Monitor memory usage
From Domoticz
Revision as of 11:26, 9 May 2018 by Calimero (talk | contribs) (Script with comments)
Purpose
Logging memory usage of a process running on your raspberry pi
Dependencies - hardware / software / operating system
Running on linux variants like the default Raspberry Pi image
Domoticz Setup - switches, variables, version
Create a virtual sensor
1. Create dummy device in the Setup/Hardware panel
2. Create virtual 'Percentage' device (using 'Create Virtual Sensors'
3. Note the IDX in the Setup/Devices screen
Installation instructions
Login using SSH
Stay in the /home/pi directory
create a script: "nano MemoryLogging.sh"
change to executable "chmod +x MemoryLogging.sh"
add the script to crontab using "crontab -e", add a line like this:
*/10 * * * * /home/pi/MemoryLogging.sh
this will execute the script every 10 minutes
#!/bin/bash
#Retrieve memory usage of the system in percentage
MEMUSG=`free -m|grep "Mem"|awk '{print $3/($4+$3) * 100}'`
#save memory usage to domoticz, replace with you IP, Portnumber and IDX
OUTPUT=`curl "http://192.168.1.3:8080/json.htm?type=command&param=udevice&idx=59&nvalue=0&svalue=$MEMUSG"`
Example of use (if relevant) i.e. output files / screen displays
Check the device in the utility tab
