue=0&svalue=Finished%20Charging"
elif [ $charging1 = "true" ]
then
curl -i -H "Content-Type: application/json" "http://$domtoiczusername:$domtoiczpassword@$domtoiczip:8080/json.htm?type=command¶m=udevice&idx=$textidx&nvalue=0&svalue=$chargetype%20Charging%0A$remaining%20Mins%20Remaining"
fi
fi
range=`echo "scale=0 ; $rangekm * 0.63" | bc`
curl -i -H "Content-Type: application/json" "http://$domtoiczusername:$domtoiczpassword@$domtoiczip:8080/json.htm?type=command¶m=udevice&idx=$peridx&nvalue=0&svalue=$batpercent"
curl -i -H "Content-Type: application/json" "http://$domtoiczusername:$domtoiczpassword@$domtoiczip:8080/json.htm?type=command¶m=udevice&idx=$milesidx&nvalue=0&svalue=$range"
sleep 150
sh $scriptpath && exit
Script for Kilometres
vin="VIN NUMBER"
#Script Variables
#Script
then
chargetype="Fast"
then
chargetype="Slow"
fi
then
curl -i -H "Content-Type: application/json" "http://$domtoiczusername:$domtoiczpassword@$domtoiczip:8080/json.htm?type=command¶m=udevice&idx=$textidx&nvalue=&svalue=Not%20Plugged%20In"
then
then
then
fi
fi
curl -i -H "Content-Type: application/json" "http://$domtoiczusername:$domtoiczpassword@$domtoiczip:8080/json.htm?type=command¶m=udevice&idx=$milesidx&nvalue=0&svalue=$rangekm"
sleep 150
Editing the Scirpt
Feel free to change the text shown in the if statements to suit your taste/language.
You can also change the update time at the bottom of the script after sleep
sleep 150
