Preparing a Raspberry PI (Arch Linux)
From Domoticz Wiki
To prepare a Raspberry PI (Arch Linux) from scratch to run Domoticz
The Arch Linux distro is for advanced users (not recommended for beginners)
Download the Arch image http://www.raspberrypi.org/downloads
Follow instructions to prepare an SD-card http://elinux.org/RPi_Easy_SD_Card_Setup
Get your Rpi up-and running with this SD card.
Login with username/password (root/root)
Change password: passwd root
Setting the Timezone:
The default timezone is "Europe/London". If you live somewhere else, you can find the possible settings in the /usr/share/timezone/ directory. Find the sub-directory that describes where you live best, then find the file that corresponds to the location closest to you within your timezone.
ls /usr/share/zoneinfo
ls /usr/share/zoneinfo/America
With the above commands, I locate my timezone as "Europe/Amsterdam".
Now issue the following command:
timedatectl set-timezone Europe/Amsterdam
Change the name of your Pi:
vi /etc/hostname
Change "alarmpi" to the name chosen for your Pi.
Expand rootfs (to use full SD card capacity)
fdisk /dev/mmcblk0
Delete the second partition /dev/mmcblk0p2 d
2
Create a new primary partition and use default sizes prompted. This will then create a partition that fills the disk
n
p
2
enter
enter
Save and exit fdisk:
w
Now reboot
reboot
Once rebooted
resize2fs /dev/mmcblk0p2
Your main / partition should be the full size of the disk now.
Update the System
pacman -Syu
Add user 'pi' as sudo user:
pacman -S sudo
useradd -m pi
passwd pi (enter a password for this user)
gpasswd -a pi wheel
gpasswd -a pi uucp
visudo
Find the line starting with # %wheel ALL=(ALL) ALL , and remove the #
exit visudo with typing :w
Exit (close the SSH session) exit
Login again with SSH and from now on use the pi user
Setting the system Locale:
sudo vi /etc/locale.gen
uncomment en_US.UTF-8 UTF-8 and en_US ISO-8859-1
now run
sudo locale-gen
Updating firmware
sudo pacman -S git
sudo wget http://goo.gl/1BOfJ -O /usr/bin/rpi-update && sudo chmod +x /usr/bin/rpi-update
sudo rpi-update
And reboot again.
sudo reboot
Installing from Source
NOTE: You can also install domoticz from Aur: https://aur.archlinux.org/packages/domoticz-git/
See Install.txt file
Now backup the SD-card: --- sudo halt
Put the card in a Mac or Linux workstation. Find the raw disk device, be very careful not to overwrite your system disk:
sudo diskutil umount /dev/disk1s1
sudo dd bs=1m if=/dev/rdisk1 of=clean-rpi.img
If you use Windows, the free HDD Raw Copy Tool (<http://hddguru.com/software/HDD-Raw-Copy-Tool/>) can be used to create a compressed backup.
Options:
Fixed ip-adress:
sudo pacman –S netcfg
sudo cp /etc/network.d/examples/ethernet-static /etc/network.d/ethernet-static
Edit to you preference
sudo vi /etc/network.d/ethernet-static
Edit /etc/conf.d/netcfg
sudo vi /etc/conf.d/netcfg
Where it says NETWORKS= (ethernet-eth0) change to NETWORKS=(ethernet-static)
sudo systemctl disable [email protected]
sudo systemctl enable netcfg.service
sudo reboot
Python and the Requests package:
sudo pacman -S python python-pip
sudo pip install requests
now follow the GIT checkout/build procedure described in the INSTALL.txt
Run Domoticz as a service:
Option... Install the nano editor for easy file editing:
sudo pacman -S nano
Create a service control file:
sudo nano /etc/systemd/system/domoticz.service
Copy-paste the following content:
[Unit]
Description=domoticz_service
[Service]
ExecStart=/home/pi/domoticz/domoticz
StandardOutput=null
[Install]
WantedBy=multi-user.target
Enable the service:
sudo systemctl enable domoticz.service
Start the service:
sudo systemctl start domoticz.service
Check that the service started:
sudo systemctl status domoticz.service
