RFLink Gateway USB
From Domoticz Wiki
Revision as of 13:07, 28 January 2018 by Xztraz (talk | contribs) (Introduction)
Introduction
RfLink is a modular radio gateway for your 433Mhz devices. And also some other bands depending on what radio module it's equipped with. It can be bought somewhat assembled in a kit or you can build it from scratch. It uses an arduino mega shield as a base and adds a shield for radio stuff
See RFLink Hardware
List of supported devices by RfLink
Shields and kits can be bought from nodo-shop and the firmware downloaded from here (please support the devs)
Setup
First Plugin you RFLink to your Domoticz machine
  • Go to Setup -> Hardware
  • Select Type: RFLink Gateway USB
  • Select correct com port (on rpi ex. /dev/ttyUSB30)
  • Give it a name. Ex RfLink433
  • Push Add
Now if you have "Accept new hardware" enabled under settings, it should start to populate the device list with new devices. Add them by the green arrow.
