Garden Irrigation
From Domoticz Wiki
Revision as of 08:53, 27 May 2018 by Rohald (talk | contribs) (Lua script)
Introduction
This script has the intention to control and maintain your garden soil humidity.
Its a hodgepodge of different scripts found on the Domoticz forum.
Took me a couple of weeks to write/test (copy/past) the script.
But i'm happy i can share this script with you all.
It's my first LUA script so it may not be cleanest but it does the job ;-)
Be aware that using this script for the first time it may take awhile before irrigation script has collected all the data.
I wrote this script for my own little garden project and to beable to automate irrigation while i'm gone.
The topic can be found here: [1]
Somehow it got out of hand and got big.
So i thought that maybe some of you could have a benefit of this.
Although the script is intended for irrigation.
You could adapt it for other projects.
I do assume that when you want to use this script you already have the knowhow of Lua, Domoticz and other features needed to use this script.
As i won't explain the entire installation ;-)
How it works and what it does
- Checks if all Virtual switches and uservariables are available, if not then it won't trigger the program and alert you which variable is missing
- It scraps WeatherUnderground data and processing it to usable data
- It monitors buienradar (optional) to see if there are any showers upcoming 2hr
- It scraps temperature and humidity from your moist sensor and processing it to usable data
- It lets you choose when to irrigate via (Day of the week, month and time of the day)
- By an extensive Settings Menu you can set various settings to control when to irrigate settings ranges from: Min/Max WeaterTemp, Min/Max SoilTemp, Min/Max SoilHumidity pct, Amount of rain, wind, UV, day, month to stop or start irrigating.
- Also it detects if you are irrigating manual or stopped the program manually
- When a irrigation has taken place then the next irrigation will take place at the next scheduled Time Of The Day
- The irrigation has a optional MaxRunTime, when exceeded then it will stop at you desired MaxRunTime
- Irrigation will stop when the Soil Humidity has reached your desired Humidity Target
Dependencies
- Virtual switch to be able to manual override the irrigation program (Manual Override)
- Soil Moist & Humidity sensor
- Active WeatherUnderground account
- Switch to be able to control your waterpump/valve which is somehow wireless connected to domoticz
UserVariables to create
- VarBuienRadarCon (type=integer, value=0)
- VarFollowsProgram (type=integer, value=0)
- VarManOverride (type=integer, value=0)
- VarMaxRunTime (type=integer, value=0)
- VarMoistHumCon (type=integer, value=0)
- VarMoistLastSeen (type=integer, value=0)
- VarMoistOnline (type=integer, value=0)
- VarMoistOnlineHum (type=integer, value=0)
- VarMoistTempCon (type=integer, value=0)
- VarProgram (type=integer, value=0)
- VarProgramHasRun (type=integer, value=0)
- VarProgramStopHum (type=integer, value=0)
- VarScheduledDays (type=integer, value=0)
- VarScheduledMonths (type=integer, value=0)
- VarScheduledTOD (type=integer, value=0)
- VarScheduledTODcurrent (type=integer, value=0)
- VarWeatherCon (type=integer, value=0)
Finalize
Be aware that i'm not a coder and it's maybe not the cleanest script ever, but who cares as it works ;-)
I hope it can be of use to you and feel free to adapt it.
Bug fixes, patches, and improvements are hapiliy accepted of course.
Same counts for LUA optimizations as this is the first time i wrote,copy/past a LUA script.
When i started this i didn't had a clue what i was doing ;-)
Credits
- Nicky Bulthuis -/- for the dusk sensor script
- Hans van der Heijden -/- for the IsItGonnaRain script
- anonymous user -/- for the "Reading weather station data" script
- dannybloe -/- for Humidity Control script
- And to all those who i forgot to mention
Lua script
       script_time_irrigation.lua
       @author: Siewert Lameijer
       @since: 2015-07-14
       @version: 1.0
       @Garden Irrigation lua script
    Credits:
    -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
    The topic can be found here: https://www.domoticz.com/forum/viewtopic.php?f=38&t=6904
    I do assume that when you want to use this script you already have the knowhow of Lua and Domoticz.
    The script does the following:
    - It lets you choose when to irrigate(Day of the week, month and time of the day)
    The Hardware i use:
    - DIY Garden irrigation piping as seen in the topic
    - Washer Watervalve 2-way
    - KaKu ACM-3500-3 3-in-1 unit
    Siewert Lameijer
    Dependencies:
    1x Virtual switch to be able to manual override the irrigation program (Manual Override)
    1x Soil Moist & Humidity sensor
    1x Active WeatherUnderground account
    1x Switch to be able to control your waterpump/valve which is somehow wireless connected to domoticz
    1x Garden with irrigation hardware xD
    The following UserVariable have to be create:
    Changelog:
    Version 1.1
    - URL buienradar has changed
    Version 1.0
    - Initial release
    Version 0.9
    - Added thirth Log Info option (only Pump info)
    Version 0.8
    - Added validate check for switches and uservariables
    - Fixed some misspelling (Do you find more misspellings, please let me know
    - Added Max MoisSensor Last Seen option
    Version 0.7
    - Rewrote script due to a issue for which i couldn't find the culprit
    - Reduced the amount of uservariables
    - Some UserVariables have been renamed
    - Fixed Soil Humidity scrap script
    - Added MoistSensor Last Seen Check (max last seen is set to 10min)
    - Fixed MaxRunTime Counter
    - Changed Buienradar prediction to 2hr as this is the max by Buienradar it self
    - Optimized Manual pump start
    - Optimized displayed text in log regarding the running program and it's doings
    - Fixed program stop when target humidity has been reached
    - Fixed TimeOfTheDay schedule
    - Added counter to log to see how long the irrigation program is still active until shutdown
    - Added code to check when the moist sensor was last seen, if longer then 10minuten then no irrigation
    Version 0.6
    - Optimized reset switches
    - Added new UserVariable for be sure a irrigation cycle has complete ( VarProgramHasRun (type=integer, value=0) )
    - Fixed some issues with Manual Override
    - Added extra lines to show in log if you enabled manual override
    Version 0.5
    - Buienradar MaxRainFall changed, it is now a average of your desired max rain fall input to prevent the switch to flip flop
    - Optimized Moist sensor script as it now triggers irrigation on a minimum value and shutsdown on a maximum value
    - Added extra loggin option
    - Added option to use Buienradar or not
    - Added option to use Dutch or English translation
    Version 0.4
    - Changed Days, Months to text instead of numbers as input
    - Optimized irrigation program ending and keeping it that until the next time schedule
    Version 0.3
    - Added Buienradar (IsItGonnaRain) script
    - Optimized Max irrigation time script
    - Clean some code
    - Reorderd printed text
    Version 0.2
    - Added counter for Max irrigation time
    - Added manual override
    - Optimized WeatherUnderground scraping data
    - Optimized Moist sensor scraping data
    - Optimized user input Time Of The Day, Days and Months
    Version 0.1
    - Added WeatherUnderground and scraping data
    - Added Moist sensor scraping Temp & Humidity data
    - Added Moist sensor online check
    - Added user input for Time Of The Day where irrigation may start
    - Added user input for days and months where the irrigation may start
    -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-]]
    -- Settings Begin
    -- Set your desired language (English, Dutch)
    local lang = 'English'
    -- Logging:
    -- 0 = None,
    -- 1 = Little Bit,
    -- 2 = All,
    -- 3 = Only Pump Info
    local logging = 2
    -- Water Valve/Pump Variables
    -- Name of your irrigation switch for water valve/pump
    local VarIsPump = 'Irrigation_Valve'
    -- Max minuten/times we want to switch OFF irrigation after the program has started.
    local VarMaxRunTime = 45
    -- Virtual Switches Variables
    -- Name of your manual override virtual switch
    local VitManOverride = 'Irrigatie_Manual_Override'
    -- WeatherUnderGround Settings
    -- Name of your Weatherstation widget which contains humidity,uv,temp and pressure
    local weatherstation = 'Barometer'
    -- Name of your Weatherstation Wind widget
    local wind = 'Wind'
    -- Name of your Weatherstation Rain widget
    local rain = 'Regenmeter'
    -- Name of your Weatherstation UV widget
    local uv = 'UV'
    -- WeatherUnderground Variables
    -- Set your prefered max rain fall, higher won't trigger irrigation
    local RainMax = '0'
    -- Set your prefered minimum outside temperature for irrigation, Lower won't trigger irrigation
    local WeatherTempMin = '13'
    -- Set your prefered maximum outside temperature for irrigation, Higher won't trigger irrigation
    local WeatherTempMax = '25'
    -- Set your prefered maximum UV for irrigation, Higher won't trigger irrigation
    local UVMax = '5'
    -- Set your prefered max windspeed km/h, higher won't trigger irrigation
    local WindSpeed = '50'
    -- Set your prefered max windgust km/h, higher won't trigger irrigation
    local WindGust = '150'
    -- BuienRadar Location and minimum Rain Fall Variables
    -- Do you want to use BuienRadar? Yes or No (only usable for Dutch users)
    local Buienradar = 'No' --(Dutch weather, rain prediction)
    -- Set your location by adding Lat/Lon
    local lat = '53.338023'
    local lon = '6.303114'
    -- Set your minimum rain fall for in a periode of 24hr
    -- mm/per uur = 10^((waarde -109)/32)
    -- Dus 77 = 0.1 mm/uur
    local  VarMaxRainFall = '100'
    -- MoistSensor Variables
    -- Name of your Moist Sensor device
    local MoistSensor = 'MoistSensor'
    -- Last Seen Max time in seconds for when the program will halt
    local VarMoistLastSeen = 300
    -- Your target soil humidity percentage
    local VarTarHum = '75'
    -- Your minumim soil humidity percentage from which the irrigation will start
    local VarMinHum = '45'
    -- Your Minumum soil temperature, Lower won't trigger irrigation
    local VarTarTempMin = '12'
    -- Your Maximum soil temperature, Higher won't trigger irrigation
    local VarTarTempMax = '30'
    -- Scheduled Days
    -- Set your desired TimeOfDay for irrigation (Morning=0, Afternoon=1, Evening=2 or Night=3)
    local VarTimeOfDay = '2'
    -- Set your desired irrigation day, leave blank for no irrigation
    -- Set Mon, Tue, Wed, Thu, Fri, Sat or Sun
    local VarDay1 = 'Mon'
    local VarDay2 = ''
    local VarDay3 = 'Wed'
    local VarDay4 = ''
    local VarDay5 = 'Fri'
    local VarDay6 = ''
    local VarDay7 = 'Sun'
    -- Scheduled Months
    -- Set your desired irrigation month, leave blank for no irrigation,
    -- Set months like: Jan, Feb, Apr, May, Jun, Jul, Aug, Sep, ect ect
    local VarMonth1 = ''
    local VarMonth2 = ''
    local VarMonth3 = ''
    local VarMonth4 = 'Apr'
    local VarMonth5 = 'May'
    local VarMonth6 = 'Jun'
    local VarMonth7 = 'Jul'
    local VarMonth8 = 'Aug'
    local VarMonth9 = 'Sep'
    local VarMonth10 = ''
    local VarMonth11 = ''
    local VarMonth12 = ''
    -- Settings End
                            Don't edit anything below this line or you could break the script!
    -- Irrigation Program Variables Check
    -- Error logging.
    function error(msg)
       print("--------------------------------------------------------------------------------------")
       print('-- Irrigation [ERROR] ==>  ' .. msg)
    function validate()
    result = true
    -- Switches and Devices Error logging.
       if not otherdevices[VarIsPump] then
          error('Device [' .. VarIsPump .. '] doesnt exist.')
             result = false
       if not otherdevices[VitManOverride] then
          error('Device [' .. VitManOverride .. '] doesnt exist.')
                result = false
       if not otherdevices[weatherstation] then
          error('Device [' .. weatherstation .. '] doesnt exist.')
                result = false
       if not otherdevices[wind] then
          error('Device [' .. wind .. '] doesnt exist.')
                result = false
       if not otherdevices[rain] then
          error('Device [' .. rain .. '] doesnt exist.')
                result = false
          error('Device [' .. uv .. '] doesnt exist.')
                result = false
       if not otherdevices[MoistSensor] then
          error('Device [' .. MoistSensor .. '] doesnt exist.')
                result = false
    -- User Variables Error logging.
       if not uservariables['VarBuienRadarCon'] then
          error('User Variable [ VarBuienRadarCon ] doesnt exist.')
          result = false
       if not uservariables['VarFollowsProgram'] then
          error('User Variable [ VarFollowsProgram  ] doesnt exist.')
          result = false
       if not uservariables['VarManOverride'] then
          error('User Variable [ VarManOverride  ] doesnt exist.')
          result = false
       if not uservariables['VarMaxRunTime'] then
          error('User Variable [ VarMaxRunTime  ] doesnt exist.')
          result = false
       if not uservariables['VarMoistHumCon'] then
          error('User Variable [ VarMoistHumCon  ] doesnt exist.')
          result = false
       if not uservariables['VarMoistLastSeen'] then
          error('User Variable [ VarMoistLastSeen  ] doesnt exist.')
           result = false
       if not uservariables['VarMoistOnline'] then
          error('User Variable [ VarMoistOnline  ] doesnt exist.')
          result = false
       if not uservariables['VarMoistOnlineHum'] then
          error('User Variable [ VarMoistOnlineHum  ] doesnt exist.')
          result = false
       if not uservariables['VarMoistTempCon'] then
          error('User Variable [ VarMoistTempCon  ] doesnt exist.')
          result = false
       if not uservariables['VarProgram'] then
          error('User Variable [ VarProgram  ] doesnt exist.')
          result = false
       if not uservariables['VarProgramHasRun'] then
          error('User Variable [ VarProgramHasRun  ] doesnt exist.')
          result = false
       if not uservariables['VarProgramStopHum'] then
          error('User Variable [ VarProgramStopHum  ] doesnt exist.')
          result = false
       if not uservariables['VarScheduledDays'] then
          error('User Variable [ VarScheduledDays  ] doesnt exist.')
          result = false
       if not uservariables['VarScheduledMonths'] then
          error('User Variable [ VarScheduledMonths  ] doesnt exist.')
          result = false
       if not uservariables['VarScheduledTOD'] then
          error('User Variable [ VarScheduledTOD  ] doesnt exist.')
             result = false
       if not uservariables['VarScheduledTODcurrent'] then
          error('User Variable [ VarScheduledTODcurrent  ] doesnt exist.')
          result = false
       if not uservariables['VarWeatherCon'] then
          error('User Variable [ VarWeatherCon  ] doesnt exist.')
          result = false
    return result
    -- END Irrigation Program Variables Check
    if validate() then
    time = os.date("*t")
    -- Scrapping Weather Data from WeatherUnderground
    if logging >= 1 and logging <= 2 then
       if lang == 'Dutch' then
       print('-- Irrigatie [HET WEER]');
       print('-- Irrigation [WEATHER]');
    -- WeatherStation data:
    sWeatherTemp, sWeatherHumidity, sWeatherUV, sWeatherPressure, sWeatherUV2 = otherdevices_svalues[weatherstation]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
    sWeatherTemp = tonumber(sWeatherTemp);
    sWeatherHumidity = tonumber(sWeatherHumidity);
    sWeatherUV = tonumber(sWeatherUV);
    sWeatherPressure = tonumber(sWeatherPressure);
    sWeatherUV2 = tonumber(sWeatherUV2);
    if logging == 1 then
          print("-- Irrigatie ==> [WeerStation] - Temperatuur: " .. sWeatherTemp .. " ");
          print("-- Irrigation ==> [WeatherStation] - Temperature: " .. sWeatherTemp .. " ");
    if logging == 2 then
          print("-- Irrigatie ==> [WeerStation] - Vochtigheid: " .. sWeatherHumidity .. " ");
          print("-- Irrigatie ==> [WeerStation] - Barometer: " .. sWeatherPressure .. " ");
          print("-- Irrigation ==> [WeatherStation] - Humidity: " .. sWeatherHumidity .. " ");
          print("-- Irrigation ==> [WeatherStation] - Pressure: " .. sWeatherPressure .. " ");
    -- Windmeter data:
    sWindDirectionDegrees, sWindDirection, sWindSpeed, sWindGust, sWindTemperature, sWindFeel = otherdevices_svalues[wind]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
    sWindDirectionDegrees = tonumber(sWindDirectionDegrees);
    sWindDirection = (sWindDirection);
    sWindSpeed = tonumber(sWindSpeed);
    sWindGust = tonumber(sWindGust);
    sWindTemperature = tonumber(sWindTemperature);
    sWindFeel = tonumber(sWindFeel);
          print("-- Irrigatie ==> [Windmeter] - Windsnelheid: " .. sWindSpeed .. " ");
          print("-- Irrigatie ==> [Windmeter] - Windvlaag: " .. sWindGust .. " ");
          print("-- Irrigation ==> [Windmeter] - Windspeed: " .. sWindSpeed .. " ");
          print("-- Irrigation ==> [Windmeter] - Windgust: " .. sWindGust .. " ");
          print("-- Irrigatie ==> [Windmeter] - Windrichting (in graden): " .. sWindDirectionDegrees .. " ");
          print("-- Irrigatie ==> [Windmeter] - Windrichting: " .. sWindDirection .. " ");
          print("-- Irrigatie ==> [Windmeter] - Windtemperatuur: " .. sWindTemperature .. " ");
          print("-- Irrigatie ==> [Windmeter] - Gevoelstemperatuur: " .. sWindFeel .. " ");
          print("-- Irrigation ==> [Windmeter] - Winddirection (in degrees): " .. sWindDirectionDegrees .. " ");
          print("-- Irrigation ==> [Windmeter] - Winddirection: " .. sWindDirection .. " ");
          print("-- Irrigation ==> [Windmeter] - Windtemperature: " .. sWindTemperature .. " ");
          print("-- Irrigation ==> [Windmeter] - Windfeel: " .. sWindFeel .. " ");
    -- Rainmeter data:
    sRainmeterCurrent, sRainmeterTotal = otherdevices_svalues[rain]:match("([^;]+);([^;]+)")
    sRainmeterCurrent = tonumber(sRainmeterCurrent);
    sRainmeterTotal = tonumber(sRainmeterTotal);
          print("-- Irrigatie ==> [Regenmeter] - Actuele regenval: " .. sRainmeterCurrent .. " ");
          print("-- Irrigatie ==> [Regenmeter] - Totale regenval: " .. sRainmeterTotal .. " ");
          print("-- Irrigation ==> [Rainmeter] - Actual rain is: " .. sRainmeterCurrent .. " ");
          print("-- Irrigation ==> [Rainmeter] - Total rain is: " .. sRainmeterTotal .. " ");
    -- UV data:
    sUV, sSolar = otherdevices_svalues[uv]:match("([^;]+);([^;]+)")
    sUV = tonumber(sUV);
    sSolar = tonumber(sSolar);
       print("-- Irrigatie ==> [UV] - UV Sterkte: " .. sUV .." ");
       print("-- Irrigation ==> [UV] - UV Strength: " .. sUV .." ");
    if  sRainmeterTotal <= tonumber (RainMax)
       and sWeatherTemp >= tonumber (WeatherTempMin)
       and sWeatherTemp <= tonumber (WeatherTempMax)
       and sUV <= tonumber (UVMax)
       and sWindSpeed <= tonumber (WindSpeed)
       and sWindGust <= tonumber (WindGust)
    then
       print("-- Irrigatie ==> [WEER INFO] - Weer conditie lijkt goed voor irrigatie");
       print("-- Irrigation ==> [WEATHER INFO] - Weather conditions are looking good and ready for irrigation");
       if(uservariables['VarWeatherCon'] == 0) then
       commandArray['Variable:VarWeatherCon']= '1'
       print("-- Irrigatie ==> [WEER INFO] - Weer conditie lijkt NIET goed voor irrigatie");
       print("-- Irrigation [WEATHER INFO] ==> Weather conditions aren't good for irrigation");
       if(uservariables['VarWeatherCon'] == 1) then
       commandArray['Variable:VarWeatherCon']= '0'
    -- Checking Buienradar
    if Buienradar == 'Yes' then
          print("-- Irrigation [BUIENRADAR]");
        tempfilename = '/var/tmp/rain.tmp'
        totalrain = 0
        rainlines = 0
       function IsItGonnaRain( minutesinfuture )
           --url='http://gps.buienradar.nl/getrr.php?lat='..lat..'&lon='..lon
           url='https://gadgets.buienradar.nl/data/raintext?lat='..lat..'&lon='..lon
           read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
           file = io.open(tempfilename, "r")
           while true do
              line = file:read("*line")
              if not line then break end
              linetime=string.sub(tostring(line), 5, 9)
              linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
              difference = os.difftime (linetime2,os.time())
              if ((difference > 0) and (difference<=minutesinfuture*60)) then
                 rain=tonumber(string.sub(tostring(line), 0, 3))
                 totalrain = totalrain+rain
                 rainlines=rainlines+1
           file:close()
           averagerain=totalrain/rainlines
           return(averagerain)
        function round(num, idp)
           local mult = 10^(idp or 0)
           return math.floor(num * mult + 0.5) / mult
    -- Is it gonna rain for the upcoming 2hr YES/NO
           minutes=120
           RainPrediction = IsItGonnaRain(minutes)
           RainmmHour=10^((RainPrediction-109)/32)
           if RainPrediction >= tonumber (VarMaxRainFall) then
              verw = 3
            if (uservariables['VarBuienRadarCon']) == 1  then
            commandArray['Variable:VarBuienRadarCon']= '0'
             print('-- Irrigation ==> [REGEN] - ['..RainPrediction..'] regen verwacht binnen 2uur')
              verw = 2
            if (uservariables['VarBuienRadarCon']) == 0  then
            commandArray['Variable:VarBuienRadarCon']= '1'
             print('-- Irrigatie ==> [REGEN] - Geen of weinig regen verwacht binnen 2uur')
    -- MoistSensor Scrapping Temparature and humidity
        smoistsensorTemp, smoistsensorHumidity = otherdevices_svalues[MoistSensor]:match("([^;]+);([^;]+);([^;]+)")
        smoistsensorTemp = tonumber(smoistsensorTemp);
        smoistsensorHumidity = tonumber(smoistsensorHumidity);
          print("-- Irrigatie [GROND CONDITIES]");
          print("-- Irrigation [SOIL CONDITION]");
          print("-- Irrigatie ==> [VochtSensor] - Grond Temperatuur: " .. smoistsensorTemp .. " ");
          print("-- Irrigatie ==> [VochtSensor] - Grond Vochtigheid: " .. smoistsensorHumidity .. " ");
          print("-- Irrigation ==> [MoistSensor] - Soil Temperature: " .. smoistsensorTemp .. " ");
          print("-- Irrigation ==> [MoistSensor] - Soil Humidity: " .. smoistsensorHumidity .. " ");
    -- MoistSensor Checking Soil Temperature Conditions
    if    smoistsensorTemp >= tonumber (VarTarTempMin)
       and smoistsensorTemp <= tonumber (VarTarTempMax)
    then
    if logging <= 2 then
          print("-- Irrigatie ==> [VochtSensor] - Grond temperatuur is goed voor irrigatie");
          print("-- Irrigation ==> [MoistSensor] - Soil temperatuur is fine for irrigation");
       if(uservariables['VarMoistTempCon'] == 0) then
       commandArray['Variable:VarMoistTempCon']= '1'
    elseif    smoistsensorTemp <= tonumber (VarTarTempMin) then
          print("-- Irrigatie ==> [VochtSensor] - Grond temperatuur is te laag");
          print("-- Irrigation ==> [MoistSensor] - Soil Temperature is to low");
          if(uservariables['VarMoistTempCon'] == 1) then
          commandArray['Variable:VarMoistTempCon']= '0'
    elseif   smoistsensorTemp >= tonumber (VarTarTempMax) then
          print("-- Irrigatie ==> [VochtSensor] - Grond temperatuur is te hoog");
          print("-- Irrigation ==> [MoistSensor] - Soil Temperature is to high");
    -- MoistSensor Checking Soil Humidity Conditions
    if    smoistsensorHumidity >= tonumber (VarMinHum)
       and smoistsensorHumidity <= tonumber (VarTarHum)
    then
          print("-- Irrigatie ==> [VochtSensor] - Grond vochtigheid is goed, geen irrigatie nodig");
          print("-- Irrigation ==> [MoistSensor] - Soil Humidity conditions are fine, no irrigation required");
       if(uservariables['VarMoistHumCon'] == 1) then
       commandArray['Variable:VarMoistHumCon']= '0'
    elseif    smoistsensorHumidity <= tonumber (VarMinHum) then
          print("-- Irrigatie ==> [VochtSensor] - Grond vochtigheid is te laag");
          print("-- Irrigation ==> [MoistSensor] - Soil humidity is to low");
          if(uservariables['VarMoistHumCon'] == 0) then
          commandArray['Variable:VarMoistHumCon']= '1'
    elseif   smoistsensorHumidity >= tonumber (VarTarHum) then
          print("-- Irrigatie ==> [VochtSensor] - Grond vochtigheid is te hoog");
          print("-- Irrigation ==> [MoistSensor] - Soil humidity is to high");
    -- MoistSensor online check
    if (smoistsensorTemp == 0 or smoistsensorTemp == nil) then
       print("-- Irrigatie ==> [VochtSensor] - [ERROR] Vochtsensor geeft een temperatuur aan van 0 of nil");
        print('-- Irrigation ==> [MoistSensor] - [ERROR] Moist Sensor reports Temp is 0 or nil')
       if(uservariables['VarMoistOnline'] == 1) then
       commandArray['Variable:VarMoistOnline']= '0'
       if(uservariables['VarMoistOnline'] == 0) then
       commandArray['Variable:VarMoistOnline']= '1'
    if (smoistsensorHumidity <= 6 or smoistsensorHumidity == nil) then
       print("-- Irrigatie ==> [VochtSensor] - [ERROR] Vochtsensor geeft een vochtigheid aan van 0 of nil");
        print('-- Irrigation ==> [MoistSensor] - [ERROR] ==> Moist Sensor reports wrong Humidity values')
       if(uservariables['VarMoistOnlineHum'] == 1) then
       commandArray['Variable:VarMoistOnlineHum']= '0'
       if(uservariables['VarMoistOnlineHum'] == 0) then
       commandArray['Variable:VarMoistOnlineHum']= '1'
    -- MoistSensor Last Seen Check
    t1 = os.time()
    s = otherdevices_lastupdate[MoistSensor]
       year = string.sub(s, 1, 4)
       month = string.sub(s, 6, 7)
       day = string.sub(s, 9, 10)
       hour = string.sub(s, 12, 13)
    Moist = (os.difftime (t1, t2))
    if (Moist > VarMoistLastSeen) then
    print('--')
       print('--')
       print('-- Irrigatie ==> [VochtSensor] - [ERROR] Vochtsensor '..Moist..' Seconden geleden voor het laatste gezien')
       print('-- Irrigatie ==> [VochtSensor] - Dat is te lang geleden om een betrouwbaar beeld te vormen')
       print('--')
       print('-- Irrigation ==> [MoistSensor] - [ERROR] MoistSensor last seen '..Moist..' seconds ago')
       print('-- Irrigation ==> [MoistSensor] - Thats too long ago to be reliable')
       if(uservariables['VarMoistLastSeen'] == 1) then
       commandArray['Variable:VarMoistLastSeen']= '0'
       print('-- Irrigatie ==> [VochtSensor] - Vochtsensor '..Moist..' Seconden geleden voor het laatste gezien')
       print('-- Irrigation ==> [MoistSensor] - MoistSensor last seen '..Moist..' seconds ago')
       if(uservariables['VarMoistLastSeen'] == 0) then
       commandArray['Variable:VarMoistLastSeen']= '1'
    -- Retrieve Date & Time
        week       = tonumber(os.date("%V"));
       month       = tostring(os.date("%b"));
        dayno       = tonumber(os.date("%d"));
        dayofweekno = tonumber(os.date("%w"));
        day       = tostring(os.date("%a"));
        hour       = tonumber(os.date("%H"));
        min       = tonumber(os.date("%M"));
    -- Checking Scheduled Days
       print('-- Irrigatie [ROOSTER]')
       print('-- Irrigation [TIMEFRAME]')
    if day == VarDay1 or day == VarDay2 or day == VarDay3 or day == VarDay4 or day == VarDay5 or day == VarDay6 or day == VarDay7
       then
       print(os.date("-- Irrigatie ==> [Rooster] - Vandaag is het %A en jouw ingeroosterde voorkeurs irrigatie dag"))
       print(os.date("-- Irrigation ==> [Scheduled Days] - Today is %A and it is your desired scheduled day"))
       print('-- Irrigatie ==> [Rooster] - Ingeroosterde dagen: '..VarDay1..'  '..VarDay2..'  '..VarDay3..'  '..VarDay4..'  '..VarDay5..'  '..VarDay6..'  '..VarDay7..'')
       print('-- Irrigation ==> [Scheduled Days] - Scheduled days: '..VarDay1..'  '..VarDay2..'  '..VarDay3..'  '..VarDay4..'  '..VarDay5..'  '..VarDay6..'  '..VarDay7..'')
       if(uservariables['VarScheduledDays'] == 0) then
       commandArray['Variable:VarScheduledDays']= '1'
       print(os.date("-- Irrigatie ==> [Rooster] - Vandaag is het %A en is NIET jouw ingeroosterde voorkeurs irrigatie dag"))
          print(os.date("-- Irrigation ==> [Scheduled Days] - Today is %A and it is NOT your desired scheduled day"))
          print('-- Irrigation ==> [Scheduled Days] - Scheduled days are: '..VarDay1..'  '..VarDay2..'  '..VarDay3..'  '..VarDay4..'  '..VarDay5..'  '..VarDay6..'  '..VarDay7..'')
       if(uservariables['VarScheduledDays'] == 1) then
       commandArray['Variable:VarScheduledDays']= '0'
    -- Scheduled Months
    if month == VarMonth1 or month == VarMonth2   or month == VarMonth3 or month == VarMonth4 or month == VarMonth5 or month == VarMonth6 or month == VarMonth7 or month == VarMonth8 or month == VarMonth9 or month == VarMonth10 or month == VarMonth11 or month == VarMonth12
    then
          print(os.date("-- Irrigatie ==> [Rooster] - Vandaag is het en dag in %B, en jouw ingeroosterde voorkeurs irrigatie maand"))
          print(os.date("-- Irrigation ==> [Scheduled Months] - Today is a day in %B, and is scheduled for irrigation"))
          print('-- Irrigatie ==> [Rooster] - Ingeroosterde maanden: '..VarMonth1..'  '..VarMonth2..'  '..VarMonth3..'  '..VarMonth4..'  '..VarMonth5..'  '..VarMonth6..'  '..VarMonth7..' '..VarMonth8..' '..VarMonth9..' '..VarMonth10..' '..VarMonth11..' '..VarMonth12..'')
          print('-- Irrigation ==> [Scheduled Months] - Scheduled months: '..VarMonth1..'  '..VarMonth2..'  '..VarMonth3..'  '..VarMonth4..'  '..VarMonth5..'  '..VarMonth6..'  '..VarMonth7..' '..VarMonth8..' '..VarMonth9..' '..VarMonth10..' '..VarMonth11..' '..VarMonth12..'')
       if(uservariables['VarScheduledMonths'] == 0) then
       commandArray['Variable:VarScheduledMonths']= '1'
             print(os.date("-- Irrigatie ==> [Maand Rooster] - Vandaag is het een dag in %B, en is NIET jouw ingeroosterde voorkeurs irrigatie maand"))
             print(os.date("-- Irrigation ==> [Scheduled Months] - Today is a day in %B, and isn't scheduled for irrigation"))
          print('-- Irrigation ==> [Scheduled Months] - Scheduled months are: '..VarMonth1..'  '..VarMonth2..'  '..VarMonth3..'  '..VarMonth4..'  '..VarMonth5..'  '..VarMonth6..'  '..VarMonth7..' '..VarMonth8..' '..VarMonth9..' '..VarMonth10..' '..VarMonth11..' '..VarMonth12..'')
       if(uservariables['VarScheduledMonths'] == 1) then
       commandArray['Variable:VarScheduledMonths']= '0'
    -- Scheduled Day Time
    if (timeofday['Daytime']) and (time.hour < 12)
    then
          if  (uservariables['VarScheduledTODcurrent'] ~= 0) then
                commandArray['Variable:VarScheduledTODcurrent']= '0'
    elseif (timeofday['Daytime']) and (time.hour >= 12)
    then
          if (uservariables['VarScheduledTODcurrent'] ~= 1) then
             commandArray['Variable:VarScheduledTODcurrent']= '1'
    elseif (timeofday['Nighttime']) and (time.hour < 22)
    then
          if (uservariables['VarScheduledTODcurrent'] ~= 2) then
             commandArray['Variable:VarScheduledTODcurrent']= '2'
    elseif (timeofday['Nighttime']) and (time.hour >= 22)
    then
          if (uservariables['VarScheduledTODcurrent'] ~= 3) then
             commandArray['Variable:VarScheduledTODcurrent']= '3'
    then
    if (uservariables['VarScheduledTODcurrent']) == tonumber (VarTimeOfDay) then
          print("-- Irrigatie ==> [Rooster] - Huidige dagdeel komt overeen met jouw voorkeurs dagdeel")
          print("-- Irrigation ==> [Scheduled Time] - Time of the Day matches your desired scheduled TimeOfTheDay")
       if (uservariables['VarScheduledTOD']) == 0 then
       commandArray['Variable:VarScheduledTOD']= '1'
          print("-- Irrigatie ==> [Rooster] - Huidige dagdeel komt NIET overeen met jouw voorkeurs dagdeel")
          print("-- Irrigation ==> [Scheduled Time] - Time of the Day doesn't match your desired scheduled TimeOfTheDay")
       if (uservariables['VarScheduledTOD']) == 1 then
       commandArray['Variable:VarScheduledTOD']= '0'
    if (uservariables['VarScheduledTOD'] == 1
       and uservariables['VarScheduledMonths'] == 1
       and uservariables['VarScheduledDays'] == 1
       and uservariables['VarMoistHumCon'] == 1
       and uservariables['VarMoistTempCon'] == 1
       and uservariables['VarBuienRadarCon'] == 1
       and uservariables['VarWeatherCon'] == 1
       and uservariables['VarMoistOnline'] == 1
       and uservariables['VarMoistOnlineHum'] == 1
       and uservariables['VarMoistLastSeen'] == 1
       and uservariables['VarProgramStopHum'] == 0
       and uservariables['VarManOverride'] == 0
       and uservariables['VarProgramHasRun'] == 0
       and uservariables['VarFollowsProgram'] == 0
       and uservariables['VarProgram'] == 0
       and otherdevices[VarIsPump] == 'Off')
    then
    commandArray['Variable:VarProgram']= '1'
    then
    local VarIsCounter = 'VarMaxRunTime'
    local VarMax = VarMaxRunTime * -1
    if logging >= 1 or logging == 3 then
       print('-- Irrigatie [PROGRAMMA]')
        print('-- Irrigation [PROGRAM]')
    if otherdevices[VitManOverride]  == 'On' and uservariables['VarManOverride'] == 0
       then
       commandArray['Variable:VarManOverride']= '1'
    elseif otherdevices[VitManOverride]  == 'On' and uservariables['VarManOverride'] == 1 and uservariables['VarMaxRunTime'] ~= VarMax
       then
       commandArray['Variable:VarMaxRunTime']=tostring(VarMax)
       commandArray['Variable:VarProgram']= '0'
       commandArray['Variable:VarProgramRun']= '0'
       commandArray['Variable:VarProgramHasRun']= '0'
       commandArray[VarIsPump]='Off'
    elseif otherdevices[VitManOverride]  == 'Off' and uservariables['VarManOverride'] == 1
       then
       commandArray['Variable:VarManOverride']= '0'
    function info(msg)
          print('-- Irrigatie ==> [Programma] - ' .. msg)
          print('-- Irrigation ==> [Program] - ' .. msg)
    function may_update(is_irrigate)
       counter = tonumber(uservariables[VarIsCounter])
       current_counter = counter
       if is_irrigate and uservariables['VarManOverride'] == 0 and counter >= 0 then
          counter = math.min(1, counter + 1)
       elseif not is_irrigate and uservariables['VarManOverride'] == 0 and counter <= 0 then
          counter = math.max(VarMaxRunTime * -1, counter - 1)
       if uservariables['VarManOverride'] == 0 then
          counter = 0
       if counter ~= current_counter then
          commandArray['Variable:' .. VarIsCounter]=tostring(counter)
       result = false
       if is_irrigate and counter >= 1 then
          result = true
       elseif not is_irrigate and math.abs(counter) >= VarMaxRunTime then
          result = true
       return result
    function on_off(is_irrigate)
       update_allowed = may_update(is_irrigate)
          info('Pomp Status [' .. otherdevices[VarIsPump] .. ']')
          info('Pump State [' .. otherdevices[VarIsPump] .. ']')
       if update_allowed then
          if otherdevices[VarIsPump] == 'Off'
             and uservariables['VarProgram'] == 1
             and is_irrigate then
              commandArray[VarIsPump]='On'
          elseif (otherdevices[VarIsPump] == 'On'
                and not is_irrigate) then
             commandArray['Variable:VarProgramHasRun']= '1'
             commandArray['Variable:VarFollowsProgram']= '0'
    function is_VarProgram_aan()
       result = false
       result = (uservariables['VarProgram'] == 1)
        return result
       on_off(is_VarProgram_aan())
    -- New timeframe so irrigation reactivated
    if (uservariables['VarScheduledTOD']) == 0 and (uservariables['VarProgramHasRun']) == 1
       then
       commandArray['Variable:VarProgramStopHum']= '0'
    -- Irrigation Program manual or automatic check
    if uservariables['VarMaxRunTime'] >= 0 and otherdevices[VarIsPump] == 'Off'
    then
    commandArray['Variable:VarFollowsProgram']= '1'
    if otherdevices[VarIsPump] == 'On' and uservariables['VarFollowsProgram'] == 0
    then
          print('-- Irrigatie ==> [Programma] - Irrigatie programma manueel gestart')
          print('-- Irrigation ==> [Program] - Irrigation program started manually')
    -- Irrigation Program Max Run Time Remaining
    if uservariables['VarMaxRunTime'] <= 0 and otherdevices[VarIsPump] == 'On' and uservariables['VarFollowsProgram'] == 1
    then
    VarRemaining_counter = uservariables['VarMaxRunTime']
    VarRemaining = VarRemaining_counter + VarMaxRunTime -1
       if logging >= 2 or logging == 3 then
          print('-- Irrigatie ==> [Programma] - [' .. VarRemaining .. '] minuten resterend totdat programma word beeindigd')
          print('-- Irrigation ==> [Program] - [' .. VarRemaining .. '] minutes remaining until irrigation will stop')
    -- Stop Irrigation when Moist Humidity has reached your desired humidity
    if (uservariables['VarFollowsProgram']) == 1 and (uservariables['VarProgramStopHum']) == 0
       and smoistsensorHumidity >= tonumber (VarTarHum)
    then
       commandArray['Variable:VarProgramStopHum']= '1'
    if (uservariables['VarFollowsProgram']) == 1 and (uservariables['VarProgramStopHum']) == 1
    then
    if uservariables['VarProgramHasRun'] == 1
       then
          print('-- Irrigatie ==> [Programma] - Irrigatie programma heeft vandaag al geirrigeerd, Grondvochtigheid target is behaalt')
          print('-- Irrigatie ==> [Programma] - Programma word op de eerst volgende irrigatie dag herstart')
          print('-- Irrigation ==> [Program] - Irrigation program already irrigated today and soil humidity reached target')
          print('-- Irrigation ==> [Program] - Program will reactivated on the next scheduled irrigation day')
    -- Irrigation Program Stop Information
       then
          print('-- Irrigatie ==> [Programma] - Irrigatie programma heeft vandaag al geirrigeerd, Grondvochtigheid target is NIET behaalt')
          print('-- Irrigation ==> [Program] - Irrigation program already irrigated today but soil humidity didnt reached target')
    if uservariables['VarProgramHasRun'] == 0 and uservariables['VarProgram'] == 0 and uservariables['VarManOverride'] == 0 and otherdevices[VarIsPump] == 'Off'
       then
          print('-- Irrigatie ==> [Programma] - Irrigatie programma standby, en word hervat als alle condities inorde zijn')
          print('-- Irrigation ==> [Program] - Irrigation program standby, awaiting for all conditions to be okay')
    if uservariables['VarManOverride'] == 1 and otherdevices[VarIsPump] == 'Off'
       then
          print('-- Irrigatie ==> [Programma] - Irrigatie programma manueel gestopt')
          print('-- Irrigation ==> [Program] - Irrigation program Stopped, Manual Override')
Links
LUA Garden Irrigation Thread {Script}
DIY Garden Irrigation Thread {ShowYourProject}
--Siewert308SW (talk) 16:32, 14 July 2015 (CEST)
