Install.txt
Prerequisites
Windows
- VS2017 (community edition is OK)
- Get Domoticz source via GitHub (see Installation below)
- Download and extract this file into folder domoticz/msbuild: https://cdn.rawgit.com/domoticz/win32-libraries/master/WindowsLibraries.7z
Ubuntu / Raspberry Pi (wheezy)
sudo apt-get install build-essential -y
sudo apt-get install cmake libboost-dev libboost-thread-dev libboost-system-dev libsqlite3-dev subversion curl libcurl4-openssl-dev libusb-dev zlib1g-dev libssl-dev git
Debian stretch
sudo apt-get install cmake libboost1.61-dev libboost-system1.61-dev libboost-thread1.61-dev libsqlite3-dev subversion curl libcurl4-openssl-dev libusb-dev zlib1g-dev libssl-dev git
Raspberry Pi (Arch Linux)
sudo pacman -S gcc cmake subversion boost sqlite make curl libusb zlib1g-dev
Debian (Mac OS)
See Mac_OSX
Synology
Make sure the device is bootstrapped
Install some packages
ipkg install gcc
ipkg install make
ipkg install optware-devel (dont worry about the wget-ssl error)
ipkg install boost-dev
ipkg install boost-thread
ipkg install boost-system
ipkg install boost-date-time
ipkg install libcurl-dev
ipkg install libusb
ipkg install zlib1g-dev
Install cmake
(Take a coffee while doing the bootstrap and make commands)
wget http://www.cmake.org/files/v2.8/cmake-2.8.10.tar.gz
tar xvf cmake-2.8.10.tar.gz
cd cmake-2.8.10
./bootstrap
make
make install
cd ..
rm -R cmake-2.8.10
rm cmake-2.8.10.tar.gz
Fix known pthread problem
1. backup the pthread libraries found in /opt/arm-none-linux-gnueabi/lib/:
mkdir /opt/arm-none-linux-gnueabi/lib_disabled
mv /opt/arm-none-linux-gnueabi/lib/libpthread* /opt/arm-none-linux-gnueabi/lib_disabled
2. Copy the pthread libraries found in /opt/lib
cp /lib/libpthread.so.0 /opt/arm-none-linux-gnueabi/lib/
cd /opt/arm-none-linux-gnueabi/lib/
ln -s libpthread.so.0 libpthread.so
ln -s libpthread.so.0 libpthread-2.5.so
3.
cp /opt/lib/libboost_* /lib
Verify http://forum.synology.com/enu/viewtopic.php?p=185512#p185512 to check your /root/.profile
4. Install the FTDI and usb drivers
For a tutorial on a DS212+ see: http://sirloon.net/installing-usb-serial-modules-on-nas-synology-ds212
Basic installation:
insmod usbserial.kp
insmod ftdi_sio.ko
mknod /dev/usb/ttyUSB0 c 188 0
Plug your USB RFXtrx transceiver, verify it is found with
dmesg
You should see messages about it and an assigned usb device (in my case /dev/usb/ttyUSB0).
Go back to root folder for the next steps: cd
OpenZWave
OpenZWave is required for example to use an Aeon USB V2 ZWave adapter.
Install libudev-dev
We assume the specific dependencies for your system have been installed.
sudo apt-get install libudev-dev
Compile OpenZWave
git clone https://github.com/OpenZWave/open-zwave.git
ln -s open-zwave open-zwave-read-only
cd open-zwave
make
cd ..
Update OpenZWave
cd open-zwave
git pull
make clean
make
cd ..
Installation
Get the source code and compile with:
git clone https://github.com/domoticz/domoticz.git domoticz
cd domoticz
git pull
cmake -DCMAKE_BUILD_TYPE=Release .
Note 1: For recent Debian version, these options may be required for compilation to succeed: -DBOOST_LIBRARYDIR=/usr/lib/x86_64-linux-gnu -DBoost_USE_MULTITHREADED=OFF
Note 2: If you got undefined reference to boost::atomics::detail::lockpool::get_lock_for(void const volatile*)' linker error, append -lboost_atomic at the end of ./CMakeFiles/domoticz.dir/link.txt
Note 3: If you face runtime issues please use cmake -DCMAKE_BUILD_TYPE=Debug . to recompile and review logs for troubleshooting
make
Note: Compiling on the Raspberry Pi will take about 45 minutes
You should now have the binary application, you can start it with
./domoticz
For additional parameters type:
sudo ./domoticz -h
Upgrading
To Update to a newer version:
- stop the application (control-c), or stop the startup script (see below) with /etc/init.d/domoticz.sh stop
- Execute
cd /home/pi/domoticz (or where you installed domoticz)
git pull
make
- start domoticz
If you have installed the Unix startup script (see below), you can also update with the provided script:
./updatedomo
How to start domoticz at boot (Unix only)
sudo cp domoticz.sh /etc/init.d
sudo chmod +x /etc/init.d/domoticz.sh
sudo update-rc.d domoticz.sh defaults
Edit the startup script, esp. point DAEMON to the installation folder:
sudo nano /etc/init.d/domoticz.sh
DAEMON=/home/pi/domoticz/domoticz
If you want to use another web interface port change:
OPTIONS="-www 8080"
You can now start/stop domoticz with:
sudo /etc/init.d/domoticz.sh start
sudo /etc/init.d/domoticz.sh stop
To check if domoticz is running:
sudo /etc/init.d/domoticz.sh status
If your system supports it you can also issue:
sudo service domoticz.sh start
sudo service domoticz.sh stop
sudo service domoticz.sh status
